uus teema   vasta Ärifoorumid »  Arvutitehnika ja tarkvara müük/vahetus »  10» M: Workstation kraami :: Asukoht: Keila märgi kõik teemad loetuks
Kristoferr
Kristoferr
sõnum 09.06.2026 17:40:05 10» M: Workstation kraami :: Asukoht: Keila vasta tsitaadiga
1. Asus ProArt X870E-CREATOR WIFI
https://www.asus.com/motherboards-components/motherboards/proart/proart-x870e-creator-wifi/
AH: 350-
2. Ryzen 9 9950X, Delidded + AM5 High Performance Heatspreader. Üks väga tubli isend.
https://www.amd.com/en/products/processors/desktops/ryzen/9000-series/amd-ryzen-9-9950x.html
https://www.thermal-grizzly.com/en/heatspreader/s-tg-hphs
AH: 300-
3. Arctic Liquid Freezer III 420 A-RGB Black
https://www.arctic.de/en/Liquid-Freezer-III-420-A-RGB/ACFRE00145A
AH 70-
4. Powercolor RX 7900 XTX Red Devil 24GB. Ilmselt kõige parema jahutusega XTX (enne pakkumist kontrolli kas kasti mahub!)
https://www.powercolor.com/product-detail71.htm
H: 650-
5. 128GB (2x64) DDR5-6400, Corsair Vengeance CMK128GX5M2B6400C42
https://www.corsair.com/us/en/p/memory/cmk128gx5m2b6400c42/vengeance-128gb-2x64gb-ddr5-dram-6400mt-s-cl42-intel-xmp-memory-kit-cmk128gx5m2b6400c42
AH: 800-
6. NZXT C1000 Gold ATX 3.1.
https://nzxt.com/en-intl/products/c1000-gold-atx
AH: 100-
7. Deepcool CH780 Black
https://www.deepcool.com/products/Cases/CH780-Panoramic-Tempered-Glass-ATX-Case/2023/17534.shtml
AH: 125-
8. Uus! ASUS ProArt PA602 Wood Edition Tempered Glass
https://www.asus.com/motherboards-components/cases/proart/proart-pa602-wood-edition-tempered-glass-panel/
H: 175-
9. Uus! Intel BE200 WIfi-7 kaart. Komplektis on ka kaablid ja välised antennid
H: 20-
10. Palit GT1030 2GB GDDR5 low profile videokaart.
https://www.techpowerup.com/gpu-specs/palit-gt-1030-low-profile.b4640
H: 25-
Liitu Opencode Go soodsa coding plaaniga ja saa 5€ soodust!
Liitu Wise'ga!
Kommentaarid: 267 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 218
Dreamlover
Dreamlover
sõnum 09.06.2026 19:41:11 vasta tsitaadiga
5 AH
ARVUTID
3G1,5/3G2,5/5G1,5/5G2,5 KAABEL
HDD kettad
Kommentaarid: 1904 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 1327
Kristoferr
Kristoferr
sõnum 10.06.2026 22:18:31 vasta tsitaadiga
Liitu Wise'ga!
jimmmmmy19
sõnum 11.06.2026 00:38:01 vasta tsitaadiga
4. Kui vana ja karp ?
Kommentaarid: 26 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 24
Kristoferr
Kristoferr
sõnum 11.06.2026 08:09:18 vasta tsitaadiga
Täpset vanust ei tea. Originaalkarp ilma ümbriseta.
Liitu Wise'ga!
Allar119
sõnum 11.06.2026 10:36:19 vasta tsitaadiga
10. OK
Kristoferr
Kristoferr
sõnum 14.06.2026 08:26:50 vasta tsitaadiga
Kirjuta/helista kuidas kätte soovid saada. Pakiautomaat on +4€. Keilas käest kätte sobib ka.
Kui üle ei pakuta, siis läheb AH'ga homme õhtul lukku.
Liitu Wise'ga!
karl660
sõnum 15.06.2026 11:13:01 vasta tsitaadiga
2. AH
Kristoferr
Kristoferr
sõnum 21.06.2026 23:46:27 vasta tsitaadiga
karl660 kirjutas:
2. AH
Kui juurde ei pakuta, siis reedel lukku ja saad endale.
Teoreetiliselt 9950x asemel võimalik ka 7700x loobuda. Sellisel juhul jätan 9950X, Delidded + AM5 High Performance Heatspreader endale. Emb-kumb siis.
Liitu Wise'ga!
caramis
caramis
sõnum 22.06.2026 14:00:24 vasta tsitaadiga
küsin sekka, et kui suur vahe originaal IHSiga oli temperatuuride osas?
up
Kommentaarid: 173 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 150
Kristoferr
Kristoferr
sõnum 22.06.2026 15:01:05 vasta tsitaadiga
ca 300mhz all core sain juurde. Kui biosest maksimum +200mz anda, siis all core load temperatuurid jooksevad 16-tuumalisel Ryzeni, toatemperatuuril vesijahutusega, alati piirajasse. Sh ei ole vahet, kui vinge see jahutus on.
Liitu Wise'ga!
