| Millist versiooni omad? |
| Shield 2015 16GB |
6% |
[ 3 ] |
| Shield Pro 2015 500GB |
0% |
[ 0 ] |
| Shield 2017 16GB |
11% |
[ 5 ] |
| Shield Pro 2017 500GB |
2% |
[ 1 ] |
| Shield 2019 8GB |
4% |
[ 2 ] |
| Shield Pro 2019 16GB |
75% |
[ 34 ] |
| hääli kokku : 45 |
S.I.L.L.U
12.01.2022 22:56:13
| Midagi asjalikku ka uuendusega?
| Kommentaarid: 93 loe/lisa |
87 |
Snaxez
13.01.2022 09:04:56
| S.I.L.L.U kirjutas: |
| Midagi asjalikku ka uuendusega? |
Release Note-ides küll midagi erilist silma ei jäänud. https://www.nvidia.com/en-us/shield/software-update/
SHIELD TV gets upgraded to Android 11. Updates include new privacy features, and a new default keyboard with built-in text to speech capabilities.
Includes Android security patch level September 2021
Adds support for aptX compatible Bluetooth headsets
Adds option to automatically disconnect Bluetooth devices on sleep
Adds option to match content audio resolution (high resolution audio)
Adds new Gboard keyboard option
Adds new Energy saver setting for additional power customization
Adds Stadia button support to XBOX, Playstation, and SHIELD controllers
Additional bug fixes
| Kommentaarid: 58 loe/lisa |
53 |
313 |
Snaxez
15.01.2022 11:29:50
| mul juba esines see "audio may be lost untill shield is rebooted".
53 |
313 |
Fixed
17.01.2022 09:45:23
| Snaxez kirjutas: |
| mul juba esines see "audio may be lost untill shield is rebooted". |
Esines eile täpselt sama probleem. Praegu juba kahetsengi, et nii ruttu selle suure uuenduse tegin kuna üleüldiselt väga halvasti töötab kõik.
Minul siis kasutusel see toru versioon.
| Kommentaarid: 38 loe/lisa |
36 |
Snaxez
17.01.2022 12:56:39
| Fixed kirjutas: |
| Snaxez kirjutas: |
Minul siis kasutusel see toru versioon. |
Ma panin sinna hotfix listi end kirja, ja sain ka paranduse kätte. Pole seda viga enam näinud.
53 |
313 |
Kozlor
01.02.2022 00:07:06
Hotfix #3
Telia TV äpp arvab, et tegemist on tahvliga ja uninstallib Android TV äppi ja lase tahvli äppi peale.
Shieldi forumist sain vastuse:
Resolves mouse click not working
In HotFix 3 is confusing some apps that shield is a touchscreen/tablet device.
Lisaks hotfix 3 peale panekut sain ka perioodilise teleka ja shieldi väljalülituse. Kasutan IR Shieldi ja vanema Samsungi teleka juhtimise jaoks. Peale rebooti on korras. Kui sleebist üles tuleb hakkab nali kohe pihta.
| Kommentaarid: 4 loe/lisa |
Rauno266
01.02.2022 10:42:23
| Paras käkk on see Android 11 upgrade. Nii palju katkisi featuure polegi ammu ühe android uuendusega näinud.
| Kommentaarid: 45 loe/lisa |
41 |
JazZ
01.02.2022 13:16:19
Mul on hakanud pärast seda android 11 uuendust lambist restartima, nii nädalas korra või kaks. Kellelgi veel?
2015 Shield
wirx
01.02.2022 13:37:19
Mul peale uuendamist hakib päris mitmes kohas pilt, Amazon videos korduvalt ühe filmi jooksul ning ka netflixis paar korda täheldanud, enne update oli 0 probleemi. Ei soovita kellelgi updateda, mingeid lisa võimalusi küll ei näe, et oleks juurde tulnud, aga asju katki palju läinud. Lisaks on uimasem box nüüd, äppid avanevad kauem.
| Kommentaarid: 80 loe/lisa |
313 |
JazZ
02.02.2022 18:36:12
| wirx kirjutas: |
| Mul peale uuendamist hakib päris mitmes kohas pilt, Amazon videos korduvalt ühe filmi jooksul ning ka netflixis paar korda täheldanud, enne update oli 0 probleemi. Ei soovita kellelgi updateda, mingeid lisa võimalusi küll ei näe, et oleks juurde tulnud, aga asju katki palju läinud. Lisaks on uimasem box nüüd, äppid avanevad kauem. |
Kusjuures jah, enne jäid äpid mällu, kui vahepeal midagi muud kasutasid ja tagasi eelmisse läksid siis tuli hetkega lahti, nüüd laeb peaaegu iga kord äpi nullist käima.
aeropiloot
16.02.2022 20:18:43
| Shield Experience 9.0.1 on väljas. Kas keegi on peale lasknud?
| Kommentaarid: 19 loe/lisa |
18 |
Fixed
16.02.2022 20:35:27
| aeropiloot kirjutas: |
| Shield Experience 9.0.1 on väljas. Kas keegi on peale lasknud? |
Jah on uuendus peal ja võib hetkel öelda, et minul nüüd lõpuks kõik toimib kenasti.
Vahepeal tänu Android 11 uuendusele oli shield täielikuks peldikuks muutunud aga tore on, et asjad lõpuks laabuvad.
36 |
313 |
argentum7
18.02.2022 12:52:18
| NBA app endiselt ei tööta aga see on nende viga. Nad uuendasid veebruari alguses oma appi aga see pole Shield Experiencega kooskõlas . Natuke vihale ajab, isegi Telia sai oma appi kiiremini korda kui rikas NBA.
97 |
S.I.L.L.U
21.03.2022 00:52:05
Keegi teab miks Telia app töötab ilusti peale installi aga nii kui Shield välja lükata ja tagasi sisse, siis ei lähe Telia app enam käima. Korra viskab logo ette ja siis uuesti viskab algmenüüse.
Kui teha appile uninstall ja uuesti peale lasta ning logida sisse, siis jälle töötab ilusti kuni välja lükata.
87 |
Kasutaja36
27.03.2022 10:40:03
| Küsiks siin targematelt. Nimelt soov proovida Go3 näitama saada pooltargas Philipsi telekas. Shield oma põhimõttelt sarnane Chromecastile, et Androidi baasil ja saab seadme enda läbi appe kasutada a la Go3 Eesti. Või olen tööpõhimõttest valesti aru saanud. Shieldi kaaluks ehk selle mõttega et äkki tulevikus mängu ka striimida ja lahjemal variandil hinnavahemik väga suur ei ole.
wirx
27.03.2022 11:28:34
Go3 töötab kenasti ja AI upscale samuti, ainus miinus on see, et automaatselt ei vali go3 parimat resolutsiooni. Samas ei tee go3 seda ka üheski telekas, kuigi net on 200mbit.
12.04.2022 22:18:35
Kes ei soovi järgmist suuremat update oodata, uusimad hotfixid saab selle kaudu:
https://docs.google.com/forms/d/e/1FAIpQLSdSt_r0ntNMmK4xqQw9mevgWe4_8v2L-pBkcnhYLdJziB0eKw/viewform?usp=pp_url&entry.1352533101=DONTDELETE-
The first 9.0.1+ HotFix image was deployed on 2/16/2022 based on the 9.0.1 public image and contains the following fixes:
First HotFix (33.1.0.291 deployed 2/16/2022) :
Resolves Paragon files system crash/hang while using external hard drives with NTFS/exfat format
Fixes a cec issue where shield won’t go to sleep
Resolves issue where adopted storage starts migrating but doesn't always complete
Resolves issue with mouse click not working
Resolves issue where Samba Mac client getting error when copying file to USB Hard-Drive
Resolves issue where Playback status shows up on home screen even after exiting an app
Resolves issue of framework restart while enabling Dolby Vision on Phillips TV
Second Hotfix (33.1.0.301 deployed on 3/2/2022):
Resolves Wifi disconnects on a subset mesh/band steering network setups with wifi roaming enabled
Improves file transfer performance
Resolves delayed mounting of external drives
Resolves issue with Files app not always showing all files
Resolves drive speed test when adopting a storage drive always reports drive too slow
Resolves issue when Kodi is running in the background, refresh rate changes on apps in the foreground
Resolves popping audio when playing back over BT headphones while Dolby Processing is enabled
Resolves Xbox360 controller dpad registers double input in some apps
Resolves NVIDIA Share fails with message "Android database insertion failure" when external storage is connected
Resolves Dolphin Emulator can see the content on NAS, but failed to write to NAS
Resolves Atresplayer Spanish TV app crashes
Adds ability to open data and obb folders of USB drive attached to SHIELD from windows
Third Hotfix (33.1.0.319 deployed on 3/25/2022):
Resolves issue pairing Dual Shock 3, XBOX, and Switch controllers
Resolves bug where video colors would be displayed incorrectly when HW acceleration is enabled (1080 dvd rips with 709 color not advertising their color space were interpreted as 601. You can now change the default to 709 in developer options)
Fixes bug affecting streaming to Twitch (Nvidia Share)
Adds helpful notifications when connecting or formatting removable storage
Fixes bug where system would hang when access home screen after matching frame rate in Kodi
Fixes bug where surround upmixer would stop working after playing Dolby audio streams
Adds Plex support for latest Hauppauge WinTV-dualHD DVB-T tuner (EU only)
Fixes bug where AI upscaling could not be changed in Netflix app
Resolves issue where Documents UI cannot access external storage folders
Resolves issue where SD card notification would be displayed when launching apps
Resolves issue when capturing screenshots in GeForce NOW using NVIDIA Share
Resolves crash issue with Google Play Games on 2015/2017 SHIELDs.
Resolves localization issue with Canadian Language selection of energy start timers
Resolves audio issues when connecting headset to 2015 SHIELD Controller |
Plex katki tehtud Shieldi peal
https://forums.plex.tv/t/nvidia-shield-dolby-truehd-playback-is-borked/778375
NVIDIA Shield TV update 9.0.2 rolls out with a ton of bug fixes
https://www.xda-developers.com/nvidia-shield-tv-update-9-0-2-update/
_________________ Müüa: Xbox 360 S 4GB (UUS)
Müüa: Xbox 360 S 250GB (UUS) |
313 |
Snaxez
21.05.2022 13:04:04
| Kas see 9.0.2 (33.1.0.319) on hetkel latest? Kopp ees juba sellest, et iga kord restarti peab tegema heli saamiseks.
53 |
313 |
Maxxxim
23.05.2022 13:11:28
| Snaxez kirjutas: |
| Kas see 9.0.2 (33.1.0.319) on hetkel latest? Kopp ees juba sellest, et iga kord restarti peab tegema heli saamiseks. |
Developer seadete alt on USB sound välja lülitatud?
| Kommentaarid: 97 loe/lisa |
94 |
