XeStAiSy
Aeg Maha 2a
30.09.2020 09:02:59
Siis kui kellad alla tõmmati siis tõesti vahet pole milliste capidega kaardi saad ei ole vist mõtet palju peale maksta mõne fps pärast. Neli aastat on ikkagi max mis kasutad, kui vahepel mingi uus rakett on müügile tulnud ja enamus tootjaid pakuvad garantiid 4+ Selle 3080 saad rahumeelil skippida mõned põlvkonnad kui jääd sinna 1080p kanti.
_________________ Punktkeevitus patareidele/akudele. Akutrelli/laptopi/e-bike. PM
viimati muutis XeStAiSy 30.09.2020 09:06:12, muudetud 1 kord |
| Kommentaarid: 12 loe/lisa |
bang1bang
30.09.2020 09:18:00
1-3p....vale
alates 1050....vale
bang1bang
m8markus
30.09.2020 10:05:03
| freestyler kirjutas: |
| Stabby kirjutas: |
| heretic666 kirjutas: |
https://www.guru3d.com/news-story/gigabyte-releases-statement-regarding-the-sp-cap-and-mlcc-capacitor-on-geforce-rtx-3080-graphics-cards.html
It is false that POSCAP capacitors independently could cause a hardware crash. Whether a graphics card is stable or not requires a comprehensive evaluation of the overall circuit and power delivery design, not just the difference in capacitor types. POSCAPs and MLCCs have different characteristics and uses, thus it is not true to assert that one capacitor type is better than the other.
The GIGABYTE GeForce RTX 30 graphics cards are designed in accordance with NVIDIA specifications and have passed all required testing, thus the product quality is guaranteed. GIGABYTE GeForce RTX 3080 GAMING OC and EAGLE OC series graphics cards use high-quality, low-ESR 470uF SP-CAP capacitors, which meet the specifications set by NVIDIA and provide a total capacity of 2820u in terms of GPU core power, higher than the industry’s average. The cost of SP-CAP capacitors is not lower than that of MLCCs. GIGABYTE values product integrity highly and definitely does not reduce costs by using cheap materials. |
ilmselt see driverite taha jäi seekord jah |
minu arust on viga siiski riistvaras. uute driveritega tõmmati lihtsalt kellad allapoole, et kaart ei kellaks end üle kriitilise piiri. |
Midagi seal allapoole ei tõmmatud, nagu oli vanadega 1980 max mida näen 3090-ga ja täpselt sama oli uutega, minul ei muutunud midagi nende draiveritega
| Kommentaarid: 44 loe/lisa |
40 |
freestyler
30.09.2020 10:37:33
| 1980 pole ka kriitiline, nii et sul ei peagi midagi muutuma.
heretic666
30.09.2020 10:50:54
| Kellel siis peab?
| Kommentaarid: 73 loe/lisa |
XeStAiSy
Aeg Maha 2a
m8markus
30.09.2020 12:29:42
| AMD toetab juba PCIe 4.0, ammu räägitud seda siin...
40 |
heretic666
30.09.2020 12:35:23
Ma arvan et Margus ise ka teab seda ja pidas silmas et 9900K @ gen 3.0 vs AMD 3900XT @ gen 4.0 vahe olematu kui arvestada ainult pcie versiooni.
Gamingu jõudluselt sõidab Intel AMDst (veel) ette hoolimata pci-e 3.0 genist.
XeStAiSy
Aeg Maha 2a
30.09.2020 12:37:52
| m8markus kirjutas: |
| AMD toetab juba PCIe 4.0, ammu räägitud seda siin... |
Sa mõtled ,et ma ei tea. Mina võrdlen PCI-E v3.0 tulemusi vs v4.0. Samuti võrdlen erinevaid CPUsid mis lähiajal olnud.
m8markus
30.09.2020 12:43:58
| Inteli PCIe 4.0 toega prose pidi järgmine aasta tulema, 4 aastast vist päris ootama ei pea
40 |
erick
30.09.2020 12:44:09
| Scart kirjutas: |
| Tomorrow kirjutas: |
Stabiilsus? Aga Nvidia draiverid pidid ju olema NII head võrreldes AMD crapiga  |
Tuttuue kaardiseeria esimene real driver parandab beeta-driverite probleemid. Ülejäänud uudised lapsemeelsetele kell 11. Ma saan aru, et AMDi poisid on harjunud, et nende 5700XT ei tööta esimesed viis kuud peale ostmist, aga mõned meist on natuke parema teenusega harjunud. |
Üldiselt ma ennast ei sega sellistesse asjadesse, aga seltsimehel on point. Kui sõbrale sai RX 5700 XT PCsse pandud, siis sai loetud küll neid redditi threade. Ei mäleta, millal Nvidia viimati nii bugiste driveritega asja välja lasi. Võibolla FX 5000-seeria 2003? Las poisid töötavad oma driverite kallal paar versiooni, enne kui hakkame siin tõrva peale valama.
96 |
sacher
30.09.2020 13:20:47
| Inteli PCIe 4.0 toega prose pidi järgmine aasta tulema, 4 aastast vist päris ootama ei pea |
Linus sai mingi early sampli Inteli läpakast, mida oma peakanalis puudutas ning sellel oli PCIe 4.0 olemas.
_________________ no shit sherlock |
| Kommentaarid: 29 loe/lisa |
29 |
m8markus
30.09.2020 13:37:11
| emadel on olemas, prosed ei toeta veel intelil
40 |
RustyZ
30.09.2020 13:50:26
| jeesus188 kirjutas: |
1-3p....vale
alates 1050....vale
ärge uskuge seda infot. Helistasin neile ja küsisin, et kas tõesti saabub 2. oktoober TUF kaarte.
Vastus on selline, et tuleks 2. oktoobril ikkagi uuesti kontrollida. Et neile on küll maaletooja juures broneeritud mingid kaardid aga reaalselt selgub 2.okt.
Seega julged tellivad... või teadjamad lisavad nüüd siia, et kui nad ütlevad et neil broneeritud siis mis see realnõi tähendab.
_________________ Wreckfest 2 server: 136.243.70.252:30102 | parool: isamaa (kui on enabled) |
| Kommentaarid: 16 loe/lisa |
Zonerman
30.09.2020 14:17:59
Täna Caseking uuendas oma hindasid. Nüüd on tavaline TUF juba 850.- ja OC 900.- praktiliselt. Tänan ei, mina lükkan oma ostu uude aastasse või kui AMD üllatab. Pigem uuendan CPU sügisel.
Nvidia võib oma olematu saadavusega ja vahendajate suure ahnusega kuu peale sõita.
Nvidia redditis TUF tellijad kes tellisid 17. sept pole saanud ka kinnitust kuna nad kätte saavad. Osadele on öeldud millalgi novembris ehk ja osadel pole mingit aega öeldud
| Kommentaarid: 68 loe/lisa |
67 |
majooro
30.09.2020 14:19:07
| Zonerman kirjutas: |
Nvidia võib oma olematu saadavusega ja vahendajate suure ahnusega kuu peale sõita |
+1. NVIDIA launchiski spekulantidele need kaardid
| Kommentaarid: 30 loe/lisa |
29 |
Nipi1000
30.09.2020 14:22:39
| RustyZ kirjutas: |
Seega julged tellivad... või teadjamad lisavad nüüd siia, et kui nad ütlevad et neil broneeritud siis mis see realnõi tähendab. |
puhas reklaam lihtsalt poele, antud tooteid ei ole võimalik ei tellida ega broneerida(puudub võimalus ostukorvi lisada)...2. okt võid ju seda lehekülge neil refreshida, lootuses et õnnestub mõni saada, aga sügavalt kahtlen
...või kui kõik helistama ja uurima hakkavad, siis ehk eemaldavad need kuniks reaalselt midagi saada
| Kommentaarid: 21 loe/lisa |
20 |
Zonerman
67 |
majooro
30.09.2020 14:40:35
| majooro kirjutas: |
+1. NVIDIA launchiski spekulantidele need kaardid  |
Asi on nii karm, et ma tegin Nvidia reddit teema, kuhu hüppas keegi mulle kohe peale kui ma mainisin hindasid ja 0 saadavust. Moderaatorid eemaldasid minu teema
Ärge jumala eest kiruge seal sellel teemal. |
Ilmselt võis põhjus olla ka selles, et soovitakse hoida sellekohast arutlust 3080 & 3090 Launch Thread'is.
https://www.reddit.com/r/nvidia/comments/j1l4bg/rtx_3080_3090_launch_thread_part_4/
See on ikka megaLOL
https://buyrtx3080.com/index.html
29 |
Arx07
30.09.2020 14:41:55
Zonerman, eks seal toodetakse sitta ka korralikult ja kui neid mõttetuid teemasid ära ei kustutaks keegi siis seal jääbki kammima kuni midagi asjalikku üldse leiab. Iga 10 minti tagant keegi postitab pildi ka enda RTX-st...
Aga eks reddit muidu üldiselt ka tundlik koht, ma sain perma bänni seal selle eest, et ühe pildi kohta ütlesin "like a fag".
heretic666
Mugman
30.09.2020 15:06:02
... a miks nad lubatust niipalju hindasi tõstavad Tahavad nõudlust vähemaks kruttida või?
| Kommentaarid: 65 loe/lisa |
61 |
Arx07
30.09.2020 15:08:40
Mugman, raha tahavad - nagunii ostetakse ära.
Ausad müüjad müüvad ikka õige hinnaga, ooteaeg nendel küll eriti pikk (näiteks Jimms.fi)
wirx
30.09.2020 15:38:51
Tootja tahab, mitte jaemüügi pood. Kui Jimmil õnnestus saada vana hinnaga, siis ehk saab odavalt sealt, kui mitte tõuseb ka nende hind, niipea kui kaardid kohal ja eeltellilused tühistatakse ära.
| Kommentaarid: 80 loe/lisa |
Arx07
30.09.2020 15:46:53
wirx, teine partii TUFe läks neil ikka sama hinnaga ja võetakse ka uusi tellimusi vastu sama hinnaga.
Strixide kohta Asus ütles, et pole nii ulme järjekord ja novembris hetkeseisuga hiljemalt kõik praegu eeltellitud asjad tarnitud. TUFe küll ilmselt tellitakse kõvasti rohkem.
EDIT: okei seda ütles mingi eBuyer, mitte Asus:
wirx
30.09.2020 18:41:02
No peale tootjat tuleb veel, regiooni juht, siis hulgiladu ja siis lõpuks veel pood ise ka. Kõikidel krabisevat vaja. Kui 1000-ga ostetakse ära hetkega, miks peakski keegi 700ga sama asja müüma. Sinnani, kuni turul pole piisavalt videokaarte ei müüda neid ka tootja "soovitusliku" hinnaga, kellele ei meeldi kapitalistid, siis idanaabritest pakuvad nii Vene, Hiina, kui ka Põhja-Korea alternatiivseid variante
majooro
30.09.2020 20:04:58
wirx, jääb mulje, et sa õigustad sellist spekuleerimist Igasugune tänuväärne töö vajab ka õiglast tasu. Millist tänuväärset tööd teeb spekulant? Ta ju põhimõtteliselt parasiteerib tegelike tööinimeste (insenerid, projekteerijad, tootejuhid, robotite operaatorid jne...) tulemusliku töö viljadel. Need on inimesed, tänu kellele sünnivad sellised tooted, mis toovad inimestele ühel või teisel moel kasu. Mis kasu on inimkonnal parasiteerivatest spekulantidest? Sellistelt tuleks ära võtta kõik, mis nad kokku on riisunud ja ühiskondlikule tööle saata.
29 |
Kristoferr
30.09.2020 20:24:43
majooro, Tagasi sotsialismi ja elu lill.
| Kommentaarid: 267 loe/lisa |
218 |
Viilutaja
| Kommentaarid: 226 loe/lisa |
196 |
heinzv
majooro
30.09.2020 20:47:30
Kristoferr, kas kapitalism välistab õiglase äri? On ju olemas ärikoodeks ehk -eetika. Hinna kujunemine on ju põhitõde. See koosneb toote omahinnast, transpordikuludest, töötajate töötasudest ja siis jääb ettevõtte kasumimarginaal. Kõik need elemendid on alati eelnevalt paika pandud. Egas meil pole tegemist ühepäeva ettevõtetega. Sinna alla võib siis juba skalperid liigitada.
See saadavuse jutt on viimase aja liigkasuvõtjate bullshit. Siin pole tegemist haruldaste muldmetallidega, mida vajatakse täppisteaduslike seadmete ehituseks või termotuumadünaamilisteks reaktsioonideks ja järjekordse õnnetuse tagajärjel vajus kaevandus kokku. Tegemist on tarbekaubaga, millele ahned sulid keeravad täiesti õigustamatult hindasid otsa. Kas kellegi kulud on kuskil suurenenud? Võib-olla on tööjõudu juurde värvatud? Mis on eetiline põhjus selliseks hinnatõusuks?
Või oleme jõudnud kapitalismi sellesse faasi, kus ei ärieetika ega üldse inimlikud väärtused enam midagi ei loe, kus üks inimene õgib teist inimest? Sellisel juhul on selle kapitalismi aeg tõesti oma aja ära elanud. Kindlasti pole aga vaja tagasi minna sotsialismi, vaid arenenud ühiskonnal on aeg vajaduspõhisele tootmisele üle minna ning vaadata üle iga ühiskonnaliikme panus inimkonna üldisesse arengusse ja heaollu, mitte iga indiviidi isiklikku heaollu.
29 |
wirx
30.09.2020 21:11:10
Paluks linki ülemaailmsele ärikoodeksile...meenub üks piraatide film sellise jutu peale. Mine mõnest bensukast läbi ja mõtle oma jutu peale sügavalt;)
majooro
29 |
wirx
30.09.2020 21:44:02
Kaugemale, kui Volkswageni mainimine ei jõudnud(kuidas tõmbas kõikidele diisli klientidele koti pähe üle maailma) ja mis kasu sellest on, et Eestis mingi seltskond on ajaviiteks sellise jutu kirja pannud, kui Leedu hulgiladu tõstab hinda ning Saksa kodanikust Euroopa toote juht tõstab hinda ning Aasias asuv tootja tõstab hinda. Oleks veel riigikogu seda kinnitanud, võiks ju keelustada sellised firmad, firma omanikelt firmad ära võtta, nemad ja nende pered kuhugile, no näiteks kasvõi siberisse saata ja siis alles jäänud firma ustavatele mitte kapitalistede vahel ära jagada.
Kütusemafia hind on kõik lihtsalt üks suur kasumi mull ja kohe päris kindlasti on kütust rohkem vaja, kui uut ja kiiret videokaarti.
Tegelt paistab, et sul pole maailmast suurt aimu ja see on ikka totaalne OT siinses teemas, kustutage palun keegi ära, see vestlus.
Viilutaja: Niipalju, kui mina teste tegin 3080 siis küll ei täheldanud vanade ja uute driverite vahel mitte mingit kiiruse vahet. Võibolla oli 0.1% aga see tuleb niiehknaa sisse ka siis, kui samade driveritega mitu korda järjest teha sama testi. 3090 pole samuti ühtegi korda kokku jooksnud, vanu drivereid pole proovinud ja ei näe vanadel mõtet ka.
30.09.2020 21:46:56
ma saan aru, et vahede visualiseerimiseks vaja aga holy crappy graphs.
vahe numbrites on 1.2% (1% low) ja 0.83% (avg). frametime variance on 0.1% kehvem.
_________________ - londiste
217 |
majooro
30.09.2020 21:50:49
| wirx, kuule teadja mees, kui sa tahad minu maailmavaateid arutada, siis minu number on profiilis. Küll riik selleni ka jõuab, ära põe...
29 |
Anna tooli
30.09.2020 21:59:49
mis eetiline?
nõudlus suurem kui tootmine
nii kuis oli 2018a alguses kaevandusbuum - letid suht tühjad ning saadaolev oli 1,5x hinnaga
300 |
aff
30.09.2020 22:14:24
| Early Access kirjutas: |
mis eetiline?
nii kuis oli 2018a alguses kaevandusbuum - letid suht tühjad ning saadaolev oli 1,5x hinnaga |
Siis need suured ärieetikud müüsid siin oma kasutatud kaarte MSRP + 35% . Tuletage nüüd meelde mis hinnaga siis populaarsemad kaevanduskaardid liikusid.
| Kommentaarid: 72 loe/lisa |
Dolph
30.09.2020 22:17:11
| majooro kirjutas: |
Või oleme jõudnud kapitalismi sellesse faasi, kus ei ärieetika ega üldse inimlikud väärtused enam midagi ei loe, kus üks inimene õgib teist inimest? Sellisel juhul on selle kapitalismi aeg tõesti oma aja ära elanud. Kindlasti pole aga vaja tagasi minna sotsialismi, vaid arenenud ühiskonnal on aeg vajaduspõhisele tootmisele üle minna ning vaadata üle iga ühiskonnaliikme panus inimkonna üldisesse arengusse ja heaollu, mitte iga indiviidi isiklikku heaollu. |
Mees, sa ei tea, millest räägid. Kapitalismis on turumajandus, kus hinna paneb paika pakkumine ja nõudlus. Kui nõudlus ületab pakkumist hinnal X, siis hind tõuseb. Need, kes toodavad ja müüvad ühiskonna poolt kõrgelt väärtustatud asju teenivad korralikult. See on turumajanduse olukorras ühiskonda edasi viiv jõud. Kui lood midagi, mis teistele on väga väärtuslik, siis saad rikkaks. See motiveerib selliseid asju looma. Minu arust ei ole mõeldav, et vahet pole, kas toodad sita või hea graafikakaardi, ikka pead ikka samasuurt raha teenima kulud+väike protsent.
Hetkel on nõudluse ja pakkumise ristpunkt kõrge hinna juures. Turul on ostjaid, kes on nõus üle maksma. Kui need ostjad saavad oma kaardid kätte, siis jäävad järgi madalama hinnaga ostjad ja hind langeb.
Täiendavalt, tipptasemel just välja ilmunud graafikakaart ei ole eluks vajalik asi, vaid luksuskaup, mida ei pea pakkuma hinnaga, mida kõik on suutelised maksma. Samamoodi nagu Ferrari on kallis. Sa ei nõua ju, et Ferrari peab maksma kulud+väike marginaal,, aga graafikakaardil peaks see justkui nii olema. Puhas nonsense.
14 |
Barmalej
30.09.2020 22:19:48
3080 otsas. 3090 otsas.
Meestel närvid läbi =)
| Kommentaarid: 13 loe/lisa |
IceUul
Sinu Ema
30.09.2020 22:24:41
Kannatust.
Varsti ületab pakkumine nõudlust ja hinnad lähevad normaalseks, oodake paar kuud.
Ma ise ootan novembrini, vaatan kuidas uus AMD kaart konkureerib ja mis Nvidia kaarditel lõplik hind tuleb.
Siis vaatab, mida on mõistlik osta. Tormi joosta uuele tootele, ongi tavaliselt selline tulemus!
| Kommentaarid: 219 loe/lisa |
188 |
aff
30.09.2020 22:28:13
| IceUul kirjutas: |
Kannatust.
Siis vaatab, mida on mõistlik osta. Tormi joosta uuele tootele, ongi tavaliselt selline tulemus!  |
+1 mõistlik mõttekäik. Ise vaatan sama moodi. Kui kogu see jama ja jant võtab aega pool aastat+ (sinna võiks ka võimalikud uued refresh vms kaardid sisse arvestada) , siis otsustan kas üldse oma 2080ti pensionile saadan. . Hetkel karjuvat vajadust selleks pole.
mihkel7
30.09.2020 22:29:31
| IceUul kirjutas: |
Kannatust.
Aga siis ei ole seda tunnet ju "Minul on aga sinul ei ole"
| Kommentaarid: 53 loe/lisa |
50 |
heinzv
30.09.2020 22:33:34
Kusjuures, mitte keegi ei käsi kõrgemat raha välja käia. Samuti, nagu ei käsi keegi edasimüüjaid rügama, et vaid moraalitundest nõudlikud kliendid MSRP hinnaga ära teenindada. Ka nende töömaht on tõusnud ja võib sellega saab igati õigustada hinnatõusu. Eriti, kui see eeldab uute süsteemide ja nimekirjade loomist.
Teemasse niivõrd-kuivõrd haakuv huvitav video https://www.youtube.com/watch?v=Wny-d15ZETw&t=1291s&ab_channel=JoeScott
Anna tooli
30.09.2020 22:44:40
| aff198 kirjutas: |
mis eetiline?
Siis need suured ärieetikud müüsid siin oma kasutatud kaarte MSRP + 35% . Tuletage nüüd meelde mis hinnaga siis populaarsemad kaevanduskaardid liikusid. |
Kas nad oleksid pidanud siis müüma -35%, kui samal hetkel oli poes +50%? Keegi ju ei käsi ometigi ülehinnatud toodet osta; aga kui turgu oli, siis mis otsast müüjale altkulmu vaadata, kui ostja oli loll
300 |
aff
30.09.2020 22:51:55
| aff198 kirjutas: |
mis eetiline?
Kas nad oleksid pidanud siis müüma -35%, kui samal hetkel oli poes +50%? Keegi ju ei käsi ometigi ülehinnatud toodet osta; aga kui turgu oli, siis mis otsast müüjale altkulmu vaadata, kui ostja oli loll |
Sinu vastus võtabki selle eetika teema kokku. Müün kasvõi 2k euriga. Kui on ostjaid siis jääb hind samaks seni kuni enam neid pole. Ja kui keegi tuleb ütleb, et võtan su viimase 2.5k euriga siis müün ka selle maha. Mitte ei hakka siin jahuma ärieetikast. PS: poes olid asjad otsas sel ajal aga kõvem mängurikaart 1080ti liikus ikka enam vähem sama hinnaga, sest seda kaevurid eriti ei tahtnud .
Edit: Mõni parema mäluga mees ütleb mis summaga siin AMD 2k ja 4k kaardid liikusid võrreldes poe hindadega.
Zonerman
01.10.2020 01:55:34
| Barmalej kirjutas: |
Meestel närvid läbi =) |
Mul suht poogen. Küll aga vaatan mida teevad hinnad. Saadavus 0 vähemalt kuni novembrini kindlasti aga hinda kruvitakse järjest juurde. Kokkuvõttes liigub sinna 2080Ti kanti. 1100+
Eks siis näeme kui palju ja kas üldse see hind alla tuleb. Halvemal juhul ootab Nvidia refreshi ära ja ostab siis järelturult odavalt. Mina ei usu, et see hind lähiajal alla 850 kukub isegi kui kaardid on laos kohe olemas. Alla tulevad hinnad teosammul kui just AMD ei üllata.
Gigabyte info kaartide osas selle kohta väitis tuleb midagi https://www.gigabyte.com/Graphics-Card/GV-N3080AORUS-M-10GD#kf . Hinda me muidugi ei tea
Eesti on mingi arengumaa, siia ei tule
https://www.dateks.lv/en/cenas/videokartes/596245-zotac-geforce-rtx-3080-10gb-gddr6x-trinity?q=Rtx%203080
hyper666
27 minutes ago
I heard that more stock in Lithuania will be coming at early-mid November. So that is why I copped this one.
67 |
Viilutaja
196 |
