Lorien
03.11.2005 12:43:01
| s4nder kirjutas: |
| Võib-olla mõeldi talve all ka jaanuari-veebruari. |
Ja nii ka on! 8)
Edit:
Väike update inimesed Eile alustati lõpuks Beta-testimist. Välja said valitud mõned (sajad) õnnelikud, avalikkusele ei ole see veel kahjuks suunatud....eks paista, mis feedbacki hakkab tulema
http://forums.ubi.com/groupee/forums/a/tpc/f/1851065692/m/9791089003/r/2071001463#2071001463
EDIT2: Viimane intervjuu, mis annab mängust rohkem inffi juba....tõlkima ei viitsi kahjuks hakata.
1) There will be no restrictions depending on race, skill or Heros level concerning the usage of artifacts.
2) Artifact information text shows its abilities. There are no hidden powers which you need to unlock somehow (my edit: the question was about SoD artifact system I guess).
3) There will be NO cursed artifacts, which cannot be removed until some decursing is made.
4) Q Can I hold my Heros turn and make a move, when it is most desired? Like casting Slow spell after the enemy Hero casts Haste spell? Or do I have to wait until the next turn?
And also what is the general turn system? How is it organized?
A You can hold your Heros initiative by half, but it will not give you a possibility to act at any moment you like (like in HoMMI-HoMMIII), but generally you can control the turn in wich your units move.
A-2 Combat is not literally turn-based. It is a real-time combat with pauses (my edit: ??? I think she meant one of the game modes here).
5) Q Will there be some mechanisms (like ATB-scale), which can help me to find out in wich turn the units will act in the long run?
A - The ATB-scale system is now in the process of reworking, but you will not be able to guess the turn of unit moves over large scales of time.
6) The aquatic creatures will act like in HoMMI-III, meaning they will be static.
7) Q - Will there be full detailed table after victory like in Warlords 3? The number of units killed, numbers of saves made, etc.
A No.
8) Each faction will have its unique skill, like Necromancy for Necropolis Heroes. (my edit: great thing for the balance)
9) The square grind walking distance will count this way: 1/1,5 meaning the first diagonal square will cost as much as 2 vertical/horizontal, the second will cost 1, then 2, then 1 again, etc.
10) Q What will be the maximum screen resolution?
A We cant tell you for sure yet. Likely it will be 1600x1200.
11) Each factions caster units will have different spell-lists and abilities.
12) The Spellbook will not be redesigned. So its 6 spells per page.
13) Q Will there be Phoenix? If it will, in which way? Neutral creature? Summoned through Summoning portal?
A The question is far too straight. Lets say yes, Phoenix is in (my edit: YAY!!). But in which way it will still be a secret.
14) The Heroes will be able to fly from place to place via teleportation spell, but only if certain conditions are met.
15) The Heroess specializations will be rather trivial. No unique specs like in Armageddon Blade, etc.
16) Q - Will there be any mechanisms or other technical stuff?
A Yes, for example Golems and Balistas are mechanical. But there will be now guns or Techno-Dragons.
17) Q - Will the blood be spilled from the Undead?
A For now it is spilling.
18) The basic Hero stats will be Offence, Defence, Spell Power and Knowledge (their names are still not final though).
19) If the battle is lost you will be able to re-hire the Hero, just as in HoMMIII.
20) The creatures will not be able to climb walls (so we are left only with flying and teleportation)
21) You cannot put your archer-units upon the walls or towers.
21) There will be no game optimization for Sli-videocards.
22) There will be situations where a unit with high initiative will already make 5 actions, while another unit with lower initiative will make only 3.
23) There will be NO elixirs or potions in the game.
24) There will be different difficulty levels. But how they differ is another question)
25) The defensive buildings will progress as usual Fort-Citadel-Castle.
26) The game cinematics will be engine-based.
27) You will be able to live some of your forces to guard your different resource-production mines.
28) Only Heroes can gain experience, units cannot.
29) Only two heroes can participate in one battle.
30) The information on the experience system will be given at the late November-beginning of December.
31) The world maps will be greater than 144x144. The exact maximum map size will be revealed later.
32) The game models are made with MAYA system.
33) Upon the entering the City you will be shown a short movie where the camera circles around the city but you can skip it. While at the city screen you can freely turn or adjust your camera view.
34) Artifacts can be sold.
35) Q Can the Hero retreat if all of his units are blinded (or are under some other harmfull effects that makes them to pass a turn)?
A this is still under work.
36) The units will face each other in usual manner.
_________________ Live and let die.
| Kommentaarid: 9 loe/lisa |
darknes89
03.11.2005 18:56:02
mis siin ikka kosta on
kui juba testitakse betat siis võib ka arvata et on ka demo tulemas või mis ?.....aga noh mingis videos rääkis kah et demo on väga igav mängida isegi neil....et teed ühekorra läbi ja siis rohkem nagu ei viitsi mängida...
aga muidu ikkagi pean ütlema et Heroes of Might and Magic 3 osa oli ikka üle kõige !!
_________________ CaseDisplay.eu
ETSY shop
PC modding, abiekraanid, simracing ekraanid.
Rocky |
| Kommentaarid: 78 loe/lisa |
72 |
Scart
10.11.2005 11:33:14
link :: kae siit
Q& A's
101 |
Lorien
28.12.2005 01:28:20
Voww, Rakshasa ja Colossus näevad väga võimsad välja!
kjaups
MeesKesTuliMetsast
142 |
der hammer
28.12.2005 01:57:22
| kjaups kirjutas: |
| Kas asjal mingit ametliku demo on ka välja lastud, bugide vaba ??? |
Ei.
Kurat nad venitavad nii kaua. Mängitav alpha oli juba ammu väljas.
_________________ Tere. |
| Kommentaarid: 149 loe/lisa |
130 |
Timberg
ööKARU
28.12.2005 06:48:26
Las venitavad.. ega siit midagi head ei tule. Juba need 2 panevad paika, et pettumus tulemas..
272 |
Paganarh
28.12.2005 12:58:21
| Timberg kirjutas: |
Las venitavad.. ega siit midagi head ei tule. Juba need 2 panevad paika, et pettumus tulemas.. |
see tüüp räägib inglisekeelt nii vigaselt et ei soovita sul neid asju tõe pähe võtta, Timberg
A-punktis ei saanud üldse arugi mis modet mõeldakse. küsiti ilmselt lahingu kohta ning punkti 16) vastus on puhas typo. minumeelest ta ütleb ikka "But there will be no guns or Techno-Dragons." milleks muidu see "but" seal on?.
anyhow, whatever ei võtaks tõsiselt seda venekat
| Kommentaarid: 15 loe/lisa |
kjaups
MeesKesTuliMetsast
142 |
der hammer
28.12.2005 14:29:30
Timberg ise olen alphat mänginud ja väga meeldis.
Esimesest A-st ei saa aru . A2- lahing oli väga hea. Ta on ikkagi turn based ,aga julmalt muutnud. 3D-na väga hästi välja kukkunud.
16)Q- Ise kärutasin küll ühe suure noole laskmis ballistaga seal ringi ja ei ole eriti õnnetu ka ,et mingeid roboteid ei tule.
130 |
robin
14.01.2006 14:01:34
19. jaanuar algab open beta!
link kah
| Kommentaarid: 55 loe/lisa |
51 |
Vananematu
14.01.2006 16:23:11
| Oo, kena uudis. Seda mängu mängiks hea meelega juba võrgus. Kohvi tass kõrval ja muidku klõbistaks.
| Kommentaarid: 31 loe/lisa |
28 |
soovija
14.01.2006 16:24:40
| Erksxx kirjutas: |
| Oo, kena uudis. Seda mängu mängiks hea meelega juba võrgus. Kohvi tass kõrval ja muidku klõbistaks. |
alphale tegin tiiru peale
85 |
project
14.01.2006 17:19:55
Video Card: DirectX® 9 compliant w/ 64MB RAM (128 MB recommended)
ti4200 pole vis directX 9 complaint? et fulli siis saab või ei saa selle kaardiga taguda?
| Kommentaarid: 93 loe/lisa |
85 |
soovija
14.01.2006 17:40:11
| project kirjutas: |
ti4200 pole vis directX 9 complaint? et fulli siis saab või ei saa selle kaardiga taguda? |
saab vast ikka
85 |
Laifstaile
14.01.2006 19:38:10
| räägi siis kuidas on mäng
| Kommentaarid: 25 loe/lisa |
24 |
robin
14.01.2006 19:48:04
see alpha või? nii buge täis, et sellest pole mõtet rääkidagi.
päris mäng pole veel väljas..
51 |
soovija
14.01.2006 20:35:19
| robin kirjutas: |
päris mäng pole veel väljas.. |
alpha oli väga bugine ,häält polnud selles alguse dialoogis bullshit
85 |
RobertP
14.01.2006 23:24:10
| Kust saaks seda alfat proovida?
soovija
14.01.2006 23:42:50
| RobertP kirjutas: |
| Kust saaks seda alfat proovida? |
see oli juba ammu aega tagasi väljas ,ise sain kuskilt saidilt. Seda jagati niisama
85 |
robin
15.01.2006 00:27:37
| RobertP kirjutas: |
pole ju eriti mõtet, kuna avalik beta on kohe-kohe saadaval..
51 |
Lorien
16.01.2006 16:01:06
Just, ainult 3 päeva oodata veel
Drake
17.01.2006 12:38:08
loodame siis et betas on ka multiplayer sees.
ja et pole memory leak-e täis nagu alfa, et kui 2G mälu pole ja swapile ruumi kah antud pole,
siis paneb mõne aja peale pange.
"action" dialoogid olid kuidagi liiga WC3 nägu :S
üldine gameplay aga mõnusalt homm3
d.
_________________ On the other hand, I've turned rivers into blood... kings into cripples... cities into salt. So I don't think that I have to explain myself to you. -Gabriel- |
| Kommentaarid: 90 loe/lisa |
85 |
HDTanel
Overclocker
17.01.2006 12:46:47
Hmm omg.
Mul on SLI, 18. Jan 3DMark2006, 19. Jan HOMM5... mida veel tahta Loodame, et läbi interneti saab realtime pelada vms
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
17.01.2006 16:51:21
| PlatoonSgtElias kirjutas: |
Loodame, et läbi interneti saab realtime pelada vms  |
siis pole see enam homm
| Kommentaarid: 85 loe/lisa |
HDTanel
Overclocker
17.01.2006 16:52:53
Einoh internetis on käikudega väga mõttetu. See oleks vägagi homm siiski edasi kui SP oleks turn based või valikuliselt realtime! Saad aru mingi ajalimiit on sul ja siis saab turn läbi aga nagu kõigil korraga... et keegi ei peaks ootama.
496 |
piq
17.01.2006 18:35:17
et patuuni suur soov on et saaks hommi asemel yhe wowi juurde kus saab ise sis grupiga liikuda , hmm se oleks ju nagu dungeon siege vai miskit sellist juba
pleks enam turnbased strat vaid täiesti tavaline mp rpg
| Kommentaarid: 28 loe/lisa |
26 |
HDTanel
Overclocker
17.01.2006 19:44:11
Komoon, internet võiks vabalt valikuline olla! Või sulle meeldib 8 inimesega pelada ja siis oma turni oodata 30minti ja siis 4minti teha enda turni? jäädki mängima
496 |
One
17.01.2006 19:46:22
ime, et sõdu turn based süsteemis ei peeta..
et algul ründab üks ja teine passib ja siis teine ja esimene passib
728 |
HDTanel
Overclocker
17.01.2006 19:47:13
Male. See suht norm. Saad rahuga oma rünnakuid planeerida
496 |
Laifstaile
24 |
Reimo005
17.01.2006 21:10:34
| Winterwind kirjutas: |
et algul ründab üks ja teine passib ja siis teine ja esimene passib  |
Miks sa võrdled sellist asja sõjaga? See on mäng, neile kellele selline süsteem meeldib, mina tean et osad inimesed lausa fännavad turn based game kuna siis ei pea kogu aeg hiir käes vehkima ja rabelema, teed omad käigud ära ja ootad rahus. Üldjuhul kui selline mäng ei meeldi siis ei ole mõtet tulla siia teemasse et muudame selle mängu nüüd järgmiseks red alerdiks.
| Kommentaarid: 12 loe/lisa |
12 |
17.01.2006 23:01:50
täpselt.. seal mängus on ju tegelikult samuti väga julm strateegia taga, sel ajal kui teised käivad mõtled täpselt, mida järgmine käik teha võimalikult vähese ajaga et teised vähem jõuaksid mõelda
Paganarh
18.01.2006 13:36:30
On saadud küll netis mängitud HOMM3'e. Võtsid rahulikult ploki õltsi ette, ajasid rahva kokku, mäng läks käima ning möll toimus hommikuni.
Ei olnud üldse igav oodata Esiteks turnidel ajalimiit peale pandud, et mõni mökutama ei jääks, teiseks käis räme taunt ja fleim omavahel.
Pikad on need mängud küll jah, kuid selline see turnbased süsteem juba on. Mina on üks neist kes seda süsteemi väga aus hoiavad.
Olen juba selline vaikselt nohistaja
Drake
19.01.2006 12:29:46
kas on see tõesti tõsi ?
tegu siis vb mingi vanema closed beta file-ga
ftp://ftp.ubi.com/emea/homm5/NDA/HOMM_beta.zip
saadud on see link siit:
http://heroescommunity.com/viewthread.php3?TID=16895
panin tirima, eks näis
siin on muidugi ka muid huvitavaid asju:
ehk siis Beta Test 4.
mis suure tõenäosusega on õigem, kuna taga olev lühend MP annab lootust võrgulisaks
d.
viimati muutis Drake 19.01.2006 12:40:30, muudetud 5 korda |
85 |
Alvaaro
19.01.2006 14:56:12
| see on seal küll miski jama lahti ei saa pakkida kh
| Kommentaarid: 217 loe/lisa |
182 |
piimaPAKK
19.01.2006 16:36:47
NDA - non disclosure agreement - ehk siis leping, millega üks osapool kinnitab, et ei räägi nähtust kolmandatele isikutele ehk siis kasutatav KINNISE testimise ajal.
Anyways HOMM on ikka rohkem hotseat pela kui interneti oma. Siis ikka saad näost näkku sõimata ja parastada ja segada ja spioneerida ja vinguda miks teistel kõik parem on
Drake
19.01.2006 18:59:05
see üks suur on 25 detsembri beta.
4 väiksemat oli veebruaril kokku pakitud.
d.
85 |
juurastaja
19.01.2006 19:48:07
| Drake kirjutas: |
d. |
eksid
HOMM_beta.zip on viimati muudetud 25.11.2005 (25. november)
need jupid on viimati muudetud 2.01.2006 (2. jaanuar siis)
30 |
ZerOZer05
19.01.2006 20:25:54
http://forums.ubi.com/groupee/forums/a/tpc/f/1851065692/m/5741045004/p/1
| UbiRazz kirjutas: |
Were sorry to announce that the open beta for Heroes of Might and Magic V will be delayed for a short period. Were currently working very hard to get the client stable and ready for release and we will announce a new release date shortly, probably in a matter of hours. The beta itself is likely to start in a matter of days, not weeks, so keep checking the website for the latest information.
Thanks for your patience |
niiet praegu on open beta viivitatud.
Sain selle beta 4 jupid tõmmatud kui sellel on üks probleem: tal on starforce peal ja see küsib sinult activation keyd.
arvatavasti see seal ftp serveris on siiski closed beta.
project
19.01.2006 21:14:10
99% tiris ära ning siis. File download of Homm_beta.zip was not completed sudessfully due to unexpected server response.
421 idle timeout 600 seconds: closing control connection
The joy
85 |
kjaups
MeesKesTuliMetsast
19.01.2006 22:19:13
| project kirjutas: |
The joy |
ma tirisin ära. praegu pakkin lahti. 2 cd-d
[EDIT] Lahe, Starforce mõnnalt peal . Kas siis mingit testimis teemat tavainimestele polegi või võetakse kohe ka beta pealt raha nagu MW-s
_________________ M: korter Mustamäel
YAGA müügiputka |
142 |
Drake
19.01.2006 23:14:04
et kahjuks jah, tegu siiski closed betaga, vabandust, et teid ähmi täis ajasin, kuid polnud võimalik endal enne testida.
open betaga peab ootama siiski, sest homm-i loojad ajasid küll poisid kiima ja panid nii mõnegi kaagi 20ks tunniks arvuti taha ootama, kuid ei saanud avalikustada betat, kuna see polnud veel piisavalt tarbijasõbralik.
siit aga ka moraal, et oleks pidanud ise osalema betatestimises.
järgmiste mängudega tuleks siis silm http://www.betadogs.com/ peal hoida, et ehk läheb õnneks.
edit: ja kuupäevaga eksisin jah, mõtlesin jaanuarit, kuid kirjutasin kogemata veebruari
d.
85 |
kjaups
MeesKesTuliMetsast
142 |
robin
20.01.2006 00:38:05
Njah, alles testitav beta on väljas ja juba müüvad ... Sutsu kahtlane
see on ju pre-order..
51 |
kjaups
MeesKesTuliMetsast
20.01.2006 01:13:27
| robin kirjutas: |
see on ju pre-order.. |
Oih, sorry, ennist see punane märgike jäi kahe silma vahele. Kuid kui nad nüüd selle betaga põlevad, siis venib see ikka päris pikkale
YAGA müügiputka |
142 |
Dominus
20.01.2006 11:34:43
njah,tõmbasin HOMM_beta.zip ära ja mängida ei saagi...pettumus kui suur
76 |
HDTanel
Overclocker
20.01.2006 11:46:34
Kuda selle 2CD versiooniga jäi siis
496 |
20.01.2006 13:18:30
Kuda selle 2CD versiooniga jäi siis  |
starforce
Auron
20.01.2006 14:17:29
Mingit pirajuttu ajage MSN'is
133 |
