Apple'i boss Steve Jobs naases korraks haiguspuhkuselt avalikkuse ette, esitledes San Franciscos ovatsioonide saatel tahvelarvuti iPadi teise põlvkonna mudelit.
Uus iPad on kiirema protsessoriga kui selle eelkäija, kahe kaameraga - üks pildistamisega ja teine videokõneks - ning sarnase kestvusega. Sisselülitatuna peaks aku vastu pidama kümme tundi. IPad muutub ka õhemaks - 8,8 millimeetrit praeguse 13,4 asemel.
Thinner than the iPHONE 4!
Faster with an all new A5 chip, 9X faster than iPad 1.
HDMI OUTPUT at 1080P! YES! Mirrored output cable available.
Prices start at $499 for WiFI only 16 GB
Available in BLACK and WHITE!
iOs update that makes an iPhone 4 a WIFI spot, so you dont need anything but the iPad 2 wifi!
HD Video Recording, and AWESOME video editing.
TWO cameras, and of course, facetime.
Announced at an event currently taking place in San Francisco, California, the iPad 2 has been made official and will be available in two colors, black and white, when it launches Friday week (March 11).
Aside from having a 33 percent slimmer design (it’s thinner than iPhone 4), the iPad 2 packs a new chip that Apple is calling the A5. It’s dual-core, packs twice the speed and nine times faster graphics but with the same low power consumption as the A4. It’s got that same 10 hour battery life; two cameras, one on the front and one on the back; a built in the gyroscope; and HDMI out via a small adapter that allows you to charge at the same time.
It’s available on both AT&T and Verizon and Apple is keeping the same $499 base price for the 16GB WiFi-only model. From there, prices go up as far as $829 (that’s for the 64GB 3G model). However, Apple was quick to point out that five out of six of the iPad models are priced at under $799, which was a sly little dig at the $799 Motorola Xoom.
Apple also revealed something called Smart Covers, which clip onto the side of the iPad 2 and magnetically sticks to the front of the device. Peeling it away will wake up the device and it can be folded up in a number of different configurations for multiple ‘standing’ options. The Smart Covers come in a range of colors in either polyurethane or leather and will cost $39 (poly) and $69 (leather).
Oleneb, mis tempos ning kui praktiline selle UI on ( kuna pöidlaid üle fullqwerty vehkida 10" on lollus, siis ideaalis oleks parem ja vasak klaviatuur, kus näppudega vehtida ja autospellinguid tulistada ).
Nutitelefoniga on hulga mugavam minu nägemust mööda.
Aga kui tõsiselt rääkida, siis kirjaplokk ja kvaliteetne kirjutusvahend või netbook.
nojah ekraani PPI võiks küll kõrgem olla. sellisel seadmel peab lihtsalt olema kõrge resolutsioon, et silmad ära ei väsiks näiteks raamatut lugedes vms.
sellise junniga oleks vast siis võimalik konspekti kirjutada kui ei trüki vaid reaalselt pulgaga nühid plaati. jube ebamugav võib olla trükkida asjaga mis sisuliselt on "laud". Ehk siis 0% feedback'i seadmelt kui trükkid.
head trükkimasinat vaja siis tasuks vaadata parem üks korralik netbook või veel parem korralik läppar. tablet funksioon oleks sellel hää kuna siis saaks ka pulgaga joonised vms asjad vast konspekti visata. _________________ |--{o,o}-----(\__/)-----------------|
olen proovinud ipadi jaoks mõeldud klaviatuuri, üsna mõistlik vigur. Mulle istuks kah füüsiline klaver rohkem kui ekraani peal toksimine.
mis mõte sellel ipad'il on kui ostad eraldi klaveri + padi hoidja? parem siis juba netbook, läppar osta.
eriti veider oleks vaadata kedagi kes kannab kaasas ipad'i ja selle klaverit kuna vastasel juhul ei ole asi mugav kasutada _________________ |--{o,o}-----(\__/)-----------------|
mis mõte sellel ipad'il on kui ostad eraldi klaveri + padi hoidja? parem siis juba netbook, läppar osta. :roll:
eriti veider oleks vaadata kedagi kes kannab kaasas ipad'i ja selle klaverit kuna vastasel juhul ei ole asi mugav kasutada :lol:
Kui on vaja kaasas kandmiseks klaviatuuriga seadet siis iPad ilmselt jah pole parim variant, pigem mõni netbook (Maci lineupis siis Air). Samas veebi ja multimeedia + vähema suhtluse (Skype, MSN, Facebook jne.) jaoks on puutetundliku ekraaniga pad täitsa hea. Ma ise olen mõned nädalad Androidiga mobla omanik ning ausalt üteldes ei ole kodus suure arvuti taha enam nii palju kippunudki kui varem. Töö juures saan niigi arvutiga sisuliselt 8h tööd teha, kodus vaatan mõned enda jaoks huvitavad asjad veel lisaks üle ning selle jaoks sobiks mingitsorti pad tegelikult väga hästi. Mobiil täidab ka eesmärgi ära, lihtsalt ekraani suurus seab omad piirangud. Samas saab isegi trükkida moblaga lühemad e-mailid ära.
Kas pad'iks on Androidi, iOS'i või millegi muuga riist, on teine teema juba. Hetkel tundub, et Apple on hinna/kvaliteedi poolest väga tugevalt kanda kinnitanud.
Huvitav, kas videokõnede jaoks on standard ka olemas? Hetkel iPad suhtleb teiste Mac'i seadmetega nagu ma aru saan - Facetime töötab ainult i-maailmas. Väheke universaalsem lähenemisviis on sümpaatsem, samas videokõne vist ei ole väga levinud veel.
Milles probleem, Skype ju on olemas iOS peal. iPhone 4-ga saan videokõnet skypes teha nii macile, windowsile, teisele iOS-ile jne.
kusjuures androidile väga valus. tootjad ja google jurasid-mis jurasid oma honeycombiga, küll võrreldi vana ipadiga nii ja naa ja küll kiideti. aga toodet reaalselt müügis ei ole.
apple aga vaikselt-vaikselt tegi oma asju ja vupsti, toode valmis. säh sulle motorola xoomid ja galaxy tab2-d ja muud sägad. vot nii on vaja toota. mitte muneda.
honeycombi ja dualcore android tableteid oli juba eelmisel aastal vaja ja et oleks worldwide reaalselt müügis, aga mida pole seda pole. on mingid pooletoobised hiina näkatsid või igivana mobiilile optimeeritud osi-ga mudelid. nüüd tuli apple ja varastas kogu feimi ära.
Eestis tuli esimene versioon iPadist ametlikult alles aasta alguses müüki. Juba teine versioon väljas. Deem, kähku käib see värk Apple'il _________________ M: Intel i5 4590 protsessorid: 10€/tk M: HP Elitedesk 800 G3 SFF: 90€/tk M: HP Elitedesk 800 G2 Mini 35W: 90€/tk
Õhuke on küll ilus ja puha, aga arvestades selle riistapuu kasutusiseloomu.. ringi trampida ja hoo pealt kasutada, siis võiks ikka kuskilt kinni ka hoida olla. Paberilehte hoida on suht ebamugav.
Oleks mõned USB pesad, siis oleks asjal isegi jumet, praegusel kujul pole sellega suurt midagi peale hakata. Igatsugu ebastandardsed õunaussiaugud ei lähe arvesse.
Mida sa sinna ühendada tahad siis niiväga? Mu tavalises tööläpakas koguvad USB pesad ainult tolmu.
mälupulga äkki? _________________ You win again, gravity!
C-4 can make a dull day fun
there are very few problems that can't be remedied with the proper application of explosives
Eks see ongi ideoloogia erinevus. Apple puhul pigem eeldatakse, et sa ei taha lisada moblale/pad'ile/arvutile midagi ise vaid sul on kohe olemas Apple poolt kõik, mis vaja. iPadi näitel - kohe on kaasas 16/32/64GB mälu, millest võiks nagu piisata. Kui ei siis selleks on kodus server, kus on sees terake või paar, suhtlus käib üle wifi.
Kui on soov näiteks mälupulka külge panna või mälukaardi pesaga seadme järgi või veel midagi ise lisada - selleks on teised tootjad, seadmed ja ideoloogiad. Apple puhul on sul "arvuti" ekraan, mille külge läheb üks kaabel - toide (iMac'i mõtlen siis). iPhone puhul on samuti loobutud kaardipesast. iPad on samuti üks konkreetne tükk, mida pole vaja laiendada. Jah, see on ühelt poolt piirav aga teisalt ka kasutaja jaoks lihtsam kuna kogu süsteemon loodud töötama out-of-the-box.
paljud apple kasutajad kasutavad mobile me virtuaalse diski pilveteenust, mis süsteemi nii hästi integreeritud, et paistab kui tavaline võrguketta share. kokku vist 20GB by default ja seda saab vastavalt oma soovidele ära jagada e-maili ja failidele või kasutatakse dropbox jms teenuseid.
kaamera vms ühendamiseks võiks jah pesa olla, aga tegelikult ju camera-connection kit olemas. lihtsalt paarkümmend doltsi peab selle eest välja käima.
Raamatu lugemiseks pole LCD'd mõeldud. Selleks on eraldi seadmed mis maksavad kordades vähem, mille pilt on palju parem pikema ajaliseks lugemiseks ning mille aku kestab kordades kauem. _________________ Teach a man to reason and he'll think for a lifetime
Ei ütleks, et kvaliteetsed e-ink seadmed mida sa ilmselt silmas pead sama ekraanisuuruse juures nüüd kordades vähem maksaksid vaata, et pigem isegi vastupidi aga muus osas on sul muidugi õigus, ehk kindlasti pole LCD raamatu lugemiseks see parim lahendus ehkki ise netbooki ekraanilt päris hulka raamatuid läbi lugenud aga siiski kavas selleks edaspidi üks korralik e-ink seade soetada kui nende hinnad nüüd veidi langema peaksid.
viimati muutis Pikkkõrv 04.03.2011 00:03:47, muudetud 1 kord
On kindle'st paremaid apraate? Viimane maksab alla 200 euro vs 2.5-4x enam ipadi eest. Ühtlasi ei näe mingit mõtet hankida 9" suurust kolakat raamatute lugemiseks, füüsilised raamatud on oluliselt väiksema suurusega _________________ Teach a man to reason and he'll think for a lifetime
iPad-iga ekraanisuuruselt võrreldav ehk 9,7" Kindle maksab siiski enam mitte 200 vaid 400, mis on ikka natuke palju ainult raamatu lugemiseks mõeldud seadme eest. Mis puutub aga suuremasse ekraani siis aastate lisandudes ja nägemise nõrgenedes hakkad seda ilmselt sinagi hindama, pealegi on suuremalt ekraanilt parem pdf vormingus asju lugeda, milliseid endiselt paraku päris hoolega üllitatakse ehkki see vorming elektrooniliste raamatute jaoks just mitte kõige sobivam ei ole.
Apple wireless bluetooth klaver töötab ka iPadiga, niiet ei pea isegi eraldi ostma.
Tegelikult töötab ilmselt suvaline wireless klaver sama hästi. Mul pole võimalust olnud küll pikemalt näppida ipadi, kuid suva infra/bluetooth hiir sobib, siis sobib klaver ka. Näiteks mingi logitechi oma
Muuseas, vaadates poodides pakutavaid netbooke, siis äärmisel juhul saab nendega kiirelt vaadata uudiseid ja maile. Kellel silmad kehvemad, siis unusta ära pikalt netbookiga vaatamine. Pakun välja, et peale 1h lugemist on silmad paistes ja punased. 7k välja käia junni eest - ma ei tea, ma siis lahendaks selle teistmoodi juba. Milleks mulle netbook?
altrnatiivina on ju samsungil väjas analoogne asi. emt ja elisa pakuvad. androidi peal.
ipad on põgus mobiilne vahend. Dirigendid räägivad, et ipadiga on päris hea kontserditel olla dirigeerida.
Ise ipadi ei igatse siiski. Mulle meeldivad küll tehnikavidinad, aga kuskil on piir päris elu ja tehnoloogilise elu vahel _________________ Asju saab kah teisiti teha!
aga kõik "puudused" ongi selle toote "omadused". Kuniks tuleb järgmine versioon kus tuleb uus hype jms ajupesu....
nagu sony ps3 pult oli vahepeal nextgen ilma vibrata ja pärast nextgen koos vibraga _________________ |--{o,o}-----(\__/)-----------------|
Täpselt nii, Järgmine tuleb Flashi toega ja ülejärgmine USB toega, siis 3D ekraaniga (Prillid vajalikud), siis 3D ekraaniga (prillid pole vajalikud) jne jne
ja applepeded muudkui ostavad
asjameez kirjutas:
Ei tea kedagi, kes teaks kedagi, kes kasutaks iPadi.
iPAD kasutajaid on vähe kuna seda läheb vaja väga kitsale ringile:
1. Siis kui sa ei ole kodus ega tööl
2. Siis kui sa oled rikas
3. Siis kui sa oled koolis ja ei viitsi loengut kuulata
4. Siis kui tahad lennukis filmi vaadata
5. Siis kui viitsid seda kaasas tassida
6...?
Sellest võiks mulle asja olla, mis ka mu läptopi suudaks asendada. Kui nüüd ekraan oleks matt ja aku ka üle 3h kestaks oleks ostja.
viimati muutis DVDRW 05.03.2011 11:31:50, muudetud 3 korda
Olen mõnda aega kasutanud seda jublakat ja kõlbab asi ainult voodis brausimiseks. Laua peal on juba jama näiteks, kui spetskaani pole, sest käes seda näiteks ei hoia. Aku on küll sigahea. _________________ KASS
6. Siis, kui sa elad Aasias - seal on igalühel metroos iPad näpus. Ja kel iPadi pole, on viimase gen. iPhone...
p.s. sama trend on paljudes heaoluriikides...
Milleks on vaja netbookiga raamatut lugeda? Tean isiklikust kogemusest, et näiteks 3-4h konspekteerida pole küll mingi probleem. Kui peale 1h netbookiga töötamist on silmad paistes ja punased, soovitan arsti juurde pöörduda. Olen 2 aastat netbooki kasutanud ning kuigi olen tahvelarvuteid proovinud, ei veena need mind tahvelarvutit ostma.
1) Tahvelarvutid on hetkel väga kallid.
2) Netbookiga saab oluliselt paremini konspekteerida, tahvelarvutile klaviatuuri soetamine on minu arvates koomiline. Ta ei olegi selleks mõeldud.
3) Uuematel netbookidel on 250 GB kõvaketas, mis võimaldab päris palju sinna sisse mahutada. Ole siis filmi- või muusikasõber, võid ka mõlemat olla, kuna kõik mahub ära.
4) Minu endine Acer Aspire One oli juba 2 aastat tagasi sümpaatse klaviatuuriga (92 %), päris uute mudelite peal on veel mõnusam kirjutada.
5) 7000 krooni maksavad äärmisel juhul kahetuumalise prosega netbookid. Tavalise, kuid piisava jõudlusega Intel Atom N455-ga varustatud netbooki saab kätte praeguses rahas 300-350 € eest.
Ma ei ütle, et netbook on lahendus kõigile maailma hädadele, kuid ta on mõistliku hinnaga, kerge sülearvuti, mille peal on hea tegeleda lihtsamate asjadega (muusika kuulamine, konspekteerimine etc.) ning on liikuva inimese parim sõber.
aga jah kurb ... aga nii see kohati tundub olevat konsuumerite seas.
Üks koht kus seda jublakat oleks mugavam kasutada kui läpparit, netbooki vms asja oleks "kitsates" kohtades kus ei mahu läppar ära. Samas tablet'iga saaks sama asja teha _________________ |--{o,o}-----(\__/)-----------------|
Käisin just Cebit-il ja seal olid kõik kohad Androidiga tableteid täis. Oli mälukaardi lugejatega ja igasugu pesadega ja ühel jubinal oli isegi standardne USB port küljes. Kõigi nende junnide läbiv joon oli see, et nad olid paras kräpp. Uimased, tõksivad ja koostekvaliteedist parem ei räägigi. Ainuke riistapuu, millel tõesti korralik korpus ja mida oli hea käes hoida, seda hakkas sõber näppima, näppis kaks minutit ja siis pani riistapuu pildi tasku. Konkreetselt. Seega jah, odavat tabletit mida kasutada saaks, ei paista kuskilt. Ja need mis kasutada kõlbavad, need on iPad-ist jälle kallimad. _________________ God grant me the serenity to accept the things I cannot change, courage to change the things I can, and wisdom always to tell the difference.
Mis mõttes 0% feedback? Sa ei tunne, kuidas sõrmeots midagi puudutab? Sellega ongi juba töö tehtud ja täht kirjas, sa ei pea tunnetama, et klahv käis põhjas ära ja tükk saiapuru ei olnud seekord segamas.
sirius4k kirjutas:
Keegi ei keela sul seda tüki vabalt valitud paksusega papi külge kleepida.
Ho Ho kirjutas:
Tõsi, paraku tõuseb siin esile tõsiasi, et vähesed meist soetavad endale (harva kasutatavaid) monofunktsionaalseid seadmeid. iPad'iga saab peale raamatu lugemise palju muudki teha.
asjameez kirjutas:
Sa ei tunne ega tea kus su sõrmed "klaviatuuril" asuvad, selles on probleem.
rex kirjutas:
Sepavasaraga saab vajadusel ka kella parandada, iseasi kui otstarbekas ja kasutajasõbralik see on. _________________ Teach a man to reason and he'll think for a lifetime
