No_Limit
08.04.2005 07:24:29
Triple Sonic Slash'i ikka mõtled, tavaline triple slash teeb väga hädist damaget.
_________________ Ave, Caesar, morituri te salutant |
| Kommentaarid: 46 loe/lisa |
40 |
VibU
08.04.2005 14:28:32
| No_Limit kirjutas: |
| Triple Sonic Slash'i ikka mõtled, tavaline triple slash teeb väga hädist damaget. |
ple eriti kusrsis enam
| Kommentaarid: 4 loe/lisa |
Dominus
08.04.2005 21:55:10
Mafka needs help
ühesõnaga lasin L2 peale.Mis nüüd? et nagu tõsiselt ei mäleta mis tegema pidi.Otsingust ei leidnud kah midagi arukat.
Oleks tore kui keegi nüüd abistaks
viimati muutis Dominus 08.04.2005 22:08:48, muudetud 1 kord |
76 |
VibU
08.04.2005 22:07:06
Ok, C3 Tex Tutor
1) Install Lineage2
2) Install Server Patch
3) Install Level Patch (if available)
C3 Textures can be found easily on DC++ or any other file sharing program... Enter the keywords "L2 C3 Textures Final (or Clean)", and there you have a 300MB+ file to download.
4) Extract the Texture archive in root folder of Lineage2 (usually "C:\Program Files\Lineage2\"), overwrite any file necessary.
Download this Texture Patch:
http://student.pb.bielsko.pl/~gbizon/ul2/armorgrp.rar
5) Extract the contents of the above Texture Patch in "C:\Program Files\LineageII\System" folder.
I hope thats all it takes to make this work, this procedure works for me and there were no critical errors. I've been testing this Setup for almost a week now.
If it doesn't work leave your comments here.
Dominus
08.04.2005 22:16:37
Server Patch,Level patch? tõsist seletamist on vaja mulle
no ei jaga mina enam midagi...nagu naabik noh
76 |
VibU
08.04.2005 22:20:36
| Mafka kirjutas: |
no ei jaga mina enam midagi...nagu naabik noh  |
eiei, see on nagu bnb servu kohta, sa lihtsalt t6mba see c3 texture asi ja valmis!
btw, bnb servus C2 skillid valmis , ja t66tavad C1-s ka ! nüüd peab ootama kuna lisatakse,
siis TH - huhu
Dominus
08.04.2005 23:05:05
aga kuidas ma saaks 2-serveri vahet mängida? pean pidevalt vahetama neid l2.ini faile?oli vist mingi multi värk millega vabalt vahetada sai?
viimati muutis Dominus 09.04.2005 16:17:38, muudetud 1 kord |
76 |
painkillah
09.04.2005 00:36:06
VibU, ka tiiiight servus teeb karnage rasket tööd et c2 skille külge pookida, mis peakski varsti juhtuma.
level patch peaks olema patch mis näitab mobi levelit ja kas on aggro/või mitte
| Kommentaarid: 95 loe/lisa |
6 :: |
86 |
No_Limit
09.04.2005 03:48:48
HSC on võimalik vanu skille C2 raames edasi arendada, küll kunagi ka C2 uued skillid tulevad
40 |
Merc
09.04.2005 09:07:12
| Nii mul on selline küsimus et kas keegi teab mille pärast mul vahest lihtsalt lambist tulevad crtical errorid ette ehk siis viskab mängust kah välja. Kas nagu sellel vahet on mis texturid peal mul on??
VibU
09.04.2005 09:22:43
| Merc kirjutas: |
| Nii mul on selline küsimus et kas keegi teab mille pärast mul vahest lihtsalt lambist tulevad crtical errorid ette ehk siis viskab mängust kah välja. Kas nagu sellel vahet on mis texturid peal mul on?? |
esimesed c3 mida proovisin olid mingid vigased, ja ei sobinud c1 clientile. si*aks erroreid oli..
t6mba c2 textured ja siis lisa see http://student.pb.bielsko.pl/~gbizon/ul2/armorgrp.rar
siis peaksid n2gema c3-e, ilma errotiteta
Dominus
09.04.2005 16:37:20
| No krt.Lasin L2 peale,L2C1Updates ja serveri patch peale.Regasin tiiightis ära,hakkan sisse logima ja no ei lähe.Mis värk on?
76 |
ZAndlamb
09.04.2005 17:00:46
server äkki maas
EDIT: Server Status: Offline -- Server down becos one of the dedicated servers is broke, hard drive formatted, DATABASE BACKED-UP VERY LUCKILY
| Kommentaarid: 22 loe/lisa |
22 |
Dominus
09.04.2005 17:24:52
| mnjah...mis serverites te veel mängite peale HSC ja B&B? ja kas saaks linke nendele?ja kellelgi c2 või c3 töötavaid linke on?
76 |
arvutisõber
09.04.2005 18:50:11
| ZAndlamb kirjutas: |
| DATABASE BACKED-UP VERY LUCKILY |
no krt, neil on ju 2 HDD -d, eeldatavasti raidis.
_________________ ... |
| Kommentaarid: 55 loe/lisa |
53 |
Dominus
09.04.2005 20:12:02
damnit noh...andke mulle priva servude linke,tahan täiega pelada aga tiiiight or smt on maas ja teisi ei leia
76 |
Snaxez
| Kommentaarid: 61 loe/lisa |
54 |
Metsjeesus
09.04.2005 23:15:28
Ma oleks väga tänulik kui keegi annaks ~10x ratedega serveri lingi, C2.
Ohoo, ülal antud lingil on kah mingi valik servereid, aga ei ütleks ära kui keegi teab veel mingit head.
_________________ Füsioteraapia alane hindamine & nõu ¤ treeningfilosoofia & toitumine ¤ kaela- ja õlavöötme lihaspingete leevendamine |
94 |
Dominus
10.04.2005 01:10:53
Snaxez,pooled servud on kas maas või mingid vigased
mul oleks vaja mingit C1 servut mitte C2-te...kuna C2-te mul ple.
HSC vist oli veel C1 ? Ja B&B? kas saaks B&B linki?
76 |
VibU
pilsner
10.04.2005 10:42:55
tere |
ma tõmbasin ka selle mängu aga nüüd ma avastasin et see raibe on tasuline vist aga ma ei ole kindel kas keegi teab sellest midagi ja ma nagu regasin ära ja kõik aga nüüd ta küsib seda 20 kohalist serial koodi kus ma selle veel saaks? kui keegi teab siis palun öelge see kood!!!! ette tänades
0 |
Snaxez
10.04.2005 10:44:51
Re: tere |
| Mafka kirjutas: |
HSC vist oli veel C1 ? Ja B&B? kas saaks B&B linki? |
seal on ju suur osa serveritel taga kirjas kas C1 v6i C2....
ja teine leht kus leiab L2 serveried....
http://www.gamesites200.com/lineage2/
| pilsner kirjutas: |
ma tõmbasin ka selle mängu aga nüüd ma avastasin et see raibe on tasuline vist aga ma ei ole kindel kas keegi teab sellest midagi ja ma nagu regasin ära ja kõik aga nüüd ta küsib seda 20 kohalist serial koodi kus ma selle veel saaks? kui keegi teab siis palun öelge see kood!!!! ette tänades  |
just selle sama õige koodi saad sa osta www.lineage2.com lehetl kõigest 49.99$...võis ka olla rohkem..pead ei anna
viimati muutis Snaxez 10.04.2005 10:49:35, muudetud 1 kord |
54 |
pilsner
10.04.2005 10:47:23
Aga kas kellegi teise kood ei loe ? ma ei taha nagu mingi 400 sotti selle peale raisata
0 |
VibU
10.04.2005 10:53:55
ilma koodita m2ngimiseks on privaat serverid
kodukal t6mmatud clientiga saad aint c2 servudese.. vist(m6nele c2 servule
ei sobi koduka client)
pilsner
10.04.2005 11:16:01
mnjaa |
| siis ei saagi seda mängida ju kui raha ei maksa siis on see ikka täielik pask aga keegi siis seda priva serverit ei tea veel`?
0 |
