axis
12.05.2004 18:52:30
Viska või minema?! |
Video : Hercules Radeon 8500le fdx 64MB
Driver: 7.76 cat 2.2
Mure: Ilmselt kohe küsite miks nii vanad driverid... Põhjus lihtne - nendega on arvuti kõige stabiilsem aga siiski mitte piisavalt - selleks tegingi uue teema.
Mängudes ja 3d margi testides liigub pilt suhteliselt hästi. Aga aeg-ajal jookseb arvuti kinni ja seda AINULT neti "surfates" (Mozilla Firefox, IE ) . Täielikult arvuti hangub ei tee absoluutselt midagi isegi kursor kaob.... Päästab restart...Ja WinXP annab sellise vea teate :
Ja toon välja ka logi file vms:
// Watchdog Event Log File
LogType: Watchdog
Created: 2004-05-12 18:30:06
TimeZone: -120 - FLE Standard Time
WindowsVersion: XP
EventType: 0xEA - Thread Stuck in Device Driver
// The driver for the display device got stuck in an infinite loop. This
// usually indicates a problem with the device itself or with the device
// driver programming the hardware incorrectly. Please check with your
// display device vendor for any driver updates.
EaRecovery: 1
ShutdownCount: 112
Shutdown: 0
EventCount: 6
BreakCount: 6
BugcheckTriggered: 1
DebuggerNotPresent: 1
DriverName: ati2dvag
EventFlag: 1
DeviceClass: Display
DeviceDescription: 3D Prophet 8500 Series
HardwareID: PCI\VEN_1002&DEV_514C&SUBSYS_00021681&REV_00
Manufacturer: Hercules Technologies
DriverFixedFileInfo: FEEF04BD 00010000 0006000D 000A17E6 0006000D 000A17E6 0000003F 00000008 00040004 00000003 00000004 00000000 00000000
DriverCompanyName: ATI Technologies Inc.
DriverFileDescription: ATI Radeon WindowsNT Display Driver
DriverFileVersion: 6.13.10.6118
DriverInternalName: ati2dvag.dll
DriverLegalCopyright: Copyright (C) 1998-2002 ATI Technologies Inc.
DriverOriginalFilename: ati2dvag.dll
DriverProductName: ATI Radeon Family
DriverProductVersion: 5.1.2600.0
Väike nõu alati abiks ..... palun ärge soovitage uuemaid drivereid, sest nendega see kaart ei toimi - mängudes ja ka testides (3DMark) jooksevad triibud ette vms.
Tean et see kaart ei ole just suurem asi aga ikkagi kas peale ära viskamise on võimalik mingi muu lahendus?
Tänud
Cyberlord
12.05.2004 18:58:01
Kui triibud ette jooksevad, siis vast core/mälu õhtul omadega.....kas saavad ikka korralikult jahutust?
Neid triipe millegi muuga seletada ei anna, seega suht kindel, et kaart ise on töölepingu lõpetanud 8)
| Kommentaarid: 546 loe/lisa |
449 |
axis
12.05.2004 23:33:33
| Seda juhtub ainult uuemate Driveritega ju... Need mis peal (suht vanad) nendega pole mängus jama ..jama muus ..kirjeldasin eespoool
DigeBeni
13.05.2004 09:06:46
... toksid otsingusse sisse "FDX" ja Sa leidad väga palju juttu selle kaardi teemal, üsna probleemne isend ...
163 |
Noname
13.05.2004 09:15:30
ongi perses isend, omal samasugune olnud.
mis kividega sul emaplaat on? mul oli sis730. kunagi ammu sellise kaardiga ja jamas kah ikka sitaks...mängudes koguaeg pang ja winis töötas ilusti - aitas biosis AGP aparaadi memory size muutmine, fast write näppimine ja kõik mis videoga seotud. täpselt ei mäleta mis seaded panin, et korralikult töötas.
Soovitan ükshaaval biosi erinevaid seadevõimalusi proovida - mul läks vast nädalake kuni õiged seaded kätte sain.
Kui õieti mäletan panin need ka kusagile vihikusse kirja, aga see vihik hetkel haapsalus ja peast öelda ei oska mis täpselt määravaks osutus...
edu
_________________ "Olukord on sitt, aga see on meie tuleviku väetis." - Lennart Meri
"Edu on kehv õpetaja. See ahvatleb tarku inimesi mõtlema, et nad ei saagi kaotada" - B. Gates |
| Kommentaarid: 372 loe/lisa |
321 |
tsihh
13.05.2004 11:41:35
| fastwrite maha (kui see peal juhtub olema). endal 9200ga sama jama oli mingite draiveritega - niikui FW peal oli ladus sama errorit just veebis surfates (eriti veel kui javat vaja oli)
| Kommentaarid: 59 loe/lisa |
58 |
Trwind55
16.05.2004 02:00:29
Mul see sama R8500LE FDX viskab triipu siin . Seega küsimus: kas mul on õigus garantii korras uuele vidoeokaardile, kui 3dmark programmides esimese testi ajal triibud ette viskab e. arvuti jookseb kokku?
_________________ möhhh.. |
| Kommentaarid: 22 loe/lisa |
21 |
DigeBeni
16.05.2004 11:50:58
| Trwind55 kirjutas: |
Mul see sama R8500LE FDX viskab triipu siin . Seega küsimus: kas mul on õigus garantii korras uuele vidoeokaardile, kui 3dmark programmides esimese testi ajal triibud ette viskab e. arvuti jookseb kokku? |
... Sa küsid, et kas Sul on õigus garantiile, kui ostetud ese pole sihtotstarbeliseks kasutamiseks kõlblik ? Loomulikult on Sul õigus garantiile ! Kuid selle kaardiga on säärane kala, et mõne kiibistikuga võib ta üsna korralikult koos töötada, kuid mõne puhul, ei saa isegi korralikult süsteemi püsti. Nagu ma mainisin, tasub uurida vanemaid teemasid, siin üsna palju ka võimalikest alternatiivsetest lahendustest juttu ...
163 |
ePe
16.05.2004 12:06:12
Mul oli sama probleem vana toiteplokiga.
Enne toiteploki vahetamist jõudsin ta BIOSi vahetada 9100 biosi vastu, tehase ventilaatori maha kiskuda ja asendada suure radikaga jne.
Uue toitekaga pole selliseid jamasid olnud.
| Kommentaarid: 8 loe/lisa |
Laurikre
16.05.2004 12:53:41
Aga kas kaardil Garantiid enam ei ole...
Laurikre:.
_________________ Need: Windows, .Net, Sharepoint, Exchange, Dynamics, Visual Studio, XNA, Expression, Silverlight, SQL and many other skills? Talk to me
Rohkem IT uudiseid iga päev BattleIT lehelt |
131 |
madest
16.05.2004 16:05:37
| Imestama paneb et 3dmark ja mängud norm jooksevad. Selle seeriaga tuli eestisse kõvasti vigaseid kaarte...Oli võimalus proovida 10 isendit kõik vigased. 3dmark pani kooma.... triibud... Tuttaval oli see kaart ja ainus võimalus oli underclokingut teha. Siis asi käis kuidagi
| Kommentaarid: 13 loe/lisa |
