uus teema   vasta Hinnavaatlus »  Üldfoorum »  Tehisintellektiga suhtlemine märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 43, 44, 45 ... 48, 49, 50  järgmine
Kas AI-ga suheldes tuleks olla viisakas?
JAH, muidu muutume ise matsideks
46%
 46%  [ 57 ]
Põhimõtteliselt JAH, kuid kõrvalseisjale võib see tunduda veider
20%
 20%  [ 25 ]
EI, suundan pärisinimese ja arvuti vahel alati vahet teha
25%
 25%  [ 31 ]
EI, viisakus ongi iganenud asi ja parem on kui kaob.
8%
 8%  [ 10 ]
hääli kokku : 123
elukaz
elukaz
sõnum 13.11.2025 19:36:27 vasta tsitaadiga
Kommentaarid: 193 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 155
mina634
mina634
sõnum 17.11.2025 13:03:01 vasta tsitaadiga
Rumba Ghosti Prompti tegin ümber valsi muusikale ja lisasin sõnad:
elektrooniline valsi romanss
degrass
degrass
sõnum 17.11.2025 16:03:21 vasta tsitaadiga
arXiv kirjutab: Nikolaou et al., (2025) Language Models are Injective and Hence Invertible
https://doi.org/10.48550/arXiv.2510.15511
Transformer components such as non-linear activations and normalization are inherently non-injective, suggesting that different inputs could map to the same output and prevent exact recovery of the input from a model's representations. In this paper, we challenge this view. First, we prove mathematically that transformer language models mapping discrete input sequences to their corresponding sequence of continuous representations are injective and therefore lossless, a property established at initialization and preserved during training. Second, we confirm this result empirically through billions of collision tests on six state-of-the-art language models, and observe no collisions. Third, we operationalize injectivity: we introduce SipIt, the first algorithm that provably and efficiently reconstructs the exact input text from hidden activations, establishing linear-time guarantees and demonstrating exact invertibility in practice. Overall, our work establishes injectivity as a fundamental and exploitable property of language models, with direct implications for transparency, interpretability, and safe deployment.
Näib, et LLM ei olegi must kast, mille sisust me midagi ei tea, vaid on jälgitav.
Uudis ise on mõned nädalad vana ja selle kohta leiab YT erinevaid kommentaare. Arvan, et on alati oluline tutvuda algallikaga.
All it took was for a lot of seemingly decent people to put the wrong person in power, and then pay for their innocent choice.
mina634
mina634
sõnum 17.11.2025 23:58:29 vasta tsitaadiga
Eesti versioon sellest valsist:
sõnum 18.11.2025 17:49:02 vasta tsitaadiga
Kui tõesti nii, siis tegu juba plagiaadiga.
perenoel
perenoel
sõnum 18.11.2025 18:27:41 vasta tsitaadiga
Hehee. Aga eks vaesed advokaadibürood peavad ju ka millestki elama.
The biggest delusion is that there are causes other than your own state of consciousness. - Neville Goddard
sõnum 18.11.2025 18:30:33 vasta tsitaadiga
Kui asi nii jätkub, pole sel viisil loodud videomängud enam kunst.
BA79
sõnum 18.11.2025 18:35:38 vasta tsitaadiga
Lõppkokkuvõttes liigub inimkond virtuaalmaailma suunas kus päriselu ja virtuaalset elu enam ei erista.
sõnum 18.11.2025 18:46:10 vasta tsitaadiga
Veel üks juhtum.
degrass
degrass
sõnum 19.11.2025 09:19:24 vasta tsitaadiga
SKG kirjutas:
See on kõigega nii, mis AI genereerib. Uus reaalsus. Varem oli looming protsess, mille käigus sa lõid midagi, õppisid juurde ja selle tulemusena toimus kunstniku individuaalne areng. Kopeerides varasemate kunstnike loomingut, täiustasid ning andes omapoolse panuse, lõid midagi täiesti uut. Nüüd on ainus võime, mida vajad prompt engineering. Kui AI "sisu" kellegi varasemat loomingut kopeerides valmis genereerib, kas me saame siin rääkida loomingust?
Treeningandmed on kellegi teise poolt loodud intelektuaalne omand. Kes on siin kunstnik? Kas koopiamasinal rohelist nuppu vajutades saab sinust kunstnik?
mina634
mina634
sõnum 19.11.2025 14:57:24 vasta tsitaadiga
SKG kirjutas:
PARANDUS: AI saab ette seda, mida talle antakse. See on inseneride probleem. Seda saab parandada.
perenoel
perenoel
sõnum 19.11.2025 18:48:30 vasta tsitaadiga
degrass, Aga näiteks kirjastamisel on alati lisaks kirjanikule koht ka kirjastusmajal ning toimetajatel. Sa vahetad need välja ja võid saada sootuks teistsuguse tulemuse. Sama siin. Koopiamasinaga ei ole protsess tegelikult võrreldav, sest tänane AI ei suuda eriti mitte midagi esimesel katsel valmis saada (kuigi vahel näkkab). Vahel täiustad prompti, vahel lased lihtsalt uuesti ja uuesti teha, et saada just see õige tulemus. Öeldakse, et fotograafi suurus tuleb tema prügikasti suurusest. Ehk siis - ta peab võtma palju kaadreid ja valdava enamiku nendest armutult välja praakima. Aga fotograaf on selles protsessis loovisik, kuigi lihtsalt kopeerib 3D maailma 2D kaadrisse. Lisaks prügikastile peab tal veel olema teadmine ja silm, et osata halb välja praakida. Sama kirjastusel, toimetajatel. AI-graaf on ka midagi sarnast - kui prügikast on mahukas.
sõnum 19.11.2025 19:08:41 vasta tsitaadiga
mina634 kirjutas:
SKG kirjutas:
Vahet pole.
perenoel
perenoel
sõnum 20.11.2025 00:31:00 vasta tsitaadiga
Ilmslet täitub YT juba praegu jõudsalt selliste 'suprestaaride'' kanalitega - nad on lihtsalt kõik algusjärgus ja YT soovitab ka AI materjali pika hambaga. Ainus, mis päris asjast maha jääb, on lipsynci puudumine. Seda on esialgu veel usutavalt raske teha.
Link
mina634
mina634
sõnum 20.11.2025 13:45:29 vasta tsitaadiga
Siin olemegi jõudnud etappi - kus inimene peab valima, et kas tal on tekstiline mälu või pildi mälu.
Kuna need videod on petlikud- venivad ja petavad silmi. Siis eelistan tekstilist edulugu.
Ka CV-s on kõige rohkem 1-2 pilti. Ülejäänud on tekst.
perenoel
perenoel
sõnum 22.11.2025 18:33:50 vasta tsitaadiga
Mulle tundub, et viimasel ajal on ChatGPT hakanud oma vastustes õnnestunult nalja tegema. Täidan siin näiteks just Pinterrest Business accounti formulare ja küsin ChatGPT käest, et kas peaksin alas 'Get more traffic with free expert ads help!' andma telefoninumbri, kontakteerumise emaili ja täisnime. Ja ChatGPT vastab:
Ignore it.
That screen isn’t required — Pinterest just really wants to drag you into their “Would you like a salesperson to annoy you?” funnel.
mina634
mina634
sõnum 29.11.2025 13:21:40 vasta tsitaadiga
gemini abil tehtud algoritm, mida ma oma masinas edasi töötlesin ja tulemus youtubes, meeleolumuusika:
new1
sõnum 05.12.2025 01:33:29 vasta tsitaadiga
Olen siin viimasel ajal proovinud uuesti ChatGPT-l arduinole mulle sobivat programmijuppi teha ja no täiesti edukalt on hakkama saanud sellega mida tahtnud nüüd olen. Ehk siis sim kaardi lisasin, siis erinevad sisendid saadavad erinevad sms-id, küll uksehäire, küll suitsuandur jne, impulsi pikkus vähemalt sekund, enne kui häire teeb ja peale igat sms-i teeb 10sek hiljem ka kõne, lisaks lasin tal aku pinget mõõta ja ala/ülepinge korral niisamuti sms, nüüd veel ütlesin sellele, et lisa veel mingi pilve laadimise võimekus läbi sim kaardi, ja tegi programmi ja seletas ära kus ja mida ja kuidas ning nüüd monitoorib akupinget thingspeak pilve ja kõik käib nagu kellavärk. Ise ma pole mingi koodimeister ja null teadmist ise nullist arduinodele jms koodi kirjutamise osas, ent läbi selle gpt saab põhimõtteliselt iga suvaline ka "programmeerija" olla icon_biggrin.gif elektrit/elektroonikat ma üht teist tunnen ja raua osas saan pihta, et mida need analoogsisendid, PWM väljundid jms endast kujutavad ,ent jah, üldiselt on ikka väga hea asi ses osas minusuguse juhmi jaoks programmi kirjutamise alal, nüüd saan kenasti endale sobivaid projekte hobikorras teha nendest chippidest, varasemalt olen mööda vaadanud ja vahest harva mõne kellegi teise poolt valmis kirjutatud koodi millegi jaoks kasutanud.
mina634
mina634
sõnum 06.12.2025 17:40:02 vasta tsitaadiga
Kuna EU komisjon otsustab, et milline peab olema meie pudeli kork ja kui kinni seotud, siis AI
disainis uue pudeli, saab sildi pealt kokku hoida - piim ja keefir.
Samuti on parem juba lutt (äkki oled alla 16 aasta vana)
perenoel
perenoel
sõnum 06.12.2025 17:48:53 vasta tsitaadiga
new1, MIna olen veebi jaoks lasknud teha: Javascriptis paar testi ja lihtsamat mängu. Päis palju oli vaja ümbertegemist, kuid lõpuks jõudsime täiesti rahuldavate tulemusteni. Ja kujundusega saab enamasti kohe esimesel kasel toime: annan kuvatõmmise veebilehest, html lehe (kust ta saab näha, mis klasse on kasutatud) ja CSS vaili ning siis lihtsalt ütlen mis muuta vaja. Või siis isegi küsin nõu, mis kenam ja funktsionaalsem oleks. Pärast pole muud kui uuendatud CSS üles laadida. Unustatud on ajad, mil sellise asjaga mitu tundi ise pusida tuli.
renx09
renx09
sõnum 12.12.2025 13:10:48 vasta tsitaadiga
https://www.yankodesign.com/2025/12/10/tws-earbuds-with-built-in-cameras-puts-chatgpts-ai-capabilities-in-your-ears/
Kommentaarid: 315 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 252
mina634
mina634
sõnum 22.12.2025 17:10:13 vasta tsitaadiga
Jõudsime AI-ga sinnamaani, et odavam on CPU+GPU-AI-kiip rakendusega super- või klasterarvuti kui kallis laboritingimustes qubit kvantarvuti:
Sest 1 puhas qubit vajab 1000 füüsilist veaparandusega qubitit. Kui veaparandus läheb paremaks siis räägime.
Praegu on tööstustase ikka CPU/GPU/AI . 1 ja 0 . Ja olulisemalt odavam.
sõnum 22.12.2025 19:28:04 vasta tsitaadiga
AI eksib enesekindlalt. Oli lähedal, kuid videos oli siiski Kate Matl (Kateřina Mátlová).
Aq
sõnum 22.12.2025 22:36:59 vasta tsitaadiga
Ma vaatan, et siin teemas kirjutatakse tehisintellektist väga laialt, seega... äkki sobib siit küsida ka selle teema kohta.
Küsimus - mis teie ütlete, kas see on tõesti eestikeelne tehisintellektiga tehtud muusika:
https://www.youtube.com/watch?v=NhTsd2iJiqE
Lisaks on seal kanalil veel mitmeid sarnaseid videosid, aga see on kõige uuem.
Video on ilmselgelt tehisintellekt, aga kas ka sõnad ja eriti - meloodia ja vokaal? Minu alarmid läksid küll väga tööle, ei oska ka internetist enam kusagilt otsida, kes selle kanali taga on jne... Igatahes, nii laulu sõnad, kui asjaolu, et laulu stiil muutub mitu korda laulu jooksul + minu kõrva järgi ka teatud "artefaktid" on olemas (eriti meessoost vokaalil ja osalt ka meloodial endal, naissoost vokaalil tuvastan neid vähem).
Kas tõesti on asi nii kaugel, et eesti keel ka enam ei päästa ära tehisintellekti eest? "Vanasti" oli tal eesti keelega veel raskuseid igatahes.
woox2k
woox2k
sõnum 22.12.2025 22:49:39 vasta tsitaadiga
Aq kirjutas:
Täitsa puhas Suno solk. Sunol ongi meie keel kõige arenenum aga üsna spetsiifilise ja häiriva aktsendiga laulab ikka.
Mess with the best, die like the rest!
Kommentaarid: 20 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 18
uus teema   vasta Hinnavaatlus »  Üldfoorum »  Tehisintellektiga suhtlemine mine lehele eelmine  1, 2, 3 ... 43, 44, 45 ... 48, 49, 50  järgmine
