uus teema   vasta Tarkvara »  Arvutimängude foorum »  Hitman: Blood Money märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 14, 15, 16 ... 21, 22, 23  järgmine
libe
kvaliteetne mees
libe
sõnum 23.06.2006 17:35:56 vasta tsitaadiga
link :: Hitman: Blood Money Patch v1.2 English
1.2 on ka väljas
This patch contains fixes to the following issues:
- Fixes crash when firing weapon on shaderquality medium on FX cards.
- Fixes lighting issues when running on shaderquality medium FX cards.
- Added Shadermodel select to GFX Configuration application (if model is unsupported then defaults to High).
- "SliOverrde" command added to GFX Configuration application. Select this option to turn off autodetection of Sli as EnableSli command is now performed automatically if SLi hardware configuration detected.
- Soft shadows and hard shadows were incorrectly labelled in the Render Menu.
- Installs msvcr71.dll in to application directory in case file is missing from system.
- Removed optimisation where character models were displayed in LOD3 when redrawn after leaving the screen.
- Smoothed level opening transition with postfilters disabled
- Fix to the low performance problems that have been experienced on some hardware configurations.
- After extended play sessions game could crash to desktop when transitioning between levels.
- Items could become stuck in mid-air if game was saved and then loaded directly after a throwing action.
- Hitman Logo on Main Menu could disappear at 1280x720 resolution.
- Screen borders on cutscenes could be displayed badly at certain screen resolutions.
- Game could crash if menu is invoked on death sequence after a 3 headshot revival has been performed.
- Game could crash if when loading and saving within certain locations after making changes to render options.
- Fix to blurring of Weapon Upgrade Icons when running at LOW in render options.
- Fix for very occasional graphics corruption when using fibre-wire in 1st person and moving camera very quickly.
- Fix for slightly oversized Red dot scope zoom.
viimati muutis libe 23.06.2006 18:17:47, muudetud 1 kord
me@homeq
me@homeq
sõnum 23.06.2006 18:06:43 vasta tsitaadiga
libe,link vigane.
http://www.eidosinteractive.co.uk/support/search.html?gmid=172
me@homeq
me@homeq
sõnum 23.06.2006 18:34:52 vasta tsitaadiga
endal viskas kirja ette hitman not found aga sai alles uus windows peale pandub ehk selle pärast viskas selle ette,peab hitmanile reinstalli tegema.kas 1.2 patchi võib otse 1.0 peale panna?
killerdogg
killerdogg
sõnum 23.06.2006 21:32:23 vasta tsitaadiga
Sai siis meistriteos lõpuni mängitud äsja...
Ma ei tea, kas see on minu loll lootus, kuid osad siin räägivad, et mäng lõpeb kurvalt.
Julgen vastu väita, lõpuvideos, siis, kui mängu tegijad näidati, oli selgelt kuulda, kuidas 47 aeglased südamelöögid tuksusid... icon_rolleyes.gif
Ühes missioonis anti spetsiaalne mürk kasutamiseks, võibolla oli tegu samasuguse seerumiga? Võibolla on järge oodata sama tegelasega?
Kommentaarid: 2 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 1
reitz90
sõnum 23.06.2006 21:38:58 vasta tsitaadiga
killerdogg kirjutas:
W ikka vajutasid?
rait021
rait021
sõnum 24.06.2006 09:23:21 vasta tsitaadiga
Kommentaarid: 12 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 11
weedstone
weedstone
sõnum 25.06.2006 15:30:29 vasta tsitaadiga
palju neid missioone kokku on? kui ma nüüd õiieti mõletan siis viimane mida mängisin oli see mingi haigla oma kus 1-e agendi pidi välja toimetama jne
Kommentaarid: 129 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 124
reitz90
sõnum 25.06.2006 19:19:48 vasta tsitaadiga
Tegin "murder of grows" missioonis tänavad puhtaks. Jätsin ainult ühe inimese, ellu ja see ka sellepärast, et teda ei tohtinud tappa. Terroristi reitingu sain. Imelik, et ainult 129 surma registreeriti. Neid oli kindlasti palju palju rohkem kelle ma ära tapsin. Või on mõeldud ainult, neid kes ei ole "random people" vaid need kes on näiteks baarides, turvamehed, targetid ja muud sellised.
infidel
infidel
sõnum 25.06.2006 21:13:09 vasta tsitaadiga
Terrorist on jama reiting, mängida tuleks ikka Psychopath/Sociopath reitingule (laipu palju, alerte vähe).
Kommentaarid: 36 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 35
libe
kvaliteetne mees
libe
sõnum 25.06.2006 21:16:47 vasta tsitaadiga
infidel kirjutas:
reitz90
sõnum 26.06.2006 15:07:56 vasta tsitaadiga
Huvitav, miks ma professionali sain, kas pole usutav, et 23 inimest uppusid ühte basseini ära?
Xenomorph
sõnum 29.06.2006 13:02:03 vasta tsitaadiga
Valusalt hiir tõkkab menüüs
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 29
me@homeq
me@homeq
sõnum 29.06.2006 13:03:34 vasta tsitaadiga
StaticX kirjutas:
fast writes peal?
Xenomorph
sõnum 29.06.2006 13:07:07 vasta tsitaadiga
mis se on ja kus se on
weedstone
weedstone
sõnum 29.06.2006 13:10:26 vasta tsitaadiga
StaticX kirjutas:
võta see biosist maha
Xenomorph
sõnum 29.06.2006 13:11:50 vasta tsitaadiga
a mis se teeb ja teistele asjadele ka kuidagi mõjub ?
weedstone
weedstone
sõnum 29.06.2006 13:18:04 vasta tsitaadiga
The AGP fast write BIOS setting allows the processor to communicate directly with the graphics processor, ignoring the need to send data through the system's memory. This should be enabled to provide a performance boost. You should ensure that your video card supports fast writes before setting this option, however.
http://www.pcstats.com/articleview.cfm?articleid=1590&page=18
Noname
Noname
sõnum 29.06.2006 18:23:04 vasta tsitaadiga
nvidia kaardi puhul tuleb kiiruselisa, ati saasta puhul hakkab asi tihtipeale jamama
Kommentaarid: 371 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 321
Velociraptor
Velociraptor
sõnum 29.06.2006 20:24:59 vasta tsitaadiga
rait021 kirjutas:
mis see viimane oli ? requiem vms ?
seal ma klõpsisin A D .. vist ? siis tõusis püsti ja lasin kõik witnessid maha.. oli see v ?
pragu alustasin uuesti ja olen raskeima astmega 7 missiooni juures.. seni veel silent assasin ja proovin edasigi 8)
kui suudan SA-na läbi teha proovin teha kõik mingi psychopatchina ( väga fun ) icon_biggrin.gif
hmm.. järg ..äkki hakkab selle ICA liikmeid tapma vms ? või liitub hoopis uuesti selle dianaga ( ta ju meelega ei tapnud teda )
tegelane peaks küll samaks jääma ma arvan.. muidu pole ju hitman icon_razz.gif
@weestone : sealt on veel palju edasi mängida icon_smile.gif
@reitz90: mis missioon see on ? või see mingi kõik kokku ?
viimati muutis Velociraptor 29.06.2006 20:28:18, muudetud 1 kord
Kommentaarid: 32 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 30
reitz90
sõnum 29.06.2006 21:30:14 vasta tsitaadiga
DrZ kirjutas:
"A New life"
Ei usu, et järgmises osas ta neid ICA agente tapma hakkab, sest kedagi pole enam tappa. Lõpupoole Diana ju ütles, et ainult nemad kahekesi agentuurist alles jäänud.
Võimalik, et ta laseb ennast kloonida ja seikleme uutes osades Mr 48'ga icon_razz.gif , sest ta hakkab juba vanaks jääma.
Valdars
Valdars
sõnum 29.06.2006 21:33:52 vasta tsitaadiga
A kes ütleb,et mr.48 olemas ei ole? Ega see 47 talle juhuslikult nimeks ei pandud.
Kommentaarid: 47 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 44
reitz90
sõnum 29.06.2006 21:56:18 vasta tsitaadiga
Valdars kirjutas:
Ta on jah 47's kloon ja neid kloone on veelgi aga lihtsalt ütlesin pool naljaga 48
spikhoff
sõnum 30.06.2006 00:23:28 vasta tsitaadiga
Sai installitud see hitman... pmst läks kohe kustutamisele kuna ei viitsinud hakata nuputama miks mäng hakib täiega... sätted olid suht maas... kellelgi teisel kah sarnaseid probleeme selle mänguga ati x800 seeria kaartidega?
Kommentaarid: 59 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 54
posthuman
posthuman
sõnum 01.07.2006 15:41:38 vasta tsitaadiga
rait021 kirjutas:
Igastahes jah, siis kui kirjad jooksid ja 47 oli kabelis, siis ta süda tuksus.. Surnul teadupärast ei tuku midagi icon_wink.gif
Flavius
sõnum 01.07.2006 15:47:03 vasta tsitaadiga
Kommentaarid: 126 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 118
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Hitman: Blood Money mine lehele eelmine  1, 2, 3 ... 14, 15, 16 ... 21, 22, 23  järgmine
