uus teema   vasta Hinnavaatlus »  Microsoft »  Windows 11 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 78, 79, 80 ... 152, 153, 154  järgmine
sõnum 25.05.2023 16:51:30 vasta tsitaadiga
SKG kirjutas:
Linuxi turuosa on vaga vaike: https://en.wikipedia.org/wiki/Usage_share_of_operating_systems#Desktop_and_laptop_computers
Kui MS on selle 7Zip ja RAR loojatega kooskolastanud ja koik osapooled onnelikud, siis koik okei muidugi
Ma ei tea mida seal kooskõlastada on. Vastavate formaatide loojad on ilmselt õnnelikud, et kümned kui mitte sajad miljonid inimesed saavad neid formaate tulevikus kasutada ilma lisatarkvara paigaldamata.
Pealegi jutt käib ainult formaatide äratundmisest ja lahtipakkimisest. Eeldan, et keerukamata asjade nagu kokkupakkimine jms featuuride jaoks on vaja vastav 7z ja WinRAR tarkvara paigaldada ka tulevikus.
Can I use 7-Zip in a commercial organization?
Yes, 7-Zip is free software. You can use it on any computer. You don't need to register or pay for 7-Zip.
Can I use the source code of 7-Zip in a commercial application?
Since 7-Zip is licensed under the GNU LGPL you must follow the rules of that license. In brief, it means that any LGPL'ed code must remain licensed under the LGPL. For instance, you can change the code from 7-Zip or write a wrapper for some code from 7-Zip and compile it into a DLL; but, the source code of that DLL (including your modifications / additions / wrapper) must be licensed under the LGPL or GPL. Any other code in your application can be licensed as you wish. This scheme allows users and developers to change LGPL'ed code and recompile that DLL. That is the idea of free software. Read more here: https://www.gnu.org/. You can also read about the LZMA SDK, which is available under a more liberal license.
https://www.7-zip.org/faq.html
win.rar GmbH is committed to supporting the Microsoft release cadence for Windows 11™. win.rar GmbH works closely with Microsoft to make sure that WinRAR is fully compatible with Windows 11™.
https://www.win-rar.com/windows-11-support-statement.html?&L=0
Bilderberg
Bilderberg
sõnum 25.05.2023 16:52:10 vasta tsitaadiga
napoleon kirjutas:
See windows subsystem for linux oli vist muu asi. Tekkis mingi virtuaalmasina moodi asi, aga hosti failisüsteemiga ma ei mäletagi kas ei saanud üldse läbi või oli read only. Korra proovisin, aga kasutu minu jaoks. Parem lasen juba virtualboxis tõupuhta linuxi käima.
Korra oli vaja, siis küll linuxi ketta avas vabalt ja failid sain kätte.
sõnum 25.05.2023 17:12:45 vasta tsitaadiga
Tomorrow, pidasin silmas, et ajalooliselt pole Microsoftile sellised asjad hasti loppenud, kus nad oma turupositsiooni ara kasutades teatud tarkvara Windowsi uritavad integreerida. Alustades brauserist, Media player - Windows N. Euroopa Komisjoniga on neil palju kana kitkuda olnud.
6/4/2025, RFK Jr: "The most effective way to prevent the spread of measles is the MMR vaccines."
Mnator
sõnum 25.05.2023 17:24:40 vasta tsitaadiga
SKG kirjutas:
minu meelest kana kitkuda on olnud katsetel tõkestada konkureerivaid lahendusi aga mitte lihtsalt kellegi teise väljatöötatud lahenduste levitamisel
sõnum 25.05.2023 17:34:17 vasta tsitaadiga
SKG, Need näited on väga erinevad praegusest. Minevikus üritati ära kasutada monopoli aga kokkupakkimstarkvara osas ei ole Microsoftil isegi mingit oma lõppkasutaja toodet - rääkimata monopolist. Jah tehniliselt neil on .cab ja .msu formaadid aga need on üsna piiratud otstarbega kokkupakitud arhiivid (peamiselt windowsi uuenduste ja draiveritega seonduvad).
Tuntud ja laialt kasutatud formaatide integreerimine on ainult teretulnud. https://en.wikipedia.org/wiki/Comparison_of_file_archivers
Ma ütleks, et käivitusfailide osas on Microsoftil palju suurem monopol .exe ja .msi näol. Kuigi need võivad olla tehtud paljude erinevate programmidega nagu InstallShield, NSIS, INNO Setup jne.
Palju suurem probleem Windowsis on ikkagi oma Store ja Edge pealesurumine.
BA79
sõnum 25.05.2023 17:46:38 vasta tsitaadiga
napoleon kirjutas:
Ma ka sain read-only's ainult vaadata. Isegi kopeerida ei õnnestunud. Rakenduse nimi mida kasutasin hetkel ei tule meelde kuigi proovisin jah W11 all oma Ubuntu kõvaketast USB kettana. Googeldamine soovitab lihtsama lahendusena Win masinasse installida nt Ubuntu VM ja sinna ketas haakida (nii failidele ligipääsuks kui ka LUKS krüpteeringus ketta avamiseks).
sõnum 25.05.2023 18:10:32 vasta tsitaadiga
Tomorrow kirjutas:
MP3 ja PDF oli tollal samuti laialt levinud formaat.
BA79
sõnum 25.05.2023 18:42:26 vasta tsitaadiga
Enamus meediafailide formaate on kasutatavad vabavaralise litsentsiga. Samas enkoodreid toetavate tarkvarade valik on kitsendatud ja kui on soov enamike meediaformaatide tuge saada, peab Linuxi puhul natuke vaeva nägema ja erinevaid enkoodreid toetavaid pakke installima. Eks Windowsi puhul on ka mitmeid erinevaid vabavaralisi meediarakendusi, mis kasutavad vabavaralise litsentsiga levitatavaid enkoodreid.
sõnum 25.05.2023 20:38:55 vasta tsitaadiga
Pidasin silmas, et kui Microsoft soovis MP3 ja PDF naol tuntud ja laialt kasutatud formaate integreerida, siis teadagi, kuidas see kulges.
Keegi teab, kuidas mikrofoni voluumitugevus 100 peale fikseerida? Windows liigutab seda mingi automaatikaga oma suva jargi.
Panen 100% peale, siis keegi mone aja parast Teams-is kurdab, et ei kuule mind hasti - vaatan settinguid, Windows ise 67% peale pannud icon_mad.gif
edit:
Proovin seda.
https://chrome.google.com/webstore/detail/disable-automatic-gain-co/clpapnmmlmecieknddelobgikompchkk
BA79
sõnum 25.05.2023 21:24:27 vasta tsitaadiga
Ei oska kommenteerida, miks Windows ise reguleerida tahab, aga minu meelest peaks saama heliseadmeid reguleerida ka iga äpi/rakenduse jaoks eraldi. Vast mõni linnuke panna-maha võtta või eriseade heliseadme draiveri paneelist?
Mul nt on Bluetoothiga teinekord jama, et kui kasutan ja korraks "Mute" panen siis tagasi vaigistuse mahavõtmisel heli ei taastu. Näpi/seadista, võimle aga automaatselt ei tule heli tagasi või ei lülita ümber BT väljundilt HDMI audiole. Aitab ainult arvuti restart. Arvutil tundub BT-d juhtivat Nahimic tarkvara aga see töötab nagu jumal juhatab.
Bilderberg
Bilderberg
sõnum 25.05.2023 22:06:49 vasta tsitaadiga
SKG kirjutas:
edit:
Proovin seda.
Minul aitas linnuke, kui deaktiveerida heliefektid. Miks toimis ei tea:
sõnum 25.05.2023 22:28:49 vasta tsitaadiga
Kõlarite heliefektid? Need mul nagunii deaktiveeritud, kuid kuidas see mikrofoni helitasemega saab seotud olla?
Bilderberg
Bilderberg
sõnum 26.05.2023 07:48:20 vasta tsitaadiga
SKG kirjutas:
Mul jah mikrofon välja lülitatud, aga probleem vist analoogne, mis heliga:
https://ded9.com/low-microphone-volume-in-windows-11-fix-the-problem/
sõnum 26.05.2023 08:07:04 vasta tsitaadiga
Teams > Settings > Devices > Automatically Adjust Device Sensitivity.
sõnum 26.05.2023 14:32:20 vasta tsitaadiga
Betamax kirjutas:
Kasutan Teamsi Edge brauseris.
sõnum 26.05.2023 15:50:30 vasta tsitaadiga
Miks sa Store'ist äppi ei kasuta või installi täisprogrammi?
sõnum 26.05.2023 16:00:34 vasta tsitaadiga
Pole vajadust olnud. Mis eelised sel appil on?
sõnum 26.05.2023 16:19:01 vasta tsitaadiga
Saad audio-video osa paremini seadistada. Pluss veel nipet-näpet. Ma ausalt öeldes näen Teamsi veebiversioonil mõtet ainult siis, kui tekstivestlust vaja pidada. Audio-video ja failindus on täisversioonis mugavam.
napoleon
Unknown virus
napoleon
sõnum 26.05.2023 16:56:33 vasta tsitaadiga
ot:
tekstivestluse jaoks on skype mugavam. Jah blablabla eluvõõras koodineeger ei saa aru, et teams seaded võib keegi kuskil kaugelt peale lükata, aga ikkagi....
BA79
sõnum 26.05.2023 18:05:54 vasta tsitaadiga
Teamsi äpi kasutamiseks peab minu kogemust mööda olema organisatsiooni liige kus on Office 365 kasutuses või kasutama MS kontot. Eraisikud nt gmailiga ei saa tasuta kasutada (peab ostma vähemalt Office 365 Personal). Vähemalt mina ei saanud. Selleks, et gmailiga saab kasutada ainult Teamsi veebiversiooni. Veebiversioon on jah natuke nuditud aga ajab asja ära.
Ise pidin olude sunnil samuti ühe vestluse Teamsis tegema veebiversioonis.piversiooniga sisse logida ei saanud sest need kontod mis äpiga seotud olid, on suletud kuna ma ei kuulu enam sellesse organisatsiooni millega mu Teamsi konto e-mail seotud oli.
viimati muutis BA79 26.05.2023 20:55:46, muudetud 1 kord
sõnum 26.05.2023 20:48:34 vasta tsitaadiga
napoleon kirjutas:
ot:
Skype on surnud. Ükski enesest lugupidav firma ei kasuta seda. Mingid õnnetud riigiasutused on veel selle peale jäänud, aga mu maailm on Teamsis. Microsoft365 ei sisalda enam Skype Businessigi.
napoleon
Unknown virus
napoleon
sõnum 26.05.2023 20:58:19 vasta tsitaadiga
See teamsi chat on kuidagi kehva. Mida nad siis kasutavad? Messengeri?
Tox ja signal on ju hardcore vendade jaoks, neid asutused ei kasutaks ilmselt.
sõnum 26.05.2023 21:00:06 vasta tsitaadiga
Jep, meil firmas ainult Teams. Kuna too parast palju aknaid lahti, siis ei tahaks uhte proge juurde installida. Edge on kasutuses nagunii.
Tana igatahes mikrofoni helitugevus ei muutunud, peale selle Edge extensioni installimist.
BA79
sõnum 26.05.2023 21:05:25 vasta tsitaadiga
Betamax kirjutas:
napoleon kirjutas:
ot:
Olen nõus, et Skype on praktiliselt surnud. Kindlasti mingi marginaalne osa arvutikasutajatest kasutab, aga enamus mitte.
Üldjoontes võib Skype ebapopulaarsust seletada sellega, et inimesed ei suhtle selle kaudu enam. Seda rakendust tabas MSN saatus, pärast seda kui Facebook võttis MSN rolli üle, suri MSN välja sest asemele hakati pakkuma Skype'i, aga seda tabas ebaedu. Nüüd suhtlevad kõik otse nutitelefoni vahendusel. Ettevõtted kus on klienditeenindus veebis, kasutavad juturobotit. Ärikontaktid kas Teamsis või Messengeris kuna saab ka FB videokõne teel suhelda.
Mul on ka Skype konto, aga ei leia enam kasutust sest keegi ei kasuta ega jaga mulle oma Skype'i. Seega milleks?!?
viimati muutis BA79 26.05.2023 21:08:34, muudetud 1 kord
sõnum 26.05.2023 21:08:19 vasta tsitaadiga
Betamax kirjutas:
napoleon kirjutas:
ot:
Sa ikka tead, et Skypel ja Skype for Businessil, pole midagi ühist peale nime?
Skype for Business oli tegelikult rebranditud Lync.
uus teema   vasta Hinnavaatlus »  Microsoft »  Windows 11 mine lehele eelmine  1, 2, 3 ... 78, 79, 80 ... 152, 153, 154  järgmine
