mine lehele eelmine  1, 2, 3 ... 283, 284, 285 ... 405, 406, 407  järgmine
Alla 1 aasta
11%
 11%  [ 49 ]
1-3 aastat
31%
 31%  [ 141 ]
4-6 aastat
25%
 25%  [ 113 ]
7-10 aastat
18%
 18%  [ 82 ]
11-13 aastat
7%
 7%  [ 33 ]
14-16 aastat
3%
 3%  [ 14 ]
17-20 aastat
0%
 0%  [ 4 ]
Üle 20 aasta
1%
 1%  [ 5 ]
hääli kokku : 441
sõnum 30.12.2020 15:53:31 vasta tsitaadiga
FYI: See jublakas pidavat LG-dele sobima: https://www.amazon.ca/gp/aw/d/B00BBD7NFU
I've been the happy owner of a 65" LG OLED B7 TV for 3 years, but the one caveat that has always stuck in my craw has been LG's use of a 100base-T fast ethernet interface on the set. For the majority of use cases, this likely suffices, however if you want to direct play high bitrate 4K HDR remuxes over the LG Plex app, it's a bit of a showstopper. I'm happy to say I've finally solved the problem—without having to compromise (either downloading lower bitrate files, or purchasing an android box or Shield or something)—and have my OLED B7 connected to my home network at gigabit speeds. I purchased a cheap ($20 CAD) Cable Matters USB3 to Gig Ethernet Adaptor, plugged it in the USB3 port on the back of the LG, and switched my ethernet cable from the built-in RJ45 to the adapter. When powering up the TV, it reports no wired network connection, and no wifi connection (I have it turned off), however the set does have a network connection, and shows green on my switch, indicating a gigabit connection. When playing back high bitrate remuxes, my plex dashboard on my server shows spikes up to 248 mbps to the LG B7, and buffering pauses are nonexistent now. See in the comments below for pics.
Müüa: Xbox 360 S 250GB (UUS)
m2ka
sõnum 30.12.2020 17:21:33 vasta tsitaadiga
SKG kirjutas:
Endal samamoodi adapter kasutusel ja toimib normaalselt:
https://www.tp-link.com/us/home-networking/usb-converter/ue300/
Kommentaarid: 55 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 52
anubis
anubis
sõnum 30.12.2020 17:27:34 vasta tsitaadiga
Hea. Mul C6, proovin ära.
Kommentaarid: 336 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 283
kedambarai
kedambarai
sõnum 30.12.2020 23:51:48 vasta tsitaadiga
andreL kirjutas:
tofay kirjutas:
Miks windowsi enda cast ei sobi? Ehk faili peal paremklikk ja cast to device-teler. Edasi muidugi majandab teler, milliseid koodekeid toetab jne. Subtiitrid eelnevalt lisada video konteinerisse MKVToolNix abil.
Ma ei saa ka aru, miks on vaja asju nii keeruliselt ajada...
Native WiDi võiks siiski töötada, kui ei, siis mingi Win 10 draiverikala.
k.
sõnum 31.12.2020 09:18:34 vasta tsitaadiga
Suure tõenäosusega maale läheb järgmine aasta uus telekas loosi, sellest LG 86" võiks mingi 4k versioon ka tulla. 8k pole küll vaja, lisaks premium maks juures selle mõttetu 8k pärast.
Kui keegi annaks piiramatu 5G või optilise kaabli, siis veel teoreeriliselt kasu, kuigi vaevalt icon_lol.gif
NATAS999
sõnum 31.12.2020 09:32:29 vasta tsitaadiga
jeesus188 kirjutas:
8k materjali pole saada minu teada kuskilt veel. või on siis juba?
cabbage
cabbage
sõnum 31.12.2020 10:24:07 vasta tsitaadiga
Eile õhtul jamasin selle WIDIga ja täielik porr ikka. Bahepeal sain käima, siis oli black screen (samsung teler).
Tõmbasin plex - kõik timm 5 minutiga ja senini probleemivaba kasutus. Kvaliteet mäe jagu üle sellest, kui sain widiga korraks tööle filmi. Arvasin, et see töötab vaid eraldi filmiserverile aga täitsa vabalt saad arvutist streamida ning samal ajal ise edasi geimida kui elukaaslane tahab midagi vaadata. Soovitus thumbs_up.gif
sõnum 31.12.2020 10:24:38 vasta tsitaadiga
NATAS999 kirjutas:
jeesus188 kirjutas:
Mingid demosi vast leiab, aga suures plaanis neid pole ja ei tule niipea. Mõttetu värk, pixlid odavad, sp topivad neid ja küsivad extra raha
infect
infect
sõnum 31.12.2020 11:09:14 vasta tsitaadiga
cabbage kirjutas:
Enda lokaalne Plex on tõesti mega hea asi ikka. Eriti hea, kui ühel sõbral on oma server ja sul sinna ka ühendatud icon_biggrin.gif !
tomPärnu
sõnum 31.12.2020 11:20:00 vasta tsitaadiga
Tere. On siis plaanis uus telekas endale soetada, kuna telekaid niipalju siis mõtlesin et uurin targematekäest. Telekas võiks olla 65 tolli ja kunagi plaanis ps5 ka soetada siis peaks telekas üle 100hz olema ?
https://pood.telia.ee/telerid/65--QLED-teler-Samsung-Q77T/QE65Q77TATXXH endale jäi selline asi silma ( just teliast tänu 0% intressi järelmaksu pärast ) aga küsimus selline et kui suur nende hzide vahe on... näiteks 60 või 100. Kui neid hz-e ei vaataks siis saaks teleka pmts. Poole soodsamalt.
anubis
anubis
sõnum 31.12.2020 11:29:52 vasta tsitaadiga
Poole soodsamalt saad sa ka palju kehvema paneeli.
Anna tooli
sõnum 01.01.2021 20:54:12 vasta tsitaadiga
Samsung's 2021 TVs to feature HDR10+ Adaptive
https://www.flatpanelshd.com/news.php?subaction=showfull&id=1609403955
Kommentaarid: 363 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 299
sõnum 02.01.2021 06:49:20 vasta tsitaadiga
Vastu seina jooksevad sellega
piraat262
piraat262
sõnum 02.01.2021 06:54:21 vasta tsitaadiga
Pole ükski dünaamiliselt muutuv väärtus ühelgi teleril pilti paremaks teinud, mille poolest see funktsioon erinev peaks olema? Scene-by-scene kõlab juba hirmsalt.
Kommentaarid: 72 loe/lisa Kasutajad arvavad:  :: 1 :: 3 :: 66
somnambuul
sõnum 02.01.2021 09:00:59 vasta tsitaadiga
piraat262 kirjutas:
Dolby Vision nii ju töötabki. Üritavad oma versiooni teha.
sõnum 02.01.2021 16:01:20 vasta tsitaadiga
Vasak kolmandik backlightist on nüüd kutu. Garantii lõpes kuu tagasi minu teada.
Mida veel proovida, enne kui uus teler osta?
raxz
sõnum 02.01.2021 16:04:00 vasta tsitaadiga
sõnum 02.01.2021 16:07:57 vasta tsitaadiga
raxz kirjutas:
Nagu näed mänguasjadest, mul käib seal teleri ees iga päev raju mäng. Lähiajal ei hakka küll miskit hinnalist ostma. Oleks elu liiga stressav icon_lol.gif
sõnum 02.01.2021 16:56:31 vasta tsitaadiga
Võid ise vahetada kui oskad ..iseasi kas on mõtet
von Wu
von Wu
sõnum 02.01.2021 17:18:16 vasta tsitaadiga
Odavalt kasutatud teler osta on vast mõttekam. Eriti kui pidev lõhkumisoht on.
Osta auto ära
Kommentaarid: 890 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 669
sõnum 02.01.2021 17:39:07 vasta tsitaadiga
jeesus188 kirjutas:
pois11
sõnum 02.01.2021 17:54:05 vasta tsitaadiga
Kui remondiks läks siis kas keegi eestis sellist asja teeks?
https://www.facebook.com/media/set/?vanity=Reparatii.display.LCD&set=a.2615488375375882
Mul on täpselt sama telekas sama veaga. Võtsin korra kaane maha ja proovisin survestada ühest ja teisest otsast aga ei midagi. Tundub, et kaabel ise on defektne. Huvitav on muidugi see, et viga esineb külmast peast. Kui sirka 30min. mängib siis kaob ära.
sõnum 02.01.2021 18:05:36 vasta tsitaadiga
SKG kirjutas:
jeesus188 kirjutas:
Enamjaolt ikka taustavalguses olnud, siis nii mõnigi neid vahetanud....sama hea tulemus ei tule, aga tööle saanud.
Olenevalt teleka vanusest, juppide hinnast+ tarnest jne....pead ise vaatama kas mõtet jamada. Suvaline samas mõõdus telekas pole kallis
sõnum 02.01.2021 20:28:16 vasta tsitaadiga
jeesus188 kirjutas:
SKG kirjutas:
jeesus188 kirjutas:
Mnjah, hetkel tundub parim variant praegune vigasena maha müüa ja uus osta, millel pikem garantii.
Uued LG telerid DTS, DTS-HD MA heliga midagi teha oskavad? Passthrough läbi optilise toimib?
tofay
sõnum 02.01.2021 20:55:51 vasta tsitaadiga
Ei oska ja üle optilise kadudeta mitmekanaline nkn läbi ei mahu.
Kommentaarid: 12 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 10
uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  Telerite üldteema vol. 2 (Küsitlus: Kui vana on sinu igapäevaselt enimkasutatav teler?) mine lehele eelmine  1, 2, 3 ... 283, 284, 285 ... 405, 406, 407  järgmine
