janeklass
02.05.2010 13:13:05
cpu use 100% |
Tere
Mure siis sihuke,et prose use tihti peale 100%.Tegemist ei ole ühe protsessiga mis koormab vaid asi nii,kui ma ei tee midagi siis asi normis seisab kusagil 0-5%,aga nigu ma käivitan mingisuguse programmi (pole vahet mis programmi) nii viskab 100% peale.
Oskab keegi öelda mis viga,kas prose õhtal?
destiny12
02.05.2010 13:15:43
Annad arvuti andmed ka äkki?
_________________ "Ära mine sinna, kuhu rada viib. Mine selle asemel sinna, kus rada ei ole, ja saa teerajajaks." |
| Kommentaarid: 83 loe/lisa |
77 |
janeklass
02.05.2010 13:21:27
Motherboard:
Property Value
Manufacturer ASUSTeK Computer INC.
Model P5RD1-VM
Version Rev 1.xx
Serial Number MB-1234567890
North Bridge ATI RS400/RC400/RC410 Revision 01
South Bridge ALI M1573 Revision 01
CPU Intel(R) Celeron(R) CPU 2.80GHz
Cpu Socket Socket 775 LGA
System Slots 4 PCI
Memory Summary
Maximum Capacity 1024 MBytes
Maximum Memory Module Size 2048 MBytes
Memory Slots 2
Error Correction None
Warning! Accuracy of DMI data cannot be guaranteed
CPU:
Property Value
KUTI-E63CDDB4BD
Summary
Number of Logical Processors 1
Number of Physical Processors 1
CPU #1 Intel Celeron 336
CPU Name Intel(R) Celeron(R) CPU 2.80GHz
CPU Code Name Prescott
Vendor GenuineIntel
Number of Bits 64
Instruction Set MMX, SSE, SSE2, SSE3, ET64
Platform Name Socket 775 LGA
Revision G1
Technology 90 nm
Original Clock 2800 MHz
Original System Clock 133 MHz
Original Multiplier 21.1
CPU Clock 2807 MHz
System Clock 133.3 MHz
FSB 533.2 MHz
Number of Cores 1
Core #1
Speed 2799.6 MHz
Multiplier 21.0
Virtual Technology Supported No
Hyper Threading Supported Yes
Cache
L1 Data Cache 16 KBytes
L1 Trace Cache 12 Kµops
L2 Cache 256 KBytes
Juan Pablo
02.05.2010 13:26:03
celeron......
29 |
janeklass
02.05.2010 13:33:23
| celeron jah,on see halb w?
Juan Pablo
29 |
janeklass
02.05.2010 14:17:21
| Ma uurin seda asja.Aga kui nüd sellest minu probleemist rääkida,siis mis selle põhjuseks võiks olla?
Marie
74 |
janeklass
02.05.2010 19:19:14
Re: cpu use 100% |
1.
| janeklass kirjutas: |
| Tegemist ei ole ühe protsessiga mis koormab |
2.
| vaid asi nii,kui ma ei tee midagi siis asi normis seisab kusagil 0-5%, |
Seega ei ole tegemist süsteemi ebanormaalse hõivatusega, vaid idle-s ehk tühikäigul on ka protsessori hõivatus madal - seega ei ole siin midagi kurta. Kui sul oleks protsessor kogu aeg või väga tihti 100% koormatud ja samal ajal sinu käivitatud programmidele ressurssi napib, siis on põhjust seda ebanormaalseks pidada.
3.
| aga nigu ma käivitan mingisuguse programmi (pole vahet mis programmi) nii viskab 100% peale. |
Sa siis tahad, et sinu programmid ei töötaks nii kiiresti, kui see vähegi on võimalik, vaid et programmid uimerdaksid, samas kui protsessor pooleldi looderdab? Oled ikka selle asja läbi mõelnud põhjalikult? Kui tegemist ei ole just akudelt töötava sülearvutiga, siis oleks just selline olukord ebanormaalne ja tähendaks seda, et protsessorile ei jõuta ette sööta nii palju tööd, kui ta tegelikult teha jõuaks (esineb näiteks töötamisel suurte andmemahtudega, mida loetakse kettalt või salvestatakse sinna, protsessi kiiruse dikteerib ketta töökiirus ja protsessoril ei ole nii palju tööd, kui ta teha jõuaks)
| Oskab keegi öelda mis viga,kas prose õhtal? |
Ei ole sul seal viga midagi, just täpselt nii süsteem ju töötama peabki. Kui midagi teha ei ole, siis on kasutus madal ja kui midagi teha on, siis tehakse seda nii kiiresti kui võimalik, hõivates CPU 100%-liselt ja jagades need protsendid kõigi hetkel töötavate protsesside vahel.
Ei maksa segi ajada protsessori hõivatust mälukasutusega. Erinevalt mälust peabki protsessor olema 100% hõivatud, kui tal midagi on vaja teha ja olema kuni paari protsendi jagu hõivatud, kui tal midagi peale süsteemi püstihoidmise teha ei ole.
Windows 7 puhul on aga ka mälu haldamisega natuke teised lood.
janeklass
02.05.2010 20:07:09
Ma väljendasin enne vb natuke halvasti ennast,ma toon siis näite.
Mul käib praega windows update,cpu use 100% ja nüd tahan hakata näiteks muusikat kuulama aga see on suht keeruline kuna süsteem väga aeglane,kui player üldse käivitub siis väga kaua läheb aega.
02.05.2010 20:41:42
Windows Update tarvitab tegelikult üsna palju ressurssi. Palju su arvutil mälu on? Millist antiviirust kasutad?
janeklass
02.05.2010 20:52:29
| Mälu on 512mb ja viirusetõrjeks on mse.
02.05.2010 21:43:02
Vaatasin just praegu su HDTune pilti esimest korda - esiteks on ketta temperatuur üsna kriitilise piiri peal. Ehk pole see ainult ketta paigutusest tingitud vaid su arvuti kipub ehk üldse liiga kuumaks minema - see oleks ka jõudluse languse üheks kindlaks põhjuseks. Everestiga vist vaatasid arvuti andmeid varem - vaata ka temperatuurid üle.
janeklass
03.05.2010 06:50:12
| Palju on norm ketta temperatuur? Kui mingi jahutus juurde panna ja ketastele suunata oleks sellest abi?
r4ido
03.05.2010 07:25:48
Endal oli sarnane probleem maal p4 ja maxtori 40gb ja teise kettaga proovides lippas ilusti, arvatavasti on ketas oma viimaseid hingetõmbeid tegemas, sest arvuti conf suht sama sinuomaga, kuid kiiruse poolest peaks igaljuhul asju normaalselt laadima.
Endal linnas kolm ketast üksteise otsas ja temp 32-35 olenevalt kettast, vent eest peale puhumas.
Lahenduseks puhastada kasti ja võimalusel lisada sissepuhuv vent, soovitavalt ketta ette kui kast seda võimaldab.
Mälu kasutus mitu mb? Sest kui üle 512 mingi protsessiga tõmbab, siis hakkab ketas swappima ja ongi üliaeglane.
| Kommentaarid: 74 loe/lisa |
68 |
| Kommentaarid: 1156 loe/lisa |
724 |
r4ido
03.05.2010 18:30:36
ei ole surnud kahjuks hmonitor näitas veel 58% elukest järgi sellel
aga teemasse siis 30-40 vahel on mu arust norm ketta temp...no madalam võib ka olla muidugi
68 |
janeklass
03.05.2010 18:54:49
| r4ido kirjutas: |
Mälu kasutus mitu mb? Sest kui üle 512 mingi protsessiga tõmbab, siis hakkab ketas swappima ja ongi üliaeglane.  |
Sain jatuse eest puhuma pandud,nüd Ketaste temp 34. Mälukasutus mittemidagi tehes on 65%.
724 |
janeklass
03.05.2010 20:39:17
Startup näeb välja sihuke:
ctfmon.exe C:\WINDOWS\system32\ctfmon.exe
SoundMAX "C:\Program Files\Analog Devices\SoundMAX\Smax4.exe" /tray
MSSE "C:\Program Files\Microsoft Security Essentials\msseces.exe" -hide -runkey
ATIPTA "C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe"
SoundMAXPnP C:\Program Files\Analog Devices\Core\smax4pnp.exe
Ma usun ,et ned vast on ikka kõik vajalikud?
pohmakas,
käed värisevad
03.05.2010 21:51:13
| Lase Spyboti vms asjaga üle, endal viirus sarnaselt kooma tõmmanud.
| Kommentaarid: 166 loe/lisa |
137 |
Heineken
03.05.2010 22:42:49
Mul käib praega windows update,cpu use 100% ja nüd tahan hakata näiteks muusikat kuulama aga see on suht keeruline kuna süsteem väga aeglane,kui player üldse käivitub siis väga kaua läheb aega. |
Mida sa iidsest Celeronist ikka ootad ?
| Kommentaarid: 24 loe/lisa |
23 |
724 |
CoiL
| Kommentaarid: 95 loe/lisa |
83 |
724 |
janeklass
04.05.2010 17:05:30
Nu nii hijackthis log näeb välja sihuke:
Logfile of Trend Micro HijackThis v2.0.4
Scan saved at 7:02:07, on 4.05.2010
Platform: Windows XP SP3 (WinNT 5.01.2600)
MSIE: Internet Explorer v8.00 (8.00.6001.18702)
Boot mode: Normal
Running processes:
C:\WINDOWS\System32\smss.exe
C:\WINDOWS\system32\winlogon.exe
C:\WINDOWS\system32\services.exe
C:\WINDOWS\system32\lsass.exe
C:\WINDOWS\system32\Ati2evxx.exe
C:\WINDOWS\system32\svchost.exe
C:\Program Files\Microsoft Security Essentials\MsMpEng.exe
C:\WINDOWS\System32\svchost.exe
C:\WINDOWS\Explorer.EXE
C:\WINDOWS\system32\spoolsv.exe
C:\Program Files\uTorrent\uTorrent.exe
C:\WINDOWS\system32\msiexec.exe
C:\Program Files\Trend Micro\HiJackThis\HiJackThis.exe
R0 - HKCU\Software\Microsoft\Internet Explorer\Main,Start Page = http://google.com/
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Page_URL = http://go.microsoft.com/fwlink/?LinkId=69157
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Default_Search_URL = http://go.microsoft.com/fwlink/?LinkId=54896
R1 - HKLM\Software\Microsoft\Internet Explorer\Main,Search Page = http://go.microsoft.com/fwlink/?LinkId=54896
R0 - HKLM\Software\Microsoft\Internet Explorer\Main,Start Page = http://go.microsoft.com/fwlink/?LinkId=69157
O2 - BHO: AcroIEHelperStub - {18DF081C-E8AD-4283-A596-FA578C2EBDC3} - C:\Program Files\Common Files\Adobe\Acrobat\ActiveX\AcroIEHelperShim.dll
O4 - HKLM\..\Run: [SoundMAX] "C:\Program Files\Analog Devices\SoundMAX\Smax4.exe" /tray
O4 - HKLM\..\Run: [MSSE] "C:\Program Files\Microsoft Security Essentials\msseces.exe" -hide -runkey
O4 - HKLM\..\Run: [ATIPTA] "C:\Program Files\ATI Technologies\ATI Control Panel\atiptaxx.exe"
O4 - HKLM\..\Run: [SoundMAXPnP] C:\Program Files\Analog Devices\Core\smax4pnp.exe
O4 - HKCU\..\Run: [ctfmon.exe] C:\WINDOWS\system32\ctfmon.exe
O9 - Extra button: (no name) - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra 'Tools' menuitem: @xpsp3res.dll,-20001 - {e2e2dd38-d088-4134-82b7-f2ba38496583} - C:\WINDOWS\Network Diagnostic\xpnetdiag.exe
O9 - Extra button: Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O9 - Extra 'Tools' menuitem: Windows Messenger - {FB5F1910-F110-11d2-BB9E-00C04F795683} - C:\Program Files\Messenger\msmsgs.exe
O22 - SharedTaskScheduler: Browseui preloader - {438755C2-A8BA-11D1-B96B-00A0C90312E1} - C:\WINDOWS\system32\browseui.dll
O22 - SharedTaskScheduler: Component Categories cache daemon - {8C7461EF-2B13-11d2-BE35-3078302C2030} - C:\WINDOWS\system32\browseui.dll
O23 - Service: Ati HotKey Poller - ATI Technologies Inc. - C:\WINDOWS\system32\Ati2evxx.exe
04.05.2010 22:46:41
Kas torrenti faile salvestad samale kettapartitsioonile, kus asub ka Windows?
Ole palun kena, pane käima command prompt (Start -> Run: cmd -> OK) ja kopeeri siit sinna käsk:
| defrag "%systemdrive%" -a -v > "%systemdrive%\defrag.txt" |
pärast selle käsu andmist peaksid leidma oma süsteemikettalt (tavaliselt C: ) tekstifaili defrag.txt - ava see fail ja kopeeri sisu siia foorumisse ning pane see code-tagide vahele.
janeklass
06.05.2010 17:23:20
Ei torrent salvestab üldse teisele kettale.
siin siis defrag.txt:
Windows Disk Defragmenter
Copyright (c) 2001 Microsoft Corp. and Executive Software International, Inc.
Analysis Report
Volume size = 74,52 GB
Cluster size = 4 KB
Used space = 6,35 GB
Free space = 68,17 GB
Percent free space = 91 %
Volume fragmentation
Total fragmentation = 19 %
File fragmentation = 39 %
Free space fragmentation = 0 %
File fragmentation
Total files = 32ÿ477
Average file size = 284 KB
Total fragmented files = 5ÿ720
Total excess fragments = 33ÿ285
Average fragments per file = 2,02
Pagefile fragmentation
Pagefile size = 672 MB
Total fragments = 1
Folder fragmentation
Total folders = 2ÿ663
Fragmented folders = 117
Excess folder fragments = 769
Master File Table (MFT) fragmentation
Total MFT size = 34 MB
MFT record count = 35ÿ262
Percent MFT in use = 99
Total MFT fragments = 2
You should defragment this volume.
724 |
janeklass
06.05.2010 18:33:52
| Teen ära! Aga äkki oskad soovitada mõnda programmi selleks ,olen kuulnud et win enda oma ei pidanud kõige parem olema.
Mercury
06.05.2010 22:03:47
Auslogics BoostSpeed
| Kommentaarid: 61 loe/lisa |
60 |
janeklass
07.05.2010 17:45:24
| Se k... kast sööb mu närvid seest ära,nüüd on tekinud mingi muu jama. Asi nii, läksin korra poodi kast käis ilusti.Tulin tagasi oli ees blue sgreen,mingi pikk tekst ja lõpus oli "dump psyhical memory" midagi taolist.Tegin siis resa,peale resa ees tekst järgmise kirjaga"Identifying IDE drives .?.x". IDE ketas pole mul üldse ühendatudgi,mõtlesin siis et lähen pane selle IDE biosist "not installed",aga biosi ei lähe.
Marie
07.05.2010 18:13:43
| Se k... kast sööb mu närvid seest ära,nüüd on tekinud mingi muu jama. Asi nii, läksin korra poodi kast käis ilusti.Tulin tagasi oli ees blue sgreen,mingi pikk tekst ja lõpus oli "dump psyhical memory" midagi taolist.Tegin siis resa,peale resa ees tekst järgmise kirjaga"Identifying IDE drives .?.x". IDE ketas pole mul üldse ühendatudgi,mõtlesin siis et lähen pane selle IDE biosist "not installed",aga biosi ei lähe. |
Ja andiski kõvaketas lõpuks otsad, kohe teema alguses arvasin, et süsteemiketas vigane
74 |
janeklass
Marie
07.05.2010 18:27:00
See näitab, et kettal olev failisüsteem on vigane, parandas vead ära, märkis vigased kohad ära ja mõnda aega võib see ketas edasi töötada, soovitav oleks siiski ka ise kettale vigatekontroll uuesti lasta teha koos vigaste sektorite otsinguga, samuti Disk Defragmenter käima lasta
74 |
janeklass
07.05.2010 19:33:18
Tootja kettautiliidi DOS versiooniga peaks ketta üle kontrollima - kas on viga kettas ja kui on, siis kui halb selle seis tegelikult on.
Edasine tegevus oleneb testi tulemustest.
Märt.
07.05.2010 22:48:24
Endal oli kaks korda sama error- ühel juhul oli süüdlaseks haige mälu, teisel juhul peedistatud Windows. Kettad töötavad aga tänini laitmatult. Soovitaks peale kettakontrolli ka mälu memtestiga piinata- õhtul käima ja hommikuks peaks selgus majas olema. Endal ei kulunud küll minutitki toona Memtestiga, juba algul kukkus erroreid pilduma.
| Kommentaarid: 29 loe/lisa |
23 |
janeklass
08.05.2010 13:42:34
| Mul on olemas UBCD aga kast ei boodi plaadilt millegi pärast,provisin ka win plaadiga aga seda ka ei boodi.
08.05.2010 14:00:12
Et masinal enne kettaga jantima hakkamist BSOD-i ei esinenud, siis pole mälu viga nii tõenäoline kui just ketta viga, aga välistada seda muidugi ei saa. Kui ketta testimisel vigu näha pole või testimise käigus masin samuti kokku jookseb, siis peaks küll mälu kontrollima hakkama.
Kõige selle jaoks peab aga masin CD pealt bootima. Kas BIOS-is on esimeseks bootivaks seadmeks valitud CD või midagi muud?
Samuti on paljude emaplaatide puhul võimalik arvuti käivitamisel POST testi esimeste sekundite jooksul, samal ajal kui DEL klahviga pääseb BIOS-i kallale, mõne F-klahviga võimalik ette manada boot-menüü, kus siis saab selleks korraks bootimise allika käsitsi valida. Selle menüü F-klahv on erinevatel emaplaatidel erinev, nii et midagi kindlat öelda ei oska (menüü avaneb alles pärast POST testi, nii et mõnel masinal puudub enne seda igasugune tagasiside selle kohta, kas F-klahvile vajutus üldse registreeriti)
(minu käest on läbi käinud masinad, millel pääseb bootimise menüüsse F12, F11, F8 või F2 klahviga ning minu praegusel läpakal peab üldse vajutama Escape-klahvi ja siis tegema eraldi BIOS-i menüüst kas setup, boot-menüü või veel mõne muu valiku. Mõnel saab selle menüü üldse välja lülitada, mõnel parooliga kaitsta, mõnel POST testi ajal vastavat vihjet ekraani all näidata, mõnel aga puuduvad igasugused valikud)
janeklass
08.05.2010 17:52:21
BIOS-is on pandud cd seade esimeseks,aga ta ei hakka cd-lt lugema(varem on ilusti teinud seda) isegi win cd-d ei hakka lugema.F8 tagudes tuleb boot-menu kül ette aga seal ta ei näita üldse cd seadet.
Nu eile tuli esimest korada blue sgreen varem pole midagi olnud.
08.05.2010 18:15:47
Kui masin boot-menüüs CD-seadet ei näita, kas ta mujal BIOS-is seda üldse näitab? Seadme kaabel on ikka emaplaadiga ühendatud?
viimati muutis Dogbert 08.05.2010 18:15:56, muudetud 1 kord |
Marie
08.05.2010 18:15:50
Nu eile tuli esimest korada blue sgreen varem pole midagi olnud. |
Kas CD seade vigane, kaablid vigased või hakkab emaplaat otsi andma, vigane - lühises kõvaketas võib emaplaadil oleva kõvaketaste kontrolleri osaliselt töökõlbmatuks muuta, samuti vigane - nõrk toiteplokk.
Arvan, et sul on kõik arvuti detailid oma aja ära elanud, nii toiteplokk, emaplaat, CD/DVD seade, kui kõvaketas, mälu samuti vähe, peale protsessori mis samuti saast ei saakski midagi muud kasutada kui korpust, korpus ka arvatavasti kulunud, väike, õhukesest plekist.
Pead vist mõtlema hakkama uue arvuti soetamise peale
74 |
08.05.2010 18:21:24
Vana see masin ju küll on, aga kas just nii läbi omadega, et enam miski ei kõlba, ma kohe väita ei julgeks. Kui raha on, siis võiks uuema muretseda küll, aga kui sellega priisata pole, saab väiksema kuluga selle vanakese ka veel oma tudisevatel jalgadel liikuma, ma arvan.
janeklass
09.05.2010 13:39:39
| Marie kirjutas: |
Pead vist mõtlema hakkama uue arvuti soetamise peale  |
Kaablid vaatasin üle paistavad korras ja ilusti ühentatud.Ei tea kas kõik detailid ikka on oma aja ära elanud,arvuti ise on umbes 4 aastat tagasi ostetud,toitplokk sai vahetatud umbes aasta tagasi ja cd seade on kül mingi vana sai ja korpus on ikka täitsa läbi. Uue arvuti ostmine tiksub juba pikemat aega peas ,aga hetkel rahaline seis ei luba seda.
Se kast käitub ikka väga imelikult üks hetk töötab ja teine hetk mitte,praega näiteks töötab ja paistab et mingisugused probleeme pole.Cd seade kusjuures win-s sees olles töötab ilusti aga kui tahan bootida migilt plaadilt siis ei tööta. Kas neid diagnostikaid saab teha ka win-s sees(mem-test ,hard drive diagnostika jne).
10.05.2010 17:58:44
Ketta SMART infot saab vaadata Windowsi all (näiteks Everest on abiks) ja natuke testida ka (HD Tune Pro 15 päeva töötav versioon sobib näiteks), aga süsteemiketast, kus windows ise peal istub, saab piisavalt põhjalikult testida vaid mõne muu andmekandja pealt booditud tootja poolt (kodulehel) pakutava DOS-utiliidiga, isegi kui tootja ka Windowsi all töötavat utiliiti pakub, sest viimasega saab korralikult testida vaid mitte-süsteemikettaid.
Mälu saab testida vaid juhul, kui see pole kasutuses ja Windowsi all ei tööta ükski piisavalt pädev mälutest.
Memtest86+ algversioon baseerub põhjalikult modifitseeritud ja äärmiselt kärbitud Linux 1.2.1 kernelil (ja Windowsis pole sellega muidugi midagi teha)
Kõikvõimalikke anomaaliaid võivad põhjustada punnis ja/või lekkivad kondensaatorid emaplaadil (peamiselt protsessori toiteahela omad) - vaata need üle igaks juhuks. Minu töö juures läksid ühel säästu(saasta-)arvutil need konded juba vähem kui 3 aastaga - vahetasin nädalat paar-kolm tagasi.
Toiteploki omad ehk veel häireid põhjustada ei tohiks, kui just plokk ise puhta praak ei ole.
____________________________
Mind ikkagi häirib see, et CD-seade ei boodi ja ei ilmu ka BIOS-i boot-menüüsse. Selline asi võib juhtuda näiteks sel juhul, kui BIOS-is on kettakontrolleri selle liidese seadistuses, mille külge CD-seade on pistetud, valitud ketta automaatse tuvastamise (Auto) asemel "None". AWARD BIOS-is vasaku tulba kõige esimene menüü, teistes BIOS-ides ka kusagil eespool.
Või siis on see kontrolleri liides üldse välja lülitatud - PATA ketaste kontrolleril saab tihtipeale BIOS-is primaarset ja sekundaarset kanalit eraldi sisse-välja lülitada (Integrated Peripherals vms)
Sel juhul POST testi käigus sealt mingit seadet ei otsita ja ketas on BIOSile nähtamatu. Windows XP all on selline ketas aga näha (vähemalt esimesel juhul küll).
Kontrolli üle.
janeklass
13.05.2010 17:26:57
Kontrolli üle. |
Vaatasin kondekad üle,paistsid korras. Sain cd-seadme tööle mul oligi biosis keta tuvastamine "None" pandud.
Tegin UBCD-ga keta ja mälu testid ka ära ,kumbgi ei näidanud midagi ja arvuti on ka siiamaani ilusti töötanud.Ma ei saa aru mis võis selle blue screeni põhjuseks olla,lambist ta ei tulnud ju,sellel pidi mingi põhjus olema ju. MÜSTIKA!
PokerAce
09.06.2010 00:38:28
Nonii .. aga minul on ka CPU põhjas:P
Väike everesti report ja tulemuseks:
Temperatures:
Motherboard 33 °C (91 °F)
CPU 43 °C (109 °F)
CPU Diode 76 °C (169 °F)
GPU Diode 56 °C (133 °F)
SAMSUNG HD160JJ 44 °C (111 °F)
Kindlasti leidub siin inimene, kes oskab öelda, milles see viga täpsemalt seisneb, et see CPU diode temp nii kõrge on ? Ja mis seda ravida aitaks kui aitaks:O?
Pisut andmeid ...
Motherboard:
CPU Type AMD Athlon 64, 2000 MHz (10 x 200) 3200+
Motherboard Name ECS nForce4-A939 (3 PCI, 2 PCI-E x1, 1 PCI-E x16, 4 DDR DIMM, Audio, Gigabit LAN)
Motherboard Chipset nVIDIA nForce4, AMD Hammer
System Memory 1536 MB (PC3200 DDR SDRAM)
DIMM1: Apacer Tech. 77.G1136.9BG 1 GB PC3200 DDR SDRAM (3.0-4-4-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz) (2.0-3-3-6 @ 133 MHz)
DIMM2: 512 MB PC3200 DDR SDRAM (3.0-4-4-8 @ 200 MHz) (2.5-3-3-7 @ 166 MHz) (2.0-3-3-6 @ 133 MHz)
BIOS Type Award (06/30/06)
(ei hakanud uut teemat tegema, kui teema juba sellega ühtib.)
Heineken
09.06.2010 00:56:27
| Ilmselt andur peksab segast .
23 |
