XeStAiSy
Aeg Maha 2a
30.09.2020 08:02:59
Siis kui kellad alla tõmmati siis tõesti vahet pole milliste capidega kaardi saad ei ole vist mõtet palju peale maksta mõne fps pärast. Neli aastat on ikkagi max mis kasutad, kui vahepel mingi uus rakett on müügile tulnud ja enamus tootjaid pakuvad garantiid 4+ Selle 3080 saad rahumeelil skippida mõned põlvkonnad kui jääd sinna 1080p kanti.
_________________ Punktkeevitus patareidele/akudele. Akutrelli/laptopi/e-bike. PM
viimati muutis XeStAiSy 30.09.2020 08:06:12, muudetud 1 kord |
| Kommentaarid: 12 loe/lisa |
bang1bang
30.09.2020 08:18:00
1-3p....vale
alates 1050....vale
bang1bang
m8markus
30.09.2020 09:05:03
| freestyler kirjutas: |
| Stabby kirjutas: |
| heretic666 kirjutas: |
https://www.guru3d.com/news-story/gigabyte-releases-statement-regarding-the-sp-cap-and-mlcc-capacitor-on-geforce-rtx-3080-graphics-cards.html
It is false that POSCAP capacitors independently could cause a hardware crash. Whether a graphics card is stable or not requires a comprehensive evaluation of the overall circuit and power delivery design, not just the difference in capacitor types. POSCAPs and MLCCs have different characteristics and uses, thus it is not true to assert that one capacitor type is better than the other.
The GIGABYTE GeForce RTX 30 graphics cards are designed in accordance with NVIDIA specifications and have passed all required testing, thus the product quality is guaranteed. GIGABYTE GeForce RTX 3080 GAMING OC and EAGLE OC series graphics cards use high-quality, low-ESR 470uF SP-CAP capacitors, which meet the specifications set by NVIDIA and provide a total capacity of 2820u in terms of GPU core power, higher than the industry’s average. The cost of SP-CAP capacitors is not lower than that of MLCCs. GIGABYTE values product integrity highly and definitely does not reduce costs by using cheap materials. |
ilmselt see driverite taha jäi seekord jah |
minu arust on viga siiski riistvaras. uute driveritega tõmmati lihtsalt kellad allapoole, et kaart ei kellaks end üle kriitilise piiri. |
Midagi seal allapoole ei tõmmatud, nagu oli vanadega 1980 max mida näen 3090-ga ja täpselt sama oli uutega, minul ei muutunud midagi nende draiveritega
| Kommentaarid: 44 loe/lisa |
40 |
freestyler
30.09.2020 09:37:33
| 1980 pole ka kriitiline, nii et sul ei peagi midagi muutuma.
heretic666
30.09.2020 09:50:54
| Kellel siis peab?
| Kommentaarid: 73 loe/lisa |
XeStAiSy
Aeg Maha 2a
m8markus
30.09.2020 11:29:42
| AMD toetab juba PCIe 4.0, ammu räägitud seda siin...
40 |
heretic666
30.09.2020 11:35:23
Ma arvan et Margus ise ka teab seda ja pidas silmas et 9900K @ gen 3.0 vs AMD 3900XT @ gen 4.0 vahe olematu kui arvestada ainult pcie versiooni.
Gamingu jõudluselt sõidab Intel AMDst (veel) ette hoolimata pci-e 3.0 genist.
XeStAiSy
Aeg Maha 2a
30.09.2020 11:37:52
| m8markus kirjutas: |
| AMD toetab juba PCIe 4.0, ammu räägitud seda siin... |
Sa mõtled ,et ma ei tea. Mina võrdlen PCI-E v3.0 tulemusi vs v4.0. Samuti võrdlen erinevaid CPUsid mis lähiajal olnud.
m8markus
30.09.2020 11:43:58
| Inteli PCIe 4.0 toega prose pidi järgmine aasta tulema, 4 aastast vist päris ootama ei pea
40 |
erick
30.09.2020 11:44:09
| Scart kirjutas: |
| Tomorrow kirjutas: |
Stabiilsus? Aga Nvidia draiverid pidid ju olema NII head võrreldes AMD crapiga  |
Tuttuue kaardiseeria esimene real driver parandab beeta-driverite probleemid. Ülejäänud uudised lapsemeelsetele kell 11. Ma saan aru, et AMDi poisid on harjunud, et nende 5700XT ei tööta esimesed viis kuud peale ostmist, aga mõned meist on natuke parema teenusega harjunud. |
Üldiselt ma ennast ei sega sellistesse asjadesse, aga seltsimehel on point. Kui sõbrale sai RX 5700 XT PCsse pandud, siis sai loetud küll neid redditi threade. Ei mäleta, millal Nvidia viimati nii bugiste driveritega asja välja lasi. Võibolla FX 5000-seeria 2003? Las poisid töötavad oma driverite kallal paar versiooni, enne kui hakkame siin tõrva peale valama.
95 |
sacher
30.09.2020 12:20:47
| Inteli PCIe 4.0 toega prose pidi järgmine aasta tulema, 4 aastast vist päris ootama ei pea |
Linus sai mingi early sampli Inteli läpakast, mida oma peakanalis puudutas ning sellel oli PCIe 4.0 olemas.
_________________ no shit sherlock |
| Kommentaarid: 29 loe/lisa |
29 |
m8markus
30.09.2020 12:37:11
| emadel on olemas, prosed ei toeta veel intelil
40 |
RustyZ
30.09.2020 12:50:26
| jeesus188 kirjutas: |
1-3p....vale
alates 1050....vale
ärge uskuge seda infot. Helistasin neile ja küsisin, et kas tõesti saabub 2. oktoober TUF kaarte.
Vastus on selline, et tuleks 2. oktoobril ikkagi uuesti kontrollida. Et neile on küll maaletooja juures broneeritud mingid kaardid aga reaalselt selgub 2.okt.
Seega julged tellivad... või teadjamad lisavad nüüd siia, et kui nad ütlevad et neil broneeritud siis mis see realnõi tähendab.
_________________ Wreckfest 2 server: 136.243.70.252:30102 | parool: isamaa (kui on enabled) |
| Kommentaarid: 16 loe/lisa |
Zonerman
30.09.2020 13:17:59
Täna Caseking uuendas oma hindasid. Nüüd on tavaline TUF juba 850.- ja OC 900.- praktiliselt. Tänan ei, mina lükkan oma ostu uude aastasse või kui AMD üllatab. Pigem uuendan CPU sügisel.
Nvidia võib oma olematu saadavusega ja vahendajate suure ahnusega kuu peale sõita.
Nvidia redditis TUF tellijad kes tellisid 17. sept pole saanud ka kinnitust kuna nad kätte saavad. Osadele on öeldud millalgi novembris ehk ja osadel pole mingit aega öeldud
| Kommentaarid: 66 loe/lisa |
65 |
majooro
30.09.2020 13:19:07
| Zonerman kirjutas: |
Nvidia võib oma olematu saadavusega ja vahendajate suure ahnusega kuu peale sõita |
+1. NVIDIA launchiski spekulantidele need kaardid
| Kommentaarid: 30 loe/lisa |
29 |
Nipi1000
30.09.2020 13:22:39
| RustyZ kirjutas: |
Seega julged tellivad... või teadjamad lisavad nüüd siia, et kui nad ütlevad et neil broneeritud siis mis see realnõi tähendab. |
puhas reklaam lihtsalt poele, antud tooteid ei ole võimalik ei tellida ega broneerida(puudub võimalus ostukorvi lisada)...2. okt võid ju seda lehekülge neil refreshida, lootuses et õnnestub mõni saada, aga sügavalt kahtlen
...või kui kõik helistama ja uurima hakkavad, siis ehk eemaldavad need kuniks reaalselt midagi saada
| Kommentaarid: 21 loe/lisa |
20 |
Zonerman
65 |
majooro
30.09.2020 13:40:35
| majooro kirjutas: |
+1. NVIDIA launchiski spekulantidele need kaardid  |
Asi on nii karm, et ma tegin Nvidia reddit teema, kuhu hüppas keegi mulle kohe peale kui ma mainisin hindasid ja 0 saadavust. Moderaatorid eemaldasid minu teema
Ärge jumala eest kiruge seal sellel teemal. |
Ilmselt võis põhjus olla ka selles, et soovitakse hoida sellekohast arutlust 3080 & 3090 Launch Thread'is.
https://www.reddit.com/r/nvidia/comments/j1l4bg/rtx_3080_3090_launch_thread_part_4/
See on ikka megaLOL
https://buyrtx3080.com/index.html
29 |
Arx07
30.09.2020 13:41:55
Zonerman, eks seal toodetakse sitta ka korralikult ja kui neid mõttetuid teemasid ära ei kustutaks keegi siis seal jääbki kammima kuni midagi asjalikku üldse leiab. Iga 10 minti tagant keegi postitab pildi ka enda RTX-st...
Aga eks reddit muidu üldiselt ka tundlik koht, ma sain perma bänni seal selle eest, et ühe pildi kohta ütlesin "like a fag".
heretic666
Mugman
30.09.2020 14:06:02
... a miks nad lubatust niipalju hindasi tõstavad Tahavad nõudlust vähemaks kruttida või?
| Kommentaarid: 65 loe/lisa |
61 |
Arx07
30.09.2020 14:08:40
Mugman, raha tahavad - nagunii ostetakse ära.
Ausad müüjad müüvad ikka õige hinnaga, ooteaeg nendel küll eriti pikk (näiteks Jimms.fi)
