janeklass
02.05.2010 13:13:05
cpu use 100% |
Tere
Mure siis sihuke,et prose use tihti peale 100%.Tegemist ei ole ühe protsessiga mis koormab vaid asi nii,kui ma ei tee midagi siis asi normis seisab kusagil 0-5%,aga nigu ma käivitan mingisuguse programmi (pole vahet mis programmi) nii viskab 100% peale.
Oskab keegi öelda mis viga,kas prose õhtal?
destiny12
02.05.2010 13:15:43
Annad arvuti andmed ka äkki?
_________________ "Ära mine sinna, kuhu rada viib. Mine selle asemel sinna, kus rada ei ole, ja saa teerajajaks." |
| Kommentaarid: 83 loe/lisa |
77 |
janeklass
02.05.2010 13:21:27
Motherboard:
Property Value
Manufacturer ASUSTeK Computer INC.
Model P5RD1-VM
Version Rev 1.xx
Serial Number MB-1234567890
North Bridge ATI RS400/RC400/RC410 Revision 01
South Bridge ALI M1573 Revision 01
CPU Intel(R) Celeron(R) CPU 2.80GHz
Cpu Socket Socket 775 LGA
System Slots 4 PCI
Memory Summary
Maximum Capacity 1024 MBytes
Maximum Memory Module Size 2048 MBytes
Memory Slots 2
Error Correction None
Warning! Accuracy of DMI data cannot be guaranteed
CPU:
Property Value
KUTI-E63CDDB4BD
Summary
Number of Logical Processors 1
Number of Physical Processors 1
CPU #1 Intel Celeron 336
CPU Name Intel(R) Celeron(R) CPU 2.80GHz
CPU Code Name Prescott
Vendor GenuineIntel
Number of Bits 64
Instruction Set MMX, SSE, SSE2, SSE3, ET64
Platform Name Socket 775 LGA
Revision G1
Technology 90 nm
Original Clock 2800 MHz
Original System Clock 133 MHz
Original Multiplier 21.1
CPU Clock 2807 MHz
System Clock 133.3 MHz
FSB 533.2 MHz
Number of Cores 1
Core #1
Speed 2799.6 MHz
Multiplier 21.0
Virtual Technology Supported No
Hyper Threading Supported Yes
Cache
L1 Data Cache 16 KBytes
L1 Trace Cache 12 Kµops
L2 Cache 256 KBytes
Juan Pablo
02.05.2010 13:26:03
celeron......
29 |
janeklass
02.05.2010 13:33:23
| celeron jah,on see halb w?
Juan Pablo
29 |
janeklass
02.05.2010 14:17:21
| Ma uurin seda asja.Aga kui nüd sellest minu probleemist rääkida,siis mis selle põhjuseks võiks olla?
Marie
74 |
janeklass
02.05.2010 19:19:14
Re: cpu use 100% |
1.
| janeklass kirjutas: |
| Tegemist ei ole ühe protsessiga mis koormab |
2.
| vaid asi nii,kui ma ei tee midagi siis asi normis seisab kusagil 0-5%, |
Seega ei ole tegemist süsteemi ebanormaalse hõivatusega, vaid idle-s ehk tühikäigul on ka protsessori hõivatus madal - seega ei ole siin midagi kurta. Kui sul oleks protsessor kogu aeg või väga tihti 100% koormatud ja samal ajal sinu käivitatud programmidele ressurssi napib, siis on põhjust seda ebanormaalseks pidada.
3.
| aga nigu ma käivitan mingisuguse programmi (pole vahet mis programmi) nii viskab 100% peale. |
Sa siis tahad, et sinu programmid ei töötaks nii kiiresti, kui see vähegi on võimalik, vaid et programmid uimerdaksid, samas kui protsessor pooleldi looderdab? Oled ikka selle asja läbi mõelnud põhjalikult? Kui tegemist ei ole just akudelt töötava sülearvutiga, siis oleks just selline olukord ebanormaalne ja tähendaks seda, et protsessorile ei jõuta ette sööta nii palju tööd, kui ta tegelikult teha jõuaks (esineb näiteks töötamisel suurte andmemahtudega, mida loetakse kettalt või salvestatakse sinna, protsessi kiiruse dikteerib ketta töökiirus ja protsessoril ei ole nii palju tööd, kui ta teha jõuaks)
| Oskab keegi öelda mis viga,kas prose õhtal? |
Ei ole sul seal viga midagi, just täpselt nii süsteem ju töötama peabki. Kui midagi teha ei ole, siis on kasutus madal ja kui midagi teha on, siis tehakse seda nii kiiresti kui võimalik, hõivates CPU 100%-liselt ja jagades need protsendid kõigi hetkel töötavate protsesside vahel.
Ei maksa segi ajada protsessori hõivatust mälukasutusega. Erinevalt mälust peabki protsessor olema 100% hõivatud, kui tal midagi on vaja teha ja olema kuni paari protsendi jagu hõivatud, kui tal midagi peale süsteemi püstihoidmise teha ei ole.
Windows 7 puhul on aga ka mälu haldamisega natuke teised lood.
janeklass
02.05.2010 20:07:09
Ma väljendasin enne vb natuke halvasti ennast,ma toon siis näite.
Mul käib praega windows update,cpu use 100% ja nüd tahan hakata näiteks muusikat kuulama aga see on suht keeruline kuna süsteem väga aeglane,kui player üldse käivitub siis väga kaua läheb aega.
02.05.2010 20:41:42
Windows Update tarvitab tegelikult üsna palju ressurssi. Palju su arvutil mälu on? Millist antiviirust kasutad?
janeklass
02.05.2010 20:52:29
| Mälu on 512mb ja viirusetõrjeks on mse.
02.05.2010 21:43:02
Vaatasin just praegu su HDTune pilti esimest korda - esiteks on ketta temperatuur üsna kriitilise piiri peal. Ehk pole see ainult ketta paigutusest tingitud vaid su arvuti kipub ehk üldse liiga kuumaks minema - see oleks ka jõudluse languse üheks kindlaks põhjuseks. Everestiga vist vaatasid arvuti andmeid varem - vaata ka temperatuurid üle.
janeklass
03.05.2010 06:50:12
| Palju on norm ketta temperatuur? Kui mingi jahutus juurde panna ja ketastele suunata oleks sellest abi?
r4ido
03.05.2010 07:25:48
Endal oli sarnane probleem maal p4 ja maxtori 40gb ja teise kettaga proovides lippas ilusti, arvatavasti on ketas oma viimaseid hingetõmbeid tegemas, sest arvuti conf suht sama sinuomaga, kuid kiiruse poolest peaks igaljuhul asju normaalselt laadima.
Endal linnas kolm ketast üksteise otsas ja temp 32-35 olenevalt kettast, vent eest peale puhumas.
Lahenduseks puhastada kasti ja võimalusel lisada sissepuhuv vent, soovitavalt ketta ette kui kast seda võimaldab.
Mälu kasutus mitu mb? Sest kui üle 512 mingi protsessiga tõmbab, siis hakkab ketas swappima ja ongi üliaeglane.
| Kommentaarid: 74 loe/lisa |
68 |
| Kommentaarid: 1152 loe/lisa |
724 |
r4ido
03.05.2010 18:30:36
ei ole surnud kahjuks hmonitor näitas veel 58% elukest järgi sellel
aga teemasse siis 30-40 vahel on mu arust norm ketta temp...no madalam võib ka olla muidugi
68 |
janeklass
03.05.2010 18:54:49
| r4ido kirjutas: |
Mälu kasutus mitu mb? Sest kui üle 512 mingi protsessiga tõmbab, siis hakkab ketas swappima ja ongi üliaeglane.  |
Sain jatuse eest puhuma pandud,nüd Ketaste temp 34. Mälukasutus mittemidagi tehes on 65%.
724 |
janeklass
03.05.2010 20:39:17
Startup näeb välja sihuke:
ctfmon.exe C:\WINDOWS\system32\ctfmon.exe
SoundMAX "C:\Program Files\Analog Devices\SoundMAX\Smax4.exe" /tray
MSSE "C:\Program Files\Microsoft Security Essentials\msseces.exe" -hide -runkey
ATIPTA "C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe"
SoundMAXPnP C:\Program Files\Analog Devices\Core\smax4pnp.exe
Ma usun ,et ned vast on ikka kõik vajalikud?
pohmakas,
käed värisevad
03.05.2010 21:51:13
| Lase Spyboti vms asjaga üle, endal viirus sarnaselt kooma tõmmanud.
| Kommentaarid: 165 loe/lisa |
137 |
Heineken
03.05.2010 22:42:49
Mul käib praega windows update,cpu use 100% ja nüd tahan hakata näiteks muusikat kuulama aga see on suht keeruline kuna süsteem väga aeglane,kui player üldse käivitub siis väga kaua läheb aega. |
Mida sa iidsest Celeronist ikka ootad ?
| Kommentaarid: 24 loe/lisa |
23 |
724 |
CoiL
| Kommentaarid: 95 loe/lisa |
83 |
