uus teema   vasta Tarkvara »  Arvutimängude foorum »  Half-Life 2 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 151, 152, 153 ... 241, 242, 243  järgmine
Ho Ho
Ho Ho
sõnum 25.09.2005 08:45:06 vasta tsitaadiga
Hmm, tundub et tõepoolest suutsid valve tüübid oma HDR'i implementatsioonis sel viisil häkkida et ka MSAA on toetatud:
http://arstechnica.com/articles/culture/lostcoast.ars/3
The second method Valve tried was used for the first Lost Coast demos. It essentially stored two different versions of each MRT (Multiple Render to Texture) map and render target, one with regular data, the other with overbright data. It too had the advantage of working with all DirectX9 hardware, but had two very important disadvantages: it would not work with MSAA, and it took up twice as much video card memory as a regular game. In addition, it would not work with video card fog effects. The need for extra texture memory could have been ignored (by simply bumping up the requirements of the game) but the lack of MSAA was a deal-breaker. As Gabe said, MSAA makes all images look so much nicer that having to remove it just to add HDR effects would be an overall step backwards. Further work was needed.
The third technique was showcased at E3 2005. It used a technique where floating point data was used for the RGB values instead of the traditional integers, allowing full storage of HDR data. (Most games running in 24-bit color use 8-bit integers—numbers from 0 to 255—for each value of red, green and blue.) This was the most accurate rendering technique, but also had the most drawbacks. For one, only NVIDIA cards supported floating-point RGB operations, leaving ATI owners out in the cold. Performance was a concern even on supported video hardware. And again, the deal breaker: no MSAA.
But Valve just wouldn't give up. Somehow, they found a compromise method that allowed almost everything they wanted to work, and with a very small performance hit. It is most similar to the second method they tried, using two different versions of each MRT map and render target, but doesn't store overbright information for every texture. Instead, only textures that require HDR are stored, along with bloom buffers. Essentially, it works by taking each map and analyzing where HDR will be used (which sources of light will have bloom effects, and which textures will have greater reflection of that light) and only storing those values.
On NVIDIA cards, it stores these values as 16-bit floating point data (what is known as a "linear color space," as opposed to separate RGB values), and on ATI cards stores it as a 4.12 integer value (again a linear space). The advantages of this technique are many. All DirectX9 hardware is supported, and because it does not require that much extra texture memory the performance hit is small even on an ATI 9600. Fog effects work, and so does FSAA. The only real downside is that HDR effects are not supported with refraction, so while light will still stream in nicely through stained-glass windows, you won't see the HDR effects when looking directly through the window at the sun. It is a small price to pay, however. This technique will be shipping with the Lost Coast, and the upcoming Day of Defeat: Source (the latter of which is already partially available for preloading via Steam, awaiting only the final code).
Nii palju kui ma aru sain kasutatakse enamus asjade jaoks mitut puhvrit ning neid mida saab tasandada tasandatakse, neid mida ei saa vist renderdatakse lihtsalt suuremal resolutsioonil(selles võin eksida). Selline tehnika lubab kasutada MSAA'd kuid mõningaid HDR'i efekte pole võimalik saavutada.
Aga seda et erilist kiirusekadu ei ole ma küll ei tahaks uskuda. Võibolla nad mõtlesid et kiirus ei ole eriti palju aeglasem võrreldes traditsioonilise HDR'iga.
Lisaks sellele tundub et taoliste häkkide tõttu peab varasemad kaardid tõepoolest ümber kompileerima:
Building levels to support this new HDR technology was a lot of work. Skyboxes (the extremely large 3D shapes, texture-mapped on the inside, that simulate the sky when in an outdoor level) had to be hand-painted in both normal and HDR-enhanced modes, as well as HDR versions of the standard Source engine cube maps (cube maps are special texture maps, six per object in the shape of a cube, that can be used to accurately simulate reflection on a shiny object). The biggest difficulty Valve found in creating these images was the lack of an HDR-equipped Photoshop. Even the most recent version, CS2, does not support HDR technology. Instead, Photoshop had to be used in conjunction with a third-party image editor called HDR Shop. This was the single biggest gripe that Valve engineers and artists had in the development of HDR content. As Gabe said, 3D video cards already support this in hardware, so why hasn't Adobe gotten around to supporting it in software?
KrikU
sõnum 26.09.2005 03:56:52 vasta tsitaadiga
Scart kirjutas:
KrikU kirjutas:
Ahjaa, see Far Cry HDR oli ka üks sitanikerdis mis lisas lihtsalt päikese 'bloom' effekti ja eriti muud midagi. HL2 HDR tuleb vähe karmim ja sellega saab ka AA reziime kasutada erinevalt Far Cryst. HL2 HDR tähendab ka muud kui bloom efekt.
tohoh, sa natuke ikka cryengine'i suhtes liiga kriitiline pole?
Ma ei kritiseerinud cryenginet (mis on minu hinnangul parim toimiv graafikamootor siiani) vaid nende varianti HDR-ist.
Auron
Auron
sõnum 26.09.2005 08:57:18 vasta tsitaadiga
Nu FC HDR polnudki see päris õige HDR vaid mingi nö.glimpse sellest patchiga asja juurdepookimise näol.True HDR vajab nats rohkem koodi kribamist kui patchiga lisada saaks.
Kommentaarid: 155 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 132
piq
sõnum 26.09.2005 18:56:22 vasta tsitaadiga
koliks äkki progemise foorumisse selle teemaga ?
mulle paraku ytleb se jutt mootorite teemal suht vähe tehke parem midagi kasulikku mitte ärge vaielge peaks ju nigu nutti jaguma vähemalt jutujärgi tundub nii.
Kommentaarid: 28 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 26
UB
UB
sõnum 26.09.2005 20:33:01 vasta tsitaadiga
piq kirjutas:
Mängumootor on osa mängust, kuidas selle saab siis kõrvale jätta! Õige asi õiges kohas!
Kommentaarid: 45 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 39
piq
sõnum 27.09.2005 14:04:36 vasta tsitaadiga
paraku jutuks hoopis teiste mängude mootorid ju täiesti erinevate tootjate poolt
seega natuke vale koht ikkagi
Ho Ho
Ho Ho
sõnum 27.09.2005 14:11:24 vasta tsitaadiga
Siin võrreldi mitmeid teisi mootoreid Source'ga. Ei saa ju mootorit iseendaga võrrelda icon_rolleyes.gif
hitimees
sõnum 30.09.2005 16:01:13 vasta tsitaadiga
ma ei mäleta enam kuidas kostüüm mängu alguses selga saada?keegi aitab äkki icon_rolleyes.gif
viimati muutis hitimees 30.09.2005 16:40:41, muudetud 2 korda
Kommentaarid: 7 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 4
v2hja
v2hja
sõnum 30.09.2005 16:15:35 vasta tsitaadiga
kuidas selle stiimist ostmisega on
krediitkaardi inff sisse ja siis saab kohe pela tirida ?
ta kui ma ostan hl2:silveri kas mulle misgine karp kah saadetakse
ja palju see +tax on
www.ninjatune.net
RIP Monkey Radio
Kommentaarid: 74 loe/lisa Kasutajad arvavad:  :: 0 :: 3 :: 60
neros
neros
sõnum 30.09.2005 16:19:59 vasta tsitaadiga
Krediitkaardi inff sisse jah ja kui pöörtšiss läbi läheb, saad tirida. Mingit karpi ei saadeta. Ainult kullaga saad.
tax... ei teagi icon_biggrin.gif aga
Day of Defeat: Source $ 19.95
Tax (Estonia) $ 3.59
niiet... vist sõltub riigist ja eesti taks on 3,59$... ei tea icon_biggrin.gif võin eksida, võimalik, et sõltub mängu enda hinnast icon_razz.gif
GitHub
.NET Core & Azure baasil lahendused ja arhitektuur - kontakt.
Kommentaarid: 48 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 40
hitimees
sõnum 30.09.2005 16:40:49 vasta tsitaadiga
hitimees kirjutas:
UB
UB
sõnum 30.09.2005 16:43:43 vasta tsitaadiga
hitimees kirjutas:
hitimees kirjutas:
Kui ise ei viitsi kapi lahti teha, siis seda tehakse ka ju sinu eest ja siis pole muud kui kappi astuda ja ongi kostüüm seljas. Ma ei saa probleemist hästi aru icon_eek.gif
ppg
ppg
sõnum 30.09.2005 16:45:00 vasta tsitaadiga
sai omalegi poest Half Life 2 ostetud
Kommentaarid: 171 loe/lisa Kasutajad arvavad:  :: 1 :: 5 :: 138
aare2
sõnum 30.09.2005 17:44:54 vasta tsitaadiga
ppg kirjutas:
Kus müüakse ja palju maksta võiks?
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 29
servechill
servechill
sõnum 30.09.2005 17:59:35 vasta tsitaadiga
Noh, mina astuksin stockmanni, kaubamajja või prismasse ja vaatkasin ringi....
Kommentaarid: 15 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 10
limp
limp
sõnum 30.09.2005 18:09:44 vasta tsitaadiga
eks ta mingine ~600 eeku maksab.
Ärgake lapsed, maailm on hädaohus
Windows keskkond on nagu li*s - kõik teda ke*ivad aga keegi teda ei armasta!
hitimees
sõnum 30.09.2005 18:29:12 vasta tsitaadiga
UB kirjutas:
hitimees kirjutas:
hitimees kirjutas:
neros
neros
sõnum 30.09.2005 18:46:12 vasta tsitaadiga
icon_lol.gif ega sul juhuslikult mingi "100" või midagi sellist kuskil ekraani allosas pole? icon_biggrin.gif
GitHub
Venturi
Venturi
sõnum 30.09.2005 18:47:00 vasta tsitaadiga
Ma ka mäletan nagu, et läksin lihtsalt vastu ja oligi seljas või oli selle kabri küljes milles kostüüm oli ping nupuke, keskel kuskil, kui üldse oli.
servechill
servechill
sõnum 05.10.2005 05:50:33 vasta tsitaadiga
Barney avab kapi ja sina astud sisse !
neros
neros
sõnum 12.10.2005 13:43:12 vasta tsitaadiga
Steam 3 siis väljas.
GitHub
Ho Ho
Ho Ho
sõnum 12.10.2005 13:57:52 vasta tsitaadiga
Keegi rag doll kung fu'd pole proovinud? Videot olen ma näinud ning peaks ütlema et pullimat mängu pole ma ammu näinud.
UB
UB
sõnum 12.10.2005 14:13:17 vasta tsitaadiga
madedog kirjutas:
ppg
ppg
sõnum 12.10.2005 14:13:29 vasta tsitaadiga
ei vaatand videotki kuigi looppis seda reklaami küll
neros
neros
sõnum 12.10.2005 14:51:06 vasta tsitaadiga
Ho Ho kirjutas:
GitHub
uus teema   vasta Tarkvara »  Arvutimängude foorum »  Half-Life 2 mine lehele eelmine  1, 2, 3 ... 151, 152, 153 ... 241, 242, 243  järgmine
