Lorien
03.11.2005 11:43:01
| s4nder kirjutas: |
| Võib-olla mõeldi talve all ka jaanuari-veebruari. |
Ja nii ka on! 8)
Edit:
Väike update inimesed Eile alustati lõpuks Beta-testimist. Välja said valitud mõned (sajad) õnnelikud, avalikkusele ei ole see veel kahjuks suunatud....eks paista, mis feedbacki hakkab tulema
http://forums.ubi.com/groupee/forums/a/tpc/f/1851065692/m/9791089003/r/2071001463#2071001463
EDIT2: Viimane intervjuu, mis annab mängust rohkem inffi juba....tõlkima ei viitsi kahjuks hakata.
1) There will be no restrictions depending on race, skill or Heros level concerning the usage of artifacts.
2) Artifact information text shows its abilities. There are no hidden powers which you need to unlock somehow (my edit: the question was about SoD artifact system I guess).
3) There will be NO cursed artifacts, which cannot be removed until some decursing is made.
4) Q Can I hold my Heros turn and make a move, when it is most desired? Like casting Slow spell after the enemy Hero casts Haste spell? Or do I have to wait until the next turn?
And also what is the general turn system? How is it organized?
A You can hold your Heros initiative by half, but it will not give you a possibility to act at any moment you like (like in HoMMI-HoMMIII), but generally you can control the turn in wich your units move.
A-2 Combat is not literally turn-based. It is a real-time combat with pauses (my edit: ??? I think she meant one of the game modes here).
5) Q Will there be some mechanisms (like ATB-scale), which can help me to find out in wich turn the units will act in the long run?
A - The ATB-scale system is now in the process of reworking, but you will not be able to guess the turn of unit moves over large scales of time.
6) The aquatic creatures will act like in HoMMI-III, meaning they will be static.
7) Q - Will there be full detailed table after victory like in Warlords 3? The number of units killed, numbers of saves made, etc.
A No.
8) Each faction will have its unique skill, like Necromancy for Necropolis Heroes. (my edit: great thing for the balance)
9) The square grind walking distance will count this way: 1/1,5 meaning the first diagonal square will cost as much as 2 vertical/horizontal, the second will cost 1, then 2, then 1 again, etc.
10) Q What will be the maximum screen resolution?
A We cant tell you for sure yet. Likely it will be 1600x1200.
11) Each factions caster units will have different spell-lists and abilities.
12) The Spellbook will not be redesigned. So its 6 spells per page.
13) Q Will there be Phoenix? If it will, in which way? Neutral creature? Summoned through Summoning portal?
A The question is far too straight. Lets say yes, Phoenix is in (my edit: YAY!!). But in which way it will still be a secret.
14) The Heroes will be able to fly from place to place via teleportation spell, but only if certain conditions are met.
15) The Heroess specializations will be rather trivial. No unique specs like in Armageddon Blade, etc.
16) Q - Will there be any mechanisms or other technical stuff?
A Yes, for example Golems and Balistas are mechanical. But there will be now guns or Techno-Dragons.
17) Q - Will the blood be spilled from the Undead?
A For now it is spilling.
18) The basic Hero stats will be Offence, Defence, Spell Power and Knowledge (their names are still not final though).
19) If the battle is lost you will be able to re-hire the Hero, just as in HoMMIII.
20) The creatures will not be able to climb walls (so we are left only with flying and teleportation)
21) You cannot put your archer-units upon the walls or towers.
21) There will be no game optimization for Sli-videocards.
22) There will be situations where a unit with high initiative will already make 5 actions, while another unit with lower initiative will make only 3.
23) There will be NO elixirs or potions in the game.
24) There will be different difficulty levels. But how they differ is another question)
25) The defensive buildings will progress as usual Fort-Citadel-Castle.
26) The game cinematics will be engine-based.
27) You will be able to live some of your forces to guard your different resource-production mines.
28) Only Heroes can gain experience, units cannot.
29) Only two heroes can participate in one battle.
30) The information on the experience system will be given at the late November-beginning of December.
31) The world maps will be greater than 144x144. The exact maximum map size will be revealed later.
32) The game models are made with MAYA system.
33) Upon the entering the City you will be shown a short movie where the camera circles around the city but you can skip it. While at the city screen you can freely turn or adjust your camera view.
34) Artifacts can be sold.
35) Q Can the Hero retreat if all of his units are blinded (or are under some other harmfull effects that makes them to pass a turn)?
A this is still under work.
36) The units will face each other in usual manner.
_________________ Live and let die.
| Kommentaarid: 9 loe/lisa |
darknes89
03.11.2005 17:56:02
mis siin ikka kosta on
kui juba testitakse betat siis võib ka arvata et on ka demo tulemas või mis ?.....aga noh mingis videos rääkis kah et demo on väga igav mängida isegi neil....et teed ühekorra läbi ja siis rohkem nagu ei viitsi mängida...
aga muidu ikkagi pean ütlema et Heroes of Might and Magic 3 osa oli ikka üle kõige !!
_________________ CaseDisplay.eu
ETSY shop
PC modding, abiekraanid, simracing ekraanid.
Rocky |
| Kommentaarid: 76 loe/lisa |
Scart
10.11.2005 10:33:14
link :: kae siit
Q& A's
101 |
Lorien
28.12.2005 00:28:20
Voww, Rakshasa ja Colossus näevad väga võimsad välja!
kjaups
MeesKesTuliMetsast
140 |
der hammer
28.12.2005 00:57:22
| kjaups kirjutas: |
| Kas asjal mingit ametliku demo on ka välja lastud, bugide vaba ??? |
Ei.
Kurat nad venitavad nii kaua. Mängitav alpha oli juba ammu väljas.
_________________ Tere. |
| Kommentaarid: 149 loe/lisa |
130 |
Timberg
ööKARU
28.12.2005 05:48:26
Las venitavad.. ega siit midagi head ei tule. Juba need 2 panevad paika, et pettumus tulemas..
272 |
Paganarh
28.12.2005 11:58:21
| Timberg kirjutas: |
Las venitavad.. ega siit midagi head ei tule. Juba need 2 panevad paika, et pettumus tulemas.. |
see tüüp räägib inglisekeelt nii vigaselt et ei soovita sul neid asju tõe pähe võtta, Timberg
A-punktis ei saanud üldse arugi mis modet mõeldakse. küsiti ilmselt lahingu kohta ning punkti 16) vastus on puhas typo. minumeelest ta ütleb ikka "But there will be no guns or Techno-Dragons." milleks muidu see "but" seal on?.
anyhow, whatever ei võtaks tõsiselt seda venekat
| Kommentaarid: 15 loe/lisa |
kjaups
MeesKesTuliMetsast
140 |
der hammer
28.12.2005 13:29:30
Timberg ise olen alphat mänginud ja väga meeldis.
Esimesest A-st ei saa aru . A2- lahing oli väga hea. Ta on ikkagi turn based ,aga julmalt muutnud. 3D-na väga hästi välja kukkunud.
16)Q- Ise kärutasin küll ühe suure noole laskmis ballistaga seal ringi ja ei ole eriti õnnetu ka ,et mingeid roboteid ei tule.
130 |
robin
14.01.2006 13:01:34
19. jaanuar algab open beta!
link kah
| Kommentaarid: 55 loe/lisa |
51 |
Vananematu
14.01.2006 15:23:11
| Oo, kena uudis. Seda mängu mängiks hea meelega juba võrgus. Kohvi tass kõrval ja muidku klõbistaks.
| Kommentaarid: 31 loe/lisa |
28 |
soovija
14.01.2006 15:24:40
| Erksxx kirjutas: |
| Oo, kena uudis. Seda mängu mängiks hea meelega juba võrgus. Kohvi tass kõrval ja muidku klõbistaks. |
alphale tegin tiiru peale
85 |
project
14.01.2006 16:19:55
Video Card: DirectX® 9 compliant w/ 64MB RAM (128 MB recommended)
ti4200 pole vis directX 9 complaint? et fulli siis saab või ei saa selle kaardiga taguda?
| Kommentaarid: 92 loe/lisa |
84 |
soovija
14.01.2006 16:40:11
| project kirjutas: |
ti4200 pole vis directX 9 complaint? et fulli siis saab või ei saa selle kaardiga taguda? |
saab vast ikka
85 |
Laifstaile
14.01.2006 18:38:10
| räägi siis kuidas on mäng
| Kommentaarid: 25 loe/lisa |
24 |
robin
14.01.2006 18:48:04
see alpha või? nii buge täis, et sellest pole mõtet rääkidagi.
päris mäng pole veel väljas..
51 |
soovija
14.01.2006 19:35:19
| robin kirjutas: |
päris mäng pole veel väljas.. |
alpha oli väga bugine ,häält polnud selles alguse dialoogis bullshit
85 |
RobertP
14.01.2006 22:24:10
| Kust saaks seda alfat proovida?
soovija
14.01.2006 22:42:50
| RobertP kirjutas: |
| Kust saaks seda alfat proovida? |
see oli juba ammu aega tagasi väljas ,ise sain kuskilt saidilt. Seda jagati niisama
85 |
robin
14.01.2006 23:27:37
| RobertP kirjutas: |
pole ju eriti mõtet, kuna avalik beta on kohe-kohe saadaval..
51 |
Lorien
16.01.2006 15:01:06
Just, ainult 3 päeva oodata veel
Drake
17.01.2006 11:38:08
loodame siis et betas on ka multiplayer sees.
ja et pole memory leak-e täis nagu alfa, et kui 2G mälu pole ja swapile ruumi kah antud pole,
siis paneb mõne aja peale pange.
"action" dialoogid olid kuidagi liiga WC3 nägu :S
üldine gameplay aga mõnusalt homm3
d.
_________________ On the other hand, I've turned rivers into blood... kings into cripples... cities into salt. So I don't think that I have to explain myself to you. -Gabriel- |
| Kommentaarid: 89 loe/lisa |
84 |
HDTanel
Overclocker
17.01.2006 11:46:47
Hmm omg.
Mul on SLI, 18. Jan 3DMark2006, 19. Jan HOMM5... mida veel tahta Loodame, et läbi interneti saab realtime pelada vms
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
17.01.2006 15:51:21
| PlatoonSgtElias kirjutas: |
Loodame, et läbi interneti saab realtime pelada vms  |
siis pole see enam homm
| Kommentaarid: 85 loe/lisa |
