lighT
22.08.2004 18:37:00
Agepture size.-milleks vaja?-Palju panna? |
| Tükk aega juba huvitab, et milleks seda vaja läheb. Mul on endal radeon 9600pro 256ddr.
| Kommentaarid: 35 loe/lisa |
28 |
Eser
22.08.2004 19:29:16
First of all, AGP Aperture memory will not be used until your video card's on-board memory is running low. That means it will usually not impact your gaming performance because developers are trying hard to not exceed the on-board memory limits.
The bigger your video memory, the smaller your Aperture Size could be. However with later games requiring more and more texture memory a good number seems to be 128MB Aperture Size for all cards with 64 MB to 256 MB Video RAM.
Setting the Aperture Size to HUGE values will not increase performance because this merely sets the maximum amount of physical memory that can be used. It only makes the GART Table bigger because every 4K page has its own entry, no matter if allocated or not.
Setting the Aperture Size to too small values could result in running out of available texture memory especially on a low-mem video card. It is also possible that developers make use of the GART's features by creating textures as 'non-local'
_________________ Must, ja karvane ! |
| Kommentaarid: 23 loe/lisa |
22 |
margusser
22.08.2004 19:31:12
las ta olla 256mb
minuarust ei mõjuta see midagist
167 |
arnis
22.08.2004 23:59:43
Ega ei mõjutagi, enne kui su videokaardi mälu
otsa saab, kui saab, siis alles hakkab ta seda
kasutama. Tglt kohe alguses kasutab ta ~5-10MB
olenevalt mängust
_________________ Teen kodudes elektriasju korda. 40€/h. Anna murest märku.
Ooteajad hetkel suured (üle kuu)
Ka korteriühistud ja ettevõtted. Auditi ettevalmistused. |
117 |
Ramones
23.08.2004 03:13:42
| Nojah mul FarCry kasutas 64MB medium settingutega ja no AA/AF...
| Kommentaarid: 76 loe/lisa |
75 |
