| Kommentaarid: 92 loe/lisa |
Dijital
| Kommentaarid: 41 loe/lisa |
ricom2ger
11.01.2020 10:12:20
Radeon Settings Host Application ikka tiksub 20% peal
_________________ Kamehameha in your face! |
111 |
11.01.2020 10:19:57
stats maas? relive maas? kogemata mõnd klaviatuuri shortcutti pole vajutanud?
_________________ - londiste
217 |
ricom2ger
11.01.2020 10:27:16
Kõik olen lülitanud välja, ja see jama kahe erineva masinaga.
111 |
Vael
11.01.2020 14:42:03
| Factory Reset seadistusega tegid uuenduse?
| Kommentaarid: 17 loe/lisa |
16 |
ricom2ger
12.01.2020 19:15:06
| Vael kirjutas: |
| Factory Reset seadistusega tegid uuenduse? |
Proovitud, ka puhta Windowsi otsa lastud. Muutusteta
111 |
Kristocfc
14.01.2020 22:47:44
mul oli foorumist ostetud kuu aega vana 5700xt kasutuskõlbmatu uusimate driveritega- black screenid ja crash to desktop.
nüüd 19.7.5 ja 0 probleemi peale kuu aega kasutamist.
| Kommentaarid: 64 loe/lisa |
55 |
Vael
15.01.2020 16:47:50
| 19.12.2 paistab ka enam vähem olevat, 20.1.1 pealt läksin tagasi..
16 |
16.01.2020 09:50:59
https://wccftech.com/amd-radeon-adrenalin-20-1-2-driver-out-now/
Support For
Dragon Ball Z™: Kakarot
Vulkan®1.2
Product is conformant with the Vulkan® 1.2 Specification. Vulkan and the Vulkan logo are registered trademarks of the Khronos Group Inc.
Fixed Issues
Some UE4 based titles such as KovaaK 2.0: The Meta™, Tetris Effect™ and Snooker 19™ may fail to launch with Adrenalin 2020 edition software.
Some single display Radeon RX 5700 series graphics product system configurations may experience intermittent reboots when the system is left idle on desktop.
Known Issues
Radeon Anti-Lag enable and disable beep notifications may be played in error when individually pressing keys assigned to the hotkey.
The Radeon Software Overlay hotkey notification may sometimes be displayed during video playback in web browsers or launching some video player applications.
Integer Scaling option is not showing up or available on some Windows®7 system configurations.
Factory Reset install may keep previously configured Radeon Software game profiles. This can cause mismatch between global graphics settings and per profile settings.
Text overflow in some UI boxes or toast messages may be experienced in some language localizations.
Radeon Software may open with an inconsistent size or may not keep its previously set size when opened.
Some Vulkan® gaming applications may crash when performing a task switch with Radeon Image Sharpening enabled.
Integer Scaling may cause some video content to show flicker when the display resolution is set to less than native resolution.
Some Radeon RX 5700 series graphics users may intermittently experience a black screen while gaming or on desktop. A potential temporary workaround is disabling hardware acceleration in applications running in the background such as web browsers or Discord.
A limited number of games such as Nioh™, Dead or Alive 6™, Dragon Quest Builders 2™ and Atelier Ryza™ may crash or fail to launch.
Vael
16.01.2020 16:57:57
No anna minna, mitmes kuu se jba on ja ikka ei saa black screen crashe ära parandatud. Mul ka Discord taustal, vahet pole kas HW acc on või mitte.
Raud on iseenesest hea, aga ma ei tea kaua meeskonnakaaslased veel kannatavad kui ma FS end game ära kaon ja seepärast võit jääb noppimata.
Kuidas see lugu oligi "ükskord prahvatab vimm..." Ja tuleb nvidia poolele üle kolida.
16 |
sessa
17.01.2020 01:06:35
| ei tea pole ühtegi probleemi olnud draiveritega mul muidugi rx580 kah vb asi selles
| Kommentaarid: 75 loe/lisa |
63 |
WäntWõll
make.believe
17.01.2020 12:31:55
see tundub jah viimase seeria RX 5700 häda, mul ka 0 muret
300 |
Vael
01.02.2020 09:45:56
Tekitab usaldust jälle.
Märkasin ühes hiljutises versioonis nuppu- send (bug) feedback. Väga teretulnud kui ei pea kusagile tühja amd foorumisse ronima, et vigade kohta raporteerida.
16 |
ricom2ger
01.02.2020 20:09:06
| ricom2ger kirjutas: |
Radeon Settings Host Application ikka tiksub 20% peal  |
Võttis küll aega, aga 20.1.4 parandas selle bugi ära.
111 |
Kristocfc
04.02.2020 12:25:33
| kas Teil 5700xt crash to desktop ja black screen probleemid kadunud? kas võiks uuendada nüüd miskise päevakajalise driveri versiooni peale?
55 |
Vael
04.02.2020 18:08:21
| Kristocfc kirjutas: |
| kas Teil 5700xt crash to desktop ja black screen probleemid kadunud? kas võiks uuendada nüüd miskise päevakajalise driveri versiooni peale? |
jumala eest ära tee seda,viga.
Ma lasin uue windoosa ja sellega kõige uuemad amd driverid peale. 20.1.4 pangestus iga 5min tagant. Rookisin amd chipseti ja gpu driverid masinast ja lasin vanemad peale, 2h oli bfv jutti probleemivaba. 19.11.2 paistab kõige uuem stabiilne olevat, sealt edasi läks allamäge, kõiki järjest Factory reset/clean uninstalliga katsetanud.
16 |
Kristocfc
04.02.2020 18:39:24
njaa, tänan. siis istun ka oma vana probleemivaba driveri paketi otsas.
55 |
Vael
16 |
Anna tooli
16.02.2020 23:30:08
tulin teiselt tootjalt siia üle
uus kaart, uued draiverid
ükski mäng normaalselt ei jookse
jõhker ämber ja raha raiskamine
300 |
sant
16.02.2020 23:32:47
| Early Access kirjutas: |
jõhker ämber ja raha raiskamine |
Amd klassikaline reegel on: oota vähemalt 1 aasta peale uue kaardi väljatulekut enne kui ostad, siis on ehk draiver väljas mis kaardi tööle paneb
_________________ So, at the end of the day, after I have butchered all the nvidiots all around me, standing alone in a pool of blood surrounded by the corpses of my victims, a horrible truth reveals itself to me: I am an amd\ati fänboy...and I must do my dark masters bidding, for I am damned for all eternity... |
| Kommentaarid: 67 loe/lisa |
60 |
Anna tooli
17.02.2020 00:00:36
ma arvasin et see reegel kehtis umbes 10a tagasi, mitte täna
oma viga et teemat ei lugenud
300 |
sant
17.02.2020 00:08:56
| ma arvasin |
Arvamine on perssekeeramiste oma omast käest tean. Ma olen loobunud arvamisest, mul ei ole piisavalt raha et arvata
60 |
Anna tooli
17.02.2020 00:33:35
true story
aga mõni stabiilne versioon leidub?
kõikse uuemaga dirt2 sõitis küll; shootereid aga pole proovinud ..
300 |
17.02.2020 01:06:27
| rmc kirjutas: |
19.11.3 RX580 8GB ja kõik fain, uuema peale ei julge minna.  |
Proovi. Also, mis kaart ja mis katki ka?
182 |
Anna tooli
300 |
Vael
17.02.2020 17:44:42
Hetke AMD draiverid on jah õudus kuubis, 1a tagasi oli samas elu lill(vähemalt FuryX-ga). Alates Vega väljalaske hetkest on allakäik toimunud.
Aga jah AMD Clean Utility vms üle lasta masin, siis 19.10.x või 19. 11.x proovida. Endal 19.11.2 toimetab.
16 |
17.02.2020 19:00:19
Early Access, said Afterburneri sulgemisega korda?
182 |
Anna tooli
17.02.2020 20:19:17
nope
vähemalt BL2-ga on sama jänt
edit: 19.11.3 ja afterburneri kooslus töötab paremini ja kannatas nt BL2-te mängida küll
300 |
Maxstpau
18.02.2020 09:42:01
| Minul Vega64 kaardiga 19.11.x ei tööta. Peale shutdowni kaob OC/UV profiil ja FRC ära, AMD paneel ei tule lahti, lihtsalt crashib kuid arvuti töötab edasi.
100 |
Anna tooli
18.02.2020 10:09:37
| Ma lasin vaid draiveid. AMD Panel, HDMI audio jms sodi jätsin kõrvale
300 |
Draco
18.02.2020 10:29:56
| Maxstpau kirjutas: |
| Minul Vega64 kaardiga 19.11.x ei tööta. Peale shutdowni kaob OC/UV profiil ja FRC ära, AMD paneel ei tule lahti, lihtsalt crashib kuid arvuti töötab edasi. |
Strix Vega64 ja viimased AMD driverid. Overdrive`n`Tool abiga on kerge UV&OC ja probleeme pole .
Kokkuvõtteks on viimase aasta jooksul masinaga kokku olnud üldse 2 probleemi, mõlemad seotud Ubisoftiga (ülla ülla) aga muus osas töötab.
Enne seda oli probleem ASUS`se emaplaadi BIOS`iga aga see läheb teemast juba kõrvale.
_________________ Purgatory Judgement |
| Kommentaarid: 12 loe/lisa |
12 |
Maxstpau
18.02.2020 12:00:51
| Uued driverid töötavad ilusti kuid uuest versioonist kaotati ära FRC mida sooviksin edasi kasutada.
100 |
21.02.2020 15:31:46
Ei teagi, kas vaadata tarkvara või raua suunas aga... XFX RX480 4GB'ga on häda. Installin AMD uusimad (või eelviimased või ca aasta vanad draiverid ära), peale restarti näiteks Afterburneris on kaart näha aga ükski mäng ei käivitu, Radeon Software ütleb "No AMD graphics driver is installed, or AMD driver is not functioning properly". Enne oli arvutis nVidia kaart (ja neid on selle Windows installiga olnud ikka mitmeid), DDU'ga olen AMD/nVidia GPU draivereid safe modes korduvalt maha lasknud, ei midagi. Install on alati muretu, peale installi nagu polekski midagi tehtud.
Device manageris on ka hüüumärgiga.
Ideid?
viimati muutis Dirty Harry 21.02.2020 15:41:52, muudetud 1 kord |
147 |
21.02.2020 15:50:19
Täiendasin vahepeal, "Device manageris on ka hüüumärgiga", "There is a problem with Radeon (TM) RX 480 Graphics device. For more information, search for 'graphics device driver error code 43'"
Eelmises arvutis töötas selles mõttes "aga"-dega, et kaevamisel jooksis kokku, mängud jmt olid okei. GPU-Z seest ei suutnud testakent leida...
Ükski 3D ei tööta jah. St muidu ma ei võimleks aga kuna eelmisel omanikul oli muus osas töötanud (ja ta on usaldusväärne inimene) siis tahaks käima saada.
147 |
21.02.2020 15:53:38
Kui Afterburner kaarti näitab, siis kas kellasi saab muuta? Et paneks võimalikult madalad kellad prooviks.
Vb AMD installeri süü. Võib proovida draiverid lahti pakkida kuni .inf failideni ja läbi Device Manageri ette sööta. Juhul kui see ei aita ja jääb kollase hüüumärgiga, siis kahtlustaks ikka raua viga.
Milline muu platvorm on? Eelkõige emaplaat, win versioon, toide jne.
21.02.2020 16:02:11
| Afterburner näitab kaarti aga mitte draiverit, ei saa kellasid muuta. Käsitsi draiveri installi tegelikult juba proovisin ka, see jäi mainimata enne. R1700, MSI Mate B350, Seasonic Fanless 520W, W10 1909. Aga vist saab tahtmine võimelda otsa...
147 |
21.02.2020 16:32:01
Sõbral oli vahepeal ühe vana kaevuriga probleeme (RX480 GTR 8GB) ja umbes sarnane keiss... Aero oli välja lülitatud, driverid olid justkui installitud, ent ei toiminud nagu peaks ja device manageris hüüumärk jne. - mängud lihtsalt ei läinud käima jne.
Õnnestus taas ellu tagasi tuua komboga mobo BIOS-i ülekirjutamine, resetimine ja uus seadistamine, GPU BIOS-i ülekirjutamine, driverite mahavõtmine ja taasinstall ning reaalselt füüsiliselt masinast välja võtmine, väljas olla laskmine, jne.
Lõpuks mingil hetkel lihtsalt kõik toimis nagu varem.
182 |
21.02.2020 17:55:11
| Ilmselt midagi sarnast jah, rmc. Igaljuhul kuna on dual BIOS kaart siis teise BIOSega läks käima. Aga eks häda oli muuhulgas selles, et proovitud sai mitut asja ja mis täpselt aitas, pole 100 ja 1% kindel.
147 |
22.02.2020 16:10:54
Nii mul endalgi lõpuks asi lahenes . Seletas siis teisele, mis viga oli ja, kuidas korda tegid.
Aga soovitaks originaalbiosid üles leida ja selle vigase poole üle flashida. Suht lihtne. Vajadusel saan kirjutada, kuidas.
182 |
Kremka
| Kommentaarid: 80 loe/lisa |
72 |
28.02.2020 22:39:23
Fixed Issues
Performing a task switch with some Radeon Software features enabled or some third-party applications with hardware acceleration running in the background may cause a system hang or black screen.
Improvements have been made that allow for more responsive fan ramp up or fan ramp down times on Radeon RX 5700 series graphics products.
Performance Metrics Overlay and Radeon WattMan incorrectly report lower than expected clock speeds on Radeon RX 5700 series graphics products during gaming workloads.
When Instant Replay is enabled, a TDR or black screen may occur when launching games or applications.
A black screen may occur when toggling HDR on in the game settings of Battlefield V.
The Witcher 3: Wild Hunt may experience an application hang or black screen during certain parts of the game or intermittently during gameplay.
Some video content in Chrome may appear as a black screen or be unresponsive on Radeon RX 5000 series graphics products when hardware acceleration is enabled.
Metro Exodus may experience an application hang or TDR when choosing some specific dialogue prompts in the Sam's Story DLC.
Grand Theft Auto V may experience an application crash when invoking Radeon Software's overlay with third party OSD applications running.
Monster Hunter World : Iceborne may experience intermittent crashes while idle or on the character creation screen.
Some games colors may appear washed out when HDR mode has been enabled in game and Windows on Radeon RX 5700 series graphics products
After a Factory Reset installation with the 'Keep My Settings' option chosen, Instant Replay could fail to function if it was enabled in the previous Radeon Software installation.
When invoking Radeon Software's overlay while a game is open users may observe flickering in the game or in the Radeon Software interface.
Radeon Software may experience a crash and error message when locking Windows or performing a sleep or hibernate with the Radeon Software Streaming tab open.
A loss of display with working audio may be experienced on a limited number of displays when performing a mode change on Radeon RX 5000 series graphics products.
Radeon Software may fail to launch if Radeon Software's overlay is disabled and a game is running in the background.
Battlefield V may experience an application hang or TDR after extended periods of play.
Some Origin games may fail to be detected or may detect the incorrect game title in Radeon Software.
Some productivity applications are being detected and listed in the Radeon Software games tab.
The Radeon Chill hotkey could sometimes continue to remain enabled once the user has removed or disabled the hotkey.
Red Dead Redemption 2 may exhibit blocky textures on snow covered terrain.
After resuming from sleep, Chrome may experience an application crash if video content was previously playing on Radeon RX 5700 series graphics products.
Radeon FreeSync status in Radeon Software may sometimes fail to update when enabling or disabling the feature through the display itself.
Fortnite may experience an application crash on Radeon RX 500 series Hybrid Graphics system configurations.
Known Issues
Enhanced Sync may cause a black screen to occur when enabled on some games and system configurations. Enhanced Sync has been temporarily disabled from the gaming profile and any users who may be experiencing issues with Enhanced Sync enabled should disable it as a temporary workaround.
Performance Metrics Overlay and Radeon WattMan incorrectly report higher than expected idle clock speeds on Radeon RX 5700 series graphics products. Performance and power consumption are not impacted by this incorrect reporting.
DOOM may experience an intermittent system hang or application crash during gameplay.
Desktop cursor may intermittently remain visible after toggling Radeon Software's overlay in some games. A workaround is to bring up the game menu or task switch to refresh the cursor.
A system crash or hang may occur when running the Final Fantasy XIV: Shadowbringers benchmark.
The Gaming tab in Radeon Software may display some folder locations appearing as games.
Radeon Software may open with an inconsistent window size or may not keep its previously set size when opened.
Modifying the HDMI Scaling slider may cause FPS to become locked to 30.
Some games may exhibit stutter intermittently during gameplay on Radeon RX 5000 series graphics products.
Some games may experience stutter while using Instant Replay or third-party applications that stream or perform screen capture. A potential workaround is to disable these features or applications while gaming.
Although Radeon Software Adrenalin 2020 Edition 20.2.2 resolves many black screen issues, AMD is aware that some users may still experience black screen or system hang issues during extended periods of gameplay. AMD will continue to monitor and investigate reports of these issues closely.
Important Notes
This optional release of Radeon Software Adrenalin 2020 Edition is targeted towards resolving recent important issues identified by our community. We will be closely monitoring feedback on the release, and encourage users to submit issues they encounter at www.amd.com/report.
Source: AMD |
Vael
29.02.2020 10:17:03
BFV fixed issues all mitu korda mainitud, peab kohe proovile panema.
16 |
Vael
05.03.2020 18:13:34
it just works. Navi oli 2p draividega kasutuses, no probs
lükkasim fury x asemele. Ühtki muudatust ei teinud. Ka probleemivaba siiani
16 |
Kristocfc
10.03.2020 17:26:34
| pean ära proovima, saan aimu anda kas 5700xt black screenib ikka.
55 |
degreal
26.03.2020 13:57:19
Kas radeoni kasutajaliidese saaks uninstallida? Iga kord kui driver update teha siis see nssib Eclipse hotkey-d ära. näiteks ctrl+shift+r hüppab mingi huinjaa lahti. ctrl+shift+c on ka rikutud aga midagi lahti ei hüppa aga on reserveeritud mingi installeerimata radeoni tarkvara jaoks (Re-Live). Esimese saab radeoni settingutest ära tühistada aga teise kohta settinguid pole ja peab regeditiga jebima. Peale driveri update jälle kõik rikutud.
viimati muutis degreal 26.03.2020 15:27:52, muudetud 1 kord |
| Kommentaarid: 28 loe/lisa |
26 |
26.03.2020 14:14:47
See on veidi ajuvaba, jah, et igast hotkeysid eemaldada, disableda, jne. ei saa.
Kõik võiks ikkagi kasutajapoolt kontrollitud olla, st. ka tarkvara ise võiks modulaarne olla - jooksutatakse seda osa, mida vaja.
Aga ReLive-i ei pea installima, muidu. IMO installimisel küsib, kas soovid.
182 |
