uus teema   vasta Hinnavaatlus »  Multimeedia- ja helifoorum »  NVidia Shield arutelu märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 5, 6, 7 ... 12, 13, 14  järgmine
Millist versiooni omad?
Shield 2015 16GB
6%
 6%  [ 3 ]
Shield Pro 2015 500GB
0%
 0%  [ 0 ]
Shield 2017 16GB
11%
 11%  [ 5 ]
Shield Pro 2017 500GB
2%
 2%  [ 1 ]
Shield 2019 8GB
4%
 4%  [ 2 ]
Shield Pro 2019 16GB
75%
 75%  [ 34 ]
hääli kokku : 45
S.I.L.L.U
sõnum 12.01.2022 22:56:13 vasta tsitaadiga
Midagi asjalikku ka uuendusega?
Kommentaarid: 96 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 90
Snaxez
Snaxez
sõnum 13.01.2022 09:04:56 vasta tsitaadiga
S.I.L.L.U kirjutas:
Release Note-ides küll midagi erilist silma ei jäänud. https://www.nvidia.com/en-us/shield/software-update/
SHIELD TV gets upgraded to Android 11. Updates include new privacy features, and a new default keyboard with built-in text to speech capabilities.
Includes Android security patch level September 2021
Adds support for aptX compatible Bluetooth headsets
Adds option to automatically disconnect Bluetooth devices on sleep
Adds option to match content audio resolution (high resolution audio)
Adds new Gboard keyboard option
Adds new Energy saver setting for additional power customization
Adds Stadia button support to XBOX, Playstation, and SHIELD controllers
Additional bug fixes
Kommentaarid: 61 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 54
sõnum 14.01.2022 23:18:55 vasta tsitaadiga
Esimene hotfix juba. Peab eraldi signup tegema selle jaoks.
https://docs.google.com/forms/d/e/1FAIpQLSfZKoA78miKEiAXBsJlJZXtH8M_dGOjLXV6HBKc5Zw11_FSUg/viewform
Snaxez
Snaxez
sõnum 15.01.2022 11:29:50 vasta tsitaadiga
mul juba esines see "audio may be lost untill shield is rebooted".
sõnum 16.01.2022 22:17:53 vasta tsitaadiga
Bugid:
https://piunikaweb.com/2022/01/15/nvidia-shield-tv-bugs-issues-tracker-heres-the-current-status/
Fixed
sõnum 17.01.2022 09:45:23 vasta tsitaadiga
Snaxez kirjutas:
Esines eile täpselt sama probleem. Praegu juba kahetsengi, et nii ruttu selle suure uuenduse tegin kuna üleüldiselt väga halvasti töötab kõik.
Minul siis kasutusel see toru versioon.
Snaxez
Snaxez
sõnum 17.01.2022 12:56:39 vasta tsitaadiga
Fixed kirjutas:
Snaxez kirjutas:
Ma panin sinna hotfix listi end kirja, ja sain ka paranduse kätte. Pole seda viga enam näinud.
sõnum 29.01.2022 14:32:13 vasta tsitaadiga
Hotfix #2
#3
Kozlor
sõnum 01.02.2022 00:07:06 vasta tsitaadiga
Hotfix #3
Telia TV äpp arvab, et tegemist on tahvliga ja uninstallib Android TV äppi ja lase tahvli äppi peale.
Shieldi forumist sain vastuse:
Resolves mouse click not working
In HotFix 3 is confusing some apps that shield is a touchscreen/tablet device.
Lisaks hotfix 3 peale panekut sain ka perioodilise teleka ja shieldi väljalülituse. Kasutan IR Shieldi ja vanema Samsungi teleka juhtimise jaoks. Peale rebooti on korras. Kui sleebist üles tuleb hakkab nali kohe pihta.
Kommentaarid: 4 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 2
Rauno266
sõnum 01.02.2022 10:42:23 vasta tsitaadiga
Paras käkk on see Android 11 upgrade. Nii palju katkisi featuure polegi ammu ühe android uuendusega näinud.
Kommentaarid: 45 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 41
JazZ
sõnum 01.02.2022 13:16:19 vasta tsitaadiga
Mul on hakanud pärast seda android 11 uuendust lambist restartima, nii nädalas korra või kaks. Kellelgi veel?
2015 Shield
wirx
wirx
sõnum 01.02.2022 13:37:19 vasta tsitaadiga
Mul peale uuendamist hakib päris mitmes kohas pilt, Amazon videos korduvalt ühe filmi jooksul ning ka netflixis paar korda täheldanud, enne update oli 0 probleemi. Ei soovita kellelgi updateda, mingeid lisa võimalusi küll ei näe, et oleks juurde tulnud, aga asju katki palju läinud. Lisaks on uimasem box nüüd, äppid avanevad kauem.
sõnum 01.02.2022 13:51:07 vasta tsitaadiga
Ainuke probleem oli Plex serveriga mul, pidi share uuesti ette näitama. Muid probleeme ei tekkinud peale upgrade.
JazZ
sõnum 02.02.2022 18:36:12 vasta tsitaadiga
wirx kirjutas:
Kusjuures jah, enne jäid äpid mällu, kui vahepeal midagi muud kasutasid ja tagasi eelmisse läksid siis tuli hetkega lahti, nüüd laeb peaaegu iga kord äpi nullist käima.
aeropiloot
aeropiloot
sõnum 16.02.2022 20:18:43 vasta tsitaadiga
Shield Experience 9.0.1 on väljas. Kas keegi on peale lasknud?
Kommentaarid: 19 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 18
Fixed
sõnum 16.02.2022 20:35:27 vasta tsitaadiga
aeropiloot kirjutas:
Jah on uuendus peal ja võib hetkel öelda, et minul nüüd lõpuks kõik toimib kenasti.
Vahepeal tänu Android 11 uuendusele oli shield täielikuks peldikuks muutunud aga tore on, et asjad lõpuks laabuvad.
sõnum 16.02.2022 21:40:19 vasta tsitaadiga
Jah, lasin peale. Tundub, et nad panid need 3 hotfixi kokku ja võibolla midagi veel.
Kõik okei, aga mul töötas enne ka juba kõik.
argentum7
argentum7
sõnum 18.02.2022 12:52:18 vasta tsitaadiga
NBA app endiselt ei tööta aga see on nende viga. Nad uuendasid veebruari alguses oma appi aga see pole Shield Experiencega kooskõlas . Natuke vihale ajab, isegi Telia sai oma appi kiiremini korda kui rikas NBA.
Kommentaarid: 102 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 97
S.I.L.L.U
sõnum 21.03.2022 00:52:05 vasta tsitaadiga
Keegi teab miks Telia app töötab ilusti peale installi aga nii kui Shield välja lükata ja tagasi sisse, siis ei lähe Telia app enam käima. Korra viskab logo ette ja siis uuesti viskab algmenüüse.
Kui teha appile uninstall ja uuesti peale lasta ning logida sisse, siis jälle töötab ilusti kuni välja lükata.
Kasutaja36
Kasutaja36
sõnum 27.03.2022 10:40:03 vasta tsitaadiga
Küsiks siin targematelt. Nimelt soov proovida Go3 näitama saada pooltargas Philipsi telekas. Shield oma põhimõttelt sarnane Chromecastile, et Androidi baasil ja saab seadme enda läbi appe kasutada a la Go3 Eesti. Või olen tööpõhimõttest valesti aru saanud. Shieldi kaaluks ehk selle mõttega et äkki tulevikus mängu ka striimida ja lahjemal variandil hinnavahemik väga suur ei ole.
wirx
wirx
sõnum 27.03.2022 11:28:34 vasta tsitaadiga
Go3 töötab kenasti ja AI upscale samuti, ainus miinus on see, et automaatselt ei vali go3 parimat resolutsiooni. Samas ei tee go3 seda ka üheski telekas, kuigi net on 200mbit.
sõnum 12.04.2022 22:18:35 vasta tsitaadiga
Kes ei soovi järgmist suuremat update oodata, uusimad hotfixid saab selle kaudu:
https://docs.google.com/forms/d/e/1FAIpQLSdSt_r0ntNMmK4xqQw9mevgWe4_8v2L-pBkcnhYLdJziB0eKw/viewform?usp=pp_url&entry.1352533101=DONTDELETE-
phpBB [media]
https://forums.plex.tv/t/nvidia-shield-dolby-truehd-playback-is-borked/778375
NVIDIA Shield TV update 9.0.2 rolls out with a ton of bug fixes
https://www.xda-developers.com/nvidia-shield-tv-update-9-0-2-update/
Snaxez
Snaxez
sõnum 21.05.2022 13:04:04 vasta tsitaadiga
Kas see 9.0.2 (33.1.0.319) on hetkel latest? Kopp ees juba sellest, et iga kord restarti peab tegema heli saamiseks.
sõnum 21.05.2022 15:02:40 vasta tsitaadiga
See peaks viimane olema jah.
Maxxxim
sõnum 23.05.2022 13:11:28 vasta tsitaadiga
Snaxez kirjutas:
Developer seadete alt on USB sound välja lülitatud?
Kommentaarid: 105 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 100
uus teema   vasta Hinnavaatlus »  Multimeedia- ja helifoorum »  NVidia Shield arutelu mine lehele eelmine  1, 2, 3 ... 5, 6, 7 ... 12, 13, 14  järgmine
