10.09.2024 17:35:15
Tjah, selle raha eest võiks vähemalt vertikaalse ständigi kaasa panna... (konkurendil on hinnas).
Arvan, et PS5 Pro adoption rate jääb ilmselt veel väiksemaks kui PS4 Pro oma, sest hind on päris jube ja gamerid ei küsinud uue mid-gen konsooli järele... Olen jälginud eri allikaid ja valdav arvamus on see, et "PS5-st pole isegi viimast võetud, milleks PS5 Pro vaja on?"
Visuaalselt tundub, et selle 800 eest ei saa isegi optilist seadet, vaid tegu on digital only ehk soodsama versiooniga? Ma ei tea... kui sisemine SSD pole vaikimisi 2TB siis tuleb politseisse helistada
_________________ "We're doing the studies to make the proof" - RFK Jr. |
313 |
1dumbpcuser
10.09.2024 18:00:24
Mis PS5 pron"launch title" on? Ehk mis oleks esimene mäng, mis näitaks selle toorest jõudlust?
_________________ M: |
95 |
hkurujo88r
10.09.2024 18:06:00
| Optilise seadme saad eraldi juurde osta kui tahad. Läheb sama mis praegu slim mudelile läheb. 2tb mälu ka.
120 |
S.I.L.L.U
10.09.2024 18:09:44
Available: November 7, 2024
Preorders: September 26, 2024
Price: $699.99 USD, £699.99 GBP, €799.99 EUR, and ¥119,980 JPY (includes tax)
Tech specs:
It will include a 2TB SSD, a DualSense wireless controller and a copy of Astro’s Playroom pre-installed in every PS5 Pro purchase. PS5 Pro is available as a disc-less console, with the option to purchase the currently available Disc Drive for PS5 separately.
The big three.
Upgraded GPU: With PS5 Pro, we are upgrading to a GPU that has 67% more Compute Units than the current PS5 console and 28% faster memory. Overall, this enables up to 45% faster rendering for gameplay, making the experience much smoother.
Advanced Ray Tracing: We’ve added even more powerful ray tracing that provides more dynamic reflection and refraction of light. This allows the rays to be cast at double, and at times triple, the speeds of the current PS5 console.
AI-Driven Upscaling: We’re also introducing PlayStation Spectral Super Resolution, an AI-driven upscaling that uses a machine learning-based technology to provide super sharp image clarity by adding an extraordinary amount of detail.
| Kommentaarid: 93 loe/lisa |
87 |
pots4t4j4
10.09.2024 18:25:04
Ps5 seisab juba aastaid kasutust leidmata, iga poole aasta tagant saab puldile software update teha thats it, ei tea kellel seda pro versiooni vaja veel
401 |
andreL
10.09.2024 18:27:19
| Vote with your wallet. SONY sales management on ikka väga pilvedes omadega. Vaadates kommentaare, siis inimesed pole absoluutselt rahul ja seda põhjusega. 800 euri ilma disci ja vertical standita on täielik absurdsus.
| Kommentaarid: 69 loe/lisa |
63 |
hkurujo88r
10.09.2024 18:32:20
| Tavalist ps5 osteti ju 800€ eest, mis see siis nüüd pro mudeli eest ära maksta pole?
120 |
lightbluefox
10.09.2024 19:37:14
Mida see Pro siis nüüd nii väga rohkem pakub, kas quality vs performance valikut pole enam vaja ühegi mängu puhul teha, kuna kõik jookseb 4k 60fps max graafikaga?
Kahtlustan, et kui siiani ei võta suurem osa mängudest PS5st maksimumi, siis ei hakka ilmselt kõik mängud nüüd PS5 Pro enhanced kleepsuga tulema
| Kommentaarid: 45 loe/lisa |
44 |
10.09.2024 20:55:52
| hkurujo88r kirjutas: |
| Tavalist ps5 osteti ju 800€ eest, mis see siis nüüd pro mudeli eest ära maksta pole? |
Palju neid ikka oli, kes tegelikult sellist hinda maksid?
Ise ostsin alles siis kui 2023 alguses vaba saadavus tekkis ja peaaegu poole vähema eest.
| lightbluefox kirjutas: |
Kahtlustan, et kui siiani ei võta suurem osa mängudest PS5st maksimumi, siis ei hakka ilmselt kõik mängud nüüd PS5 Pro enhanced kleepsuga tulema  |
No Spider-Manis ja Ratchet & Clankis ju näed, kuidas kaugel taustal on detailsem ning GT7 autod peegeldavad üksteise pealt /s
Sony jättis selle video all kommenteerimise avatuks, kõik on oodatult väga ühemeelne.
313 |
Alari A.
10.09.2024 21:10:31
Tootke peale ja järelturul on elu lill. Saan vana PS5 200 millegagi.
viimati muutis Alari A. 10.09.2024 21:11:21, muudetud 1 kord |
| Kommentaarid: 662 loe/lisa |
543 |
10.09.2024 21:13:59
| Alari A. kirjutas: |
Rada on sama aastaid olnud. Taaskasutajad, kuis mina, saan äkki PS5 Disci alla 300€ kätte nagu ammusel ajal sain ühe PS4 mudeli mis oli juba ilma läikiva kaaneta.
Tootke peale ja järelturul on elu lill  |
Kui PS4 Pro välja tuli, siis Sony langetas tavalise PS4 hinna $100 võrra alla ($299) ja PS4 Pro tuli sama hinnaga, mis PS4 algselt oli ($399)
Üha enam tundub, et Sony on järjekorde ämbriga hakkama saanud. Vaatasin just Saksa Amazoni... Sisuliselt 2x hinnavahe - sel pole samuti ständi ja optilist seadet, seega hea võrrelda. Selle saab umbes samal ajal ehk Mustal Reedel ilmselt alla 400 kätte juba. Kas nad tõesti arvavad, et inimesed hakkavad 800 eurot ehk kahekordset hinda välja käima?
https://www.amazon.de/-/en/9577294/dp/B0CLTBHXWQ/
viimati muutis SKG 10.09.2024 21:14:28, muudetud 1 kord |
313 |
Dj-E
Aeg Maha 2a
10.09.2024 21:14:27
_________________ Eesti suurim Ubisofti fänn!!! |
| Kommentaarid: 22 loe/lisa |
21 |
313 |
| Kommentaarid: 92 loe/lisa |
1dumbpcuser
11.09.2024 07:14:26
No vähemalt on see siis esimene konsooli, mis peaks ka reaalselt enamikke, kui mitte kõiki kataloogi mänge ilma trikkideta 4k renderdada suudab?
95 |
Snaxez
11.09.2024 08:03:34
EU hinnaga on ikka korralikult võssa pandud. Oleks siis sama € hind, mis usd on, nagu vanasti. Lisaks disc drive ka juurde vaja osta. (Miterassa hind näitab 149,99€ ja gameroomis 129€) Ei imestaks, kui PS6 ei tulegi disc optionit.
Internal storage-i upgrade ei paku väga huvi. Hetkel 4TB 990Pro sees, ja see pole veel täis saanud.
| Kommentaarid: 59 loe/lisa |
53 |
Kustav
11.09.2024 08:16:53
Kui peaks täna konsooli ostma, siis eelistaks kindlalt PRO-d - järelturul on juba väärtus suurem.
_________________ Kogun protsessoreid  |
160 |
11.09.2024 09:43:22
Selle jaoks on eraldi teema: https://foorum.hinnavaatlus.ee/viewtopic.php?p=11507825
Vaevalt, et eriti palju müüb, jääb väikeseks osaks nagu PS4 Pro. Tolle kogu müük vist moodustas ainult 13% kogu PS4 müügist kui ma õigesti mäletan. Ja PS4 Pro tuli müügile sama hinnaga, millega PS4 eelnevalt letil oli (399). Tavalise PS4 hind langetati 299 peale. Hetkel on olukord väga erinev.
| 1dumbpcuser kirjutas: |
| No vähemalt on see siis esimene konsooli, mis peaks ka reaalselt enamikke, kui mitte kõiki kataloogi mänge ilma trikkideta 4k renderdada suudab? |
Kindlasti mitte, ära seda küll eelda.
Nagu videost-st näha oli, siis Hogwarts Legacy mängus demonstreeriti RT võimekust, kuid selle "unustas" Mark Cerny mainida, et see mäng ju jooksis silmnähtavalt 30FPS seal, mitte 60FPS, mis pidi olema Pro konsooli peamine selling point - 60FPS aga ilma Fidelity Mode ohverdamata. Native 4K võib kohe unustada. Tundub, et 5 Pro lihtsalt silub olemasolevate mängude kaadrisagedust ja lisab veidi silmailu, mille demonstreerimiseks pidid nad kõvasti sisse zoomima.
| Kustav kirjutas: |
| Kui peaks täna konsooli ostma, siis eelistaks kindlalt PRO-d - järelturul on juba väärtus suurem. |
Sinu arvates peaaegu 2x hind on õigustatud? Tavaline PS5 on ~420 eur
313 |
heretic666
11.09.2024 09:49:49
Toppigu 6 months timed exclusive GTA 6 only on PS 5 Pro siis lendavad need kõik riiulitelt
| Kommentaarid: 73 loe/lisa |
Laifstaile
11.09.2024 10:35:03
| Dj-E kirjutas: |
| Laifstaile kirjutas: |
| Järjest rohkem tundub see Pro sinna 700 kanti kiskuvat... |
Pro ei peagi odav olema. Nii nagu telefonidegi puhul on Pro versioonid kallimad ja need polegi vaestele mõeldud. |
tuleb nii välja...
Aga konsool peaks tulema "nüüd" müüki aga GTA6 on väidetavalt edasi lükatud järgmise aasta keskele/teise poolde...
Kas PS4 väljalaske Last of Us 2 saab re-remake PS5 Pro versiooni nüüd ja küsitakse uued 70€
| Kommentaarid: 25 loe/lisa |
24 |
Lingumees
11.09.2024 10:40:14
| Hetkel ei ole turul mänge, mis mõjutaks tegema upgrade pro peale. V-o järgmine aasta on, aga alles viimasel aastal on stuudiod loobunud mängude väljastamist eelmise generatsiooni peale. Esitluse lõpus tekkis mul küsimus, kas tõesti praegusele platvormile ei suudate neid AI-tehnoloogia asju pakkuda.
| Kommentaarid: 4 loe/lisa |
11.09.2024 10:47:43
| heretic666 kirjutas: |
Toppigu 6 months timed exclusive GTA 6 only on PS 5 Pro siis lendavad need kõik riiulitelt  |
Ei usu, ega siis tavaline PS5 müügilt ära kao, see jääb ülekaalukalt popimaks versiooniks. Millel saab olema ka GTA 6.
800-900 konsooli eest käivad välja ainult suurimad fännid, keda hind ei huvita ja ostavad kõike, mida Sony toodab ja need, kes veel vanematega koos elavad ja oma raha eest renti/arveid/toitu ostma ei pea.
313 |
Laifstaile
11.09.2024 13:50:02
| Isegi suur fanboy dreamcastguy ütles ei...mis sest et "töö" on ps mänge pelda
24 |
Kustav
11.09.2024 14:14:46
Nagu ikka, alguses hala ja pärast ostad ikka, sest kõik läheb kallimaks ja harjud viimaks reaalsusega ära.
Samamoodi oli ka telefonide maailmas kui maagiline 1k piir sai ületatud, nüüd keskklassi telefon ka 400€, mõni aasta tagasi 300€
160 |
11.09.2024 15:06:19
| Kustav kirjutas: |
Samamoodi oli ka telefonide maailmas kui maagiline 1k piir sai ületatud, nüüd keskklassi telefon ka 400€, mõni aasta tagasi 300€  |
Telefon on tänapäeval sisuliselt eluks vajalik sidevahend, mida peab omama. Konsool on meelelahutuslik luksuskaup.
Eestlane ikka naljalt neid üle 1K telefone ei osta, müüjad neid edetabeleid avaldavad ja topis alati need odavad A-seeria Samsungid, mitte 1K või üle maksvad telefonid.
313 |
