uus teema   vasta Tarkvara »  Arvutimängude foorum »  Heroes Of Might And Magic arutelu märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3, 4 ... 24, 25, 26  järgmine
Lorien
Lorien
sõnum 03.11.2005 12:43:01 vasta tsitaadiga
s4nder kirjutas:
Võib-olla mõeldi talve all ka jaanuari-veebruari.
Ja nii ka on! 8)
Edit:
Väike update inimesed icon_smile.gif Eile alustati lõpuks Beta-testimist. Välja said valitud mõned (sajad) õnnelikud, avalikkusele ei ole see veel kahjuks suunatud....eks paista, mis feedbacki hakkab tulema thumbs_up.gif
http://forums.ubi.com/groupee/forums/a/tpc/f/1851065692/m/9791089003/r/2071001463#2071001463
EDIT2: Viimane intervjuu, mis annab mängust rohkem inffi juba....tõlkima ei viitsi kahjuks hakata.
1) There will be no restrictions depending on race, skill or Hero’s level concerning the usage of artifacts.
2) Artifact information text shows it’s abilities. There are no “hidden” powers which you need to unlock somehow (my edit: the question was about SoD artifact system I guess).
3) There will be NO “cursed” artifacts, which cannot be removed until some decursing is made.
4) Q – Can I hold my Hero’s turn and make a move, when it is most desired? Like casting “Slow” spell after the enemy Hero casts “Haste” spell? Or do I have to wait until the next turn?
And also – what is the general turn system? How is it organized?
A – You can hold your Hero’s initiative by half, but it will not give you a possibility to act at any moment you like (like in HoMMI-HoMMIII), but generally – you can control the turn in wich your units move.
A-2 – Combat is not literally turn-based. It is a real-time combat with pauses (my edit: ??? I think she meant one of the game modes here).
5) Q – Will there be some mechanisms (like ATB-scale), which can help me to find out in wich turn the units will act in the long run?
A - The ATB-scale system is now in the process of reworking, but you will not be able to guess the turn of unit moves over large scales of time.
6) The aquatic creatures will act like in HoMMI-III, meaning – they will be static.
7) Q - Will there be full detailed table after victory like in Warlords 3? The number of units killed, numbers of saves made, etc.
A – No.
8) Each faction will have it’s unique skill, like Necromancy for Necropolis Heroes. (my edit: great thing for the balance)
9) The square grind walking distance will count this way: 1/1,5 – meaning the first diagonal square will cost as much as 2 vertical/horizontal, the second will cost 1, then 2, then 1 again, etc.
10) Q – What will be the maximum screen resolution?
A – We can’t tell you for sure yet. Likely it will be 1600x1200.
11) Each faction’s “caster” units – will have different spell-lists and abilities.
12) The Spellbook will not be redesigned. So it’s 6 spells per page.
13) Q – Will there be Phoenix? If it will, in which way? Neutral creature? Summoned through Summoning portal?
A – The question is far too straight. Lets say – yes, Phoenix is in (my edit: YAY!!). But in which way – it will still be a secret.
14) The Heroes will be able to “fly” from place to place via teleportation spell, but only if certain conditions are met.
15) The Heroes’s specializations will be rather trivial. No unique specs like in Armageddon Blade, etc.
16) Q - Will there be any mechanisms or other technical stuff?
A – Yes, for example Golems and Balistas are mechanical. But there will be now guns or Techno-Dragons.
17) Q - Will the blood be spilled from the Undead?
A – For now – it is spilling.
18) The basic Hero stats will be – Offence, Defence, Spell Power and Knowledge (their names are still not final though).
19) If the battle is lost – you will be able to re-hire the Hero, just as in HoMMIII.
20) The creatures will not be able to “climb walls” (so we are left only with flying and teleportation)
21) You cannot put your archer-units upon the walls or towers.
21) There will be no game optimization for Sli-videocards.
22) There will be situations where a unit with high initiative will already make 5 actions, while another unit with lower initiative will make only 3.
23) There will be NO elixirs or potions in the game.
24) There will be different difficulty levels. But how they differ – is another question)
25) The defensive buildings will progress as usual – Fort-Citadel-Castle.
26) The game cinematics will be engine-based.
27) You will be able to live some of your forces to guard your different resource-production mines.
28) Only Heroes can gain experience, units cannot.
29) Only two heroes can participate in one battle.
30) The information on the experience system will be given at the late November-beginning of December.
31) The world maps will be greater than 144x144. The exact maximum map size will be revealed later.
32) The game models are made with MAYA system.
33) Upon the entering the City you will be shown a short movie – where the camera circles around the city but you can skip it. While at the city screen you can freely turn or adjust your camera view.
34) Artifacts can be sold.
35) Q – Can the Hero retreat if all of his units are blinded (or are under some other harmfull effects that makes them to pass a turn)?
A – this is still under work.
36) The units will face each other in usual manner.
Live and let die.
Kommentaarid: 9 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 8
darknes89
darknes89
sõnum 03.11.2005 18:56:02 vasta tsitaadiga
kui juba testitakse betat siis võib ka arvata et on ka demo tulemas või mis ?.....aga noh mingis videos rääkis kah et demo on väga igav mängida isegi neil....et teed ühekorra läbi ja siis rohkem nagu ei viitsi mängida...
aga muidu ikkagi pean ütlema et Heroes of Might and Magic 3 osa oli ikka üle kõige !!
CaseDisplay.eu
ETSY shop
PC modding, abiekraanid, simracing ekraanid.
Rocky
Kommentaarid: 76 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 70
Scart
Scart
sõnum 10.11.2005 11:33:14 vasta tsitaadiga
link :: kae siit
Q& A's
Lorien
Lorien
sõnum 28.12.2005 01:28:20 vasta tsitaadiga
Live and let die.
kjaups
MeesKesTuliMetsast
kjaups
sõnum 28.12.2005 01:30:31 vasta tsitaadiga
Kas asjal mingit ametliku demo on ka välja lastud, bugide vaba ???
YAGA müügiputka - SNAP pildipank
M: 3D Touch V3.2 15€
Kommentaarid: 173 loe/lisa Kasutajad arvavad:  :: 0 :: 3 :: 142
der hammer
der hammer
sõnum 28.12.2005 01:57:22 vasta tsitaadiga
kjaups kirjutas:
Ei.
Kurat nad venitavad nii kaua. Mängitav alpha oli juba ammu väljas.
Tere.
Kommentaarid: 149 loe/lisa Kasutajad arvavad:  :: 2 :: 1 :: 130
Timberg
ööKARU
Timberg
sõnum 28.12.2005 06:48:26 vasta tsitaadiga
Las venitavad.. ega siit midagi head ei tule. Juba need 2 panevad paika, et pettumus tulemas..
Paganarh
Paganarh
sõnum 28.12.2005 12:58:21 vasta tsitaadiga
Timberg kirjutas:
see tüüp räägib inglisekeelt nii vigaselt et ei soovita sul neid asju tõe pähe võtta, Timberg
A-punktis ei saanud üldse arugi mis modet mõeldakse. küsiti ilmselt lahingu kohta ning punkti 16) vastus on puhas typo. minumeelest ta ütleb ikka "But there will be no guns or Techno-Dragons." milleks muidu see "but" seal on?.
anyhow, whatever icon_razz.gif ei võtaks tõsiselt seda venekat
kjaups
MeesKesTuliMetsast
kjaups
sõnum 28.12.2005 13:11:06 vasta tsitaadiga
Timberg, selle pisikese juttu järgi tuleb asi nagu kolmas seeria. No mis seal nutta, kolmandat seeriat mängin veel siiani icon_lol.gif thumbs_up.gif
der hammer
der hammer
sõnum 28.12.2005 14:29:30 vasta tsitaadiga
Timberg ise olen alphat mänginud ja väga meeldis.
Esimesest A-st ei saa aru icon_biggrin.gif . A2- lahing oli väga hea. Ta on ikkagi turn based ,aga julmalt muutnud. 3D-na väga hästi välja kukkunud.
16)Q- Ise kärutasin küll ühe suure noole laskmis ballistaga seal ringi ja ei ole eriti õnnetu ka ,et mingeid roboteid ei tule.
Tere.
robin
robin
sõnum 14.01.2006 14:01:34 vasta tsitaadiga
19. jaanuar algab open beta!
link kah
Kommentaarid: 55 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 51
Vananematu
Vananematu
sõnum 14.01.2006 16:23:11 vasta tsitaadiga
Oo, kena uudis. Seda mängu mängiks hea meelega juba võrgus. Kohvi tass kõrval ja muidku klõbistaks.
Kommentaarid: 31 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 28
soovija
soovija
sõnum 14.01.2006 16:24:40 vasta tsitaadiga
Erksxx kirjutas:
Kommentaarid: 100 loe/lisa Kasutajad arvavad:  :: 0 :: 4 :: 85
project
project
sõnum 14.01.2006 17:19:55 vasta tsitaadiga
Video Card: DirectX® 9 compliant w/ 64MB RAM (128 MB recommended)
ti4200 pole vis directX 9 complaint? et fulli siis saab või ei saa selle kaardiga taguda?
Kommentaarid: 92 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 84
soovija
soovija
sõnum 14.01.2006 17:40:11 vasta tsitaadiga
project kirjutas:
Laifstaile
sõnum 14.01.2006 19:38:10 vasta tsitaadiga
räägi siis kuidas on mäng
robin
robin
sõnum 14.01.2006 19:48:04 vasta tsitaadiga
see alpha või? nii buge täis, et sellest pole mõtet rääkidagi.
päris mäng pole veel väljas..
soovija
soovija
sõnum 14.01.2006 20:35:19 vasta tsitaadiga
robin kirjutas:
alpha oli väga bugine ,häält polnud selles alguse dialoogis bullshit
RobertP
RobertP
sõnum 14.01.2006 23:24:10 vasta tsitaadiga
Kust saaks seda alfat proovida?
soovija
soovija
sõnum 14.01.2006 23:42:50 vasta tsitaadiga
RobertP kirjutas:
see oli juba ammu aega tagasi väljas ,ise sain kuskilt saidilt. Seda jagati niisama icon_biggrin.gif
robin
robin
sõnum 15.01.2006 00:27:37 vasta tsitaadiga
RobertP kirjutas:
pole ju eriti mõtet, kuna avalik beta on kohe-kohe saadaval..
Lorien
Lorien
sõnum 16.01.2006 16:01:06 vasta tsitaadiga
Live and let die.
Drake
sõnum 17.01.2006 12:38:08 vasta tsitaadiga
loodame siis et betas on ka multiplayer sees.
ja et pole memory leak-e täis nagu alfa, et kui 2G mälu pole ja swapile ruumi kah antud pole,
siis paneb mõne aja peale pange.
"action" dialoogid olid kuidagi liiga WC3 nägu :S
d.
On the other hand, I've turned rivers into blood... kings into cripples... cities into salt. So I don't think that I have to explain myself to you. -Gabriel-
Kommentaarid: 90 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 85
HDTanel
Overclocker
HDTanel
sõnum 17.01.2006 12:46:47 vasta tsitaadiga
Hmm omg.
Mul on SLI, 18. Jan 3DMark2006, 19. Jan HOMM5... mida veel tahta icon_lol.gif thumbs_up.gif Loodame, et läbi interneti saab realtime pelada vms icon_smile.gif
Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
sõnum 17.01.2006 16:51:21 vasta tsitaadiga
PlatoonSgtElias kirjutas:
siis pole see enam homm
HDTanel
Overclocker
HDTanel
sõnum 17.01.2006 16:52:53 vasta tsitaadiga
Einoh internetis on käikudega väga mõttetu. See oleks vägagi homm siiski edasi kui SP oleks turn based või valikuliselt realtime! Saad aru mingi ajalimiit on sul ja siis saab turn läbi aga nagu kõigil korraga... et keegi ei peaks ootama.
Krüpto
piq
sõnum 17.01.2006 18:35:17 vasta tsitaadiga
et patuuni suur soov on et saaks hommi asemel yhe wowi juurde kus saab ise sis grupiga liikuda , hmm se oleks ju nagu dungeon siege vai miskit sellist juba
pleks enam turnbased strat vaid täiesti tavaline mp rpg
Kommentaarid: 28 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 26
HDTanel
Overclocker
HDTanel
sõnum 17.01.2006 19:44:11 vasta tsitaadiga
Komoon, internet võiks vabalt valikuline olla! Või sulle meeldib 8 inimesega pelada ja siis oma turni oodata 30minti ja siis 4minti teha enda turni? icon_rolleyes.gif jäädki mängima
Krüpto
One
sõnum 17.01.2006 19:46:22 vasta tsitaadiga
ime, et sõdu turn based süsteemis ei peeta..
et algul ründab üks ja teine passib ja siis teine ja esimene passib beer_yum.gif
HDTanel
Overclocker
HDTanel
sõnum 17.01.2006 19:47:13 vasta tsitaadiga
Krüpto
Laifstaile
sõnum 17.01.2006 20:35:05 vasta tsitaadiga
Reimo005
Reimo005
sõnum 17.01.2006 21:10:34 vasta tsitaadiga
Winterwind kirjutas:
Miks sa võrdled sellist asja sõjaga? See on mäng, neile kellele selline süsteem meeldib, mina tean et osad inimesed lausa fännavad turn based game kuna siis ei pea kogu aeg hiir käes vehkima ja rabelema, teed omad käigud ära ja ootad rahus. Üldjuhul kui selline mäng ei meeldi siis ei ole mõtet tulla siia teemasse et muudame selle mängu nüüd järgmiseks red alerdiks.
sõnum 17.01.2006 23:01:50 vasta tsitaadiga
täpselt.. seal mängus on ju tegelikult samuti väga julm strateegia taga, sel ajal kui teised käivad mõtled täpselt, mida järgmine käik teha võimalikult vähese ajaga et teised vähem jõuaksid mõelda icon_wink.gif
Paganarh
Paganarh
sõnum 18.01.2006 13:36:30 vasta tsitaadiga
On saadud küll netis mängitud HOMM3'e. Võtsid rahulikult ploki õltsi ette, ajasid rahva kokku, mäng läks käima ning möll toimus hommikuni.
Ei olnud üldse igav oodata icon_smile.gif Esiteks turnidel ajalimiit peale pandud, et mõni mökutama ei jääks, teiseks käis räme taunt ja fleim omavahel.
Pikad on need mängud küll jah, kuid selline see turnbased süsteem juba on. Mina on üks neist kes seda süsteemi väga aus hoiavad.
Drake
sõnum 19.01.2006 12:29:46 vasta tsitaadiga
kas on see tõesti tõsi ?
tegu siis vb mingi vanema closed beta file-ga
ftp://ftp.ubi.com/emea/homm5/NDA/HOMM_beta.zip
saadud on see link siit:
http://heroescommunity.com/viewthread.php3?TID=16895
siin on muidugi ka muid huvitavaid asju:
ehk siis Beta Test 4.
mis suure tõenäosusega on õigem, kuna taga olev lühend MP annab lootust võrgulisaks
d.
viimati muutis Drake 19.01.2006 12:40:30, muudetud 5 korda
Alvaaro
Alvaaro
sõnum 19.01.2006 14:56:12 vasta tsitaadiga
see on seal küll miski jama lahti ei saa pakkida kh
Kommentaarid: 217 loe/lisa Kasutajad arvavad:  :: 3 :: 3 :: 182
piimaPAKK
piimaPAKK
sõnum 19.01.2006 16:36:47 vasta tsitaadiga
NDA - non disclosure agreement - ehk siis leping, millega üks osapool kinnitab, et ei räägi nähtust kolmandatele isikutele ehk siis kasutatav KINNISE testimise ajal.
Anyways HOMM on ikka rohkem hotseat pela kui interneti oma. Siis ikka saad näost näkku sõimata ja parastada ja segada ja spioneerida ja vinguda miks teistel kõik parem on icon_lol.gif
Drake
sõnum 19.01.2006 18:59:05 vasta tsitaadiga
see üks suur on 25 detsembri beta.
4 väiksemat oli veebruaril kokku pakitud.
d.
juurastaja
juurastaja
sõnum 19.01.2006 19:48:07 vasta tsitaadiga
Drake kirjutas:
d.
eksid
HOMM_beta.zip on viimati muudetud 25.11.2005 (25. november)
need jupid on viimati muudetud 2.01.2006 (2. jaanuar siis)
ZerOZer05
sõnum 19.01.2006 20:25:54 vasta tsitaadiga
http://forums.ubi.com/groupee/forums/a/tpc/f/1851065692/m/5741045004/p/1
UbiRazz kirjutas:
We’re sorry to announce that the open beta for Heroes of Might and Magic V will be delayed for a short period. We’re currently working very hard to get the client stable and ready for release and we will announce a new release date shortly, probably in a matter of hours. The beta itself is likely to start in a matter of days, not weeks, so keep checking the website for the latest information.
Thanks for your patience
niiet praegu on open beta viivitatud.
Sain selle beta 4 jupid tõmmatud kui sellel on üks probleem: tal on starforce peal ja see küsib sinult activation keyd.
arvatavasti see seal ftp serveris on siiski closed beta.
project
project
sõnum 19.01.2006 21:14:10 vasta tsitaadiga
99% tiris ära ning siis. File download of Homm_beta.zip was not completed sudessfully due to unexpected server response.
421 idle timeout 600 seconds: closing control connection
The joy
kjaups
MeesKesTuliMetsast
kjaups
sõnum 19.01.2006 22:19:13 vasta tsitaadiga
project kirjutas:
The joy
[EDIT] Lahe, Starforce mõnnalt peal icon_evil.gif . Kas siis mingit testimis teemat tavainimestele polegi või võetakse kohe ka beta pealt raha nagu MW-s thumbs_down.gif icon_evil.gif icon_exclaim.gif
Drake
sõnum 19.01.2006 23:14:04 vasta tsitaadiga
et kahjuks jah, tegu siiski closed betaga, vabandust, et teid ähmi täis ajasin, kuid polnud võimalik endal enne testida.
open betaga peab ootama siiski, sest homm-i loojad ajasid küll poisid kiima ja panid nii mõnegi kaagi 20ks tunniks arvuti taha ootama, kuid ei saanud avalikustada betat, kuna see polnud veel piisavalt tarbijasõbralik.
siit aga ka moraal, et oleks pidanud ise osalema betatestimises.
järgmiste mängudega tuleks siis silm http://www.betadogs.com/ peal hoida, et ehk läheb õnneks.
edit: ja kuupäevaga eksisin jah, mõtlesin jaanuarit, kuid kirjutasin kogemata veebruari icon_razz.gif
d.
kjaups
MeesKesTuliMetsast
kjaups
sõnum 19.01.2006 23:41:50 vasta tsitaadiga
No kõik siis ostma ....
Njah, alles testitav beta on väljas ja juba müüvad ... Sutsu kahtlane icon_lol.gif
robin
robin
sõnum 20.01.2006 00:38:05 vasta tsitaadiga
see on ju pre-order..
kjaups
MeesKesTuliMetsast
kjaups
sõnum 20.01.2006 01:13:27 vasta tsitaadiga
robin kirjutas:
Oih, sorry, ennist see punane märgike jäi kahe silma vahele. Kuid kui nad nüüd selle betaga põlevad, siis venib see ikka päris pikkale icon_rolleyes.gif
Dominus
Dominus
sõnum 20.01.2006 11:34:43 vasta tsitaadiga
njah,tõmbasin HOMM_beta.zip ära ja mängida ei saagi...pettumus kui suur icon_razz.gif
Kommentaarid: 104 loe/lisa Kasutajad arvavad:  :: 4 :: 1 :: 76
HDTanel
Overclocker
HDTanel
sõnum 20.01.2006 11:46:34 vasta tsitaadiga
Krüpto
sõnum 20.01.2006 13:18:30 vasta tsitaadiga
starforce
Auron
Auron
sõnum 20.01.2006 14:17:29 vasta tsitaadiga
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Heroes Of Might And Magic arutelu mine lehele eelmine  1, 2, 3, 4 ... 24, 25, 26  järgmine
