One
24.07.2005 21:29:02
link :: Linux and Geforce 7800GTX do not mix well
Phoronix tests the 7800GTX with Linux drivers. The latest GPU from nVidia does disappoint horribly.
They point out that the drivers released on the same day as the launch of the Geforce 7 did not bring
about the performance expected. They will do a re-run as soon as they get new drivers.
oi, mured paradiisis?
728 |
Ho Ho
24.07.2005 22:04:57
Samal lingil:
| EDIT (23-June-05): We have now confirmed that the majority of the performance problem is indeed related to the 2D/3D switch. After tampering with nvidia-settings and the NVClock CVS for several hours, we have concluded that with the 1.0-7667 drivers once a 3D application launches that the system continues to stick to the 2D frequencies rather than their respective 3D speeds. Thus during game-play the VPU is currently running roughly 275MHz (VPU) and 1200MHz (MEM) at 1.2V rather than the 3D performance level of 430MHz (VPU) and 1200MHz (MEM) at 1.4V. We attempted to correct this problem by overclocking the 2D and also 3D speeds using CoolBits and the NVClock CVS, and taking other such steps, but so far we haven't achieved success. We can only hope right now that this is indeed the only factor causing the poor performance and that NVIDIA developers will be able to address this problem in a timely manner. Once we have access to any newer drivers or a fix we will be publishing new benchmark results for the 7800GTX. |
Ehk siis keegi on väikese äparduse teinud.
| oi, mured paradiisis? |
Huvitav kas keegi ei tahaks võtta ette näiteks UT benchmarkimist linuxis et näha mis kaardid kuidas seal töötavad? Ühtlasi võiks teha ka võrlusi draiverite installi lihtsuse koha pealt. Oleks näha kes on paradiisis, kes mitte.
Mina saaks põhimõtteliselt testida oma FX'i ning venna 9800se'd kui ma viimasel lõpuks draiverid tööle saaks.
87 |
v2hja
24.07.2005 22:21:09
5950 käest saab GLXgearsist 9800pro kuskil 3-4 kordselt mööda kotte
_________________ www.ninjatune.net
RIP Monkey Radio |
| Kommentaarid: 74 loe/lisa |
60 |
Ho Ho
24.07.2005 22:26:21
glxgearsiga videokaartide võrdlemine on sama mis seda teha quake2'ga. See on väga otseselt limiteeritud prose poolt ning videokaardi võimalustest kasutab see ainult paari protsenti.
3-4x on kiirusevahe siis kui ühel on DRI teisel mitte või siis ühel kahest suht nõrgast kaardist ei toimi 3d kiirendus
87 |
HDTanel
Overclocker
25.07.2005 09:28:02
minu Gigabyte 7800GTX on Eestis 8) 13-14 ajal järgi CoolFX G70 veeplokk kah
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
25.07.2005 09:39:05
| no läheb siis kohe modimiseks ka?
201 |
One
25.07.2005 09:39:52
| PlatoonSgtElias kirjutas: |
minu Gigabyte 7800GTX on Eestis 8) 13-14 ajal järgi CoolFX G70 veeplokk kah |
tossu
platuun ära ka seekord meid alt vea
| Magic kirjutas: |
| no läheb siis kohe modimiseks ka? |
kohe vast mitte, mul pool elu jaani käes modimises
viimati muutis Winterwind 25.07.2005 09:40:21, muudetud 1 kord |
728 |
HDTanel
Overclocker
25.07.2005 09:40:20
Liiga ettevaatlik, et uuesti midagi läbi lasta P Modimisele kolmap
496 |
ZHarp
25.07.2005 09:59:41
Võiksid ennem hullumeelset 3D Mark'i rallit mänge ka proovida ja rääkida lihtsalt sellest kuidas asjad jooksevad, milliseid settinguid mängudes võimaldab ...ilusaid screene üles loopida ...näit Far-Cry, Doom 3, Half-Life 2, Battlefield 2 jms.
| Kommentaarid: 61 loe/lisa |
56 |
Auron
25.07.2005 10:06:31
Jah platuun, mängi ikka mänge kah enne kui kaardi õhtale lased
133 |
HDTanel
Overclocker
25.07.2005 10:23:53
will do ärge nüüd neetke mind ära. Korra juhtus siis juhtus OVP läheb peale ja nüüd ikka raudselt multimeetriga enne kontrollin volte + ei keera volte üles restardi ajal
Kus te üldse soovitate volte keerata? windowsis või BIOSes?
496 |
25.07.2005 11:43:22
winnis, samas pane boot screeni ajal paus peale ja kruvi seal peale... nagu kõikse ohutum...kui nii üldse öelda saab
201 |
Jaan
25.07.2005 12:47:06
| Magic kirjutas: |
winnis, samas pane boot screeni ajal paus peale ja kruvi seal peale... nagu kõikse ohutum...kui nii üldse öelda saab  |
tuletan meelde, et nVidia videotel on pinge muutuv vastavalt reziimile (2D/3D) ja vahed üsna suured.
Kui vaja täpselt teada, palju ta 3d reziimis voltti saab, vaja mingi 3d app käima lükata ja sellel ajal keerata-mõõta.
app-ks sobib hästi 3dm2003 2 test või 2005-st midagi.
123 |
One
25.07.2005 12:59:03
platuun läks oma rondile järgi
728 |
PPriit
25.07.2005 13:04:29
Jõudu siis Platoon'ile ja jääme tulemusi ootama.
Mul endal veel tobedam seis: sai MSI NX7800GTX ära ostetud ja seisab kodus kapis
Tahaks juba proovida, aga emplaadi (DFI) saan kätte alles nädala lõpus...
| Kommentaarid: 9 loe/lisa |
9 |
25.07.2005 13:29:03
| Jaan kirjutas: |
| Magic kirjutas: |
app-ks sobib hästi 3dm2003 2 test või 2005-st midagi. |
nujah seega winnis kruttimisest ei pääse Samas seda 2D/3D reguleeringut maha võtta ei saa?
201 |
HDTanel
Overclocker
25.07.2005 13:54:17
Kaart käes oi Gigabyte karp on jube seksu õhtu kellama kätte sain ka Innovateku G70 CoolFX vesijahutus ploki ja voolikud Homme või ülehomme tuleb etc_tsiki mu poole vast oma FX57-ga
496 |
One
25.07.2005 13:55:08
gigabyte karp on megaväike, x800-l on ka 2x suurem karp
muidu tore loomake aga liiga pikk ja liiga pennike + liiga kallis
8.5k kaardi ja 1,5k veeploki eest on tavalisele lihtsurelikule ikka liig, mis liig....
728 |
HDTanel
Overclocker
25.07.2005 14:50:16
Kaardi hind oli norm imo... veeplokk kah siis mingi kvaliteetne enamvähem osta nii, et ei tea... rõõmu rohkem asjadest kui kulutatud rahast samas võib veel GTX hinnast vabalt 1500.- võtta ehk siis 7800GTX peale oma raha kulutasin täpselt 7000EEK tänu garantii nipile
edit: MSI K8N SLI ja Winchester 300+ 2x256mb mälu laseb winni peale.. testin korra igatahes kaart teeb väga vähe häält aga kuum on näppu peal ei hoia!!
PS! Hääletu kaart
496 |
Auron
25.07.2005 15:22:39
Skoore platuun RSK kähku
133 |
Sponge
25.07.2005 15:27:32
| Auron kirjutas: |
Skoore platuun RSK kähku  |
sama siin, msnis tüütasin veidi aga ütles et kohe läheb teeb mõned
| Kommentaarid: 398 loe/lisa |
323 |
HDTanel
Overclocker
25.07.2005 15:35:31
Tra peale nforce drivude peale panekut ei lähe winni enam uuesti installima... oo riiulis kellegi DFI SLI-DR testime vist sellega hoopis
edit: oh läks winni installin nüüd video drivud... arvan, et temp midagi 80c ringis haige
496 |
High-Q
25.07.2005 15:47:04
| riiulis kellegi DFI SLI-DR |
vot see on haige võõra vara loata kasutamine
97 |
HDTanel
Overclocker
25.07.2005 15:48:25
See ei läinud tööle pilti ei võtnud ette... garantiisse saatmine ootamas teda
496 |
Aegir
25.07.2005 15:49:01
ma käisin selle 7800 peal pirukaid soendamas.. räme küttekeha.. ära tuleb keelata sellised asjad.
_________________ HV teeb ka ahvist inimese. |
| Kommentaarid: 86 loe/lisa |
80 |
HDTanel
Overclocker
25.07.2005 15:55:01
irw haige ikka enam ei lugenud ühtegi plaati välja ühegi kirjutajaga masin... MSI mobo plokib vist õnneks leidsin MP3 mängija
Niih: TEMPERATUUR... kaart on täiesti vait... ja idle 53c päris hea kuigi kuum aga videokaardi kohta suht hea isegi
edit2: irw 3DMark01 alguse fps praegu RÄIGELT madal 3000+ peal 1800MHz 200FSB ja mingi esimene test 240fps
496 |
Sponge
25.07.2005 15:55:21
edit2: irw 3DMark01 alguse fps praegu RÄIGELT madal 3000+ peal 1800MHz 200FSB |
ära piina meid, lase mõni 01 03 05 run , kasvõi stock cpuga ja kelladega
323 |
HDTanel
Overclocker
25.07.2005 16:25:49
MSI K8N SLI
Winchester 3000+ 1800MHz
2x512Mb PC3200 noname defaultis
7800GTX@ 415\1200
400W Codegen huvitav kas see segaks klokkimist?
77 drivud ja highest detail
3DMark2001: 19,143p
3DMark2003: 14,748p enamvähem 1800mhz kohta
3DMark2005: 7,102p tegin X850XT rekordi üle
tra 05 jookseb... alguses fps 44
ok nüüd ootame siis koduseid tulemusi full loaed max oli 77c
496 |
PPriit
25.07.2005 16:28:39
05 tulemus kahtlaselt väike...
Või siis cpu nii palju pidurdas?
9 |
tjj
25.07.2005 16:55:06
http://firingsquad.com/hardware/athlon_64_geforce_7800_gtx_scaling/
System:
CPU AMD Athlon64 4000+
MB ASUS A8N-SLI Deluxe
Memory Kingston HyperX PC3200 2x512 Mb
OS WinXP + SP2 + DirectX 9.0c
PSU Hiper 525W
Results:
FiringSquad:
Minimum CPU, that should be used with 7800GTX to unveal it's full potential / A64 2.2GHz
| Kommentaarid: 161 loe/lisa |
6 :: |
117 |
tolm
25.07.2005 20:09:03
MSI K8N SLI
7800GTX@ 415\1200
3DMark2001: 19,143p
ok nüüd ootame siis koduseid tulemusi full loaed max oli 77c |
400W codega said 7800gtxi tööle? :|what fucking miracle is that
tee kodused testid kiiremini, jään ootama
| Kommentaarid: 12 loe/lisa |
12 |
One
25.07.2005 20:26:32
imeli oli see, et kellates hakkas kohe plokkima - throttle vist juba
nimigi ju "full throttle craphics" ehk siis täiega throttleb ja seda halvas mõttes
edit: platvorm lubas sellega 10k teha 3dmark 2005-es
ootan huviga
728 |
25.07.2005 20:32:26
| Winterwind kirjutas: |
ootan huviga  |
loodetavasti pole tegu 10K eest tossuga
aga jah, eks varsti kaart moditud ja jälle rekordid tulemas
201 |
Nu
25.07.2005 20:45:57
| Devilguy kirjutas: |
GTX pidi ju vähem energiat tarbima kui 6800Ultra ja 6800GT@Ultra töötab vabalt 400W codega.
_________________ DO you want it.. And if you had it would you flaunt it...
ss |
157 |
ZHarp
25.07.2005 21:05:57
Platoon jälgib praegu klaasistunud pilgul monitori (3D Mark jookseb juba) ja tõmbab närviliselt viimase raha eest ostetud sigarit Dammet ...score on vaja ju
56 |
One
25.07.2005 21:09:16
ära muretse - varsti tulevad need überleet postid ja lolz omfg, rolf postid
meenub see kui ta väitis, et 512mb mäluga kaart on kõvasti kiirem kui 256mb-ne
728 |
HDTanel
Overclocker
25.07.2005 22:42:19
Eh ega pole kõvasti kiirem... lihtsalt kasutas vähem operatiiv mälu ja luges mänge paremini kui vähema mäluga videokaart samapalju operatiiv mäluga.
Enivei see 7800GTX plokib sajaga panin selle vasest jahutuse peale mis 6600GT peal oli ja 2200rpm peal on temp 36c kuid sellel on mingi kiip plaadile joodetud, mis loeb pöördeid vendil... see saab nüüd aru, et vent seisab ja 3DMark2005 saan 1000p lasen just moditud 7800GTX BIOSe peale ja siis testima... osad testid korra tegin aga avaldan hiljem default tulemused polnud pahad
edit: tehtud BIOS update jätke meelde see jura kui uut radikat panete!! Peale update töötab kõik ladusalt... benchima nüüd rõdule 8)
viimati muutis HDTanel 25.07.2005 22:49:34, muudetud 1 kord |
496 |
margusser
25.07.2005 22:49:08
Imo see 7800 rokib ikka kahesotiga.
sadaüks kontrollerit on asjal sees. Jura tuleb v-moddiga ka raudselt jne.
167 |
HDTanel
Overclocker
25.07.2005 22:50:26
Ei tea... noo mingi ikka... aga mai tea.. kõigist võimalik jagu saada pea tööle vaja panna. Enivei praegu rõdu uks lahti ja temp 28c core Falconrock2 puhub peale
496 |
PPriit
25.07.2005 23:07:25
Tulemusi paluks, herr Elias, tulemusi, mitte lihtsalt "ilmateadet" .
9 |
One
25.07.2005 23:32:23
platuun just helistas ja väitis, et ta sai pea 20k @ 3dmark 2003
prose 10x280
mem 280mhz
video 550/1400
kast rõdul
728 |
margusser
25.07.2005 23:33:41
Hmm polegi paha skoor ju
24 piipu kah
167 |
Tbit
25.07.2005 23:39:59
hmm, kust ilmakaarest siis pauku ja suitsu võib näha
|OSTAN|-> T43 pikk jahutus |
230 |
margusser
25.07.2005 23:40:55
Tbit, Issand kannata no natukenegi. Alles sai kaardi ju
Päev, kaks siis vb
167 |
Tbit
26.07.2005 00:13:37
sry, ma jah natuke kärsitu inimene, eks hea asja nimel peab natuke ootama siis kah
230 |
ZHarp
26.07.2005 00:50:32
| margusser kirjutas: |
Päev, kaks siis vb |
Kamoon ...andke mehele nüüd natuke rahu selle leekides kaartide teemaga Ikke juhtub ...ja mõnikord mitukorda järiest
PS: ...ja Platoon vaat et siis alla 20k HV'sse nägu ei näita Teed margi täis omal
56 |
keegi-Hannes
| Kommentaarid: 42 loe/lisa |
38 |
HDTanel
Overclocker
26.07.2005 03:16:15
No krt argh Originaal Windows rikkus kõik ära... tahtis peale mõnda restarti aktiveerimist ja telefoni teel ainult ning 09-18ni võtavad vastu... täiesti aju.
Igatahes mingid skoorid tegin. Homme "teine" WinXP peale ning kõvemini ruunama asja 01 tahaks kah ära teha et jah... tehke üle neegripoisid
Platuun is bäk
Test:
AMD64@2861MHz
2x512Mb PC3200 Patriot 317MHz
Gigabyte 7800GTX@560\1440
WindowsXP <- fucking originaal
3DMark2003 - 20,273p http://service.futuremark.com/compare?2k3=4141239
3DMark2005 - 9,749p http://service.futuremark.com/compare?3dm05=1061951 <- Selle tulemuse parandan ümaramaks varsti
Üks ülihea asi veel, nimelt core on kõrgemal kui shim... vasest prescoti jahutus saab sigahästi kontakti... kinnises toas... 25c sooja ja videokaart on 29c idle muidugi, lihvisin asja peegliks kah ja AS5 vahele
viimati muutis HDTanel 26.07.2005 03:27:11, muudetud 1 kord |
496 |
lehm
110 |
HDTanel
Overclocker
26.07.2005 03:28:38
suht normid skoorid jah võib rahule jääda ostuga. kusjuures 550\1430 ei olnud ühtegi artifakti sees veel.
SLI-d osta ei kavatse mõttetu. Ehk saan kolmap FX57 näppida aga homme peale tööd hakkan kõvemini ruunama. See original win sucks
496 |
