uus teema   vasta Raud »  Videokaardid / Monitorid / TV »  nVidia uus 5664XP WHQL driver märgi kõik teemad loetuks
Kalle
sõnum 29.02.2004 18:18:11 nVidia uus 5664XP WHQL driver vasta tsitaadiga
EDIT: Nüüd siis alates 15.03 nVidia lehel väljas ka ametlik versioon 56.64
Lisatud on mängude jaoks päris hea feature mängude profiilide jaoks
Driverite review on siin: http://www.firingsquad.com/hardware/forceware_56.56/
Auto Installer: Yes
WHQL: Yes
Driver File: 5656XP_WHQL.exe http://www.evga.com/support/downloads/default.asp
Notes: These drivers are Microsoft WHQL certified for Windows 2000 and Windows XP. They contain a significant number of updates.
Corrected the following issues:
Corrects problems with custom Direct3D profiles
Corrects problems with custom OpenGL profiles
Corrects problems with the game Tomb Raider Angel of Darkness
Corrects problems with Dualview secondary montior support
Corrects OpenGL issues with 3D Paint 2001, Maya 5.0, and Studio Tools 11
Corrected problem with setup where users could see the error message "error loading nview.dll; access is denied"
Corrected texture corruption issues with RenderWare Studio
Corrected problems with Command and Conquer Generals
Corrected problems with Armies of eXigo
Corrected problems with Command and Conquer Zero Hour
Corrected system crash problem with Final Reality
Corrected problems with full screen spanning in Windows 2000
Corrected antialiasing issues in Flight Simulator 2004
Corrected font problems in Jedi Knight 2
Corrected performance issues with NASCAR 2003 Season
Corrected various rendering problems on Digital LCD monitors
Corrected problems with Big Mutha Truckers
Corrected performance issues with Splinter Cell
Corrected image problems with Star Wars Knights of the Old Republic
Corrected overclocking/auto overclocking through the control panel
viimati muutis Kalle 24.03.2004 18:36:56, muudetud 2 korda
Volthezz
sõnum 29.02.2004 20:39:27 vasta tsitaadiga
Kui ma neid kasutan siis winni bootides annab windows protection errori.
Kalle
sõnum 29.02.2004 21:06:42 vasta tsitaadiga
Volthezz kirjutas:
Endal töötavad küll normaalselt, pole mingit jama olnud.
Volthezz
sõnum 29.02.2004 23:59:18 vasta tsitaadiga
Need driverid on not supported by nvidia. Mõnel võib anda errori mõnel mitte.
MatrixMan
MatrixMan
sõnum 01.03.2004 01:02:22 vasta tsitaadiga
mul töötavd need modifyed driverid normaalselt, isegi FPS on rohkem icon_wink.gif
Kommentaarid: 35 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 32
Cyberlord
sõnum 01.03.2004 01:07:11 vasta tsitaadiga
Töötavad hästi aga mingit preformance vahet pole veel märganud. icon_confused.gif
Kommentaarid: 546 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 449
One
sõnum 01.03.2004 13:23:37 vasta tsitaadiga
midagi juurde küll ei tulnud, kiirust siis...
paremaks kah midagi ei muutunud - lisaks läksid farcry demo varjud vigaseks(sinisteks)
ei tea mis see nvidia tegi aga paremuse poole küll asi ei läinud, performance poolest vähemalt..
igasugu tweakimis vidinaid on jah juures ja asjad töötavad kah nagu vaja thumbs_up.gif
Volthezz
sõnum 01.03.2004 15:36:38 vasta tsitaadiga
Kas nvidia üldse tegi need driverid kui nvidia ei supporti neid ?
Kalle
sõnum 01.03.2004 18:06:43 vasta tsitaadiga
Volthezz kirjutas:
Volthezz kirjutas:
Volthezz kirjutas:
WARNING: DO NOT USE THESE DRIVERS WITH THE FX 5200 ULTRA - THE DRIVERS ON YOUR DRIVER CD ARE THE MOST APPROPRIATE FOR USE ON THAT CARD AT THIS TIME.
Kasuta oma FX5200 peal Driver Version: 45.23
MatrixMan
MatrixMan
sõnum 02.03.2004 01:03:50 vasta tsitaadiga
tegin lõpuks 3dmarki, ja selgus et hullult vähe punne sain icon_mad.gif ,
UUS
sõnum 04.03.2004 11:30:03 vasta tsitaadiga
punnid enam vähem samad aga mängudes tundub et pilt on ilusam icon_biggrin.gif icon_biggrin.gif icon_biggrin.gif
Taavi_789
sõnum 06.03.2004 11:46:28 vasta tsitaadiga
Proovisin ka ära. Kiirust juurde jah ei tulnud, aga pilt mängudes paranes.
"Audaces fortuna juvat!" (Julgeid kroonib edu!)
Kalle
sõnum 20.03.2004 17:06:27 vasta tsitaadiga
Nüüd siis alates 15.03 nVidia lehel väljas ka ametlik versioon 56.64. Sisaldab popup blokkerit IE 6 jaoks ja game profiilerit.
Kusjuures driverites kaasasolev IE6 popup killer töötab täitsa thumbs_up.gif
viimati muutis Kalle 22.03.2004 19:46:35, muudetud 2 korda
pelmeen
sõnum 20.03.2004 17:26:49 vasta tsitaadiga
Mul võttis 56.64 3dmarkis 500 punni vähemaks ja mängudes ka erinevusi pole märganud. Kas keegi sellega doom 3 beta 2( või alphat, sama asi vist) on proovinud?
http://www.hot.ee/eestiomadjobud
Ohakaoskar
Ohakaoskar
sõnum 22.03.2004 19:20:46 vasta tsitaadiga
Pilt nagu läks pisut paremaks aga skoori 3dmark2001 tõmbas küll ligi 1000 punkti alla. Mängude perfomance vist ei vähenenud, vähemalt aru pole saada.
Kommentaarid: 209 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 187
Satan
sõnum 23.03.2004 12:22:10 vasta tsitaadiga
einoh, 3d mark 2k1(2k3)-e punktivahe ei pruugi tähendada, et driver pn nüüd sit või hea. näiteks: sai paar kuud tagasi max payne 2-s nii tehtud, et frapsiga panin iga sekund teatud logima fps-i (sama koht alati) ja siis proovisin erinevaid drivereid ning arvutasin andmete põhjal keskmise ja selgus, et 46.67, mis 3d margis kõige paremad minu kaardi puhul (ti4200), olid kõige halvemad ja parimad siis 52.16, fps-ide vahe oli küll ainult 4 aga siiski.
TI4200 128MB VIVO
mutabor
mutabor
sõnum 23.03.2004 12:56:53 vasta tsitaadiga
FarCry's nagu sai keskmiselt 10 fps juurde oma fx5900'ga
/allkiri
Kommentaarid: 24 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 22
pelmeen
sõnum 24.03.2004 02:51:50 vasta tsitaadiga
Sellel pidi kaasas olema mingi ie pop-upide blokker, aga kuidas seda aktiveerida?
Kalle
sõnum 24.03.2004 03:30:54 vasta tsitaadiga
Sellelt nVidia webilehelt, kust sa selle driveri alla laed leiad nats allpoolt viite http://www.nvidia.com/object/pop-up.html
>-Shifty-
Keelatud avatar
sõnum 24.03.2004 10:49:56 vasta tsitaadiga
mina kasutan 53.03 StarStormi ... viimasepeal driverid
traks
sõnum 24.03.2004 15:28:00 vasta tsitaadiga
>-Shifty- kirjutas:
need on siis ühe teismelise "tehtud" draiverid, kus LOD bias on seatud vägisi -15 peale icon_confused.gif autori sõnul nii kvaliteetne, et näed mängudes iga liivatera. probleem on selles, et näed liivaterasid ka mängus, kus tegelikult liiva pole icon_lol.gif
>-Shifty-
Keelatud avatar
sõnum 24.03.2004 16:12:51 vasta tsitaadiga
ehm ... kuuled sa asi on selline et mida rohkem sa kiirust välja pressid oma MX400'st seda parem...ning kui töötab siis hästi...
MadMan
MadMan
sõnum 25.03.2004 00:33:54 vasta tsitaadiga
hmm mul keeras 56.64 videovaatamise tuksi. nagu mingi zoom on peal. jama.
üldine pilt nagu paranes samas.
Ikka Saab
~~NetMusique~~
Kommentaarid: 31 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 29
Kalle
sõnum 25.03.2004 03:08:16 vasta tsitaadiga
MadMan kirjutas:
Aga ehk aitab kui video ''Overlay Controls''settingute alt paned ''Video Overlay'' Zoom controlli ''Out'' e. vajutad ''Restore defaults''
pelmeen
sõnum 25.03.2004 11:30:29 vasta tsitaadiga
Draiveriga kaasas selline hoiatus, et võib automaatselt lülitada sisse clone mode-i, isegi kui ei ole 2 monitori taga. On kellegagi see juhtunud ja kust saaks seda üldse vaadata, kas see on sees?
Soskin
sõnum 25.03.2004 11:45:03 vasta tsitaadiga
Nenede Warning'utega on nii, et kaasasolevas README failis on kirjutatud ju, et nad ei toeat FX5200 seeria kaarte. icon_lol.gif thumbs_up.gif
Sellest on ka varem juba kuskil foorumites või kuskil räägitud.
Mart
Mart
sõnum 25.03.2004 11:47:31 vasta tsitaadiga
Kommentaarid: 5 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 4
MadMan
MadMan
sõnum 25.03.2004 20:35:22 vasta tsitaadiga
reinstall aitas...
Ikka Saab
~~NetMusique~~
