Kalle
29.02.2004 18:18:11
nVidia uus 5664XP WHQL driver |
EDIT: Nüüd siis alates 15.03 nVidia lehel väljas ka ametlik versioon 56.64
Lisatud on mängude jaoks päris hea feature mängude profiilide jaoks
Driverite review on siin: http://www.firingsquad.com/hardware/forceware_56.56/
Auto Installer: Yes
WHQL: Yes
Driver File: 5656XP_WHQL.exe http://www.evga.com/support/downloads/default.asp
Notes: These drivers are Microsoft WHQL certified for Windows 2000 and Windows XP. They contain a significant number of updates.
Corrected the following issues:
Corrects problems with custom Direct3D profiles
Corrects problems with custom OpenGL profiles
Corrects problems with the game Tomb Raider Angel of Darkness
Corrects problems with Dualview secondary montior support
Corrects OpenGL issues with 3D Paint 2001, Maya 5.0, and Studio Tools 11
Corrected problem with setup where users could see the error message "error loading nview.dll; access is denied"
Corrected texture corruption issues with RenderWare Studio
Corrected problems with Command and Conquer Generals
Corrected problems with Armies of eXigo
Corrected problems with Command and Conquer Zero Hour
Corrected system crash problem with Final Reality
Corrected problems with full screen spanning in Windows 2000
Corrected antialiasing issues in Flight Simulator 2004
Corrected font problems in Jedi Knight 2
Corrected performance issues with NASCAR 2003 Season
Corrected various rendering problems on Digital LCD monitors
Corrected problems with Big Mutha Truckers
Corrected performance issues with Splinter Cell
Corrected image problems with Star Wars Knights of the Old Republic
Corrected overclocking/auto overclocking through the control panel
viimati muutis Kalle 24.03.2004 18:36:56, muudetud 2 korda |
| Kommentaarid: 4 loe/lisa |
Volthezz
29.02.2004 20:39:27
| Kui ma neid kasutan siis winni bootides annab windows protection errori.
Kalle
29.02.2004 21:06:42
| Volthezz kirjutas: |
| Kui ma neid kasutan siis winni bootides annab windows protection errori. |
Endal töötavad küll normaalselt, pole mingit jama olnud.
Volthezz
29.02.2004 23:59:18
| Need driverid on not supported by nvidia. Mõnel võib anda errori mõnel mitte.
MatrixMan
01.03.2004 01:02:22
mul töötavd need modifyed driverid normaalselt, isegi FPS on rohkem
| Kommentaarid: 35 loe/lisa |
Cyberlord
01.03.2004 01:07:11
Töötavad hästi aga mingit preformance vahet pole veel märganud.
| Kommentaarid: 546 loe/lisa |
449 |
One
01.03.2004 13:23:37
midagi juurde küll ei tulnud, kiirust siis...
paremaks kah midagi ei muutunud - lisaks läksid farcry demo varjud vigaseks(sinisteks)
ei tea mis see nvidia tegi aga paremuse poole küll asi ei läinud, performance poolest vähemalt..
igasugu tweakimis vidinaid on jah juures ja asjad töötavad kah nagu vaja
728 |
Volthezz
01.03.2004 15:36:38
| Kas nvidia üldse tegi need driverid kui nvidia ei supporti neid ?
Kalle
01.03.2004 18:06:43
| Kas nvidia üldse tegi need driverid kui nvidia ei supporti neid ? |
| Need driverid on not supported by nvidia. Mõnel võib anda errori mõnel mitte. |
WARNING: DO NOT USE THESE DRIVERS WITH THE FX 5200 ULTRA - THE DRIVERS ON YOUR DRIVER CD ARE THE MOST APPROPRIATE FOR USE ON THAT CARD AT THIS TIME.
Kasuta oma FX5200 peal Driver Version: 45.23
MatrixMan
02.03.2004 01:03:50
tegin lõpuks 3dmarki, ja selgus et hullult vähe punne sain ,
panin miskid 40.72 ja kohe 1000p juures
UUS
04.03.2004 11:30:03
punnid enam vähem samad aga mängudes tundub et pilt on ilusam
| Kommentaarid: 11 loe/lisa |
Taavi_789
06.03.2004 11:46:28
Proovisin ka ära. Kiirust juurde jah ei tulnud, aga pilt mängudes paranes.
_________________ "Audaces fortuna juvat!" (Julgeid kroonib edu!) |
Kalle
20.03.2004 17:06:27
Nüüd siis alates 15.03 nVidia lehel väljas ka ametlik versioon 56.64. Sisaldab popup blokkerit IE 6 jaoks ja game profiilerit.
Kusjuures driverites kaasasolev IE6 popup killer töötab täitsa
viimati muutis Kalle 22.03.2004 19:46:35, muudetud 2 korda |
pelmeen
20.03.2004 17:26:49
Mul võttis 56.64 3dmarkis 500 punni vähemaks ja mängudes ka erinevusi pole märganud. Kas keegi sellega doom 3 beta 2( või alphat, sama asi vist) on proovinud?
_________________ http://www.hot.ee/eestiomadjobud |
Ohakaoskar
22.03.2004 19:20:46
| Pilt nagu läks pisut paremaks aga skoori 3dmark2001 tõmbas küll ligi 1000 punkti alla. Mängude perfomance vist ei vähenenud, vähemalt aru pole saada.
187 |
Satan
23.03.2004 12:22:10
einoh, 3d mark 2k1(2k3)-e punktivahe ei pruugi tähendada, et driver pn nüüd sit või hea. näiteks: sai paar kuud tagasi max payne 2-s nii tehtud, et frapsiga panin iga sekund teatud logima fps-i (sama koht alati) ja siis proovisin erinevaid drivereid ning arvutasin andmete põhjal keskmise ja selgus, et 46.67, mis 3d margis kõige paremad minu kaardi puhul (ti4200), olid kõige halvemad ja parimad siis 52.16, fps-ide vahe oli küll ainult 4 aga siiski.
_________________ TI4200 128MB VIVO |
mutabor
23.03.2004 12:56:53
FarCry's nagu sai keskmiselt 10 fps juurde oma fx5900'ga
_________________ /allkiri |
| Kommentaarid: 24 loe/lisa |
22 |
pelmeen
Kalle
>-Shifty-
24.03.2004 10:49:56
| mina kasutan 53.03 StarStormi ... viimasepeal driverid
10 |
traks
304 |
>-Shifty-
24.03.2004 16:12:51
| ehm ... kuuled sa asi on selline et mida rohkem sa kiirust välja pressid oma MX400'st seda parem...ning kui töötab siis hästi...
10 |
MadMan
25.03.2004 00:33:54
hmm mul keeras 56.64 videovaatamise tuksi. nagu mingi zoom on peal. jama.
üldine pilt nagu paranes samas.
_________________ Ikka Saab
~~NetMusique~~ |
| Kommentaarid: 31 loe/lisa |
29 |
Kalle
25.03.2004 03:08:16
| MadMan kirjutas: |
üldine pilt nagu paranes samas. |
Aga ehk aitab kui video ''Overlay Controls''settingute alt paned ''Video Overlay'' Zoom controlli ''Out'' e. vajutad ''Restore defaults''
pelmeen
25.03.2004 11:30:29
Draiveriga kaasas selline hoiatus, et võib automaatselt lülitada sisse clone mode-i, isegi kui ei ole 2 monitori taga. On kellegagi see juhtunud ja kust saaks seda üldse vaadata, kas see on sees?
Soskin
25.03.2004 11:45:03
Nenede Warning'utega on nii, et kaasasolevas README failis on kirjutatud ju, et nad ei toeat FX5200 seeria kaarte.
Sellest on ka varem juba kuskil foorumites või kuskil räägitud.
| Kommentaarid: 8 loe/lisa |
Mart
25.03.2004 11:47:31
kuidas Ti4200 lood on ?
endal hetkel 53.03, millega TV-Out on paras areng.
MadMan
29 |
