Longero
25.11.2019 23:02:24
Natuke segane värk minujaoks Samsung 883 DCT seeria SSD'dega. Võtsin vaatluse alla 2,5" tavalised 3,8 TB SSD'd kuigi ka sama seeria 1,9 TB vastu huvi.
Tundub, et just 883 DCT seeria on parim andmeketta jaoks, omadused mida teistel pole (TBW on teisejärguline minujaoks, st nagunii piisav).
Peaks siis nagu voolukatkestuse v sunniviisilise restardi vastu ka kaitsma.
Power-Loss Protection:
Protect data integrity from unexpected power loss with Samsung's advanced power-loss protection architecture. Using the electricity from a tantalum capacitor to provide enough time to transfer the cached data in the DRAM to the flash memory, you can be assured no loss of data. |
Soovin seda Samsung 883 DCT 3.8TB (Tootekood MZ-7LH3T8NE) https://www.samsung.com/us/business/products/computing/ssd/enterprise/883-dct-3-8tb-mz-7lh3t8ne/ sama SSD siin https://www.samsung.com/semiconductor/minisite/ssd/product/data-center/883dct/
Kas see SM seeria on sama mis soovitud esimene? SM883 (DWPD3.0(5yrs)) (Tootekood MZ7KH3T8HALS) https://www.samsung.com/semiconductor/ssd/datacenter-ssd/MZ7KH3T8HALS/
Ja see samuti? SSD Samsung SM883 [OEM] 3.8TB, SATA (Tootekood MZ7KH3T8HALS-00005) https://www.hinnavaatlus.ee/1453675/samsung-sm883-oem-38tb-sata/
Mis vahe on OEM ja mitte OEM tootel? Tootekoodid nagu samad SM883 (Tootekood MZ7KH3T8HALS) vs SM883 [OEM] (Tootekood MZ7KH3T8HALS-00005)
Siin enterprise SSD https://www.samsung.com/us/business/products/computing/ssd/enterprise/
Siin on Samsung Datacenter SSD https://www.samsung.com/semiconductor/ssd/datacenter-ssd/
PM883 (DWPD 1.3(3yrs)) (Tootekood MZ7LH3T8HMLT) https://www.samsung.com/semiconductor/ssd/datacenter-ssd/MZ7LH3T8HMLT/
HinnaVaatluse lingid:
SSD Samsung PM883 [OEM] 3.84TB, SATA (Tootekood MZ7LH3T8HMLT-00005) https://www.hinnavaatlus.ee/1451187/samsung-pm883-oem-384tb-sata/
_________________ Win ISO'd ja uuendused
Artiklid jagatud |
| Kommentaarid: 56 loe/lisa |
52 |
toivos
26.11.2019 11:06:39
OEM-i ketast Samsung enda omaks ei tunnista. Utiliidid ja tugi ainult läbi OEM-i.
_________________ Taastan datat katkistelt ketastelt ja katkistelt Flash(USB) mäludelt. Nüüd ka katkistelt SSD ketastelt. |
| Kommentaarid: 70 loe/lisa |
66 |
Longero
52 |
toivos
27.11.2019 11:40:37
Firmware uuenduse saad juhul kui OEM selle avalikult välja paneb.
66 |
| Kommentaarid: 1154 loe/lisa |
724 |
30.11.2019 01:02:30
Sain täna ADATA XPG GAMMIX S11 Pro 1TB kätte ja karbi peal on kiirusteks 2100/1500, igalpool mujal 3350/2800 ja datasheetil ka nii väikseid numbreid ei näe. Karbi peal antireklaam?
182 |
30.11.2019 10:19:42
| rmc kirjutas: |
Sain täna ADATA XPG GAMMIX S11 Pro 1TB kätte ja karbi peal on kiirusteks 2100/1500, igalpool mujal 3350/2800 ja datasheetil ka nii väikseid numbreid ei näe. Karbi peal antireklaam?  |
Ise oled "antireklaam".
Ja edaspidi võiks ikka enne kodutöö ära teha ja alles siis poodi minna. Siis ei saa Sa vähemalt rohkem pügada.
Iga haritud Adata toodete ostja teab, et Adatal on väga palju tooteid mida on olemas nii vanemad kui uuemad varsioonid.
Ja nii sa pügada said: tahtisid uut ja kiiret kuid said hoopis vana ja aeglase versiooni:
Vaata pilte:
1. vana ja aeglane:
2. uus ja kiire:
Nüüd võta Ubuntu mingi USB-l olev "Live"-versioon.
Ubuntu sees on programm Disks.
Seal on olemas Kiirusetest. Paned selle tööle ja näed ära selle Adata tegelikud kiirused.
PS: On ainus programm mida võid usaldada. Need Windowsi all olevad programmid on tihti nii ja naa.
211 |
30.11.2019 10:59:37
tahanteada, ja kui sa amazonis ringi klikkisid, siis see "vana ja aeglane" on gammix s5, mitte s11 pro.
_________________ - londiste
217 |
Vael
30.11.2019 12:26:34
| Pro peaks uuem olema. Ja mälu järgi oligi uuem aeglasem... Aga mitte nii palju? Võta SN ja löö googlesse, mis siin muud...
| Kommentaarid: 17 loe/lisa |
16 |
01.12.2019 04:15:17
tahanteada,
| rmc kirjutas: |
Miks sa mulle mingitest teistest mudelitest üldse räägid? Rahune veidi ja analüüsi sisu, enne kui lahmima rapsid.
Vael, vaata kommentaaris olevaid viiteid .
EDIT: Kuidas saada aru, kas SSD vajab OverProvisioning-u seadistamist või mitte?
ADATA SSD Toolbox seda varianti ei paku, samas Crucial-i programm pakub.
ADATA SSD Toolbox on sesmõttes ka eriti loll, et Firmware-i update-i võiks ikka programmis sees ise teha, mitte kodukale visata, kus sellekohast infot pole .
Plus selle asemel, et manualis soovitada korra nädalas TRIM-i jooksutada... võiks seda automaatselt tegema panna?!
182 |
Vael
01.12.2019 12:59:43
OP teeb FW ise? Kui ketast täis ei topi, siis jääb SLC cacheks piisacalt?
FW update, midagi kriitilist on ära parandatud, Crucial ja Samsung tulid ammu poolikute toodetega välja, mis nõudis uuendamist...
TRIM/optymize weekly on win10 by default C: ketta seadistus.
16 |
01.12.2019 13:24:31
Vael, puudub selle kohta info.. ainus info, mis olemasoleva OP kohta sain, oli review-st, et OP jaoks on vähem ruumi jäetud, kuna saadaval on rohkem mahtu kui eelmistel mudelitel. Tarkvaras samas OP variant puudub ja Cruciali omal nt. on see olemas... IMO võiks tootjad panna selle info ka tarkvarasse ning võimaluse OP tekitada ka muidugi... et oleks tervikülevaade.
FW-update osas ei saa aru, mida mõtled.
Win10 TRIM toimib ka reaalselt? & mul kõrvalketas ka SSD, kuidas sellele ka sisse lülitada?
182 |
01.12.2019 18:21:39
miks overprovisioning peaks seadistatav olema ketta või firmware tasemel?
| rmc kirjutas: |
| Win10 TRIM toimib ka reaalselt? & mul kõrvalketas ka SSD, kuidas sellele ka sisse lülitada? |
üldjuhul ei tohiks olla mingit vajadust ise käsitsi midagi lülitada.
kontrolliks - vastus peaks olema 0:
| fsutil behavior query DisableDeleteNotify |
217 |
01.12.2019 18:58:14
londiste, Crucial seda soovituslikult oma utiliidis (vähemalt 10%) pakub, järelikult on see mõistlik.
Eks see olenebki kettast, kas ja palju OP-d jäetud on.
Päringu vastused nullid, tänud!
182 |
Vael
01.12.2019 21:04:56
| rmc kirjutas: |
Päringu vastused nullid, tänud! |
Dynamic OP oleneb mu arust palju FW, mõni kasutab palju SLC cacheks, mõni vähem. Mõni jätab võimaluse vajadusel juurde haugata, sest muidu jookseb ketas umbe...
Crucialil olid need imelike kogustega kettad ka vahepeal tootmises, 750GB jne. Neil vb oligi võimalus 25GB-le lisaks veel juurde lisada OP jaoks...
ADATA olid\on Mixed workload tasemel kui mitte tipus pidevalt, ei näe väga vajadust nende kodukootud FW modima minna. Samsung on ka paari viimase FW-ga järgi tulnud lõpuks.
Aga ikkagi, oled kindel, et S5 endale ei saanud? s11 peaks "päris SSD" olema, DRAM ka küljes. S5 on "säästukas" HBMga ehk DDR puudub ja sellest ka aeglasem... S11 peaks ainult kirjutamiskiirus mudelite lõikes kõikuma, S5 ongi üldse aeglasem. S11 PRO peaks uuem, ilma PRO-ta vanem ver olema. tahanteada, soovitus oli mõistlik, vaata mis bench näitab ja löö S \N(ketta enda mitte karbi pealt) otsingusse. Vale ketta said siis nõua õige sisse. Võib ka olla, et karp vale.
16 |
02.12.2019 00:01:47
Vael, kõik on s11 pro oma, ainult karbi peal on kiirused lambiselt kirjas. Ei olnud ju mõistlik soovitus kui ma tean, et s11 pro, ent kiirused valed karbi peal
Kõik muud asjad on õiged, v.a. see üks kiiruse kuulutamine.
Edit, igaksjuhuks puust ja punaseks siis:
182 |
Le Inc
20.12.2019 17:11:49
Synology RS3617xs+ ja 6tk HGST Ultrastar 8 TB ketast teevad 10Gb järjestiklugemist 2.5 GB/s ja kirjutavad 520 .. 500 MB/s. Ilmselt võiks SSD ka cacheks juurde pista .. aa muidu järjestiklugemises SSD mõõdu annab välja!
54 |
loox
23.12.2019 11:27:58
| Le Inc kirjutas: |
Synology RS3617xs+ ja 6tk HGST Ultrastar 8 TB ketast teevad 10Gb järjestiklugemist 2.5 GB/s ja kirjutavad 520 .. 500 MB/s. Ilmselt võiks SSD ka cacheks juurde pista .. aa muidu järjestiklugemises SSD mõõdu annab välja!  |
HGST Ultrastar 8 TB Sustained throughput on Storagereview andmetel 205 MB/s. Kui 6 tükki neid paralleelis loeb, saab maksimaalne kiirus olla 205 x 6 = 1230 MB/s. Mis üle selle peab keemia olema (kompressioon, cache vms.).
SilQ
23.12.2019 12:39:26
Kes nii rumal on ja paneb nasi sisu paralleeli?
_________________ If you can’t explain it simply, you don’t understand it well enough – Albert Einstein |
215 |
Le Inc
23.12.2019 13:01:46
| loox kirjutas: |
| Le Inc kirjutas: |
HGST Ultrastar 8 TB Sustained throughput on Storagereview andmetel 205 MB/s. Kui 6 tükki neid paralleelis loeb, saab maksimaalne kiirus olla 205 x 6 = 1230 MB/s. Mis üle selle peab keemia olema (kompressioon, cache vms.). |
Ketta cache on sees jah, ilma cache 724 MB/s lugemine ja 557 MB/s kirjutamine.
| SilQ kirjutas: |
Kes nii rumal on ja paneb nasi sisu paralleeli?  |
RAID10 on, ehk loeb 6x kiirusega, kirjutab 3x (teoorias)
54 |
dohc-48v12
Aeg maha 1p
23.12.2019 13:05:20
Noo 5-e või 10-sse oleks ehk loogiline 1-te mõttetu( lihtsam juba kaevikusse ronida) ja 0-s on rind haavleid täis
Aga jah ise vast paneks raid 5-te lihtsalt ei ole nii julge et kaotada selline kogus andmeid.
On olemas softi põhised raid-d aga kas see just sama mis raua põhised ei oska kommenteerida.
_________________ Ime tala, Nagu ime kepike.
Miks ADMIN Anti112 ambusib mind? andis 1p cooldowni aga ma ei saa peale selle enam mitteühtegi postitust teha! üks päev ei kuid! |
6 :: |
85 |
Le Inc
23.12.2019 13:22:35
| dohc-48v12 kirjutas: |
On olemas softi põhised raid-d aga kas see just sama mis raua põhised ei oska kommenteerida. |
RAID10 läheb küll pool kettamahust raisku, aga suurem töökindlus ja taastamise kiirus on paremad kui RAID5, lisaks ka jõudlus. Kohati olen 3 kettaga RAID5 teinud, sealjuures SSD'ga ilmselt jõudluse faktor ei oleks teemaks, lisaks 1 ketta turvalisus.
54 |
SilQ
23.12.2019 14:05:05
Le Inc, Möh? Matemaatikat ei tunne. 3x kiirus on ikka raid10'ne puhul.
215 |
rycyve
23.12.2019 19:55:32
Mul näitab nii C:\Windows\system32>fsutil behavior query DisableDeleteNotify
NTFS DisableDeleteNotify = 0
ReFS DisableDeleteNotify = 1
Nagu ma aru saan siis see ReFS on miski piiratud test faili formaat või ei ja milleks see siin on
| Kommentaarid: 99 loe/lisa |
toivos
23.12.2019 21:14:11
| rycyve kirjutas: |
Nagu ma aru saan siis see ReFS on miski piiratud test faili formaat või ei ja milleks see siin on  |
https://en.wikipedia.org/wiki/ReFS
66 |
