uus teema   vasta Ärifoorumid »  Arvutitehnika ja tarkvara müük/vahetus »  10» M: Workstation kraami :: Asukoht: Keila märgi kõik teemad loetuks
Kristoferr
Kristoferr
sõnum 09.06.2026 17:40:05 10» M: Workstation kraami :: Asukoht: Keila vasta tsitaadiga
1. Asus ProArt X870E-CREATOR WIFI
https://www.asus.com/motherboards-components/motherboards/proart/proart-x870e-creator-wifi/
AH: 350-
2. Ryzen 9 9950X, Delidded + AM5 High Performance Heatspreader. Üks väga tubli isend.
https://www.amd.com/en/products/processors/desktops/ryzen/9000-series/amd-ryzen-9-9950x.html
https://www.thermal-grizzly.com/en/heatspreader/s-tg-hphs
AH: 300-
3. Arctic Liquid Freezer III 420 A-RGB Black
https://www.arctic.de/en/Liquid-Freezer-III-420-A-RGB/ACFRE00145A
AH 70-
4. Powercolor RX 7900 XTX Red Devil 24GB. Ilmselt kõige parema jahutusega XTX (enne pakkumist kontrolli kas kasti mahub!)
https://www.powercolor.com/product-detail71.htm
H: 650-
5. 128GB (2x64) DDR5-6400, Corsair Vengeance CMK128GX5M2B6400C42
https://www.corsair.com/us/en/p/memory/cmk128gx5m2b6400c42/vengeance-128gb-2x64gb-ddr5-dram-6400mt-s-cl42-intel-xmp-memory-kit-cmk128gx5m2b6400c42
AH: 800-
6. NZXT C1000 Gold ATX 3.1.
https://nzxt.com/en-intl/products/c1000-gold-atx
AH: 100-
7. Deepcool CH780 Black
https://www.deepcool.com/products/Cases/CH780-Panoramic-Tempered-Glass-ATX-Case/2023/17534.shtml
AH: 125-
8. Uus! ASUS ProArt PA602 Wood Edition Tempered Glass
https://www.asus.com/motherboards-components/cases/proart/proart-pa602-wood-edition-tempered-glass-panel/
H: 175-
9. Uus! Intel BE200 WIfi-7 kaart. Komplektis on ka kaablid ja välised antennid
H: 20-
10. Palit GT1030 2GB GDDR5 low profile videokaart.
https://www.techpowerup.com/gpu-specs/palit-gt-1030-low-profile.b4640
H: 25-
Liitu Opencode Go soodsa coding plaaniga ja saa 5€ soodust!
Liitu Wise'ga!
Kommentaarid: 267 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 218
Dreamlover
Dreamlover
sõnum 09.06.2026 19:41:11 vasta tsitaadiga
5 AH
ARVUTID
3G1,5/3G2,5/5G1,5/5G2,5 KAABEL
HDD kettad
Kommentaarid: 1905 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 1327
Kristoferr
Kristoferr
sõnum 10.06.2026 22:18:31 vasta tsitaadiga
Liitu Wise'ga!
jimmmmmy19
sõnum 11.06.2026 00:38:01 vasta tsitaadiga
4. Kui vana ja karp ?
Kommentaarid: 26 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 24
Kristoferr
Kristoferr
sõnum 11.06.2026 08:09:18 vasta tsitaadiga
Täpset vanust ei tea. Originaalkarp ilma ümbriseta.
Liitu Wise'ga!
Allar119
sõnum 11.06.2026 10:36:19 vasta tsitaadiga
10. OK
Kristoferr
Kristoferr
sõnum 14.06.2026 08:26:50 vasta tsitaadiga
Kirjuta/helista kuidas kätte soovid saada. Pakiautomaat on +4€. Keilas käest kätte sobib ka.
Kui üle ei pakuta, siis läheb AH'ga homme õhtul lukku.
Liitu Wise'ga!
karl660
sõnum 15.06.2026 11:13:01 vasta tsitaadiga
2. AH
Kristoferr
Kristoferr
sõnum 21.06.2026 23:46:27 vasta tsitaadiga
karl660 kirjutas:
2. AH
Kui juurde ei pakuta, siis reedel lukku ja saad endale.
Teoreetiliselt 9950x asemel võimalik ka 7700x loobuda. Sellisel juhul jätan 9950X, Delidded + AM5 High Performance Heatspreader endale. Emb-kumb siis.
Liitu Wise'ga!
caramis
caramis
sõnum 22.06.2026 14:00:24 vasta tsitaadiga
küsin sekka, et kui suur vahe originaal IHSiga oli temperatuuride osas?
up
Kommentaarid: 173 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 150
Kristoferr
Kristoferr
sõnum 22.06.2026 15:01:05 vasta tsitaadiga
ca 300mhz all core sain juurde. Kui biosest maksimum +200mz anda, siis all core load temperatuurid jooksevad 16-tuumalisel Ryzeni, toatemperatuuril vesijahutusega, alati piirajasse. Sh ei ole vahet, kui vinge see jahutus on.
Liitu Wise'ga!
caramis
caramis
sõnum 22.06.2026 18:01:28 vasta tsitaadiga
Kristoferr kirjutas:
mul nullis see PBO, see 95C limiidi jutt peab paika ja seetõttu lähenesin teise nurga alt asjale - power limitiga. 250W peal on all-core mul 5.1-5.3GHz sõltuvalt kui soe parasjagu vedelik on, boosti maksimum jääb 5.7 kanti. on juba delidded, aga contactframe vahel ja siis Alphacool XP3 Brass veeplokk peal vedelmetalliga. kord kuus mõtlen, et ehk peaks kas selle vägevama IHSi ligi võtma või päris selle direct-die veeploki võtma, aga seni ei ole kuskilt väga inffi saanud selle HPHS-i kohta kuniks su kuulutust nägin icon_biggrin.gif
vabandan võimaliku offtopicu pärast, aga uudishimu sai minust võitu icon_biggrin.gif
Kristoferr
Kristoferr
sõnum 23.06.2026 08:52:44 vasta tsitaadiga
Pole hullu. Kaane maha lükkamine ja paksust metallist IHS peale aretamine nii kallile prosele oli põnev töö. Aga otsest kasulikkust pigem sealt ei tule, kui just pidevalt prose mingite töödega piirajas ei ole hoida vaja. Aga stabiilsust temperatuurides ja paarsada mhz all core load tuleb küll. Vast siis natuke südamerahu ka. icon_smile.gif
FSR4.1 tuli täna just RDNA 3 peale välja. 79000XTX sai 4K resodel ja väga nõudlikes mängudes ka tugeva buusti. Ostke ära. icon_biggrin.gif Sisuliselt RTX 4090, 650€ eest, poisid-tüdrukud!
Liitu Wise'ga!
tiitk22pa
tiitk22pa
sõnum 23.06.2026 12:41:30 vasta tsitaadiga
600 eest oleksid nõus gpu müüma?
Kristoferr
Kristoferr
sõnum 23.06.2026 15:49:45 vasta tsitaadiga
tiitk22pa, Ei. Ma usun, et kaart on rohkemgi väärt, kui 650-, seega allapoole ei soovi tulla.
Liitu Wise'ga!
tiitk22pa
tiitk22pa
sõnum 23.06.2026 16:04:14 vasta tsitaadiga
ok, ma eeldan et kaart heas seisundis?
võtan 650 eest ära siis
Kristoferr
Kristoferr
sõnum 23.06.2026 16:30:40 vasta tsitaadiga
tiitk22pa, kaart on ideaalses seisukorras. Jooksutasin nii mänge, kui AI'd ja mitte ainsatki muret polnud. Kirjutan PS.
Liitu Wise'ga!
Driftmoon
Driftmoon
sõnum 24.06.2026 09:09:26 Re: Workstation kraami vasta tsitaadiga
H: 20-
Selle kohta mingit täpsemat linki või pilte oleks? Huvitaks millised need antennid ja kaablid on.
Kristoferr
Kristoferr
sõnum 01.07.2026 23:20:48 vasta tsitaadiga
4,5 ja 10 on läinud. Muu kraam alles ja nagu kirjas, siis 9950X asemel võin ka 7700X müüa.
Driftmoon, katsun varsti pildi teha.
uus AH 100-
Liitu Wise'ga!
avo78
sõnum 03.07.2026 11:56:26 vasta tsitaadiga
Tere, kas asendatud (modditud) jahutusplaadiga 9950X töötaks ka Noctua NH-D15-ga või vajab koostööks vastavat vesiahutusplokki, mis sobituks perfektselt, et ei tekiks kinnituste vahel õhku, sel juhul oleks asi kehvasti või siis teistpidi, et õhem prose kuumaplaat ei painduks läbi ebasobiva jahutuse kinnituse puhul? Kui prose läbi paindub, siis oleks häving, ehk mahakandmisele.
