uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  G70/71 ehk GF7800/7900/7600 seeria teema märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 10, 11, 12 ... 146, 147, 148  järgmine
One
sõnum 24.07.2005 20:29:02 vasta tsitaadiga
link :: Linux and Geforce 7800GTX do not mix well
Phoronix tests the 7800GTX with Linux drivers. The latest GPU from nVidia does disappoint horribly.
They point out that the drivers released on the same day as the launch of the Geforce 7 did not bring
about the performance expected. They will do a re-run as soon as they get new drivers.
Ho Ho
Ho Ho
sõnum 24.07.2005 21:04:57 vasta tsitaadiga
Samal lingil:
EDIT (23-June-05): We have now confirmed that the majority of the performance problem is indeed related to the 2D/3D switch. After tampering with nvidia-settings and the NVClock CVS for several hours, we have concluded that with the 1.0-7667 drivers once a 3D application launches that the system continues to stick to the 2D frequencies rather than their respective 3D speeds. Thus during game-play the VPU is currently running roughly 275MHz (VPU) and 1200MHz (MEM) at 1.2V rather than the 3D performance level of 430MHz (VPU) and 1200MHz (MEM) at 1.4V. We attempted to correct this problem by overclocking the 2D and also 3D speeds using CoolBits and the NVClock CVS, and taking other such steps, but so far we haven't achieved success. We can only hope right now that this is indeed the only factor causing the poor performance and that NVIDIA developers will be able to address this problem in a timely manner. Once we have access to any newer drivers or a fix we will be publishing new benchmark results for the 7800GTX.
Ehk siis keegi on väikese äparduse teinud.
oi, mured paradiisis?
Huvitav kas keegi ei tahaks võtta ette näiteks UT benchmarkimist linuxis et näha mis kaardid kuidas seal töötavad? Ühtlasi võiks teha ka võrlusi draiverite installi lihtsuse koha pealt. Oleks näha kes on paradiisis, kes mitte.
Mina saaks põhimõtteliselt testida oma FX'i ning venna 9800se'd kui ma viimasel lõpuks draiverid tööle saaks.
v2hja
v2hja
sõnum 24.07.2005 21:21:09 vasta tsitaadiga
5950 käest saab GLXgearsist 9800pro kuskil 3-4 kordselt mööda kotte
www.ninjatune.net
RIP Monkey Radio
Kommentaarid: 74 loe/lisa Kasutajad arvavad:  :: 0 :: 3 :: 60
Ho Ho
Ho Ho
sõnum 24.07.2005 21:26:21 vasta tsitaadiga
glxgearsiga videokaartide võrdlemine on sama mis seda teha quake2'ga. See on väga otseselt limiteeritud prose poolt ning videokaardi võimalustest kasutab see ainult paari protsenti.
3-4x on kiirusevahe siis kui ühel on DRI teisel mitte või siis ühel kahest suht nõrgast kaardist ei toimi 3d kiirendus
HDTanel
Overclocker
HDTanel
sõnum 25.07.2005 08:28:02 vasta tsitaadiga
minu Gigabyte 7800GTX on Eestis 8) 13-14 ajal järgi icon_biggrin.gif CoolFX G70 veeplokk kah
Minu Youtube - HDTanel
sõnum 25.07.2005 08:39:05 vasta tsitaadiga
no läheb siis kohe modimiseks ka?
One
sõnum 25.07.2005 08:39:52 vasta tsitaadiga
PlatoonSgtElias kirjutas:
Magic kirjutas:
viimati muutis Winterwind 25.07.2005 08:40:21, muudetud 1 kord
HDTanel
Overclocker
HDTanel
sõnum 25.07.2005 08:40:20 vasta tsitaadiga
Liiga ettevaatlik, et uuesti midagi läbi lasta icon_razz1.gifP Modimisele kolmap
ZHarp
sõnum 25.07.2005 08:59:41 vasta tsitaadiga
Võiksid ennem hullumeelset 3D Mark'i rallit mänge ka proovida ja rääkida lihtsalt sellest kuidas asjad jooksevad, milliseid settinguid mängudes võimaldab ...ilusaid screene üles loopida ...näit Far-Cry, Doom 3, Half-Life 2, Battlefield 2 jms. thumbs_up.gif
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 56
Auron
Auron
sõnum 25.07.2005 09:06:31 vasta tsitaadiga
HDTanel
Overclocker
HDTanel
sõnum 25.07.2005 09:23:53 vasta tsitaadiga
will do icon_razz1.gif ärge nüüd neetke mind ära. Korra juhtus siis juhtus icon_razz1.gif OVP läheb peale ja nüüd ikka raudselt multimeetriga enne kontrollin volte + ei keera volte üles restardi ajal icon_razz1.gif
Kus te üldse soovitate volte keerata? windowsis või BIOSes?
sõnum 25.07.2005 10:43:22 vasta tsitaadiga
winnis, samas pane boot screeni ajal paus peale ja kruvi seal peale... nagu kõikse ohutum...kui nii üldse öelda saab icon_razz.gif
Jaan
sõnum 25.07.2005 11:47:06 vasta tsitaadiga
Magic kirjutas:
tuletan meelde, et nVidia videotel on pinge muutuv vastavalt reziimile (2D/3D) ja vahed üsna suured.
Kui vaja täpselt teada, palju ta 3d reziimis voltti saab, vaja mingi 3d app käima lükata ja sellel ajal keerata-mõõta.
app-ks sobib hästi 3dm2003 2 test või 2005-st midagi.
Kommentaarid: 144 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 124
One
sõnum 25.07.2005 11:59:03 vasta tsitaadiga
PPriit
sõnum 25.07.2005 12:04:29 vasta tsitaadiga
Jõudu siis Platoon'ile ja jääme tulemusi ootama.
Mul endal veel tobedam seis: sai MSI NX7800GTX ära ostetud ja seisab kodus kapis icon_exclaim.gif icon_eek.gif
Tahaks juba proovida, aga emplaadi (DFI) saan kätte alles nädala lõpus... icon_cry.gif
sõnum 25.07.2005 12:29:03 vasta tsitaadiga
Jaan kirjutas:
Magic kirjutas:
nujah seega winnis kruttimisest ei pääse icon_razz.gif Samas seda 2D/3D reguleeringut maha võtta ei saa?
HDTanel
Overclocker
HDTanel
sõnum 25.07.2005 12:54:17 vasta tsitaadiga
Kaart käes icon_biggrin.gif oi Gigabyte karp on jube seksu icon_razz1.gif õhtu kellama thumbs_up.gif kätte sain ka Innovateku G70 CoolFX vesijahutus ploki icon_wink.gif ja voolikud thumbs_up.gif beer_yum.gif Homme või ülehomme tuleb etc_tsiki mu poole vast oma FX57-ga icon_biggrin.gif
One
sõnum 25.07.2005 12:55:08 vasta tsitaadiga
muidu tore loomake aga liiga pikk ja liiga pennike + liiga kallis
8.5k kaardi ja 1,5k veeploki eest on tavalisele lihtsurelikule ikka liig, mis liig....
HDTanel
Overclocker
HDTanel
sõnum 25.07.2005 13:50:16 vasta tsitaadiga
Kaardi hind oli norm imo... veeplokk kah siis mingi kvaliteetne enamvähem osta nii, et ei tea... rõõmu rohkem asjadest kui kulutatud rahast icon_wink.gif samas võib veel GTX hinnast vabalt 1500.- võtta icon_biggrin.gif ehk siis 7800GTX peale oma raha kulutasin täpselt 7000EEK icon_biggrin.gif tänu garantii nipile icon_razz.gif
edit: MSI K8N SLI ja Winchester 300+ 2x256mb mälu laseb winni peale.. testin korra icon_razz1.gif igatahes kaart teeb väga vähe häält aga kuum on icon_biggrin.gif näppu peal ei hoia!!
PS! Hääletu kaart
Auron
Auron
sõnum 25.07.2005 14:22:39 vasta tsitaadiga
Sponge
Sponge
sõnum 25.07.2005 14:27:32 vasta tsitaadiga
Auron kirjutas:
sama siin, msnis tüütasin veidi aga ütles et kohe läheb teeb mõned icon_lol.gif
Kommentaarid: 398 loe/lisa Kasutajad arvavad:  :: 4 :: 4 :: 323
HDTanel
Overclocker
HDTanel
sõnum 25.07.2005 14:35:31 vasta tsitaadiga
Tra icon_lol.gif peale nforce drivude peale panekut ei lähe winni enam icon_lol.gif uuesti installima... oo riiulis kellegi DFI SLI-DR icon_biggrin.gif testime vist sellega hoopis icon_razz1.gif
edit: oh läks winni icon_biggrin.gif installin nüüd video drivud... arvan, et temp midagi 80c ringis icon_lol.gif haige
High-Q
High-Q
sõnum 25.07.2005 14:47:04 vasta tsitaadiga
HDTanel
Overclocker
HDTanel
sõnum 25.07.2005 14:48:25 vasta tsitaadiga
See ei läinud tööle icon_razz1.gif pilti ei võtnud ette... garantiisse saatmine ootamas teda
Aegir
Aegir
sõnum 25.07.2005 14:49:01 vasta tsitaadiga
ma käisin selle 7800 peal pirukaid soendamas.. räme küttekeha.. ära tuleb keelata sellised asjad.
HV teeb ka ahvist inimese.
Kommentaarid: 86 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 80
HDTanel
Overclocker
HDTanel
sõnum 25.07.2005 14:55:01 vasta tsitaadiga
irw haige ikka icon_biggrin.gif enam ei lugenud ühtegi plaati välja ühegi kirjutajaga masin... MSI mobo plokib vist icon_razz1.gif õnneks leidsin MP3 mängija icon_biggrin.gif
Niih: TEMPERATUUR... kaart on täiesti vait... ja idle 53c thumbs_up.gif päris hea icon_eek.gif kuigi kuum aga videokaardi kohta suht hea isegi
edit2: irw icon_lol.gif 3DMark01 alguse fps praegu RÄIGELT madal icon_lol.gif 3000+ peal icon_biggrin.gif 1800MHz 200FSB ja mingi esimene test 240fps icon_lol.gif
Sponge
Sponge
sõnum 25.07.2005 14:55:21 vasta tsitaadiga
ära piina meid, lase mõni 01 03 05 run , kasvõi stock cpuga ja kelladega icon_lol.gif
HDTanel
Overclocker
HDTanel
sõnum 25.07.2005 15:25:49 vasta tsitaadiga
MSI K8N SLI
Winchester 3000+ 1800MHz
2x512Mb PC3200 noname defaultis
7800GTX@ 415\1200
400W Codegen huvitav kas see segaks klokkimist?
77 drivud ja highest detail
3DMark2001: 19,143p icon_lol.gif
3DMark2003: 14,748p enamvähem 1800mhz kohta icon_razz1.gif
3DMark2005: 7,102p icon_biggrin.gif tegin X850XT rekordi üle icon_lol.gif
ok nüüd ootame siis koduseid tulemusi icon_biggrin.gif full loaed max oli 77c
PPriit
sõnum 25.07.2005 15:28:39 vasta tsitaadiga
05 tulemus kahtlaselt väike...
tjj
tjj
sõnum 25.07.2005 15:55:06 vasta tsitaadiga
http://firingsquad.com/hardware/athlon_64_geforce_7800_gtx_scaling/
System:
CPU AMD Athlon64 4000+
MB ASUS A8N-SLI Deluxe
Memory Kingston HyperX PC3200 2x512 Mb
OS WinXP + SP2 + DirectX 9.0c
PSU Hiper 525W
Results:
FiringSquad:
Minimum CPU, that should be used with 7800GTX to unveal it's full potential / A64 2.2GHz
Kommentaarid: 161 loe/lisa Kasutajad arvavad:  :: 6 :: 0 :: 117
tolm
tolm
sõnum 25.07.2005 19:09:03 vasta tsitaadiga
MSI K8N SLI
7800GTX@ 415\1200
400W codega said 7800gtxi tööle? :|what fucking miracle is that icon_biggrin.gif
One
sõnum 25.07.2005 19:26:32 vasta tsitaadiga
imeli oli see, et kellates hakkas kohe plokkima - throttle vist juba icon_lol.gif
nimigi ju "full throttle craphics" ehk siis täiega throttleb ja seda halvas mõttes
edit: platvorm lubas sellega 10k teha 3dmark 2005-es
sõnum 25.07.2005 19:32:26 vasta tsitaadiga
Winterwind kirjutas:
Nu
Nu
sõnum 25.07.2005 19:45:57 vasta tsitaadiga
Devilguy kirjutas:
GTX pidi ju vähem energiat tarbima kui 6800Ultra ja 6800GT@Ultra töötab vabalt 400W codega.
DO you want it.. And if you had it would you flaunt it...
ss
Kommentaarid: 177 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 157
ZHarp
sõnum 25.07.2005 20:05:57 vasta tsitaadiga
Platoon jälgib praegu klaasistunud pilgul monitori (3D Mark jookseb juba) ja tõmbab närviliselt viimase raha eest ostetud sigarit icon_lol.gif Dammet ...score on vaja ju icon_smile.gif
One
sõnum 25.07.2005 20:09:16 vasta tsitaadiga
ära muretse - varsti tulevad need überleet postid ja lolz omfg, rolf postid icon_lol.gif
meenub see kui ta väitis, et 512mb mäluga kaart on kõvasti kiirem kui 256mb-ne icon_smile.gif
HDTanel
Overclocker
HDTanel
sõnum 25.07.2005 21:42:19 vasta tsitaadiga
Eh ega pole kõvasti kiirem... lihtsalt kasutas vähem operatiiv mälu ja luges mänge paremini kui vähema mäluga videokaart samapalju operatiiv mäluga.
Enivei see 7800GTX plokib sajaga icon_biggrin.gif panin selle vasest jahutuse peale mis 6600GT peal oli ja 2200rpm peal on temp 36c kuid sellel on mingi kiip plaadile joodetud, mis loeb pöördeid vendil... see saab nüüd aru, et vent seisab ja 3DMark2005 saan 1000p icon_lol.gif lasen just moditud 7800GTX BIOSe peale ja siis testima... osad testid korra tegin aga avaldan hiljem icon_razz1.gif default tulemused polnud pahad icon_biggrin.gif
edit: tehtud BIOS update icon_biggrin.gif jätke meelde see jura kui uut radikat panete!! Peale update töötab kõik ladusalt... benchima nüüd rõdule 8)
viimati muutis HDTanel 25.07.2005 21:49:34, muudetud 1 kord
margusser
sõnum 25.07.2005 21:49:08 vasta tsitaadiga
Imo see 7800 rokib ikka kahesotiga.
sadaüks kontrollerit on asjal sees. Jura tuleb v-moddiga ka raudselt jne. thumbs_up.gif
Kommentaarid: 215 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 167
HDTanel
Overclocker
HDTanel
sõnum 25.07.2005 21:50:26 vasta tsitaadiga
Ei tea... noo mingi ikka... aga mai tea.. kõigist võimalik jagu saada icon_razz1.gif pea tööle vaja panna. Enivei praegu rõdu uks lahti ja temp 28c core icon_biggrin.gif Falconrock2 puhub peale
PPriit
sõnum 25.07.2005 22:07:25 vasta tsitaadiga
Tulemusi paluks, herr Elias, tulemusi, mitte lihtsalt "ilmateadet" . icon_wink.gif
One
sõnum 25.07.2005 22:32:23 vasta tsitaadiga
platuun just helistas ja väitis, et ta sai pea 20k @ 3dmark 2003 icon_razz1.gif
prose 10x280
mem 280mhz
video 550/1400
margusser
sõnum 25.07.2005 22:33:41 vasta tsitaadiga
24 piipu kah
Tbit
sõnum 25.07.2005 22:39:59 vasta tsitaadiga
DVD is da 4483MB :-/)
|OSTAN|-> T43 pikk jahutus
Kommentaarid: 265 loe/lisa Kasutajad arvavad:  :: 0 :: 3 :: 230
margusser
sõnum 25.07.2005 22:40:55 vasta tsitaadiga
Päev, kaks siis vb
Tbit
sõnum 25.07.2005 23:13:37 vasta tsitaadiga
sry, ma jah natuke kärsitu inimene, eks hea asja nimel peab natuke ootama siis kah icon_smile.gif
ZHarp
sõnum 25.07.2005 23:50:32 vasta tsitaadiga
margusser kirjutas:
Päev, kaks siis vb
Kamoon ...andke mehele nüüd natuke rahu selle leekides kaartide teemaga icon_smile.gif Ikke juhtub ...ja mõnikord mitukorda järiest icon_smile.gif
PS: ...ja Platoon vaat et siis alla 20k HV'sse nägu ei näita icon_biggrin.gif Teed margi täis omal icon_smile.gif
keegi-Hannes
sõnum 26.07.2005 01:49:02 vasta tsitaadiga
Mitte ei leia infi kas Quadro FX 4500 saab ka juba kuskilt tellida või mitte! Kes teab privage mulle!
Või peab uskuma hoopis seda uudist http://www.theinquirer.net/?article=24837
Kommentaarid: 42 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 38
HDTanel
Overclocker
HDTanel
sõnum 26.07.2005 02:16:15 vasta tsitaadiga
No krt argh icon_evil.gif Originaal Windows rikkus kõik ära... tahtis peale mõnda restarti aktiveerimist ja telefoni teel ainult ning 09-18ni võtavad vastu... täiesti aju.
Igatahes mingid skoorid tegin. Homme "teine" WinXP peale icon_exclaim.gif beer_yum.gif ning kõvemini ruunama asja icon_wink.gif 01 tahaks kah ära teha icon_lol.gif et jah... tehke üle neegripoisid icon_razz1.gif
Platuun is bäk
Test:
AMD64@2861MHz
2x512Mb PC3200 Patriot 317MHz
Gigabyte 7800GTX@560\1440
3DMark2003 - 20,273p http://service.futuremark.com/compare?2k3=4141239
3DMark2005 - 9,749p http://service.futuremark.com/compare?3dm05=1061951 <- Selle tulemuse parandan ümaramaks varsti icon_lol.gif icon_biggrin.gif
Üks ülihea asi veel, nimelt core on kõrgemal kui shim... vasest prescoti jahutus saab sigahästi kontakti... kinnises toas... 25c sooja ja videokaart on 29c icon_biggrin.gif idle muidugi, lihvisin asja peegliks kah ja AS5 vahele
viimati muutis HDTanel 26.07.2005 02:27:11, muudetud 1 kord
lehm
lehm
sõnum 26.07.2005 02:24:38 vasta tsitaadiga
PlatoonSgtElias, õnnitlen. norm raha eest norm kaart icon_smile.gif SLI on 7800xxx-l?
http://service.futuremark.com/compare?2k3=4129280 singeli WR vist
viimati muutis lehm 26.07.2005 02:33:13, muudetud 1 kord
Kommentaarid: 117 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 110
HDTanel
Overclocker
HDTanel
sõnum 26.07.2005 02:28:38 vasta tsitaadiga
suht normid skoorid jah icon_razz1.gif võib rahule jääda ostuga. kusjuures 550\1430 ei olnud ühtegi artifakti sees veel.
SLI-d osta ei kavatse icon_razz1.gif mõttetu. Ehk saan kolmap FX57 näppida icon_biggrin.gif aga homme peale tööd hakkan kõvemini ruunama. See original win sucks
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  G70/71 ehk GF7800/7900/7600 seeria teema mine lehele eelmine  1, 2, 3 ... 10, 11, 12 ... 146, 147, 148  järgmine
