memoricab
Uus kasutaja
08.03.2025 16:58:09
In one popular site
Gigabyte GeForce RTX 5090 Windforce OC 32G GDDR7- DLSS 4 3 599.00 €
MSI GeForce RTX 5090 32G VANGUARD SOC LAUNCH EDITION GDRR7 - DLSS 4 3 699.00 €
Can you help me, are these expected and sensible prices for these models? I totally lost my estimation after rapid market changes. Are these sensible and expected reseller retail prices, or inflated by reseller because of limited stocks where reseller tries to take an advantage on low supply high demand?
Sahasrahla
08.03.2025 17:42:05
memoricab kirjutas: |
In one popular site
Can you help me, are these expected and sensible prices for these models? I totally lost my estimation after rapid market changes. Are these sensible and expected reseller retail prices, or inflated by reseller because of limited stocks where reseller tries to take an advantage on low supply high demand? |
Mis järgmiseks, kirillitsas?
memoricab
Uus kasutaja
08.03.2025 17:59:39
I don't know how to write in Cyrillic, I wish I knew. Chill papasito
heretic666
08.03.2025 18:39:55
memoricab, the prices are pretty much dictated by warehouses from where specific store is able to pick 'em. Cheapest ones I ever saw was in Estonian store was 3200€ for more "basic" model. More expensive ones ~3700€.
Kommentaarid: 72 loe/lisa |
08.03.2025 18:39:57
In one popular site
None of the current Nvidia 50 series prices are what i would consider sensible.
5090 least of all.
2200€ is what the card should realistically cost in Europe. Maybe 2500€ for nicer AIB models.
3600+ ?
Waaay overpriced. In my opinion - if you have to ask wheter the price is sensible you are not the target demographic for this product and are better off buying (also overpriced) 5080 at 1500 or better yet a used 4090 for under 2000.
I saw one for 1800 the other day at this forum. Unless you have a 4090 already. In that case i see zero reason to get 5090. It's only 35% faster and it's only exclusive software feature, the Multi Frame Generation is just a software block as i have no doubt the older cards can generate 3 or 4 extra frames with ease - if Nvidia allowed it.
Not to mention various problems 50 series - 5090 specifically is struggling with like melting cables, missing ROP's, black screen issues etc. And planned things like deprecated 32bit PhysX support in some older games.
Kommentaarid: 92 loe/lisa |
Renq
Kommentaarid: 5 loe/lisa |
09.03.2025 00:33:48
Irooniline on see, et kaardi nimi on Frostbite...
150c peaks küll edukalt külmakahjustuse ära hoidma, aga võib tekitada põletuse
Auron
09.03.2025 10:35:25
Kas PSU poolse otstega on probleem ka siis kui on nö. vanem ülemineku kabla ehk siis PSU'st tulevad ikka 6+2 pin aga kaardipoolne ots on siis see HWPR või aint selle uue standardiga kus mõlemad HWPR.
Mis lootus võiks üldse olla, et midagi suuremat ette võetakse? Seda ma väga ei usu, et rohkem powaat tahtes minnakse tagasi mingi kolme ja enama 6+2 pin peale. EPS otsi ka ei usu.
Ehk siis lahendus oleks aint uus standard - analoogne mõte aga oluliselt tummisem ots aga sellega ju raske kuna ka PSU tootjad teinud spets 3.0/3.1 toited ehk siis nüüd on probleem ka piltlikult öeldes PSU poolne
Kui tahavad seda otsa edasi hoida siis mis saab - ainuke "lahendus" panna 5080 seeriast alates 2 otsa
Kommentaarid: 152 loe/lisa |
129 |
09.03.2025 10:37:03
teha kaardi pool nii nagu 3090(ti) oli. sealpool mingilgi määral kindlustada, et voolu erinevus juhtmete vahel oleks minimaalne.
_________________ - londiste
Kommentaarid: 241 loe/lisa |
215 |
haldz
Kommentaarid: 153 loe/lisa |
138 |
caramis
09.03.2025 13:03:18
see 12VHPWR on ikka normaalne kõhulahtisus. teind siis XT120 pistiku peale see ja asi lahendatud
_________________ CAD modelleerimine - 3D-skännist või mõõtmiste-kirjelduste põhjal uue mudeli loomine
3D-printimine - kuni 350x350x420mm ühe detaili kohta, valmidus enamike termoplastikute jaoks olemas (va. PEEK, PEKK jms) |
Kommentaarid: 167 loe/lisa |
144 |
UrmoZ
10.03.2025 19:02:30
Paljudel PSU-del on modulaarsete kaablite kujul mõlemal pool 12+4pin üllitis - great, now I have 2 points of possible failure.
Sellest tulenevalt kasutaks pigem adapterit.
_________________ Amazon - will not buy! |
Kommentaarid: 220 loe/lisa |
200 |
terric
11.03.2025 02:37:32
caramis kirjutas: |
see 12VHPWR on ikka normaalne kõhulahtisus. teind siis XT120 pistiku peale see ja asi lahendatud |
Postitan siia ühe YT eksperimendi. https://www.youtube.com/watch?v=VoWcndfnqgI
Eks seal peale pistikut on kõik tublisti üledimensioneeritud ja need "kruustangid" natuke jahutavad ka mingis osas st. vaja kütta seda rauda.
Lõpus autor mainib pistiku paranemist, mille põhjustab paisumine temperatuuri tagajärjel klemmid pressivad üksteist ja kontakt paraneb.
Aga see efekt tekib ühtlase kuumutamise tagajärjel ja ikkagi suure võimsuse juures.
Mäletan, et siin käis läbi üks uudis RTX kaardist millel oli 12vhpwr pistik ilusti kaardil irdus st. kahtlustati, et nagu oleks jäänud tehases joode tegemata.
See efekt sai ka "teadusliku" kinnituse videos
Ja muidugi tuleb ka mainida, et ta veendus et pistik oleks alati korralikult sees.
Ning kindlasti juhtmed selle pistikule olid "pressitud" mitte joodetud või siis mõlemad.
Kuid leidub pistikuid millel olid juhtmed ainult joodetud. Ja on ka erinevate tootjate klemme.
PS. Mahapõlemine tekib enamasti kui on kehv kontakt ja see väike kontaktpind kuumeneb ebaühtlaselt kõrgemale temp. kui ühtlaselt kõike koormata.
Kommentaarid: 2 loe/lisa |
11.03.2025 08:57:07
terric kirjutas: |
Eks seal peale pistikut on kõik tublisti üledimensioneeritud ja need "kruustangid" natuke jahutavad ka mingis osas st. vaja kütta seda rauda. |
huvitav kas kuumusega hakkama saamise või selle ära juhtimise vaatepunktist on parem need suured juhtivad pinnad nagu tal või kaart, millel sellise koormuse all peaks olema korralik õhuvool?
215 |
Auron
11.03.2025 11:11:58
See eksperiment näitab sedae, et jõle loll on selline probleem mis saab tekkida nö. randomilt ehk siis mingi kuradi lambivennal sulab 400W loadi alla ära ja samas teine laseb 1600W ja ei sula.
129 |
11.03.2025 11:25:55
See on jah pigem nagu loto. Iga insert annab tegelikult erineva tulemuse.
Ühel võib tuttuus kaart ja kaabel esimese käigu pealt lajatada 15-20A ühele juhtmele kaablite hulgas ja samas teine võib mitu aastat probleemideta jooksutada.
Alguses võis seda veel user errori süüks ajada. Nüüd kus on color coding, sense pinnide muudatused jms see argument enam ei päde.
Tegelikult ei pädenud see kunagi. Inimesed ei unustanud äkitselt kuidas voolukaableid sisestada.
Tegelikult süü lasub paljuski Nvidia enda vooluahela disainil mis on 4090 ja 5090 peal downgrade saanud vs nt 3090 Ti.
Paraku nagu näha pole ka teised tootjad midagi õppinud. Sapphire 9070 Nitro+ mudelitel ei ole paremat vooluahelat ehitatud selle pistiku ette.
9070 kaartide madalam voolutarve (kui ~330W ja 418W peak saab madalaks lugeda) peaks need ilmselt päästma suuremast jamast.
caramis
13.03.2025 21:23:46
terric kirjutas: |
caramis kirjutas: |
PS. Mahapõlemine tekib enamasti kui on kehv kontakt ja see väike kontaktpind kuumeneb ebaühtlaselt kõrgemale temp. kui ühtlaselt kõike koormata. |
vaatasin seda videot eile. suht lototron, et tal niimoodi asi koormust talus.
kõik seletavad miskist "ää, power inputs are not balanced waa-waa". nahhui, lahendus on olemas - XT90. üks pluss, üks miinus - lihtsamaks enam ei saa. pistik ise on piisavalt tummine, et ei teki isegi mõtet, et kas on asi korralikult pesas või ei
144 |
Snaxez
13.03.2025 21:29:55
Ise ka usud, et mõni arvutikomponentide tootja paneks XT90 GPU, PSU või mobo peale?
Kommentaarid: 58 loe/lisa |
53 |
caramis
13.03.2025 21:45:56
Snaxez kirjutas: |
Ise ka usud, et mõni arvutikomponentide tootja paneks XT90 GPU, PSU või mobo peale? |
kui see kannatab julmalt ampreid tarbivaid RC autosid, siis miks ei peaks toiteks kaht jämedat kaablit kasutama kahe suure klemmiga? nagu näha, siis on ka osadel toiteplokkidel mõned klemmipesad ära sulanud/põlenud. minu asi pole uskuda seda mida tootjad teevad, minu asi on loota olemasoleva ja töötava alternatiivi kasutuselevõttu. isiklikult ei koti mind üldse need järelturu helendavad RGBLGBTQ tulukestega jubinad ja mingid erivärvides kaablid.
tootja vaatepunktist - üks pistik asendab teoorias kolme pistikut ehk 3x 8pin vs üks XT90 või XT120 isegi kui sense klemme on vaja; oluliselt suurem koormustaluvus; paksem kaabel ja pistik, kannatab "sooja" rohkem tänu rohkemale termomassile; pistiku kontakt on alati kindel ja ei kuku niisama pesast välja nagu J2C näitas ühes videos kuidas ühe sõrmega kaardist PCI-E toitekaabli välja sikutas.
aga hei, be my quest kui tahetakse mingi multikaabel lollusega edasi minna. isiklikult ei näe probleemi 10€ rohkem maksta kaardi kui ka toiteploki eest kui neil XT pistik küljes on.
144 |
terric
13.03.2025 21:54:54
caramis kirjutas: |
terric kirjutas: |
caramis kirjutas: |
kõik seletavad miskist "ää, power inputs are not balanced waa-waa". nahhui, lahendus on olemas - XT90. üks pluss, üks miinus - lihtsamaks enam ei saa. pistik ise on piisavalt tummine, et ei teki isegi mõtet, et kas on asi korralikult pesas või ei  |
Ühe pistikuga, millel on ainult üks "+" ja üks "-" klemm tekib see probleem, et siis nagu võiks ka olla 2 juhtmega ning need juhtmed oleks päris jämedad jne.
Teine probleem, et nad üritasid ühe pistikuga lahendada ära PSU max. edastatava võimsuse määramise. Kui ennem oli 6pin (75W) ja 8pin (150W) ja sealt tulid ka need voolumõõtmised iga pistiku kohta siis
nüüd on üritatud ühe pistikuga ja "tuvastuse" pinnidega lahendada.
Aga mina ise oleks näinud lahendust, et 12pin pistik aga klemmid oleks olnud samas mõõdus, mis olid 8pin ehk 12pin pistik oleks olnud suurem ja ei oleks tekkinud sisestamisel probleeme.
Oleks, et need kaardid läheks väiksemaks, sellised tellised et mahuks 4tk 8pin pesa ritta laduda ja jääks ruumi üle.
ot: |
Mul nüüd toide(v3.0), ülemineku kaablid ja adapterid käes ja need klemmid on ikka luubiga vaatamiseks. |
Arx07
13.03.2025 22:08:03
5090 tarbib niipalju, et sellel oleks pidanud küll 2 pistikupesa olema, eriti overclockijate jaoks.
5080 puhul ei näe probleemi kui enamik 4090 elasid üle lühemate "+" kontaktidega.
Kommentaarid: 3 loe/lisa |
14.03.2025 01:15:54
terric kirjutas: |
nüüd on üritatud ühe pistikuga ja "tuvastuse" pinnidega lahendada. |
tuvastuspinnid on täiesti normaalne ja kasutatav lahendus.
ka 8-pin otsal on sense pin, kui see on maandatud, siis on 8-pin ja saab 150w, muidu peaks tulema 75w.
215 |
14.03.2025 12:24:00
Tomorrow kirjutas: |
Hmm kumb osta - kas roheline 12GB kaart 750+ eest või 7% kiirem punane 16GB kaart 750+ eest? Roheline muidugi  |
kust 7%? hwu leidis 4%.
mälu on sul veidi kinnisidee, mida laiem mängijaskond tingimata ei jaga.
750 eest neid osta on muidugi... valus. kogu see põlvkonna algus, värvist olenemata, on ikka päris kõvasti fucked up. ja ostetakse pigem seda, mida kuskilt saada on.
edit: geizhalsi kiigates, siis nbb-s on 679 ja 699 hindadest alates neid olemas.
215 |
14.03.2025 13:50:37
londiste, TPU perf chart. 4K raster. Võimalik, et 4K peal annab lisa 4GB 9070'le siis suurema eelise.
