| Kui vana on sinu igapäevaselt enimkasutatav teler? |
| Alla 1 aasta |
11% |
[ 50 ] |
| 1-3 aastat |
31% |
[ 141 ] |
| 4-6 aastat |
25% |
[ 114 ] |
| 7-10 aastat |
18% |
[ 83 ] |
| 11-13 aastat |
7% |
[ 33 ] |
| 14-16 aastat |
3% |
[ 15 ] |
| 17-20 aastat |
0% |
[ 4 ] |
| Üle 20 aasta |
1% |
[ 5 ] |
| hääli kokku : 445 |
30.12.2020 16:53:31
FYI: See jublakas pidavat LG-dele sobima: https://www.amazon.ca/gp/aw/d/B00BBD7NFU
| I've been the happy owner of a 65" LG OLED B7 TV for 3 years, but the one caveat that has always stuck in my craw has been LG's use of a 100base-T fast ethernet interface on the set. For the majority of use cases, this likely suffices, however if you want to direct play high bitrate 4K HDR remuxes over the LG Plex app, it's a bit of a showstopper. I'm happy to say I've finally solved the problem—without having to compromise (either downloading lower bitrate files, or purchasing an android box or Shield or something)—and have my OLED B7 connected to my home network at gigabit speeds. I purchased a cheap ($20 CAD) Cable Matters USB3 to Gig Ethernet Adaptor, plugged it in the USB3 port on the back of the LG, and switched my ethernet cable from the built-in RJ45 to the adapter. When powering up the TV, it reports no wired network connection, and no wifi connection (I have it turned off), however the set does have a network connection, and shows green on my switch, indicating a gigabit connection. When playing back high bitrate remuxes, my plex dashboard on my server shows spikes up to 248 mbps to the LG B7, and buffering pauses are nonexistent now. See in the comments below for pics. |
313 |
m2ka
30.12.2020 18:21:33
| SKG kirjutas: |
Endal samamoodi adapter kasutusel ja toimib normaalselt:
https://www.tp-link.com/us/home-networking/usb-converter/ue300/
| Kommentaarid: 56 loe/lisa |
53 |
anubis
30.12.2020 18:27:34
| Hea. Mul C6, proovin ära.
283 |
kedambarai
31.12.2020 00:51:48
| andreL kirjutas: |
| tofay kirjutas: |
| Miks windowsi enda cast ei sobi? Ehk faili peal paremklikk ja cast to device-teler. Edasi muidugi majandab teler, milliseid koodekeid toetab jne. Subtiitrid eelnevalt lisada video konteinerisse MKVToolNix abil. |
Ma ei saa ka aru, miks on vaja asju nii keeruliselt ajada... |
Native WiDi võiks siiski töötada, kui ei, siis mingi Win 10 draiverikala.
_________________ k. |
| Kommentaarid: 7 loe/lisa |
31.12.2020 10:18:34
Suure tõenäosusega maale läheb järgmine aasta uus telekas loosi, sellest LG 86" võiks mingi 4k versioon ka tulla. 8k pole küll vaja, lisaks premium maks juures selle mõttetu 8k pärast.
Kui keegi annaks piiramatu 5G või optilise kaabli, siis veel teoreeriliselt kasu, kuigi vaevalt
NATAS999
31.12.2020 10:32:29
| jeesus188 kirjutas: |
Kui keegi annaks piiramatu 5G või optilise kaabli, siis veel teoreeriliselt kasu, kuigi vaevalt  |
8k materjali pole saada minu teada kuskilt veel. või on siis juba?
| Kommentaarid: 41 loe/lisa |
39 |
cabbage
31.12.2020 11:24:07
Eile õhtul jamasin selle WIDIga ja täielik porr ikka. Bahepeal sain käima, siis oli black screen (samsung teler).
Tõmbasin plex - kõik timm 5 minutiga ja senini probleemivaba kasutus. Kvaliteet mäe jagu üle sellest, kui sain widiga korraks tööle filmi. Arvasin, et see töötab vaid eraldi filmiserverile aga täitsa vabalt saad arvutist streamida ning samal ajal ise edasi geimida kui elukaaslane tahab midagi vaadata. Soovitus
| Kommentaarid: 42 loe/lisa |
40 |
31.12.2020 11:24:38
| NATAS999 kirjutas: |
8k materjali pole saada minu teada kuskilt veel. või on siis juba? |
Mingid demosi vast leiab, aga suures plaanis neid pole ja ei tule niipea. Mõttetu värk, pixlid odavad, sp topivad neid ja küsivad extra raha
infect
31.12.2020 12:09:14
| cabbage kirjutas: |
Tõmbasin plex - kõik timm 5 minutiga ja senini probleemivaba kasutus. Kvaliteet mäe jagu üle sellest, kui sain widiga korraks tööle filmi. Arvasin, et see töötab vaid eraldi filmiserverile aga täitsa vabalt saad arvutist streamida ning samal ajal ise edasi geimida kui elukaaslane tahab midagi vaadata. Soovitus  |
Enda lokaalne Plex on tõesti mega hea asi ikka. Eriti hea, kui ühel sõbral on oma server ja sul sinna ka ühendatud !
| Kommentaarid: 25 loe/lisa |
25 |
tomPärnu
31.12.2020 12:20:00
Tere. On siis plaanis uus telekas endale soetada, kuna telekaid niipalju siis mõtlesin et uurin targematekäest. Telekas võiks olla 65 tolli ja kunagi plaanis ps5 ka soetada siis peaks telekas üle 100hz olema ?
https://pood.telia.ee/telerid/65--QLED-teler-Samsung-Q77T/QE65Q77TATXXH endale jäi selline asi silma ( just teliast tänu 0% intressi järelmaksu pärast ) aga küsimus selline et kui suur nende hzide vahe on... näiteks 60 või 100. Kui neid hz-e ei vaataks siis saaks teleka pmts. Poole soodsamalt.
anubis
31.12.2020 12:29:52
| Poole soodsamalt saad sa ka palju kehvema paneeli.
283 |
Anna tooli
300 |
02.01.2021 07:49:20
Vastu seina jooksevad sellega
piraat262
02.01.2021 07:54:21
| Pole ükski dünaamiliselt muutuv väärtus ühelgi teleril pilti paremaks teinud, mille poolest see funktsioon erinev peaks olema? Scene-by-scene kõlab juba hirmsalt.
| Kommentaarid: 74 loe/lisa |
68 |
somnambuul
02.01.2021 10:00:59
| piraat262 kirjutas: |
| Pole ükski dünaamiliselt muutuv väärtus ühelgi teleril pilti paremaks teinud, mille poolest see funktsioon erinev peaks olema? Scene-by-scene kõlab juba hirmsalt. |
Dolby Vision nii ju töötabki. Üritavad oma versiooni teha.
| Kommentaarid: 60 loe/lisa |
54 |
02.01.2021 17:01:20
Vasak kolmandik backlightist on nüüd kutu. Garantii lõpes kuu tagasi minu teada.
Mida veel proovida, enne kui uus teler osta?
313 |
raxz
02.01.2021 17:04:00
Osta normaalne teler, mitte lihtsalt uus!
| Kommentaarid: 46 loe/lisa |
45 |
02.01.2021 17:07:57
| raxz kirjutas: |
Osta normaalne teler, mitte lihtsalt uus!  |
Nagu näed mänguasjadest, mul käib seal teleri ees iga päev raju mäng. Lähiajal ei hakka küll miskit hinnalist ostma. Oleks elu liiga stressav
313 |
02.01.2021 17:56:31
Võid ise vahetada kui oskad ..iseasi kas on mõtet
von Wu
02.01.2021 18:18:16
Odavalt kasutatud teler osta on vast mõttekam. Eriti kui pidev lõhkumisoht on.
| Kommentaarid: 897 loe/lisa |
673 |
02.01.2021 18:39:07
| Võid ise vahetada kui oskad ..iseasi kas on mõtet |
Vahetada taustavalgus või on probleem skeemis?
313 |
pois11
109 |
02.01.2021 19:05:36
| SKG kirjutas: |
Vahetada taustavalgus või on probleem skeemis?  |
Enamjaolt ikka taustavalguses olnud, siis nii mõnigi neid vahetanud....sama hea tulemus ei tule, aga tööle saanud.
Olenevalt teleka vanusest, juppide hinnast+ tarnest jne....pead ise vaatama kas mõtet jamada. Suvaline samas mõõdus telekas pole kallis
02.01.2021 21:28:16
| SKG kirjutas: |
Olenevalt teleka vanusest, juppide hinnast+ tarnest jne....pead ise vaatama kas mõtet jamada. Suvaline samas mõõdus telekas pole kallis |
Mnjah, hetkel tundub parim variant praegune vigasena maha müüa ja uus osta, millel pikem garantii.
Uued LG telerid DTS, DTS-HD MA heliga midagi teha oskavad? Passthrough läbi optilise toimib?
Specis ainult Dolby tugi mainitud
313 |
tofay
02.01.2021 21:55:51
| Ei oska ja üle optilise kadudeta mitmekanaline nkn läbi ei mahu.
| Kommentaarid: 12 loe/lisa |
10 |
