uus teema   vasta Ärifoorumid »  Ostuabi/hinnapäring »  Kohvi ja masinavaatluse teema märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 63, 64, 65 ... 67, 68, 69  järgmine
UrMo20
UrMo20
sõnum 12.11.2024 16:33:58 vasta tsitaadiga
Kellelgi on head kogemust või teab kedagi kes tegeleb kohvimasinate remondiga?
Kas kuskil katkiseid kohvimasinaid ka kokku ostetakse, nii-öelda varuosadeks?
Hiid
Hiid
sõnum 12.11.2024 17:18:50 vasta tsitaadiga
Hapud viinamarjad
Kommentaarid: 660 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 510
rex
rex
sõnum 12.11.2024 18:06:08 vasta tsitaadiga
Sattusin täna esimest korda Philips Senseo padjamasinat kasutama. Kole palju aega kulub valmisolekuks. Nagu ootaks liitrise veekannu keemaminekut. Heli on ka sarnane, kuigi kasutatav vesi peaks ju tegelikult suuremas osas väljas paagis olema ja kasutusel nö kiirboileri süsteem. Dolce Gusto kapslimasinad on oluliselt kiiremad.
Kommentaarid: 248 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 227
sõnum 12.11.2024 19:06:15 vasta tsitaadiga
Mis kellaajal te päeva viimase kohvi joote?
The second new study is a meta analysis that looked at the effect of caffeine consumption on sleep. It’s generally well known that caffeine is bad for your sleep, but the magnitude of this effect is generally under appreciated. Caffeine deteriorates pretty much every aspect of your sleep and for a much longer time than most people realize. The researchers concluded: to avoid reductions in total sleep time and sleep quality coffee should be consumed at least 8.8 hours prior to bedtime, and a standard serving of pre-workout supplement should be consumed at least 13.2 hours prior to bedtime. They found that on average in the literature, caffeine impaired sleep quality and quantity to what they called a clinically significant degree. Every individual aspect of sleep quality did not deteriorate that much. But when you add it all together and you look at the effects that that reduction in sleep time and quality has on objective tasks, it is actually quite notable. So caffeine made it harder to fall asleep. It reduced sleep efficiency and it reduced the time spent in deep sleep stages while increasing the time in light sleep stages. It also increased the time that people spent awake at night, even if they didn’t remember it afterwards. So overall, caffeine is definitely no bueno for your sleep, and it seems that even a standard single serving of coffee needs to be consumed 9 hours prior to bedtime for the average individual. or as a pre-workout supplement, which typically has about 200 milligrams of caffeine, needs to be consumed a full 13 hours prior to bedtime, which means that you would not be able to train more than, say, 12 hours before bedtime if you don’t want any negative effect on your sleep.
Now, these effects are very individual and you might not have problems falling asleep with caffeine use closer to bedtime, in that case – Great. However, you should be aware that your subjective sleep quality is not necessarily the same as your objective sleep quality, so you might not feel the effects anymore, but there can still be objective effects. In fact, in one of the studies, they found that a single double espresso consumed in the morning still objectively impaired sleep quality at night. So that’s a single double espresso consumed and that still reduced sleep quality at night, even though subjectively nobody feels anything anymore from their caffeine use that long after consumption.
https://mennohenselmans.com/7-new-studies-you-must-know-about-caffeine/
sõnum 12.11.2024 19:12:29 vasta tsitaadiga
Just tegin viimase... 21ajal magama
häh
sõnum 17.11.2024 07:10:20 vasta tsitaadiga
Katsub väga üle kuue mitte minna viimasega (11 enamasti kustu).
Magama jäämises pole probleem, ärkan hilise kohvi peale ca 2...3 ajal üles -> jama. Ehk et une kvaliteedi jutt vähemalt enda puhul peab paika.
Mis abiks, kui kohvinälg õhtul väga suur- olen teinud hilisemal tunnil kas türki või odavat käppa, väiksem kogus ühesõnaga.
rex
rex
sõnum 17.11.2024 16:40:21 vasta tsitaadiga
Siis tuleb 2-3 ajal jälle tass peale võtta ja tuleb hea uni.
Mul ka üldiselt unejama pole. Kaine juhina mõni õhtu mitu tassi kohvi ja/või energiajooki ja koju tulles ei mingit hommikuni koristamist, nagu mõni kurdab.
SSD
SSD
sõnum 17.11.2024 16:51:29 vasta tsitaadiga
rex kirjutas:
Kommentaarid: 314 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 267
häh
sõnum 17.11.2024 17:38:16 vasta tsitaadiga
See on küll õige, et üleväsinuna jääb kohvi peale magama. Kui kunagi rentalis 24h+ päevi sai tehtud, siis muidu magama enam ei jäänudki.
Aga eks vanusega toimuvad muutused, hetkel küll täielik seltskonna surm, õhtul kukub nii totaalselt ära, et... icon_biggrin.gif seda uniseks (=magama) jäämist ei mõjuta kohv ega redbull * n mitte kuidagi. Igaühel oma kiiksud.
netcat
netcat
sõnum 18.11.2024 15:34:44 vasta tsitaadiga
Rutiinselt joon kohvi ainult kord päevas hommikusöögi ajal. Hommikusöök ise võib muidugi olla millal iganes. Ükskord oli kell 15.
Samas ma eluaeg olen joonud teed (nooremana musta, ja viimased 25 aastat põhiliselt rohelist) korraliku kruusitäie just enne magamaminekut... Ja tööpäeva sees võin teed larpida kruuside kaupa külmal ajal. See on ka ju kofeiin. Ei ole täheldanud, et see segaks magamist.
Hirff
Hirff
sõnum 28.11.2024 09:56:09 vasta tsitaadiga
Hetkel mul kiviaegne DeLonghi Magnifica ESAM 4200, mis käivitab end stand by režiimist ca minutiga, teeb mulle väga edukalt paar tassi kohvi päevas ning muid vigureid masinal eriti ei olegi, loomulikult saab sättida ka kohvi kangust ja tassi suurust. Masin on olnud väga-väga kaua kasutuses, äärmiselt usaldusväärne ja probleemivaba, kuid kahjuks on hakanud kergelt "köhima" ning märku andma, et tema aeg hakkab läbi saama. Niisiis, kallid sõbrad, oskate te midagi asemele soovitada? Tahaks pigem lihtsakoelist masinast, mis on võimeline tegema paar tassi kohvi päevas ning olemas võiks olla ka hea latte tegemise võimekus. Kõikvõimalikud muud vigurid ja kas või ekraani olemasolu pole absoluutselt olulised. Hind võiks jääda alla 500€. Kuhu suunas peaksin vaatama?
sõnum 28.11.2024 10:05:56 vasta tsitaadiga
Paari tassi jaoks sobib äkki isegi kasutatud Sage Barista Pro SES878 mida parasjagu keegi foorumis müüb?
tont23
tont23
sõnum 28.11.2024 23:50:25 vasta tsitaadiga
Hirff kirjutas:
mingi odavama otsa philips peaks ka selle hinna sisse jääma icon_rolleyes.gif
Kommentaarid: 127 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 111
häh
sõnum 01.12.2024 07:25:40 vasta tsitaadiga
Alla 500 euro on isikliku tundmuse järgi kaks võimalust- kas superit tahtes ECAM või siis sama tootja ECP seeriast (boileriga kindlasti) nt 35.13 + mingi hea veski- näiteks Macap M2M. Mul on viimane kooslus olemas, reaalsed probleemid on vahustusots (see panarello vms on jama ja sinna peab ise mingi samkompunni tegema) ja ta on liiga väike ja ebamugav majandada. Kohv ise on väga hea ja hooldus lihtne.
ECAM kohta kehtib sama- panarello tüüpi vahustusots on p0rno. Pmslt on kõik lihtsad superid millel piima sissevõttu ei ole muidu väga ok, kui neil on võimalus vahustusots lihtsalt aurutoru vastu vahetada (osadel on ka kohe algusest toru olemas). Kohv on okei ja hinna kvaliteedi suhe väga hea.
Miks sellest vahustustorust räägin- hooldus (=lapiga puhtakstõmbamine) ja vahu kvaliteet. Mingit rääsunud kohupiima kusagilt välja urgitseda, tänan, ei icon_wink.gif
Muidu jah kindlasti, Sage Barista Express (mina eelistaks ise seda mudelit) on suht no brainer. Suur miinus on sisseehitatud veski, aga on hullemaid variante. Teine probleem on nendel masinatel survestatud korvide loll lahendus, nt DeLonghi lahtikäiv disain on ülimõistlik leiutis. Ergonoomika on muidu väga hea ja masin sobib poekohvi tegemiseks (just Express).
kjaups
MeesKesTuliMetsast
kjaups
sõnum 01.12.2024 12:12:31 vasta tsitaadiga
Geenivaramu järgi see kiire kohveiini lõhustumine.
YAGA müügiputka - SNAP pildipank
M: 3D Touch V3.2 15€
M: Triumph Trident 660 2023a - AHVile 200€ alla
Kommentaarid: 170 loe/lisa Kasutajad arvavad:  :: 0 :: 3 :: 139
Hiid
Hiid
sõnum 01.12.2024 13:43:29 vasta tsitaadiga
Hirff, Rimist Merrild Espresso alla 10 eur, OnOffist Ecam S 270eur. Paremat combot pole icon_wink.gif
https://onoff.ee/et/espressomasinad/53912-delonghi-ecam22112b-magnifica-s-20110854-8004399022409.html
Hapud viinamarjad
kjaups
MeesKesTuliMetsast
kjaups
sõnum 01.12.2024 15:55:09 vasta tsitaadiga
Hiid, omal sama masin juba 3 aastat.
Merrildit tööl joonud, suht lurr tundus. Mingi Eesti firma uba, prismast sai eelmine nädal 11€ kg, mingi värviline lilla pakk, seni rahul.
Hiid
Hiid
sõnum 01.12.2024 16:12:44 vasta tsitaadiga
Hapud viinamarjad
kjaups
MeesKesTuliMetsast
kjaups
sõnum 01.12.2024 18:14:13 vasta tsitaadiga
Hiid, too beež/hele pruunikas pakk? Ma neid tüüpe üldiselt ei tea, vaatan soodukat ja siis haaran mis viimati enam vähem maitse tundus või mis uut on. Üldiselt üle 13€ kilo eest ei osta.
1dumbpcuser
sõnum 01.12.2024 19:00:18 vasta tsitaadiga
kjaups kirjutas:
https://www.prismamarket.ee/entry/kohvioad-keskmine-rost-1-kg/4744743019016 icon_question.gif
M:
Kommentaarid: 102 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 97
kjaups
MeesKesTuliMetsast
kjaups
sõnum 01.12.2024 19:14:32 vasta tsitaadiga
1dumbpcuser, õige! Seni ületanud kõiksugu Lavazzad ja jazzad. Esimene uba mille perenaine normaalseks tunnistas icon_lol.gif
Hiid
Hiid
sõnum 01.12.2024 20:55:51 vasta tsitaadiga
kjaups, beez on cremoosa, see on jura. espressost räägin, nüüd on ta hõbedane mustaga...
https://www.rimi.ee/epood/ee/tooted/joogid/kohv-tee-kakao/kohvioad/kohvioad-merrild-barista-espresso-1kg/p/1014042
Hapud viinamarjad
Mini1
sõnum 03.12.2024 21:23:25 vasta tsitaadiga
Soovitage odavama otsa veskit. Soov teha tavalist filtri kohvi, aeropress jne. Kas need kohvisemu Eureka näiteks on ok?
https://www.kohvisemu.ee/p/kohviveski-rocket-espresso-mignon-filter-range-filtro-black/
Kommentaarid: 34 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 29
skyTronic
sõnum 04.12.2024 20:44:51 vasta tsitaadiga
Soovitaks magnetilise topsiga 30+ g mahutavat väljast poolt reguleeritavat käsiveskit.
Kahjuks Amazon 1zpressot enam ei müü, aga kui ma võrdlen alla 100€ 1zpressot ja Wilfa Uniformi, siis käsiveski tulemus meeldib rohkem.
https://www.youtube.com/watch?v=inI1bKxYQG4
taavi
sõnum 04.12.2024 21:49:40 vasta tsitaadiga
miks nendele parema tulemusega käsimasinatele mootorit külge pole pandud?
Kommentaarid: 68 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 59
uus teema   vasta Ärifoorumid »  Ostuabi/hinnapäring »  Kohvi ja masinavaatluse teema mine lehele eelmine  1, 2, 3 ... 63, 64, 65 ... 67, 68, 69  järgmine
