uus teema   vasta Raud »  Kõvad kettad »  SSD versus HDD märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 469, 470, 471 ... 528, 529, 530  järgmine
Longero
sõnum 25.11.2019 22:02:24 vasta tsitaadiga
Natuke segane värk minujaoks Samsung 883 DCT seeria SSD'dega. Võtsin vaatluse alla 2,5" tavalised 3,8 TB SSD'd kuigi ka sama seeria 1,9 TB vastu huvi.
Tundub, et just 883 DCT seeria on parim andmeketta jaoks, omadused mida teistel pole (TBW on teisejärguline minujaoks, st nagunii piisav).
Peaks siis nagu voolukatkestuse v sunniviisilise restardi vastu ka kaitsma.
Power-Loss Protection:
Protect data integrity from unexpected power loss with Samsung's advanced power-loss protection architecture. Using the electricity from a tantalum capacitor to provide enough time to transfer the cached data in the DRAM to the flash memory, you can be assured no loss of data.
Soovin seda Samsung 883 DCT 3.8TB (Tootekood MZ-7LH3T8NE) https://www.samsung.com/us/business/products/computing/ssd/enterprise/883-dct-3-8tb-mz-7lh3t8ne/ sama SSD siin https://www.samsung.com/semiconductor/minisite/ssd/product/data-center/883dct/
Kas see SM seeria on sama mis soovitud esimene? SM883 (DWPD3.0(5yrs)) (Tootekood MZ7KH3T8HALS) https://www.samsung.com/semiconductor/ssd/datacenter-ssd/MZ7KH3T8HALS/
Ja see samuti? SSD Samsung SM883 [OEM] 3.8TB, SATA (Tootekood MZ7KH3T8HALS-00005) https://www.hinnavaatlus.ee/1453675/samsung-sm883-oem-38tb-sata/
Mis vahe on OEM ja mitte OEM tootel? Tootekoodid nagu samad SM883 (Tootekood MZ7KH3T8HALS) vs SM883 [OEM] (Tootekood MZ7KH3T8HALS-00005)
Siin enterprise SSD https://www.samsung.com/us/business/products/computing/ssd/enterprise/
Siin on Samsung Datacenter SSD https://www.samsung.com/semiconductor/ssd/datacenter-ssd/
PM883 (DWPD 1.3(3yrs)) (Tootekood MZ7LH3T8HMLT) https://www.samsung.com/semiconductor/ssd/datacenter-ssd/MZ7LH3T8HMLT/
HinnaVaatluse lingid:
SSD Samsung PM883 [OEM] 3.84TB, SATA (Tootekood MZ7LH3T8HMLT-00005) https://www.hinnavaatlus.ee/1451187/samsung-pm883-oem-384tb-sata/
Win ISO'd ja uuendused
Artiklid jagatud
Kommentaarid: 55 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 52
toivos
toivos
sõnum 26.11.2019 10:06:39 vasta tsitaadiga
OEM-i ketast Samsung enda omaks ei tunnista. Utiliidid ja tugi ainult läbi OEM-i.
Taastan datat katkistelt ketastelt ja katkistelt Flash(USB) mäludelt. Nüüd ka katkistelt SSD ketastelt.
Kommentaarid: 69 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 65
Longero
sõnum 27.11.2019 07:39:51 vasta tsitaadiga
Ahah, ok garantiid saan läbi müüja kuid mitte nii pikka, selle elab üle ja utiliidid ka.
Kas OEM ketastel võib olla halvem firmware ja kehvemad komponendid v on kõik põhimõtteliselt sama? Eeldan, et firmware on siiski teine, muidu saaks Samsungi utikaga ligi.
Kas tasuks tagasi saata kui OEM asjad tulevad? Vaatasin netis kasutajate kommentaare ja isegi Amazon'ist tellinud inimesed saavad õige asja asemel OEM tooted. Osad müüjad üritavad üsna sarnaseid tooteid jälle sokutada õige asja asemel.
Tegu peaks nende SSD'dega olema sai tootekoodi järgi tellitud:
883 DCT 1.9TB (Tootekood MZ-7LH1T9NE) https://www.samsung.com/us/business/products/computing/ssd/enterprise/883-dct-1-9tb-mz-7lh1t9ne/
Artiklid jagatud
toivos
toivos
sõnum 27.11.2019 10:40:37 vasta tsitaadiga
Firmware uuenduse saad juhul kui OEM selle avalikult välja paneb.
sõnum 27.11.2019 12:57:11 vasta tsitaadiga
Tootja annab oma tootele tehasegaranti ütleme kolm või viis aastat, oemile saad kaks kui müüja alles on..
Kommentaarid: 1146 loe/lisa Kasutajad arvavad:  :: 3 :: 0 :: 722
sõnum 30.11.2019 00:02:30 vasta tsitaadiga
Sain täna ADATA XPG GAMMIX S11 Pro 1TB kätte ja karbi peal on kiirusteks 2100/1500, igalpool mujal 3350/2800 ja datasheetil ka nii väikseid numbreid ei näe. Karbi peal antireklaam? icon_biggrin.gif
sõnum 30.11.2019 09:19:42 vasta tsitaadiga
rmc kirjutas:
Ja edaspidi võiks ikka enne kodutöö ära teha ja alles siis poodi minna. Siis ei saa Sa vähemalt rohkem pügada.
Iga haritud Adata toodete ostja teab, et Adatal on väga palju tooteid mida on olemas nii vanemad kui uuemad varsioonid.
Ja nii sa pügada said: tahtisid uut ja kiiret kuid said hoopis vana ja aeglase versiooni:
Vaata pilte:
1. vana ja aeglane:
2. uus ja kiire:
Nüüd võta Ubuntu mingi USB-l olev "Live"-versioon.
Ubuntu sees on programm Disks.
Seal on olemas Kiirusetest. Paned selle tööle ja näed ära selle Adata tegelikud kiirused.
PS: On ainus programm mida võid usaldada. Need Windowsi all olevad programmid on tihti nii ja naa.
sõnum 30.11.2019 09:59:37 vasta tsitaadiga
tahanteada, ja kui sa amazonis ringi klikkisid, siis see "vana ja aeglane" on gammix s5, mitte s11 pro.
- londiste
Vael
sõnum 30.11.2019 11:26:34 vasta tsitaadiga
Pro peaks uuem olema. Ja mälu järgi oligi uuem aeglasem... Aga mitte nii palju? Võta SN ja löö googlesse, mis siin muud...
sõnum 01.12.2019 03:15:17 vasta tsitaadiga
tahanteada,
rmc kirjutas:
Miks sa mulle mingitest teistest mudelitest üldse räägid? Rahune veidi ja analüüsi sisu, enne kui lahmima rapsid.
Vael, vaata kommentaaris olevaid viiteid icon_razz.gif.
EDIT: Kuidas saada aru, kas SSD vajab OverProvisioning-u seadistamist või mitte?
ADATA SSD Toolbox seda varianti ei paku, samas Crucial-i programm pakub.
ADATA SSD Toolbox on sesmõttes ka eriti loll, et Firmware-i update-i võiks ikka programmis sees ise teha, mitte kodukale visata, kus sellekohast infot pole icon_biggrin.gif.
Plus selle asemel, et manualis soovitada korra nädalas TRIM-i jooksutada... võiks seda automaatselt tegema panna?!
Vael
sõnum 01.12.2019 11:59:43 vasta tsitaadiga
OP teeb FW ise? Kui ketast täis ei topi, siis jääb SLC cacheks piisacalt?
FW update, midagi kriitilist on ära parandatud, Crucial ja Samsung tulid ammu poolikute toodetega välja, mis nõudis uuendamist...
TRIM/optymize weekly on win10 by default C: ketta seadistus.
sõnum 01.12.2019 12:24:31 vasta tsitaadiga
Vael, puudub selle kohta info.. ainus info, mis olemasoleva OP kohta sain, oli review-st, et OP jaoks on vähem ruumi jäetud, kuna saadaval on rohkem mahtu kui eelmistel mudelitel. Tarkvaras samas OP variant puudub ja Cruciali omal nt. on see olemas... IMO võiks tootjad panna selle info ka tarkvarasse ning võimaluse OP tekitada ka muidugi... et oleks tervikülevaade.
FW-update osas ei saa aru, mida mõtled.
Win10 TRIM toimib ka reaalselt? & mul kõrvalketas ka SSD, kuidas sellele ka sisse lülitada?
sõnum 01.12.2019 17:21:39 vasta tsitaadiga
miks overprovisioning peaks seadistatav olema ketta või firmware tasemel?
rmc kirjutas:
üldjuhul ei tohiks olla mingit vajadust ise käsitsi midagi lülitada.
kontrolliks - vastus peaks olema 0:
fsutil behavior query DisableDeleteNotify
- londiste
sõnum 01.12.2019 17:58:14 vasta tsitaadiga
londiste, Crucial seda soovituslikult oma utiliidis (vähemalt 10%) pakub, järelikult on see mõistlik.
Eks see olenebki kettast, kas ja palju OP-d jäetud on.
Päringu vastused nullid, tänud!
Vael
sõnum 01.12.2019 20:04:56 vasta tsitaadiga
rmc kirjutas:
Dynamic OP oleneb mu arust palju FW, mõni kasutab palju SLC cacheks, mõni vähem. Mõni jätab võimaluse vajadusel juurde haugata, sest muidu jookseb ketas umbe...
Crucialil olid need imelike kogustega kettad ka vahepeal tootmises, 750GB jne. Neil vb oligi võimalus 25GB-le lisaks veel juurde lisada OP jaoks...
ADATA olid\on Mixed workload tasemel kui mitte tipus pidevalt, ei näe väga vajadust nende kodukootud FW modima minna. Samsung on ka paari viimase FW-ga järgi tulnud lõpuks.
Aga ikkagi, oled kindel, et S5 endale ei saanud? s11 peaks "päris SSD" olema, DRAM ka küljes. S5 on "säästukas" HBMga ehk DDR puudub ja sellest ka aeglasem... S11 peaks ainult kirjutamiskiirus mudelite lõikes kõikuma, S5 ongi üldse aeglasem. S11 PRO peaks uuem, ilma PRO-ta vanem ver olema. tahanteada, soovitus oli mõistlik, vaata mis bench näitab ja löö S \N(ketta enda mitte karbi pealt) otsingusse. Vale ketta said siis nõua õige sisse. Võib ka olla, et karp vale.
sõnum 01.12.2019 23:01:47 vasta tsitaadiga
Vael, kõik on s11 pro oma, ainult karbi peal on kiirused lambiselt kirjas. Ei olnud ju mõistlik soovitus kui ma tean, et s11 pro, ent kiirused valed karbi peal icon_razz.gif
Kõik muud asjad on õiged, v.a. see üks kiiruse kuulutamine.
Edit, igaksjuhuks puust ja punaseks siis:
Le Inc
Le Inc
sõnum 20.12.2019 16:11:49 vasta tsitaadiga
Synology RS3617xs+ ja 6tk HGST Ultrastar 8 TB ketast teevad 10Gb järjestiklugemist 2.5 GB/s ja kirjutavad 520 .. 500 MB/s. Ilmselt võiks SSD ka cacheks juurde pista .. aa muidu järjestiklugemises SSD mõõdu annab välja! icon_smile.gif
loox
sõnum 23.12.2019 10:27:58 vasta tsitaadiga
Le Inc kirjutas:
HGST Ultrastar 8 TB Sustained throughput on Storagereview andmetel 205 MB/s. Kui 6 tükki neid paralleelis loeb, saab maksimaalne kiirus olla 205 x 6 = 1230 MB/s. Mis üle selle peab keemia olema (kompressioon, cache vms.).
SilQ
SilQ
sõnum 23.12.2019 11:39:26 vasta tsitaadiga
If you can’t explain it simply, you don’t understand it well enough – Albert Einstein
Kommentaarid: 244 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 210
Le Inc
Le Inc
sõnum 23.12.2019 12:01:46 vasta tsitaadiga
loox kirjutas:
Le Inc kirjutas:
Ketta cache on sees jah, ilma cache 724 MB/s lugemine ja 557 MB/s kirjutamine.
SilQ kirjutas:
RAID10 on, ehk loeb 6x kiirusega, kirjutab 3x (teoorias)
dohc-48v12
Aeg maha 1p
dohc-48v12
sõnum 23.12.2019 12:05:20 vasta tsitaadiga
Noo 5-e või 10-sse oleks ehk loogiline 1-te mõttetu( lihtsam juba kaevikusse ronida) ja 0-s on rind haavleid täis icon_lol.gif
Aga jah ise vast paneks raid 5-te lihtsalt ei ole nii julge et kaotada selline kogus andmeid.
On olemas softi põhised raid-d aga kas see just sama mis raua põhised ei oska kommenteerida.
Miks ADMIN Anti112 ambusib mind? andis 1p cooldowni aga ma ei saa peale selle enam mitteühtegi postitust teha! üks päev ei kuid!
Kommentaarid: 112 loe/lisa Kasutajad arvavad:  :: 6 :: 0 :: 85
Le Inc
Le Inc
sõnum 23.12.2019 12:22:35 vasta tsitaadiga
dohc-48v12 kirjutas:
RAID10 läheb küll pool kettamahust raisku, aga suurem töökindlus ja taastamise kiirus on paremad kui RAID5, lisaks ka jõudlus. Kohati olen 3 kettaga RAID5 teinud, sealjuures SSD'ga ilmselt jõudluse faktor ei oleks teemaks, lisaks 1 ketta turvalisus.
SilQ
SilQ
sõnum 23.12.2019 13:05:05 vasta tsitaadiga
Le Inc, Möh? Matemaatikat ei tunne. 3x kiirus on ikka raid10'ne puhul.
rycyve
rycyve
sõnum 23.12.2019 18:55:32 vasta tsitaadiga
Mul näitab nii C:\Windows\system32>fsutil behavior query DisableDeleteNotify
NTFS DisableDeleteNotify = 0
ReFS DisableDeleteNotify = 1
Nagu ma aru saan siis see ReFS on miski piiratud test faili formaat või ei ja milleks see siin on icon_rolleyes.gif
Kommentaarid: 98 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 81
toivos
toivos
sõnum 23.12.2019 20:14:11 vasta tsitaadiga
rycyve kirjutas:
https://en.wikipedia.org/wiki/ReFS
uus teema   vasta Raud »  Kõvad kettad »  SSD versus HDD mine lehele eelmine  1, 2, 3 ... 469, 470, 471 ... 528, 529, 530  järgmine
