uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  nVidia Blackwell (GB202/GB203/GB205/GB206/GB207) märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 22, 23, 24 ... 35, 36, 37  järgmine
heretic666
heretic666
sõnum 08.03.2025 18:39:55 vasta tsitaadiga
memoricab, the prices are pretty much dictated by warehouses from where specific store is able to pick 'em. Cheapest ones I ever saw was in Estonian store was 3200€ for more "basic" model. More expensive ones ~3700€.
sõnum 08.03.2025 18:39:57 vasta tsitaadiga
memoricab kirjutas:
In one popular site
Gigabyte GeForce RTX 5090 Windforce OC 32G GDDR7- DLSS 4 3 599.00 €
MSI GeForce RTX 5090 32G VANGUARD SOC LAUNCH EDITION GDRR7 - DLSS 4 3 699.00 €
Can you help me, are these expected and sensible prices for these models? I totally lost my estimation after rapid market changes. Are these sensible and expected reseller retail prices, or inflated by reseller because of limited stocks where reseller tries to take an advantage on low supply high demand?
None of the current Nvidia 50 series prices are what i would consider sensible.
5090 least of all.
2200€ is what the card should realistically cost in Europe. Maybe 2500€ for nicer AIB models.
3600+ ?
Waaay overpriced. In my opinion - if you have to ask wheter the price is sensible you are not the target demographic for this product and are better off buying (also overpriced) 5080 at 1500 or better yet a used 4090 for under 2000.
I saw one for 1800 the other day at this forum. Unless you have a 4090 already. In that case i see zero reason to get 5090. It's only 35% faster and it's only exclusive software feature, the Multi Frame Generation is just a software block as i have no doubt the older cards can generate 3 or 4 extra frames with ease - if Nvidia allowed it.
Not to mention various problems 50 series - 5090 specifically is struggling with like melting cables, missing ROP's, black screen issues etc. And planned things like deprecated 32bit PhysX support in some older games.
Renq
Renq
sõnum 09.03.2025 00:19:56 vasta tsitaadiga
https://wccftech.com/12v-2x6-power-connector-cooks-at-over-150c-with-a-water-cooled-nvidia-geforce-rtx-5090/ sellega võib teed keeta küll...
sõnum 09.03.2025 00:33:48 vasta tsitaadiga
Irooniline on see, et kaardi nimi on Frostbite...
150c peaks küll edukalt külmakahjustuse ära hoidma, aga võib tekitada põletuse icon_cool.gif
Auron
Auron
sõnum 09.03.2025 10:35:25 vasta tsitaadiga
Kas PSU poolse otstega on probleem ka siis kui on nö. vanem ülemineku kabla ehk siis PSU'st tulevad ikka 6+2 pin aga kaardipoolne ots on siis see HWPR või aint selle uue standardiga kus mõlemad HWPR.
Mis lootus võiks üldse olla, et midagi suuremat ette võetakse? Seda ma väga ei usu, et rohkem powaat tahtes minnakse tagasi mingi kolme ja enama 6+2 pin peale. EPS otsi ka ei usu.
Ehk siis lahendus oleks aint uus standard - analoogne mõte aga oluliselt tummisem ots aga sellega ju raske kuna ka PSU tootjad teinud spets 3.0/3.1 toited ehk siis nüüd on probleem ka piltlikult öeldes PSU poolne icon_rolleyes.gif
Kui tahavad seda otsa edasi hoida siis mis saab - ainuke "lahendus" panna 5080 seeriast alates 2 otsa icon_neutral.gif
sõnum 09.03.2025 10:37:03 vasta tsitaadiga
teha kaardi pool nii nagu 3090(ti) oli. sealpool mingilgi määral kindlustada, et voolu erinevus juhtmete vahel oleks minimaalne.
- londiste
haldz
haldz
sõnum 09.03.2025 11:08:00 vasta tsitaadiga
https://nvidia.custhelp.com/app/answers/detail/a_id/5640/kw/hotfix
Voldi slider tootab eks nais kuidas muud asjad.
Kommentaarid: 153 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 138
caramis
caramis
sõnum 09.03.2025 13:03:18 vasta tsitaadiga
see 12VHPWR on ikka normaalne kõhulahtisus. teind siis XT120 pistiku peale see ja asi lahendatud
Kommentaarid: 174 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 151
UrmoZ
UrmoZ
sõnum 10.03.2025 19:02:30 vasta tsitaadiga
Paljudel PSU-del on modulaarsete kaablite kujul mõlemal pool 12+4pin üllitis - great, now I have 2 points of possible failure.
Sellest tulenevalt kasutaks pigem adapterit.
Amazon - will not buy!
12VHPWR or 12V2x6 GPU power connector - will not touch.
Müügiteemale PS pakkumisi ei aktsepteeri!
Kommentaarid: 226 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 206
terric
terric
sõnum 11.03.2025 02:37:32 vasta tsitaadiga
caramis kirjutas:
Postitan siia ühe YT eksperimendi. https://www.youtube.com/watch?v=VoWcndfnqgI
Eks seal peale pistikut on kõik tublisti üledimensioneeritud ja need "kruustangid" natuke jahutavad ka mingis osas st. vaja kütta seda rauda.
Lõpus autor mainib pistiku paranemist, mille põhjustab paisumine temperatuuri tagajärjel klemmid pressivad üksteist ja kontakt paraneb.
Aga see efekt tekib ühtlase kuumutamise tagajärjel ja ikkagi suure võimsuse juures.
Mäletan, et siin käis läbi üks uudis RTX kaardist millel oli 12vhpwr pistik ilusti kaardil irdus st. kahtlustati, et nagu oleks jäänud tehases joode tegemata.
Ja muidugi tuleb ka mainida, et ta veendus et pistik oleks alati korralikult sees.
Ning kindlasti juhtmed selle pistikule olid "pressitud" mitte joodetud või siis mõlemad.
Kuid leidub pistikuid millel olid juhtmed ainult joodetud. Ja on ka erinevate tootjate klemme.
PS. Mahapõlemine tekib enamasti kui on kehv kontakt ja see väike kontaktpind kuumeneb ebaühtlaselt kõrgemale temp. kui ühtlaselt kõike koormata.
sõnum 11.03.2025 08:57:07 vasta tsitaadiga
terric kirjutas:
huvitav kas kuumusega hakkama saamise või selle ära juhtimise vaatepunktist on parem need suured juhtivad pinnad nagu tal või kaart, millel sellise koormuse all peaks olema korralik õhuvool? icon_smile.gif
- londiste
Auron
Auron
sõnum 11.03.2025 11:11:58 vasta tsitaadiga
See eksperiment näitab sedae, et jõle loll on selline probleem mis saab tekkida nö. randomilt ehk siis mingi kuradi lambivennal sulab 400W loadi alla ära ja samas teine laseb 1600W ja ei sula.
sõnum 11.03.2025 11:25:55 vasta tsitaadiga
See on jah pigem nagu loto. Iga insert annab tegelikult erineva tulemuse.
Ühel võib tuttuus kaart ja kaabel esimese käigu pealt lajatada 15-20A ühele juhtmele kaablite hulgas ja samas teine võib mitu aastat probleemideta jooksutada.
Alguses võis seda veel user errori süüks ajada. Nüüd kus on color coding, sense pinnide muudatused jms see argument enam ei päde.
Tegelikult ei pädenud see kunagi. Inimesed ei unustanud äkitselt kuidas voolukaableid sisestada.
Tegelikult süü lasub paljuski Nvidia enda vooluahela disainil mis on 4090 ja 5090 peal downgrade saanud vs nt 3090 Ti.
Paraku nagu näha pole ka teised tootjad midagi õppinud. Sapphire 9070 Nitro+ mudelitel ei ole paremat vooluahelat ehitatud selle pistiku ette.
9070 kaartide madalam voolutarve (kui ~330W ja 418W peak saab madalaks lugeda) peaks need ilmselt päästma suuremast jamast.
caramis
caramis
sõnum 13.03.2025 21:23:46 vasta tsitaadiga
terric kirjutas:
caramis kirjutas:
vaatasin seda videot eile. suht lototron, et tal niimoodi asi koormust talus.
kõik seletavad miskist "ää, power inputs are not balanced waa-waa". nahhui, lahendus on olemas - XT90. üks pluss, üks miinus - lihtsamaks enam ei saa. pistik ise on piisavalt tummine, et ei teki isegi mõtet, et kas on asi korralikult pesas või ei icon_biggrin.gif
Snaxez
Snaxez
sõnum 13.03.2025 21:29:55 vasta tsitaadiga
Ise ka usud, et mõni arvutikomponentide tootja paneks XT90 GPU, PSU või mobo peale?
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 54
caramis
caramis
sõnum 13.03.2025 21:45:56 vasta tsitaadiga
Snaxez kirjutas:
kui see kannatab julmalt ampreid tarbivaid RC autosid, siis miks ei peaks toiteks kaht jämedat kaablit kasutama kahe suure klemmiga? nagu näha, siis on ka osadel toiteplokkidel mõned klemmipesad ära sulanud/põlenud. minu asi pole uskuda seda mida tootjad teevad, minu asi on loota olemasoleva ja töötava alternatiivi kasutuselevõttu. isiklikult ei koti mind üldse need järelturu helendavad RGBLGBTQ tulukestega jubinad ja mingid erivärvides kaablid.
tootja vaatepunktist - üks pistik asendab teoorias kolme pistikut ehk 3x 8pin vs üks XT90 või XT120 isegi kui sense klemme on vaja; oluliselt suurem koormustaluvus; paksem kaabel ja pistik, kannatab "sooja" rohkem tänu rohkemale termomassile; pistiku kontakt on alati kindel ja ei kuku niisama pesast välja nagu J2C näitas ühes videos kuidas ühe sõrmega kaardist PCI-E toitekaabli välja sikutas.
aga hei, be my quest kui tahetakse mingi multikaabel lollusega edasi minna. isiklikult ei näe probleemi 10€ rohkem maksta kaardi kui ka toiteploki eest kui neil XT pistik küljes on.
terric
terric
sõnum 13.03.2025 21:54:54 vasta tsitaadiga
caramis kirjutas:
terric kirjutas:
caramis kirjutas:
Ühe pistikuga, millel on ainult üks "+" ja üks "-" klemm tekib see probleem, et siis nagu võiks ka olla 2 juhtmega ning need juhtmed oleks päris jämedad jne.
Teine probleem, et nad üritasid ühe pistikuga lahendada ära PSU max. edastatava võimsuse määramise. Kui ennem oli 6pin (75W) ja 8pin (150W) ja sealt tulid ka need voolumõõtmised iga pistiku kohta siis
nüüd on üritatud ühe pistikuga ja "tuvastuse" pinnidega lahendada.
Aga mina ise oleks näinud lahendust, et 12pin pistik aga klemmid oleks olnud samas mõõdus, mis olid 8pin ehk 12pin pistik oleks olnud suurem ja ei oleks tekkinud sisestamisel probleeme.
Oleks, et need kaardid läheks väiksemaks, sellised tellised et mahuks 4tk 8pin pesa ritta laduda ja jääks ruumi üle.
ot:
Mul nüüd toide(v3.0), ülemineku kaablid ja adapterid käes ja need klemmid on ikka luubiga vaatamiseks.
Arx07
Arx07
sõnum 13.03.2025 22:08:03 vasta tsitaadiga
5090 tarbib niipalju, et sellel oleks pidanud küll 2 pistikupesa olema, eriti overclockijate jaoks.
5080 puhul ei näe probleemi kui enamik 4090 elasid üle lühemate "+" kontaktidega.
sõnum 14.03.2025 01:15:54 vasta tsitaadiga
terric kirjutas:
tuvastuspinnid on täiesti normaalne ja kasutatav lahendus.
ka 8-pin otsal on sense pin, kui see on maandatud, siis on 8-pin ja saab 150w, muidu peaks tulema 75w.
- londiste
sõnum 14.03.2025 11:30:40 vasta tsitaadiga
NVIDIA Says It Shipped Twice The RTX 50 Cards In The First Five Weeks Than RTX 40 Series; Promises Stability In Pricing Soon
https://wccftech.com/nvidia-says-it-shipped-twice-the-rtx-50-cards-in-the-first-five-weeks-than-rtx-40/
Sellist juttu võib seniilsele vanainimesele rääkida. 40 seeria launchil oli supply vähemalt 5x kui mitte rohkem.
GeForce RTX 5070 Takes The Number One Spot On Amazon, More NVIDIA GPUs Replace AMD In Best Selling GPUs List
https://wccftech.com/geforce-rtx-5070-takes-the-number-one-spot-on-amazon/
Idioodid ütleks selle peale. Hmm kumb osta - kas roheline 12GB kaart 750+ eest või 7% kiirem punane 16GB kaart 750+ eest? Roheline muidugi thumbs_up.gif
sõnum 14.03.2025 12:24:00 vasta tsitaadiga
Tomorrow kirjutas:
kust 7%? hwu leidis 4%.
mälu on sul veidi kinnisidee, mida laiem mängijaskond tingimata ei jaga.
750 eest neid osta on muidugi... valus. kogu see põlvkonna algus, värvist olenemata, on ikka päris kõvasti fucked up. ja ostetakse pigem seda, mida kuskilt saada on.
edit: geizhalsi kiigates, siis nbb-s on 679 ja 699 hindadest alates neid olemas.
- londiste
sõnum 14.03.2025 13:50:37 vasta tsitaadiga
londiste, TPU perf chart. 4K raster. Võimalik, et 4K peal annab lisa 4GB 9070'le siis suurema eelise.
sõnum 14.03.2025 13:54:37 vasta tsitaadiga
Tomorrow kirjutas:
- londiste
sõnum 14.03.2025 14:04:22 vasta tsitaadiga
Link
Naps
sõnum 14.03.2025 14:10:57 vasta tsitaadiga
Seletab kenasti ära ka nvidia loogika suuremate numbrite kohta. Põmst 5 nädalaga on 4 erinevat kaarti kokku tarnitud 2x 4090 kogusest .... puhtmatemaatiliselt, on tegelikult siis 5090 näiteks 5 nädalaga 2x vähem tarnitud.
sõnum 14.03.2025 14:18:00 vasta tsitaadiga
vaadates seda, et laoseisud ei paista ka nüüd paranevat - huvitav, kas nad juhuslikult selle mahasulamise vastu midagi ette ei kavatse võtta?
- londiste
anubis
anubis
sõnum 15.03.2025 15:18:55 vasta tsitaadiga
https://www.notebooksbilliger.de/inno3d+geforce+rtx+5070+twin+x2+881566
€649 RTX5070
sõnum 15.03.2025 15:21:41 vasta tsitaadiga
see peaks olema saksamaal pmst msrp. nvidia.de pealt vaadates on 5070 649€.
- londiste
Killhoven
OC`er
Killhoven
sõnum 15.03.2025 15:58:39 vasta tsitaadiga
londiste kirjutas:
Saksamaal Nvidia lehel on hind selline kuna Nvidia otsustas riskide vältimiseks kehva kursiga kalkuleerida. Kaarti väljatuleku ajaks oli tegelikult Euro hüppe 1,4-lt 1,8le juba ära teinud. Ajalugu on ka näidanud et vajadusel korrigeeritakse ka hindu kursile vastavalt.
Tegelik RTX 5070 hind Saksamaal võiks alata (549$ msrp/1,088 kursi vahe)*1,19(käibekas 19%)= 600€ ehk saaks müüa 599€ kenasti.
Kommentaarid: 409 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 351
heretic666
heretic666
sõnum 16.03.2025 12:39:41 vasta tsitaadiga
Kaks 5090 ventust Arvutitarka kohapeale ilmunud 3400€ tk, näis kaua nad seal siis saadaval püsivad icon_smile.gif
One
sõnum 16.03.2025 13:07:33 vasta tsitaadiga
https://www.verkkokauppa.com/fi/search?query=5070
e: arvutitargas ka kohal, kõige kräpim mudel 750€ thumbs_up.gif
heretic666
heretic666
sõnum 16.03.2025 13:12:39 vasta tsitaadiga
Soomes nvidia andnud MSRP enda lehel https://www.nvidia.com/fi-fi/geforce/graphics-cards/50-series/
5070 - €679
5070 Ti - €924
5080 - €1,229
5090 - €2,455
Nii et jah verkkokaupas on 5070 @ MSRP täitsa saadaval icon_smile.gif 9070 seeria kaartide kõrval muidugi saast see 5070.
haldz
haldz
sõnum 16.03.2025 14:26:41 vasta tsitaadiga
heretic666 kirjutas:
5070 - €679
5070 Ti - €924
5080 - €1,229
5090 - €2,455
asuse 5080 astral ka nüüd uus 450W bios väljas.
https://www.verkkokauppa.com/fi/product/972422/Asus-ROG-Astral-GeForce-RTX-5080-16-Gt-GDDR7-OC-Edition-nayt
heretic666
heretic666
sõnum 16.03.2025 15:33:42 vasta tsitaadiga
https://videocardz.com/newz/asus-implements-another-price-hike-for-geforce-rtx-5090-cards-rx-9070-xt-now-stars-at-720
sõnum 16.03.2025 16:17:44 vasta tsitaadiga
MLID ima viimases videos rääkis, et mitmetel AIB tootjatel on rahadega kitsas. Koondatakse inimesi ja tõestetakse hindu, seega pole kahtlust, et praegused hinnad on suuresti AIB teene.
Kuigi ma poleks arvanud, et ASUS kui üks suurimad selle probleemi käes vaevleb.
Pigem oleks seda oodanud neilt kes eksklusiivselt Nvidia kaarte teevad a'la Zotac jms. Võibolla need siis erinevalt ASUS'st ei tõsta hindu nii avalikult.
Zonerman
Zonerman
sõnum 17.03.2025 12:16:00 vasta tsitaadiga
Noh natuke infot jälle kuidas see 5090 hind tekib. All video klipp.
https://videocardz.com/newz/geforce-rtx-5090-at-3000-powergpu-exposes-distributor-price-gouging-impacting-system-integrators
Sõim ja räuskamine läheb SIIA
Auron
Auron
sõnum 17.03.2025 12:56:29 vasta tsitaadiga
nVidia ise seda AI'd surub ja teab vägahästi, et nõudlus suur - seega miks pole sellel "AI ajastul" tootmisvõimekust suurendatud kui ju vägahästi teatakse, et terve suur sektor on juurde tekkinud kes kaarte suurtes kogustes tahab saada?
sõnum 17.03.2025 12:59:58 vasta tsitaadiga
Auron kirjutas:
consumer kaardid ei ole ai sektor.
- londiste
heretic666
heretic666
sõnum 18.03.2025 19:59:57 vasta tsitaadiga
https://videocardz.com/newz/nvidia-introduces-rtx-pro-6000-blackwell-gpu-series-24064-cores-96gb-memory-and-up-to-600w
Optimist
Optimist
sõnum 19.03.2025 00:01:13 vasta tsitaadiga
LLM gang be like: Bro do you even MCP
Kommentaarid: 10 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 8
Wiltz
sõnum 19.03.2025 00:06:21 vasta tsitaadiga
fb marketpleissis saad kohe bänni kui proovid. aga HV foorumis keegi ehk ikka tahab, siin juba vanad peerud koos ka icon_biggrin.gif
kas see hirmus AI "teema" muidu nagu hirmus ropult pappi sisse siis ei too kah samas, või miks neid neerusid müüma peab, et AI jaoks kallist kaarti osta. raha peaks ju ropult liikuma selles valdkonnas, nagu räägitakse..
degrass
degrass
sõnum 19.03.2025 00:59:02 vasta tsitaadiga
NVIDIA DGX Station - The ultimate desktop AI supercomputer powered by NVIDIA Grace Blackwell.
NVIDIA DGX Station brings data-center-level performance to desktops for AI development. The first desktop system to be built with the NVIDIA GB300 Grace Blackwell Ultra Desktop Superchip, DGX Station features a massive 784GB of coherent memory space to accelerate large-scale training and inferencing workloads. The GB300 Desktop Superchip features an NVIDIA Blackwell Ultra GPU with latest-generation Tensor Cores and FP4 precision — connected to a high-performance NVIDIA Grace™ CPU via NVLink-C2C — delivering best-in-class system communication and performance.
https://www.nvidia.com/en-us/products/workstations/dgx-station/
https://nvidianews.nvidia.com/news/nvidia-announces-dgx-spark-and-dgx-station-personal-ai-computers
All it took was for a lot of seemingly decent people to put the wrong person in power, and then pay for their innocent choice.
Optimist
Optimist
sõnum 19.03.2025 01:24:23 vasta tsitaadiga
Ehk siis project DIGITS on nime saanud, DGX Spark. Sama GB10 Grace Blackwell Superchip ... 5x the bandwidth of fifth-generation PCIe. See on 64GB/s x5 ehk 320 GB/s. Võinuks rohkem olla ikka icon_biggrin.gif
sõnum 19.03.2025 08:44:12 vasta tsitaadiga
GPU Vendor Reveal The Reason For Higher NVIDIA RTX 50 Series Costs; Says GPU & VRAM Combo Makes Up To 80% Of Total Cost
https://wccftech.com/gpu-vendor-says-gpu-vram-combo-makes-up-to-80-of-total-cost-nvidia-rtx-50-series/
Zonerman
Zonerman
sõnum 19.03.2025 15:05:44 vasta tsitaadiga
Tomorrow, Tõlge sellele on sama, mis AMD puhul. MSRP hinnaga kaarte ei ole mõtet AIB partneritel toota, kuna kasum on palju väiksem kui OC ehk siis "premium" kaartidel.
Sisuliselt dikteerib kaardi tootja, mida ta toodab, ehk kuhu paneb need GPU died täpsemalt. See ka selgitab, et nii Nvidia kui AMD ei nõua partneritelt MSRP, ehk base kaartide tootmist peale launchi. AMD jutust sain ma aru, et nad "üritavad" veenda ja lahendust leida, kuidas MSRP kaarte rohkem toota.
Kokkuvõttes on turg selline. Niikaua kuni 3.5-4k USD hinnaga 5090 ostetakse, neid ka edasi toodetakse. Nvidia ja AMD saavad oma marginaali iga GPU die pealt kätte ja edasi vaatavad partnerid ise, mis on neile tulusam toota. Nagu ma varem mainisin vist AMD teemas üks lahendus on kvoot palju iga partner peab base mudelit tootma, et saada järgmist partiid AMD või Nvidia käest. Kuna sellist nõuet ei ole tundub, siis ei muutugi midagi tarbijale ei nüüd ega tulevikus.
Teine probleem, et tootmise hind on kallinenud ja liiga kiiresti. Kui see vastab tõele, et tootmise hind on pea sama mis MSRP, siis võib öelda, et dedicated GPU osas on seis hapu. Areng seisab ja hind kallineb kiiremini kui tegelik perf tõus (jätame kõrvale fake frame gen, kuna see on ka olukorrast sõltuv kus see kasu annab).
Auron
Auron
sõnum 19.03.2025 15:06:20 vasta tsitaadiga
Zonerman kirjutas:
Kokkuvõttes on turg selline. Niikaua kuni 3.5-4k USD hinnaga 5090 ostetakse neid ka edasi toodetakse. Nvidia ja AMD saavad oma marginaali iga GPU die pealt kätte ja edasi vaatavad partnerid ise, mis on neile tulusam toota.
Nii on. Samas võimelgu tootjad palju tahes, kui turul käib scalpimine ja ostetakse misiganes kaarti selle ülepaisutatud hinnaga siis niikaua ka selline jama toimub. Või nohh, tegelt oleks lahendus ka see kui turg kaartidest nii üle ujutada, et poleks mõtet scalpida. Samas eeldaks see seda, et ladudel ja nö. esmastel hangeldajatel peab see hinnaga huiamine võimatuks muutuma ehk siis a'la arvutitark ei saa midagi teha kui juba nemad peavad idiootse hinnaga ostma.
Renq
Renq
sõnum 19.03.2025 16:38:46 vasta tsitaadiga
https://videocardz.com/newz/nvidia-cuts-geforce-rtx-50-prices-in-europe-as-euro-strengthens
Vael
sõnum 19.03.2025 17:03:38 vasta tsitaadiga
Tomorrow kirjutas:
Pole juttugi GPU die baashinnast, seega võib jutust järeldada, et GPU tootjatel kasub isegi väike ja tõsteti hinda veelgi. GDDR7 esimene gen kallis on, sellest bõib aru saad. Aga AMD kasutab siiski GDDR6te, mille R&D ja muud kõrvalkulud peaks ammmu tasaolema teenitud...
BOM hinnast me ikka midagi ei tea, seda dikteerib AMD/Nvidia oma suva järgi. Aga eg neil pole ka mingit põhjust alandada hinda kui nagunii kõik ära ostetakse...
Tootmiskulud kallinenud? Ma ei tea et Hiimas/Taiwanis el 10x kallimalt müüakse ning et toit oleks seal 3x kallimaks läind viimastel aastatel nagu meil. Pealegi kasutatakse Hiinas orjatööjõudu ikka veel- nagu keskajal, palka ei saa üldse, süüa ei anta, kui eluvaim läbi võetakse järgmine 2miljarist asemele.
Temu selle pärast nii odavalt saabki müüa...
Ag meie lollid kujutame ette et " vaesekesed" korporatsioonid elavad nii rasket elu ja neil ikka kulud nii suured ja plekime aga üliodava/orjatööjõu kinni, arvates et mujal maailmas ka selline hinnaralli nagu meil..
anubis
anubis
sõnum 19.03.2025 17:08:32 vasta tsitaadiga
TSMC on tõstnud hinda järjest, see on fakt. Kivid pole väiksemaks jäänud. Konkurentsi pole.
https://www.notebookcheck.net/TSMC-3nm-wafer-costs-surge-to-18-000.943017.0.html
sõnum 19.03.2025 17:49:45 vasta tsitaadiga
Ma olen seda siin varemgi välja toonud, et GPU on anomaalia. Enamus muid arvutikomponente niimoodi ei kalline ja ei erine niivõrd väljareklaamitud hinnast.
Korpused pole hakanud äkitselt 3x rohkem maksma. Toidete hind on normaalne ja mingit märgatavat hinnatõusu seal pole.
Mälude hinnad on langenud. Prosede hinnad on jäänud suht samaks. 9800X3D MSRP küll veidi tõusis vs 7800X3D, aga ainult 30 võrra ja on vabalt 550€ eest ostetav (kuigi esimesed kaks kuud oli saadavus kehva ja hind 700+).
Teiste prosede hinnad on suht stabiilseks jäänud.
Emaplaatide hinnad on küll tõusnud PCIe 5.0 tõttu (ilmselt) aga ei saa ka seal öelda, et MSRP eest ühtegi emaplaati ei saaks.
Monitoride hinnad on langenud. Eriti OLED monitorid, kus isegi uus mudel hakkab 550-st ($ MSRP) ja aja jooksul ilmselt langeb veelgi.
Zonerman, Kui AIB jutt tõele vastab, siis disainijad Nvidia ja AMD (TSMC on ju tootja) on seadnud ebarealistliku MSRP 80% GPU+VRAM ja jätnud ainult 20% mänguruumi jahutuse jms jaoks.
Sinu pakutud MSRP kvoot oleks üks lahendus. Teine lahendus oleks, et Nvidia/AMD lõpetaksid ebarealistlikult madala MSRP väljakuulutamise.
AMD puhul ma veel usun, et neid kaarte on võimalik selle raha eest väikese kasumiga toota, aga Nvidia ametlikud numbrid on sama fake nagu nende benchmarkid MFG'ga.
Tegelikult Nvidia alustas seda juba RTX 2080 Ti peal, kus väljareklaamitud $999 nähti sama tihti kui päikesevarjutust. Tegelik saadavus oli $1200. Tollal polnud AI, scalpereid ja krüpto küll eksisteeris aga ma ei mäleta, et 2080 Ti oleks mingi krüpto monster olnud, sest kõrge hinna tõttu oli ROI halb.
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  nVidia Blackwell (GB202/GB203/GB205/GB206/GB207) mine lehele eelmine  1, 2, 3 ... 22, 23, 24 ... 35, 36, 37  järgmine
