OskarR89
06.11.2005 12:15:02
Ise teen ManU-ga, samuti Match Mode players. 6 raskusastmega. Mängijaid ei ole eriti vahetanud, olen ostnud Nihati, Gerrardi, Van Hooijdonki ja Zola. Gerrard on hea, valusaid pomme lööb ikka Hooijdonk ja Zola ostsin karistuslöökide lööjateks
------------------------------------Van der Sar------------------------------------
G.Neville---------Ferdinand-----------------------------Brown------------Heinze
--------------------------------------Gerrard---------------------------------------
-------------------------------Scholes------------------Rooney--------------------
--------------------------------------------------------------------------Nihat-------
-------------C.Ronaldo--------------------------------------------------------------
-----------------------------------Nistelrooy----------------------------------------
138 |
sharkman
Aeg maha 10
06.11.2005 13:45:07
ok mu barca taktika siis... paljudes kohtades on eri mängudes erinevad mängijad.. olenevalt vormist....
.............................................Valdes/Jorguera......................................
..........................Puyol/Edmilson................Pena/Marguez......................
..Belleti/Puyol.................................................................Pena/Sylvinho..
..................................Van Bommel/Xavi/Motta.......................................
.........Deco/Xavi/Bronckhorst..................................................................
...............................................Xavi/Deco/.............................................
....C.Ronaldo/Ezeguerro/Giuly...................................Ronaldinho/Robinho.
....................................Larsson/Eto/Robinho...........................................
+pingil on veel palju mehi.....
Suurim petumus on Deco...
| Kommentaarid: 22 loe/lisa |
9 :: |
OskarR89
06.11.2005 14:10:52
| Kust sa seda vormi vaatad veel?
138 |
sharkman
Aeg maha 10
07.11.2005 22:26:31
| jooksu nuppuga... taktikaid sättides...
9 :: |
ImZ
10.11.2005 14:52:09
| kas aint mulle tundub nii või ongi PE5 palju raskem kui eelmine osa :S....driblada on palju raskem ja löögile saada on ka raskem
karuke
14.11.2005 13:13:36
Jep suht palju raskem, hetkel olen Arsenaliga juba teist hooaega 2'ses divisioonis kinni ja ei saa esimesse, esimene aasta olin 4'jas viimane 3'as, ehks siis järgmine olen teine . Üldine mängu pilt muidu suht palju parem, ma mõtlen just animatsiooni poole pealt, vigastused on ka head, vennad kukuvad hüppavad püsti, ei midagi ja alles nati ajapärats lööb vigastus välja Üldiselt on väga hea mäng.
| Kommentaarid: 42 loe/lisa |
41 |
ImZ
14.11.2005 15:52:43
Detailid on väga hästi tehtud välja....viimati oli mäng kuskil talvisel perioodil ja siis oli näha kuidas mängijate suud aurasid rääkides külmast õhust:)
Aga keegi ei tea kas mingi patch ka tulekul on mis klubide nimed ja logod õigeks muudaks:S
BrutaH
14.11.2005 16:24:56
| ImZ kirjutas: |
Aga keegi ei tea kas mingi patch ka tulekul on mis klubide nimed ja logod õigeks muudaks:S |
Ammu olemas. Link
StarLight
25.11.2005 15:52:06
..keegi siin enne mainis, et mängijad ei kukku enam nii kergelt persili....krt minuarust mängiks nagu mingi kolmanda liiga naistevõistkonnad koguaeg, ainult pikali ollaksegi, jooksed kõrval ja 100 võimalusest 99 korda kukud(kukub) pikali. Kui asja kätte sain siis paar esimest päeva oli küll selline vasikainnustus, aga siis hakkas vaikselt ära tyytama see pudijalgade jama. Eriti tore on veel see systeem ehitatud, et mida raskema vastasega mängid seda vähem vigu kohtunik neile vilistab ja andestab praktiliselt kõik suluseisud, see on tavaliselt neil ainuke variant väravat saada. Vaatame, ootame kuuneda osa ära, ehk siis on asi nati korralikumaks tehtud. Seniks kolime PES 4-ja peale tagasi.
[Suht mõttetu raharaiskamine, kui neljas osa on olemas]
_________________ Make no mistake. Despite every good thing i've ever done... I'm still a bad person |
| Kommentaarid: 153 loe/lisa |
144 |
ajupea
25.11.2005 22:15:27
| See on jama, et skoorid jäävad suht alati 1:0, suuremad tulevad vaid lihtsama tasemega, aga see mõttetu, kui kogu aeg võidad. Öeldi, et kaugväravaid on lihtne lüüa, kuid mulle küll nii ei tundu. Olen aint latti põrutand kaugelt ning mõned imelikud kobinad veits kastist väljas, kuid mingeid korrelikke väravaid küll pole tulnud. See meeste kukkumine tõesti pisut liiga kerge. Muidu kas siin mängus tõesti vahel on nö ''kohtunike näpukad'' et sulukaid ei võeta?
karuke
27.11.2005 00:14:58
| Ka minu vasikavaimustu hakkab üle minema, no krt ei saa ma kohe kuidagi Arsenaliga teisest divisonist edasi. Enamsti on mängud 0:0, 1:1 või äärmise kobaga võidan. Pagan jah mehed peaks seal rohkem putru sööma hakkama, koguaeg kõhuli, samalajal vastased saavad kuidagi kergelt ilma vigadegemata palli kätte. Peab ka vist neljanda tagasi panema.
41 |
Kaniyodrift
27.11.2005 05:07:13
ma mängin selliseid mänge küll aint sõpradega kuna minuarust selles kogu fun resideerubki kuid skoorimisega meil probleeme pole - kuigi on ka nn kinniseid mänge juhtub siiski et suht tihti lõpevad mängud mingi 3:5 seisuga või nii, samuti on nö viimase minuti viigiväravaid ning mõned mängud kohe trügivad penaltiteni välja
StarLight, ma pidasin silmas sõna otseses mõttes perseli kukkumist st. seda tobedat PES4 animatsiooni, mis PES5s pea olematu - ka ei jaga ma arvamust et mehed kukuvad liiga kergelt või et kohtunik on ära ostetud
kui PES5 sain mingi kuu aega tagasi siis esimeste mängudega küll tundus et mingi pudijalgne rahvas on vastas kellele on vilemees oma õla alla pannud kuid suht ruttu sai selgeks et enamikes situatsioonides on vastase pikali lükkamine täielikult enda valik
krt kell on 5, õlts on otsas ja viimased mehed on ka ära kustunud - selleks nädalavahetuseks on jalkamängud mängitud
| Kommentaarid: 17 loe/lisa |
15 |
ImZ
27.11.2005 15:05:06
| Ise ka algul ei saanud üldse hakkama, koguaeg kaotasin 1-0 või viik 0-0...ärmisel juhul võitsin 1-0 või 2-1, aga nüüd ma juba saan vabalt hakkama, asja võlu ongi selles et mäng on väga reaalseks tehtud. Päriselt, kui jalkat vaatad ei näe ka sellist asja et üks mees väga pikalt palliga joosta saab (va Ronaldinho:D). Kui mängid head söödumängu ja kiiret söödumängu...vahetad ääri pikkade söötudega ja tsenderdustega ajad vastase meeskonna segadusse siis tulevad kollid ka ära. Mulle hakkas see mäng nüüd kll täiega meeldima, sest siin on ikka väga reaalseks tehtud kõik....tundubki nagu mängiksid ise jalkat....väga kõva peala on...peab ikka pingutama ka et väravat lüüa...PES 4-s ma võitsin vahepeal juba skooridaga 7-1 jms...siin sellist asja juba ei näe kõvemate tiimide vastu.
Kaniyodrift
27.12.2005 19:58:17
tegin siis ka esimest korda prooviks ühe single player mati arvuti vastu, valisin poolaja pikkuseks 10 mintsa ja raskusastmeks maksimumi - 6 tärni, kuna võõrastavalt kinnise mängu ja lühikese ajaperioodi tõttu jäid mõlemad väravad ka lisaajal tühjaks, läks asi penaltiteni mille arvuti kaotas kuna lõi lihtsalt ühe korra väravast mööda - naljakas oli muidugi see et mängu jooksul tegi arvuti mulle mingi 4 korda rohkem vigu
imo arvuti vastu on tegelt ikka suht kuiv ja mõttetu mängida kui sõbrad olemas, kunagi esimest korda PES2 proovides tekkis mingi üllatusmoment kui arvuti tegi keskväljalt järjest kolm täpset peasöötu mis lõppesid väravaga, hilisemates osades pole neis vähestes matides selliseid imetrikke näinud aga nõustun kasutajaga ImZ et PES4 arvuti oli ikka täielik kusik
15 |
ajupea
27.12.2005 21:08:04
Mida paremaks ma ise muutun, seda mõnusam on mängida. Enam ei kaota ma alati, vaid ikka enamasti võidan . Ainus viga on mul see, et ründajad mängivad kuidagi väga passiivselt. Nad nagu eriti ei osalekski mängud. Muidugi oleneb ikka võistkonnast ja selle taktikast ka. Sõprade vastu on ikka väga lahe mängida. Nüüd ootan statside patchi, et oleks suurem heade meeste valik, kui tuleb transferite aeg.
OskarR89
06.01.2006 22:47:24
Nüüd ka suht palju seda mänginud ja peab tõdema, et väga hea mäng ikka. Algul ei tundunud edasiminek võrreldes PES4-jaga eritit suur aga mida rohkem mängid seda rohkem meeldima hakkab
Üks probleem ainult, nimelt ükskõik mis option faili ma proovin siis ikka mingi aja pärast viskab "don't send" errori ette Teab keegi mis jama võib olla?
Lasin enda parima värava ka ülesse:
R.Carlos 41M pealt risnurka (FK)
http://www.zone.ee/malcom2002/carlos41m.avi
138 |
ajupea
26.03.2006 19:01:51
http://forums.evo-web.co.uk/showthread.php?t=22775&page=189
Minge vaadake sinna teemasse. Selle teema tegija tegi option file'i ja parandas seal kõik meeste statsid ära (hetkel veel beta). Ma olen üks õnnelikest, kes saavad proovida seda file'i ning pean ütlema, et see muudab mängu täielikult teistsuguseks. See on lihtsalt niiiiii reaalne. Mängin praegult Master League'i Liverpooliga ning see on täpselt nagu päriselt. Eriti see, kuidas poolikud teevad kõik hästi ning siis ebakindlad ründajad vussivad kõik ära. Kõige restultatiivsem ründaja siiani (umbes 6 mängu) on Fowler, kes on platsil uimane söötja, kuid kasutab oma olukorrad ära. Ma olen suhteliselt kaua osalenud seal teemas ja see muudab kõik arvamused. Enam ei tundu mulle, et ainsad head mängijad on need, kellel on vähemalt pooled näitajad kollased. Näiteks Fowleri statsid on halvemad kui default failis, mis tähendab, et ainult shooting statsid on tal "head" ja attack samuti, aga ta on täiesti hea mängija. Soovitan teilgi seda teemat jälgida. Sharkman, kas mingeid uudiseid netis mängimise kohalt pole?
soovija
| Kommentaarid: 98 loe/lisa |
83 |
StarLight
14.04.2006 11:48:59
Features of Winning Eleven 10
- Licenses have been added for the national teams of Argentina, England,
Italy, Netherlands, Spain and Sweden.
- International Challenge mode, allowing you to take any side through
all the qualifications for a World Cup.
- Passing, shooting and through balls all become 'simpler' allowing more
fluid gameplay.
- Referee's are less likely to give free-kicks for niggly fouls.
- Quick free-kicks can be performed using R1+L1.
- New "Random Selection" match mode.
- More responsive manual player switching.
Movies of Winning Eleven 10
http://www.gamershell.com/download_13233.shtml
3:35 minutes of gameplay footage
http://www.gamershell.com/download_13232.shtml
6:21 minutes of gameplay footage
http://www.gamershell.com/download_13231.shtml
1:34 minutes of cinematic footage
...Ehk siis PES 6 on tegemisel. Hetkel plaanitut reliis on 2006 sygis pleikarile.
144 |
soovija
83 |
ajupea
14.06.2006 23:08:03
| Kas Eestit saab lisada kuidagi ka ilma, et peaks uue optionsfile'i panema?
soovija
15.06.2006 08:27:17
| ajupea kirjutas: |
| Kas Eestit saab lisada kuidagi ka ilma, et peaks uue optionsfile'i panema? |
Ei saa
83 |
ajupea
15.06.2006 12:41:24
| Siis ei hakka seda tõmbama. Mul see jalkageeniuse optionfile. Sellega on lihtsalt imeline mängida. Kõik meeskonnad mängivad oma õiget mängustiili.
Kellogg's
15.06.2006 12:57:15
| Mis liigad siin mängus on täiesti litsenseeritud?
sharkman
Aeg maha 10
9 :: |
