uus teema   vasta Raud »  Protsessorid »  Intel Core i3/i5/i7/i9/Xeon protsessorite arutelu vol2 märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 48, 49, 50 ... 176, 177, 178  järgmine
anubis
anubis
sõnum 07.12.2018 11:58:11 vasta tsitaadiga
iGPU osa on jätkuvalt katki.
Voolutarve on jätkuvalt kole (i3-8121U - 10nm Cannon Lake @ 15W 2.2-3.2Ghz 2c/4t ilma iGPUta - i3-8130U 14nm Kaby Lake @ 15W 2.2-3.4Ghz 2c/4t iGPUga)
http://www.cpu-world.com/Compare/847/Intel_Core_i3_Mobile_i3-8121U_vs_Intel_Core_i3_Mobile_i3-8130U.html
edit:
http://www.cpu-world.com/Compare/853/Intel_Core_i3_Mobile_i3-8121U_vs_Intel_Core_i3_Mobile_i3-8145U.html
Whiskey Lake kõrval paistab veel eriti niru see kivi välja.
edit:
Link
edit: https://www.anandtech.com/show/13683/intel-euvenabled-7nm-process-tech-is-on-track
Originally planned to enter mass production in the second half of 2016, Intel’s 10 nm process technology is still barely used by the company today. Currently the process is used to produce just a handful of CPUs, ahead of an expected ramp to high-volume manufacturing (HVM) only later in 2019. Without a doubt, Intel suffered delays on its 10 nm process by several years, significantly impacting the company's product lineup and its business.
Now, as it turns out, Intel’s 10 nm may be a short-living node as the company’s 7 nm tech is on-track for introduction in accordance with its original schedule.
sõnum 12.12.2018 18:46:47 vasta tsitaadiga
https://www.anandtech.com/show/13699/intel-architecture-day-2018-core-future-hybrid-x86
- londiste
anubis
anubis
sõnum 13.12.2018 21:33:54 vasta tsitaadiga
https://twitter.com/jimkxa/status/1073228283901227008?s=19
Zonerman
Zonerman
sõnum 15.12.2018 00:30:03 vasta tsitaadiga
Ilusad slaidid ja muud mitte miskit asjalikku.
Mulle meeldis see "What layer does the CIA/NSA backdoor reside in?"
Sõim ja räuskamine läheb SIIA
Kommentaarid: 67 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 66
sõnum 15.12.2018 02:43:06 vasta tsitaadiga
Silmad ja kolmnurgad läksid selle huumoriga hästi kokku ka.
anubis
anubis
sõnum 16.12.2018 15:21:07 vasta tsitaadiga
https://wccftech.com/intel-xeon-w-3175x-28-core-cpu-pricing-listing-online/amp/
Kui 7980 ja 9980 tunduvad liiga odavad siis... Lahendus on olemas.
Samas müüb Intel nüüd seda kivi 2.5x odavamalt kui serverites.
heretic666
heretic666
sõnum 20.12.2018 01:33:39 vasta tsitaadiga
Direct die cooling for 9900K
https://www.caseking.de/en/intel-core-i9-9900k-coffee-lake-sockel-1151-delidded-der8auer-intel-9th-gen.-oc-frame-cpbu-173.html
Väga palju ei võida, "liquid metal" ploki ja die vahele ajada sis võidad average 4 - 10 kraadi.
Anna tooli
sõnum 21.12.2018 21:05:04 vasta tsitaadiga
https://www.tomshardware.com/news/i9-9900kf-i7-9700kf-i5-9600kf-i5-9400f-prices,38284.html
Kommentaarid: 363 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 299
sõnum 21.12.2018 21:54:45 vasta tsitaadiga
Early Access kirjutas:
Deactivating the GPU has other benefits, too. Like the other units on a chip, the integrated graphics unit consumes power, and thus produces heat. Deactivating this portion of the chip would then presumably lower thermal output, if only slightly, which could open up more headroom for higher boost clocks, longer boost duration, or overclocking capability. The disabled unit would also serve as 'dark silicon,' which is unused silicon that absorbs heat from surrounding chip structures, thus improving thermal performance.
See pole päris tõene. Inteli prosedel on nn power gating mis tähendab, et kui BIOS-st iGPU välja lülitada, siis see tõesti on väljas, ei võta voolu ega tekita kuuma.
Nagu artiklis kirjas on see puhas yield issue kus Intel otsustas defektse iGPU-ga mudelid müüki paisata keerates iGPU püsivalt kinni. Vaevalt nende kogus ka väga suur on ja need väga populaarseks saavad aga enamus inimestele (eriti 9900KF) ostjatele pole ilmselt vahet. Ryzenid on enamus kõik ilma iGPU-ta ja müüvad vägagi hästi ka mainstream segmendis. See iGPU teema on rohkem esmakordse arvuti saajate ja nende teema kes kasutavad iGPU-d millegi kiirendamiseks (mis jällegi on Adobe jms tegemate töö dGPU toetamisel). Need kes juba pikemalt arvuteid omanud või mitut lauaarvutit omavad on ilmselt ka traubleshootimise jaoks mingi teine dGPU võtta. Minul vedeleb neid vanu siin mitu tükki. Kõik Nvidia omad: 8800GTS 320 ja GTS 640 ja GTX 560.
sõnum 24.12.2018 15:26:42 vasta tsitaadiga
ASRock Z170M EXTREME4 peal on üks stock cooleriga i5-6600K, mis lähiajal korraliku jahuti ja OC selga saab. Kui tahta üpris vähe kulutada, siis 212EVO või midagi muud? (Korpus Corsair Carbide 88r ja GPU 280X WF3 hetkeseisuga).
EDIT: ise küsin, ise vastan: Arctic Freezer 33 eSports One läheb loosi.
anubis
anubis
sõnum 28.12.2018 00:22:11 vasta tsitaadiga
Link
sõnum 28.12.2018 08:42:05 vasta tsitaadiga
oeh, gamersnexus on ikka parasjagu alla käinud
nende graafikud on loetamatud. ja mission statementi arvestades võinuks siis vähemalt 9700k/8700k (ja ideaalis ka 8600k/9600k/9900k) samal taktil testida.
- londiste
rycyve
rycyve
sõnum 28.12.2018 10:33:35 vasta tsitaadiga
londiste kirjutas:
See on juba ammu nii icon_biggrin.gif Ainus asi mida sealt saab on miski asja lahkamine(videod kuigi kruvikas on neil kõver või lahja)Muud mula ei pea tõepähe võtma,sest sellex on reaalsus (sry) icon_razz.gif
Kommentaarid: 98 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 81
anubis
anubis
sõnum 28.12.2018 11:08:04 vasta tsitaadiga
Miks neid samal taktil testida?
Kui iga kivi on testitud @stock (julgelt üle poolte kasutajatest nagunii sedasi jooksutavad) ja selle konkreetse kivi @oc (entusiastid) siis saaks nagu justkui iga huviline võimalikust jõudlusest pildi ette? Eriti kui sama on ka võimalike konkurentidega tehtud.
Ma isiklikult jooksutan näiteks iga CPUd temale isiklikult kõige sobivamaks timmitud sagedusel/voldil. Mitte ei püüa nui neljaks mingit ühtlast takti saavutada. Tähendaks see ju muidu enamasti mõne isendi üle- ja teise alavoltimist.
Kui kivi voldiga ei skaleeru siis lihtsam leppida väiksema OCga või püüda undervoltida @stock. Win-win.
Killhoven
OC`er
Killhoven
sõnum 29.12.2018 09:29:30 vasta tsitaadiga
anubis kirjutas:
Ise teen täpselt sama.
Kommentaarid: 405 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 349
sõnum 29.12.2018 19:38:59 vasta tsitaadiga
Mis te arvate kas peaks tegema eraldi teema Inteli graafikakaartide jaoks, et GPU arutelu siinset teemat ei risustaks?
Keegi on teinud ka esimesed joonised kuidas Inteli graafikakaardid võiks välja näha. Muidugi suur firma teeb ise oma otsused seega selline see välja nägema ei hakka aga visuaalselt pole viga imo. Tehnilised näitajad on muidugi iseasi, sest selline pisike vurr kaardil hakkaks põrgulärmi tegema.
Igatahes: https://videocardz.com/79437/intel-graphics-xe-concept-design-raises-hopes-and-expectations
sõnum 29.12.2018 19:41:18 vasta tsitaadiga
eraldi teema.
selliste ledide peale ei hakka ükski gpu tootja ruumi raiskama, shroudi all iga vaba ruutsentimeeter läheb suurema radika võimaldamiseks.
- londiste
sõnum 29.12.2018 20:24:59 vasta tsitaadiga
londiste kirjutas:
eraldi teema.
Tegin eraldi teema: https://foorum.hinnavaatlus.ee/viewtopic.php?p=10026597
Xenomorph
sõnum 01.01.2019 12:22:57 vasta tsitaadiga
Kiire küsimus, kas keegi foorumist protsessoritega hangeldab?
Kommentaarid: 30 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 29
anubis
anubis
sõnum 01.01.2019 14:35:09 vasta tsitaadiga
Link
sõnum 02.01.2019 09:42:18 vasta tsitaadiga
rohkem tuumasid ja lõimesid on järjest enam memory-starved...
edit:
enamus infost on juba läbi käinud aga päris korralik kokkuvõte tollest inteli arhitektuuripäevast:
https://fuse.wikichip.org/news/1941/intel-reveals-10nm-sunny-cove-core-a-new-core-roadmap-and-teases-ice-lake-chips/
- londiste
anubis
anubis
sõnum 02.01.2019 10:17:40 vasta tsitaadiga
Intel oskab ikka häid protsessoreid teha.
E3-1265L v3 sai kodunasi võetud. Kui RAMi hind nii nõme poleks oleks tõenäoliselt Ryzen7 peale liikunud, kuid praegu oli terve platvormi uuendamine rahaliselt mõttetu.
Sathanas
sõnum 03.01.2019 22:38:56 vasta tsitaadiga
der8auer uurib ja testib z270 ja z370 erinevusti. Inteli väitel, et z270 ei suuda piisavalt voolu anda suurema tuumade arvuga protsessoritele ei pea kuidagi paika.
Auron
Auron
sõnum 04.01.2019 11:01:06 vasta tsitaadiga
Sathanas, küsimus pole selles kas hetkel ära toidab vaid kuidas on lood peale mitut kuud ja aastat - kui paar aastapärast plated lendama hakkaks oleks ju kisa taevani.
Kommentaarid: 154 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 131
Sathanas
sõnum 04.01.2019 17:39:15 vasta tsitaadiga
Ta proovis umbes 5 kordse varuga pinist voolu läbi lasta, sel juhul oli pini temperatuur 50 kraadi ringis. Protsessor ise kuumutab pine ja socetit oluliselt rohkem.
uus teema   vasta Raud »  Protsessorid »  Intel Core i3/i5/i7/i9/Xeon protsessorite arutelu vol2 mine lehele eelmine  1, 2, 3 ... 48, 49, 50 ... 176, 177, 178  järgmine
