uus teema   vasta Uudised »  Riistvara »  "Haiguslehel" Steve Jobs esitles uut iPadi: õhem, kiirem, kaameraga märgi kõik teemad loetuks
mine lehele 1, 2, 3  järgmine
sõnum 02.03.2011 22:40:17 "Haiguslehel" Steve Jobs esitles uut iPadi: õhem, kiirem, kaameraga vasta tsitaadiga
link :: Õhtuleht
Apple'i boss Steve Jobs naases korraks haiguspuhkuselt avalikkuse ette, esitledes San Franciscos ovatsioonide saatel tahvelarvuti iPadi teise põlvkonna mudelit.
Uus iPad on kiirema protsessoriga kui selle eelkäija, kahe kaameraga - üks pildistamisega ja teine videokõneks - ning sarnase kestvusega. Sisselülitatuna peaks aku vastu pidama kümme tundi. IPad muutub ka õhemaks - 8,8 millimeetrit praeguse 13,4 asemel.
Loe edasi Õhtuleht
EDIT: lisainfot
Thinner than the iPHONE 4!
Faster with an all new A5 chip, 9X faster than iPad 1.
HDMI OUTPUT at 1080P! YES! Mirrored output cable available.
Prices start at $499 for WiFI only 16 GB
Available in BLACK and WHITE!
iOs update that makes an iPhone 4 a WIFI spot, so you dont need anything but the iPad 2 wifi!
HD Video Recording, and AWESOME video editing.
TWO cameras, and of course, facetime.
HV valuutakalkulaator
Kommentaarid: 472 loe/lisa Kasutajad arvavad:  :: 13 :: 7 :: 359
Mario.
sõnum 02.03.2011 22:45:55 vasta tsitaadiga
Announced at an event currently taking place in San Francisco, California, the iPad 2 has been made official and will be available in two colors, black and white, when it launches Friday week (March 11).
Aside from having a 33 percent slimmer design (it’s thinner than iPhone 4), the iPad 2 packs a new chip that Apple is calling the A5. It’s dual-core, packs twice the speed and nine times faster graphics but with the same low power consumption as the A4. It’s got that same 10 hour battery life; two cameras, one on the front and one on the back; a built in the gyroscope; and HDMI out via a small adapter that allows you to charge at the same time.
It’s available on both AT&T and Verizon and Apple is keeping the same $499 base price for the 16GB WiFi-only model. From there, prices go up as far as $829 (that’s for the 64GB 3G model). However, Apple was quick to point out that five out of six of the iPad models are priced at under $799, which was a sly little dig at the $799 Motorola Xoom.
Apple also revealed something called Smart Covers, which clip onto the side of the iPad 2 and magnetically sticks to the front of the device. Peeling it away will wake up the device and it can be folded up in a number of different configurations for multiple ‘standing’ options. The Smart Covers come in a range of colors in either polyurethane or leather and will cost $39 (poly) and $69 (leather).
raxz
sõnum 02.03.2011 22:49:20 vasta tsitaadiga
Võrreldes eelmisega on ikka kõvasti arendatud.
Kes siin arvas, et ilmselt pannakse kaamera juurde ja lastakse uuena välja? icon_biggrin.gif
sõnum 02.03.2011 22:59:24 vasta tsitaadiga
Ametlik info üleval ka Apple kodulehel ->
http://www.apple.com/ipad/
http://www.apple.com/ipad/specs/
mannatera
mannatera
sõnum 02.03.2011 23:12:10 vasta tsitaadiga
Kas kellelgi on kogemus iPad'iga koolis konspekti kirjutada?
Kommentaarid: 24 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 19
flake
sõnum 02.03.2011 23:15:28 vasta tsitaadiga
einoh.. specid ei ole üldse pahad... eks varsti avaneb võimalus näppida ka thumbs_up.gif
Kommentaarid: 63 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 60
Mario.
sõnum 02.03.2011 23:17:15 vasta tsitaadiga
Oleneb, mis tempos ning kui praktiline selle UI on ( kuna pöidlaid üle fullqwerty vehkida 10" on lollus, siis ideaalis oleks parem ja vasak klaviatuur, kus näppudega vehtida ja autospellinguid tulistada ).
Nutitelefoniga on hulga mugavam minu nägemust mööda.
Aga kui tõsiselt rääkida, siis kirjaplokk ja kvaliteetne kirjutusvahend või netbook.
2III7
2III7
sõnum 02.03.2011 23:33:16 vasta tsitaadiga
nojah ekraani PPI võiks küll kõrgem olla. sellisel seadmel peab lihtsalt olema kõrge resolutsioon, et silmad ära ei väsiks näiteks raamatut lugedes vms.
Kommentaarid: 162 loe/lisa Kasutajad arvavad:  :: 0 :: 3 :: 146
angel
angel
sõnum 03.03.2011 00:48:55 vasta tsitaadiga
sellise junniga oleks vast siis võimalik konspekti kirjutada kui ei trüki vaid reaalselt pulgaga nühid plaati. jube ebamugav võib olla trükkida asjaga mis sisuliselt on "laud". Ehk siis 0% feedback'i seadmelt kui trükkid.
head trükkimasinat vaja siis tasuks vaadata parem üks korralik netbook või veel parem korralik läppar. tablet funksioon oleks sellel hää kuna siis saaks ka pulgaga joonised vms asjad vast konspekti visata.
enigma
enigma
sõnum 03.03.2011 01:14:39 vasta tsitaadiga
Kui tasuta antakse võtaks vastu.Aga muidu eales ei ostaks.
oliver.
sõnum 03.03.2011 01:25:21 vasta tsitaadiga
angel kirjutas:
olen proovinud ipadi jaoks mõeldud klaviatuuri, üsna mõistlik vigur. Mulle istuks kah füüsiline klaver rohkem kui ekraani peal toksimine.
mannatera
mannatera
sõnum 03.03.2011 07:27:28 vasta tsitaadiga
oliver. kirjutas:
Ma ise mõtlesin sama kombinatsiooni muidu
angel
angel
sõnum 03.03.2011 08:13:07 vasta tsitaadiga
mis mõte sellel ipad'il on kui ostad eraldi klaveri + padi hoidja? parem siis juba netbook, läppar osta. icon_rolleyes.gif
eriti veider oleks vaadata kedagi kes kannab kaasas ipad'i ja selle klaverit kuna vastasel juhul ei ole asi mugav kasutada icon_lol.gif
sõnum 03.03.2011 09:10:52 vasta tsitaadiga
angel kirjutas:
mis mõte sellel ipad'il on kui ostad eraldi klaveri + padi hoidja? parem siis juba netbook, läppar osta. :roll:
eriti veider oleks vaadata kedagi kes kannab kaasas ipad'i ja selle klaverit kuna vastasel juhul ei ole asi mugav kasutada :lol:
Kui on vaja kaasas kandmiseks klaviatuuriga seadet siis iPad ilmselt jah pole parim variant, pigem mõni netbook (Maci lineupis siis Air). Samas veebi ja multimeedia + vähema suhtluse (Skype, MSN, Facebook jne.) jaoks on puutetundliku ekraaniga pad täitsa hea. Ma ise olen mõned nädalad Androidiga mobla omanik ning ausalt üteldes ei ole kodus suure arvuti taha enam nii palju kippunudki kui varem. Töö juures saan niigi arvutiga sisuliselt 8h tööd teha, kodus vaatan mõned enda jaoks huvitavad asjad veel lisaks üle ning selle jaoks sobiks mingitsorti pad tegelikult väga hästi. Mobiil täidab ka eesmärgi ära, lihtsalt ekraani suurus seab omad piirangud. Samas saab isegi trükkida moblaga lühemad e-mailid ära.
Kas pad'iks on Androidi, iOS'i või millegi muuga riist, on teine teema juba. Hetkel tundub, et Apple on hinna/kvaliteedi poolest väga tugevalt kanda kinnitanud.
Huvitav, kas videokõnede jaoks on standard ka olemas? Hetkel iPad suhtleb teiste Mac'i seadmetega nagu ma aru saan - Facetime töötab ainult i-maailmas. Väheke universaalsem lähenemisviis on sümpaatsem, samas videokõne vist ei ole väga levinud veel.
Kommentaarid: 183 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 146
raciocinio
sõnum 03.03.2011 09:31:05 vasta tsitaadiga
Mark0 kirjutas:
Milles probleem, Skype ju on olemas iOS peal. iPhone 4-ga saan videokõnet skypes teha nii macile, windowsile, teisele iOS-ile jne.
sõnum 03.03.2011 09:39:04 vasta tsitaadiga
Nojah, kuidas mul nüüd Skype küll ununes icon_sad.gif. Loomulikult on see võimalus ju olemas.
flake
sõnum 03.03.2011 09:41:06 vasta tsitaadiga
Apple wireless bluetooth klaver töötab ka iPadiga, niiet ei pea isegi eraldi ostma.
miga
miga
sõnum 03.03.2011 10:51:29 vasta tsitaadiga
Tundub huvitav. Keegi USA poole ei liigu lähiajal icon_smile.gif ?
High-Q
High-Q
sõnum 03.03.2011 11:02:19 vasta tsitaadiga
kusjuures androidile väga valus. tootjad ja google jurasid-mis jurasid oma honeycombiga, küll võrreldi vana ipadiga nii ja naa ja küll kiideti. aga toodet reaalselt müügis ei ole.
apple aga vaikselt-vaikselt tegi oma asju ja vupsti, toode valmis. säh sulle motorola xoomid ja galaxy tab2-d ja muud sägad. vot nii on vaja toota. mitte muneda.
honeycombi ja dualcore android tableteid oli juba eelmisel aastal vaja ja et oleks worldwide reaalselt müügis, aga mida pole seda pole. on mingid pooletoobised hiina näkatsid või igivana mobiilile optimeeritud osi-ga mudelid. nüüd tuli apple ja varastas kogu feimi ära.
sõnum 03.03.2011 11:03:43 vasta tsitaadiga
Eestis tuli esimene versioon iPadist ametlikult alles aasta alguses müüki. Juba teine versioon väljas. Deem, kähku käib see värk Apple'il icon_biggrin.gif
Kommentaarid: 746 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 561
sirius4k
sirius4k
sõnum 03.03.2011 11:36:32 vasta tsitaadiga
Õhuke on küll ilus ja puha, aga arvestades selle riistapuu kasutusiseloomu.. ringi trampida ja hoo pealt kasutada, siis võiks ikka kuskilt kinni ka hoida olla. Paberilehte hoida on suht ebamugav.
Kommentaarid: 56 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 55
Ville
sõnum 03.03.2011 16:16:42 Ühendusi pole vasta tsitaadiga
Oleks mõned USB pesad, siis oleks asjal isegi jumet, praegusel kujul pole sellega suurt midagi peale hakata. Igatsugu ebastandardsed õunaussiaugud ei lähe arvesse.
mannatera
mannatera
sõnum 03.03.2011 16:19:40 Re: Ühendusi pole vasta tsitaadiga
Ville kirjutas:
Mida sa sinna ühendada tahad siis niiväga? Mu tavalises tööläpakas koguvad USB pesad ainult tolmu.
alec
alec
sõnum 03.03.2011 16:37:12 vasta tsitaadiga
mälupulga äkki?
You win again, gravity!
C-4 can make a dull day fun
there are very few problems that can't be remedied with the proper application of explosives
mannatera
mannatera
sõnum 03.03.2011 16:39:58 vasta tsitaadiga
Miks? BT ja Wifiga saad edukalt faile üle kanda teisele seadmele.
uus teema   vasta Uudised »  Riistvara »  "Haiguslehel" Steve Jobs esitles uut iPadi: õhem, kiirem, kaameraga mine lehele 1, 2, 3  järgmine
