libe
kvaliteetne mees
23.06.2006 17:35:56
link :: Hitman: Blood Money Patch v1.2 English
1.2 on ka väljas
This patch contains fixes to the following issues:
- Fixes crash when firing weapon on shaderquality medium on FX cards.
- Fixes lighting issues when running on shaderquality medium FX cards.
- Added Shadermodel select to GFX Configuration application (if model is unsupported then defaults to High).
- "SliOverrde" command added to GFX Configuration application. Select this option to turn off autodetection of Sli as EnableSli command is now performed automatically if SLi hardware configuration detected.
- Soft shadows and hard shadows were incorrectly labelled in the Render Menu.
- Installs msvcr71.dll in to application directory in case file is missing from system.
- Removed optimisation where character models were displayed in LOD3 when redrawn after leaving the screen.
- Smoothed level opening transition with postfilters disabled
- Fix to the low performance problems that have been experienced on some hardware configurations.
- After extended play sessions game could crash to desktop when transitioning between levels.
- Items could become stuck in mid-air if game was saved and then loaded directly after a throwing action.
- Hitman Logo on Main Menu could disappear at 1280x720 resolution.
- Screen borders on cutscenes could be displayed badly at certain screen resolutions.
- Game could crash if menu is invoked on death sequence after a 3 headshot revival has been performed.
- Game could crash if when loading and saving within certain locations after making changes to render options.
- Fix to blurring of Weapon Upgrade Icons when running at LOW in render options.
- Fix for very occasional graphics corruption when using fibre-wire in 1st person and moving camera very quickly.
- Fix for slightly oversized Red dot scope zoom. |
viimati muutis libe 23.06.2006 18:17:47, muudetud 1 kord |
| Kommentaarid: 82 loe/lisa |
me@homeq
| Kommentaarid: 23 loe/lisa |
21 |
me@homeq
23.06.2006 18:34:52
| endal viskas kirja ette hitman not found aga sai alles uus windows peale pandub ehk selle pärast viskas selle ette,peab hitmanile reinstalli tegema.kas 1.2 patchi võib otse 1.0 peale panna?
21 |
killerdogg
23.06.2006 21:32:23
Sai siis meistriteos lõpuni mängitud äsja...
Ma ei tea, kas see on minu loll lootus, kuid osad siin räägivad, et mäng lõpeb kurvalt.
Julgen vastu väita, lõpuvideos, siis, kui mängu tegijad näidati, oli selgelt kuulda, kuidas 47 aeglased südamelöögid tuksusid...
Ühes missioonis anti spetsiaalne mürk kasutamiseks, võibolla oli tegu samasuguse seerumiga? Võibolla on järge oodata sama tegelasega?
reitz90
23.06.2006 21:38:58
| killerdogg kirjutas: |
Ühes missioonis anti spetsiaalne mürk kasutamiseks, võibolla oli tegu samasuguse seerumiga? Võibolla on järge oodata sama tegelasega? |
W ikka vajutasid?
rait021
24.06.2006 09:23:21
Julgen vastu väita, lõpuvideos, siis, kui mängu tegijad näidati, oli selgelt kuulda, kuidas 47 aeglased südamelöögid tuksusid... |
Mul on tunne, et sa ei mänginud viimast missiooni lõpuni
| Kommentaarid: 12 loe/lisa |
weedstone
25.06.2006 15:30:29
palju neid missioone kokku on? kui ma nüüd õiieti mõletan siis viimane mida mängisin oli see mingi haigla oma kus 1-e agendi pidi välja toimetama jne
124 |
reitz90
25.06.2006 19:19:48
| Tegin "murder of grows" missioonis tänavad puhtaks. Jätsin ainult ühe inimese, ellu ja see ka sellepärast, et teda ei tohtinud tappa. Terroristi reitingu sain. Imelik, et ainult 129 surma registreeriti. Neid oli kindlasti palju palju rohkem kelle ma ära tapsin. Või on mõeldud ainult, neid kes ei ole "random people" vaid need kes on näiteks baarides, turvamehed, targetid ja muud sellised.
infidel
25.06.2006 21:13:09
| Terrorist on jama reiting, mängida tuleks ikka Psychopath/Sociopath reitingule (laipu palju, alerte vähe).
| Kommentaarid: 36 loe/lisa |
libe
kvaliteetne mees
25.06.2006 21:16:47
| infidel kirjutas: |
| Terrorist on jama reiting, mängida tuleks ikka Psychopath/Sociopath reitingule (laipu palju, alerte vähe). |
või siis rambo
reitz90
26.06.2006 15:07:56
Nüüd tegin professionali reitingu, accidents only
Huvitav, miks ma professionali sain, kas pole usutav, et 23 inimest uppusid ühte basseini ära?
Xenomorph
29.06.2006 13:02:03
| Valusalt hiir tõkkab menüüs
| Kommentaarid: 30 loe/lisa |
29 |
me@homeq
29.06.2006 13:03:34
| StaticX kirjutas: |
| Valusalt hiir tõkkab menüüs |
fast writes peal?
21 |
Xenomorph
29.06.2006 13:07:07
| mis se on ja kus se on
29 |
weedstone
29.06.2006 13:10:26
| StaticX kirjutas: |
| mis se on ja kus se on |
võta see biosist maha
124 |
Xenomorph
29.06.2006 13:11:50
| a mis se teeb ja teistele asjadele ka kuidagi mõjub ?
29 |
weedstone
29.06.2006 13:18:04
The AGP fast write BIOS setting allows the processor to communicate directly with the graphics processor, ignoring the need to send data through the system's memory. This should be enabled to provide a performance boost. You should ensure that your video card supports fast writes before setting this option, however.
http://www.pcstats.com/articleview.cfm?articleid=1590&page=18
124 |
Noname
29.06.2006 18:23:04
nvidia kaardi puhul tuleb kiiruselisa, ati saasta puhul hakkab asi tihtipeale jamama
_________________ "Olukord on sitt, aga see on meie tuleviku väetis." - Lennart Meri
"Edu on kehv õpetaja. See ahvatleb tarku inimesi mõtlema, et nad ei saagi kaotada" - B. Gates |
| Kommentaarid: 371 loe/lisa |
321 |
Velociraptor
29.06.2006 20:24:59
| rait021 kirjutas: |
Mul on tunne, et sa ei mänginud viimast missiooni lõpuni  |
mis see viimane oli ? requiem vms ?
seal ma klõpsisin A D .. vist ? siis tõusis püsti ja lasin kõik witnessid maha.. oli see v ?
pragu alustasin uuesti ja olen raskeima astmega 7 missiooni juures.. seni veel silent assasin ja proovin edasigi 8)
kui suudan SA-na läbi teha proovin teha kõik mingi psychopatchina ( väga fun )
hmm.. järg ..äkki hakkab selle ICA liikmeid tapma vms ? või liitub hoopis uuesti selle dianaga ( ta ju meelega ei tapnud teda )
või äkki on üldse mingi uus "agency"
tegelane peaks küll samaks jääma ma arvan.. muidu pole ju hitman
@weestone : sealt on veel palju edasi mängida
@reitz90: mis missioon see on ? või see mingi kõik kokku ?
viimati muutis Velociraptor 29.06.2006 20:28:18, muudetud 1 kord |
| Kommentaarid: 32 loe/lisa |
30 |
reitz90
29.06.2006 21:30:14
| DrZ kirjutas: |
@reitz90: mis missioon see on ? või see mingi kõik kokku ? |
"A New life"
Ei usu, et järgmises osas ta neid ICA agente tapma hakkab, sest kedagi pole enam tappa. Lõpupoole Diana ju ütles, et ainult nemad kahekesi agentuurist alles jäänud.
Võimalik, et ta laseb ennast kloonida ja seikleme uutes osades Mr 48'ga , sest ta hakkab juba vanaks jääma.
Valdars
29.06.2006 21:33:52
| A kes ütleb,et mr.48 olemas ei ole? Ega see 47 talle juhuslikult nimeks ei pandud.
| Kommentaarid: 47 loe/lisa |
44 |
reitz90
29.06.2006 21:56:18
| Valdars kirjutas: |
| A kes ütleb,et mr.48 olemas ei ole? Ega see 47 talle juhuslikult nimeks ei pandud. |
Ta on jah 47's kloon ja neid kloone on veelgi aga lihtsalt ütlesin pool naljaga 48
spikhoff
30.06.2006 00:23:28
| Sai installitud see hitman... pmst läks kohe kustutamisele kuna ei viitsinud hakata nuputama miks mäng hakib täiega... sätted olid suht maas... kellelgi teisel kah sarnaseid probleeme selle mänguga ati x800 seeria kaartidega?
| Kommentaarid: 59 loe/lisa |
54 |
posthuman
01.07.2006 15:41:38
| rait021 kirjutas: |
Millist viimast? Peale lõputiitreid tuli veel missioon?
Igastahes jah, siis kui kirjad jooksid ja 47 oli kabelis, siis ta süda tuksus.. Surnul teadupärast ei tuku midagi
| Kommentaarid: 69 loe/lisa |
67 |
Flavius
01.07.2006 15:47:03
sel ajal kui ta syda tuksub, vajuta mitu korda "w" klahvi
118 |
