No_Limit
08.04.2005 07:24:29
Triple Sonic Slash'i ikka mõtled, tavaline triple slash teeb väga hädist damaget.
_________________ Ave, Caesar, morituri te salutant |
| Kommentaarid: 46 loe/lisa |
40 |
VibU
08.04.2005 14:28:32
| No_Limit kirjutas: |
| Triple Sonic Slash'i ikka mõtled, tavaline triple slash teeb väga hädist damaget. |
ple eriti kusrsis enam
| Kommentaarid: 4 loe/lisa |
Dominus
08.04.2005 21:55:10
Mafka needs help
ühesõnaga lasin L2 peale.Mis nüüd? et nagu tõsiselt ei mäleta mis tegema pidi.Otsingust ei leidnud kah midagi arukat.
Oleks tore kui keegi nüüd abistaks
viimati muutis Dominus 08.04.2005 22:08:48, muudetud 1 kord |
76 |
VibU
08.04.2005 22:07:06
Ok, C3 Tex Tutor
1) Install Lineage2
2) Install Server Patch
3) Install Level Patch (if available)
C3 Textures can be found easily on DC++ or any other file sharing program... Enter the keywords "L2 C3 Textures Final (or Clean)", and there you have a 300MB+ file to download.
4) Extract the Texture archive in root folder of Lineage2 (usually "C:\Program Files\Lineage2\"), overwrite any file necessary.
Download this Texture Patch:
http://student.pb.bielsko.pl/~gbizon/ul2/armorgrp.rar
5) Extract the contents of the above Texture Patch in "C:\Program Files\LineageII\System" folder.
I hope thats all it takes to make this work, this procedure works for me and there were no critical errors. I've been testing this Setup for almost a week now.
If it doesn't work leave your comments here.
Dominus
08.04.2005 22:16:37
Server Patch,Level patch? tõsist seletamist on vaja mulle
no ei jaga mina enam midagi...nagu naabik noh
76 |
VibU
08.04.2005 22:20:36
| Mafka kirjutas: |
no ei jaga mina enam midagi...nagu naabik noh  |
eiei, see on nagu bnb servu kohta, sa lihtsalt t6mba see c3 texture asi ja valmis!
btw, bnb servus C2 skillid valmis , ja t66tavad C1-s ka ! nüüd peab ootama kuna lisatakse,
siis TH - huhu
Dominus
08.04.2005 23:05:05
aga kuidas ma saaks 2-serveri vahet mängida? pean pidevalt vahetama neid l2.ini faile?oli vist mingi multi värk millega vabalt vahetada sai?
viimati muutis Dominus 09.04.2005 16:17:38, muudetud 1 kord |
76 |
painkillah
09.04.2005 00:36:06
VibU, ka tiiiight servus teeb karnage rasket tööd et c2 skille külge pookida, mis peakski varsti juhtuma.
level patch peaks olema patch mis näitab mobi levelit ja kas on aggro/või mitte
| Kommentaarid: 95 loe/lisa |
6 :: |
86 |
No_Limit
09.04.2005 03:48:48
HSC on võimalik vanu skille C2 raames edasi arendada, küll kunagi ka C2 uued skillid tulevad
40 |
Merc
09.04.2005 09:07:12
| Nii mul on selline küsimus et kas keegi teab mille pärast mul vahest lihtsalt lambist tulevad crtical errorid ette ehk siis viskab mängust kah välja. Kas nagu sellel vahet on mis texturid peal mul on??
VibU
09.04.2005 09:22:43
| Merc kirjutas: |
| Nii mul on selline küsimus et kas keegi teab mille pärast mul vahest lihtsalt lambist tulevad crtical errorid ette ehk siis viskab mängust kah välja. Kas nagu sellel vahet on mis texturid peal mul on?? |
esimesed c3 mida proovisin olid mingid vigased, ja ei sobinud c1 clientile. si*aks erroreid oli..
t6mba c2 textured ja siis lisa see http://student.pb.bielsko.pl/~gbizon/ul2/armorgrp.rar
siis peaksid n2gema c3-e, ilma errotiteta
Dominus
09.04.2005 16:37:20
| No krt.Lasin L2 peale,L2C1Updates ja serveri patch peale.Regasin tiiightis ära,hakkan sisse logima ja no ei lähe.Mis värk on?
76 |
ZAndlamb
09.04.2005 17:00:46
server äkki maas
EDIT: Server Status: Offline -- Server down becos one of the dedicated servers is broke, hard drive formatted, DATABASE BACKED-UP VERY LUCKILY
| Kommentaarid: 22 loe/lisa |
22 |
Dominus
09.04.2005 17:24:52
| mnjah...mis serverites te veel mängite peale HSC ja B&B? ja kas saaks linke nendele?ja kellelgi c2 või c3 töötavaid linke on?
76 |
arvutisõber
09.04.2005 18:50:11
| ZAndlamb kirjutas: |
| DATABASE BACKED-UP VERY LUCKILY |
no krt, neil on ju 2 HDD -d, eeldatavasti raidis.
_________________ ... |
| Kommentaarid: 55 loe/lisa |
53 |
Dominus
09.04.2005 20:12:02
damnit noh...andke mulle priva servude linke,tahan täiega pelada aga tiiiight or smt on maas ja teisi ei leia
76 |
Snaxez
| Kommentaarid: 61 loe/lisa |
54 |
Metsjeesus
09.04.2005 23:15:28
Ma oleks väga tänulik kui keegi annaks ~10x ratedega serveri lingi, C2.
Ohoo, ülal antud lingil on kah mingi valik servereid, aga ei ütleks ära kui keegi teab veel mingit head.
_________________ Füsioteraapia alane hindamine & nõu ¤ treeningfilosoofia & toitumine ¤ kaela- ja õlavöötme lihaspingete leevendamine |
94 |
Dominus
10.04.2005 01:10:53
Snaxez,pooled servud on kas maas või mingid vigased
mul oleks vaja mingit C1 servut mitte C2-te...kuna C2-te mul ple.
HSC vist oli veel C1 ? Ja B&B? kas saaks B&B linki?
76 |
VibU
pilsner
10.04.2005 10:42:55
tere |
ma tõmbasin ka selle mängu aga nüüd ma avastasin et see raibe on tasuline vist aga ma ei ole kindel kas keegi teab sellest midagi ja ma nagu regasin ära ja kõik aga nüüd ta küsib seda 20 kohalist serial koodi kus ma selle veel saaks? kui keegi teab siis palun öelge see kood!!!! ette tänades
0 |
Snaxez
10.04.2005 10:44:51
Re: tere |
| Mafka kirjutas: |
HSC vist oli veel C1 ? Ja B&B? kas saaks B&B linki? |
seal on ju suur osa serveritel taga kirjas kas C1 v6i C2....
ja teine leht kus leiab L2 serveried....
http://www.gamesites200.com/lineage2/
| pilsner kirjutas: |
ma tõmbasin ka selle mängu aga nüüd ma avastasin et see raibe on tasuline vist aga ma ei ole kindel kas keegi teab sellest midagi ja ma nagu regasin ära ja kõik aga nüüd ta küsib seda 20 kohalist serial koodi kus ma selle veel saaks? kui keegi teab siis palun öelge see kood!!!! ette tänades  |
just selle sama õige koodi saad sa osta www.lineage2.com lehetl kõigest 49.99$...võis ka olla rohkem..pead ei anna
viimati muutis Snaxez 10.04.2005 10:49:35, muudetud 1 kord |
54 |
pilsner
10.04.2005 10:47:23
Aga kas kellegi teise kood ei loe ? ma ei taha nagu mingi 400 sotti selle peale raisata
0 |
VibU
10.04.2005 10:53:55
ilma koodita m2ngimiseks on privaat serverid
kodukal t6mmatud clientiga saad aint c2 servudese.. vist(m6nele c2 servule
ei sobi koduka client)
pilsner
10.04.2005 11:16:01
mnjaa |
| siis ei saagi seda mängida ju kui raha ei maksa siis on see ikka täielik pask aga keegi siis seda priva serverit ei tea veel`?
0 |
Snaxez
10.04.2005 11:22:05
Re: mnjaa |
| pilsner kirjutas: |
| siis ei saagi seda mängida ju kui raha ei maksa siis on see ikka täielik pask aga keegi siis seda priva serverit ei tea veel`? |
ega mõistus pole ikka omateha....sa oleksid kohe kõvasti targem kui sa seda teemat natuke ka loeksid
54 |
VibU
10.04.2005 11:55:29
Re: mnjaa |
| pilsner kirjutas: |
idioot?
Dominus
10.04.2005 13:10:31
kas see tiiiight on pidevalt maas? ja ega kellelgi pole c2,c3 textuure?
76 |
arvutisõber
10.04.2005 14:12:40
| Mafka kirjutas: |
kas see tiiiight on pidevalt maas? ja ega kellelgi pole c2,c3 textuure? |
Tiiiight ei ole pidevalt maas, aga no HDD crashis ja asi võib kahjuks veel päeva või kaks võtta, mina sain nii aru.
Kui servu uuesti üles pannakse, siis annan kohe teada.
53 |
ZAndlamb
10.04.2005 16:00:13
ma jälgin ka ircis seisu nii et saab teatatud ka siit poolt
EDIT: Server Status: Offline -- Karnage need someone to transfer 100$ on his e-gold account, he will pay you back 100$ on paypal. Server will be up by tomorrow if someone can help do that
22 |
Dominus
10.04.2005 17:32:58
| EDIT: Server Status: Offline -- Karnage need someone to transfer 100$ on his e-gold account, he will pay you back 100$ on paypal. Server will be up by tomorrow if someone can help do that |
lol...imo puhas scam
btw läksin mingisse lamp serverisse http://www.lineage2world.com/site/ vot...räigelt klikkisin login nuppu ja sain sisse...
aga mul mõned asjad on lihtsalt mustad...ehk nagu inventorys ja poes näen musta koha ja kirja peal aint...
kas ma pean siis tõmbama c2 textuurid või kogu c2? palun aidake keegi
ja mis oleks hea valida DE fighter classiks ? kas see vibu,dagger või mõõgamees?
76 |
LightsabeR
10.04.2005 17:48:20
Re: mnjaa |
| Snaxez kirjutas: |
| pilsner kirjutas: |
ega mõistus pole ikka omateha....sa oleksid kohe kõvasti targem kui sa seda teemat natuke ka loeksid |
Sõbralikumalt öeldes mängivad siin teemas postitavatest inimestest 99% erinevates privaat serverites. Loe, uuri, proovi ja siis küsi abi, kui probleeme tekib.
| Kommentaarid: 14 loe/lisa |
14 |
Dominus
10.04.2005 17:51:21
tra noh...mul ongi probleemid ja keegi ei aita
hakkasin mõnusalt droolides jälle enam vähem mängima aga need mustad kastid käivad pinda...
mis ma teen siis? otsin c2 textuurid või kogu update-i? ja kas keegi saaks "töötavat" c2 textures linki anda?
76 |
Djomka
10.04.2005 18:46:45
mul olid HSC's millalgi sellised asjad, aga kui kolisin uude servusse, siis pole enam probleemi olnud
12 |
No_Limit
10.04.2005 20:00:35
Ise oled sa täielik pask! Tõmba kusagil Lineage 2 C1 ja tule mängi privaat serverites, mis on tasuta. Kõik sõltub sinust, keegi ei pea sinule ette taha kõike ära tegema.
Ja kui sa tahad officialis mängida, siis algul maksad selle 50 dollarit, siis esimene kuu peaks tasuta olema ja siis pead hakkama iga kuu 13 dollarit maksma.
EDIT: See tulenes sellest, et sa ei updateind oma HSC patchi. Miks te HSC serverisse ei tule? Me teeme varsti clan level 5 ära.
40 |
Dominus
10.04.2005 21:02:34
tra kõik ignoreerivad mind rsk xD
*ahhui...andke mulle P-A-L-U-N töötavad c2 või c3 textuurid
ma tuleks HSC-i kui keegi ütleks mis minu TH-ga seal toimub (on ta riided alles? jne.)
76 |
VibU
10.04.2005 21:41:36
| Mafka kirjutas: |
ma tuleks HSC-i kui keegi ütleks mis minu TH-ga seal toimub (on ta riided alles? jne.) |
http://snaxez.pri.ee/Lineage2/L2_C2_Textures.rar
Dominus
10.04.2005 21:44:15
VibU, THANK YOU! and Thanks snaxez for hosting
ffs...sain ometigi nüüd kätte asja...loodan et need mustad kastid kah kaovad ja ma hakkan itemeid nägema.
76 |
No_Limit
10.04.2005 21:55:55
| Mafka kirjutas: |
FFS Mafka ignoreerib mind, su TH on paljas nagu porgand ja häbiks HSC komuunile.
40 |
Djomka
10.04.2005 22:46:46
no limit, muide, ma tegin selle patchi ära...osad asjad lõid erroreid ja need ma parandasin küll ära, aga ikka olid mingid jurad sellega ja tänu sellele ma ei saanud HSC'sse tulla...kui mafka tuleb, siis ma saan temaga MSN'is täpselt rääkida, et mida ta tegi ja kuidas ta asja siis lõpuks tööle sai...tuleksin ju hea meelega ja osaliksin ka clanis
12 |
Dominus
10.04.2005 22:48:19
No_Limit, häbiks? mismoodi? krt lvl 52-te algusest peale ei anna ikka nii kergelt teha
76 |
No_Limit
10.04.2005 22:51:46
Võta vana char siis ja aja talle riided selga jne.
40 |
Dominus
10.04.2005 23:27:54
mnjah...lasin snaxezi c2 textuurid peale ja ikka need mustad augud jäävad mõningate itemite peale...et mis värk on? kogu c2 update siis vaja?
mobidele tulid lvl-id kah peale...yay...muud midagi erilist ei märganud
76 |
Exalibur
11.04.2005 15:13:18
veelkord kes tahab mu acaunti siis pm (voite ka paljaks koorida enam seda ei pela)
Edit:passi ja useri andsin juba no limitile kui ta armuriline on siis ta jagab teile misket
(no limit-anna mythicule 2mil kui saad nende nanni eestt mis mul on laos ja charidel olen talle volgu)
_________________ M:Katkise videoga laptop |
| Kommentaarid: 15 loe/lisa |
14 |
No_Limit
11.04.2005 15:45:24
Mystic on vana reetur Aga jah ma olen armuline, ma jagan asju. Keegi Top D asju tahab laenata, hiljem muidugi tagastate.
Eile öösel käisin Gludio siegil, koolis olin nii unine, et silmad jooksid pasavett
40 |
Dominus
11.04.2005 16:55:49
| a teab keegi kuidas need mustad kastid ära saab ja ma asju inventoris ja poes nägema hakkaksin?
76 |
Djomka
11.04.2005 17:02:42
| vbl HSC autopatcheriga oli mingi kamm siis sul...
12 |
Darkland
11.04.2005 17:12:43
heips rahvas!
ehk on rahval soovi liituda l2planetiga C1 varsti peaks olema C2
hetkel vajalik C1 ja toimida nagu kodukal kirjas
siis vastavalt www.l2planet.com
Parim kui liituda meie klanniga = pm "devilkina
hetkel 12 klanniliiget
Dominus
11.04.2005 17:44:34
pekki...kas DE-l polegi siis dual sword meest?
ma nagu lootsin et on...aga vaatasin et ainult bow ja daggeri classis on neile mõeldud skillid...
76 |
Metsjeesus
11.04.2005 18:51:06
Gladiaator on duali mees jah? Mõtlesin teha miskit duali seppa ja tegin human warri
94 |
