uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  Agepture size.-milleks vaja?-Palju panna? märgi kõik teemad loetuks
lighT
lighT
sõnum 22.08.2004 17:37:00 Agepture size.-milleks vaja?-Palju panna? vasta tsitaadiga
Tükk aega juba huvitab, et milleks seda vaja läheb. Mul on endal radeon 9600pro 256ddr.
Kommentaarid: 35 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 28
Eser
sõnum 22.08.2004 18:29:16 vasta tsitaadiga
First of all, AGP Aperture memory will not be used until your video card's on-board memory is running low. That means it will usually not impact your gaming performance because developers are trying hard to not exceed the on-board memory limits.
The bigger your video memory, the smaller your Aperture Size could be. However with later games requiring more and more texture memory a good number seems to be 128MB Aperture Size for all cards with 64 MB to 256 MB Video RAM.
Setting the Aperture Size to HUGE values will not increase performance because this merely sets the maximum amount of physical memory that can be used. It only makes the GART Table bigger because every 4K page has its own entry, no matter if allocated or not.
Setting the Aperture Size to too small values could result in running out of available texture memory especially on a low-mem video card. It is also possible that developers make use of the GART's features by creating textures as 'non-local'
Must, ja karvane !
margusser
sõnum 22.08.2004 18:31:12 vasta tsitaadiga
las ta olla 256mb
Kommentaarid: 215 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 167
arnis
arnis
sõnum 22.08.2004 22:59:43 vasta tsitaadiga
Ega ei mõjutagi, enne kui su videokaardi mälu
otsa saab, kui saab, siis alles hakkab ta seda
kasutama. Tglt kohe alguses kasutab ta ~5-10MB
Teen kodudes elektriasju korda. 40€/h. Anna murest märku.
Ooteajad hetkel suured (üle kuu)
Ka korteriühistud ja ettevõtted. Auditi ettevalmistused.
Kommentaarid: 120 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 117
Ramones
Ramones
sõnum 23.08.2004 02:13:42 vasta tsitaadiga
Nojah mul FarCry kasutas 64MB medium settingutega ja no AA/AF...
