23.01.2008 23:08:39
Internet Explorer 8 lubab hakata veebistandardeid järgima |
Microsoft soovib muuta oma uue brauseri, Internet Explorer 8, veebimootori veebistandardeid aktsepteerivaks. Teisalt jälle toetama kõiki teisi veebilehti, mis on siiani kujundatud IE6 ja IE7 silmas pidades. Arendajad räägivad tulevase IE8 juures kolmest erinevast compatibility mode-st. Populaarseima brauseri beetaversioon jõuab avalikkuse ette selle aasta esimesel poolel.
In keeping with its ongoing aim to not "break the Web" with major changes to the Internet Explorer (IE) rendering engine, Microsoft this week revealed how it will handle its support of Web standards in the next version of the Web browser. IE 8 will sport three different compatibility modes, up from two in IE 7, one of which will more firmly conform to modern Web standards.
There's just one problem: This new more rigid standards mode won't be enabled by default because, Microsoft says, enabling it will break compatibility with too much of the existing Web. According to Chris Wilson, an IE platform architect, there are half a billion IE users and "billions" of pages on the Web today that already work in IE 6 and IE 7. Supporting incompatible standards in IE 8 would therefore be a mistake, he says.
Microsoft's "Don't break the Web" approach is a natural offshoot of the company's longstanding plans to break customer compatibility as little as possible during product upgrades. But in this case, there are concerns in the developer community that Microsoft is being far too conservative. The company's approach to compatibility in IE 8 appears to be quite complex, with the most rigid standards mode requiring developers to add certain tags to their Web site pages so that the upcoming browser will render accordingly.
The end result is this tiered support of Web standards. IE 8 will support "quirks mode," which allows the browser to render like IE 6 and previous IE versions, "standards mode," which is based on IE 7, and the new more rigid standards mode. This latter option will require developers to modify their pages to support it. |
allikas: Intenet Explorer 8 blog by Chris Wilson (IE Platform Architect) ja Microsoft Talks Standards Support for IE 8
veel: IE8 now renders the "Acid2 Face" correctly in IE8 standards mode
313 |
| Kommentaarid: 749 loe/lisa |
563 |
24.01.2008 00:01:06
ei usu... vahe tuleb umbes 2 aastat ma arvan. IE7 final tuli välja ju 2006 aasta oktoobris.
IE8 põhirõhk saab olema turvalisusel ja nagu eelnevalt öeldud, omab uut mootorit.
313 |
taimpsfm
| Kommentaarid: 8 loe/lisa |
24.01.2008 00:11:57
eks nad mõnes mõttes söövad oma suppi. kõik on nö. poolvigaste IE6 ja IE7 harjunud ja kui nüüd tahta midagi "korralikku" teha, siis ollakse nurgas - üleminek oleks liiga karm. tulemuseks see, et vaikmisi pole IE8 mode toetatud.
| As a result, according to Microsoft, an internal debug build of IE8 passes the Acid2 test in IE8 standards mode. However, the version of IE8 that will be released will not pass Acid2 as it will require pages to specifically request to be rendered in IE8 standards mode, and Acid2 does not request this. |
allikas: http://en.wikipedia.org/wiki/Internet_Explorer#Version_8
313 |
taimpsfm
24.01.2008 00:18:42
Söövadki, jah. Oleks IE6 väljatulekule järgnenud pidev ja pühendunud arendus, poleks me ilmselt selle küna ees. Oleks, poleks...
Aga see üleminek tuleks teha... IE jääbki muidu virelema.
Huvitav, milline on perspektiiv... Kas IE9 jaoks tuleb omakorda uus element lisada ja browseris on juba 4 erinevat renderdus-reiimi? Kas IE9, IE10, jne vaikimisi reiimiks on samuti IE7?
_________________ Taimar.ee — Jälgi mind Twitteris! |
painkillah
24.01.2008 00:40:03
ma lubasin ka et hakkan trenni rohkem tegema
| Kommentaarid: 95 loe/lisa |
6 :: |
86 |
Vidget
24.01.2008 10:09:59
| taimpsfm kirjutas: |
Jep, nii see on, veebiarendajad peavad kõikidele oma lehtedele lisama teatud meta-elemendi, et uus IE8 mootor tööle rakendada. Kui seda elementi pole, käitub IE8 väidetavalt nagu IE7 -- ehk siis tammub paigal ja on edasi standarditevaenulik.
Aga jah, maailm ja veebiarendajad on sellise info peale üpris kurvad ja vihased.
Huvitav, et Firefoxi ja Opera uued versioonid ei "lõhu veebi".  |
Vastupidi, veebiarendajad hõõruvad käsi kokku, neil ju jälle käed-jalad tööd täis ja raha tuleb. Eks pea nemadki kuidagi oma palga välja teenima
128 |
taimpsfm
24.01.2008 11:42:30
| Vidget kirjutas: |
| Vastupidi, veebiarendajad hõõruvad käsi kokku, neil ju jälle käed-jalad tööd täis ja raha tuleb. Eks pea nemadki kuidagi oma palga välja teenima :lol: |
IE eri versioonide bugide fiximine ei ole arendajale kuidagi meelepärane töö.
Ka siis mitte, kui selle eest makstakse. Tööd on niigi väga palju. :)
Helbeke
24.01.2008 13:45:31
Wow! Üle 10 aasta sai standardite peale vilistatud, mis siis nüüd juhtus?
_________________ i like my sugar with coffe and cream |
| Kommentaarid: 16 loe/lisa |
Nokia
Serverid.ee
24.01.2008 14:13:38
Seda tahaks küll proovida, eluaeg olnud IE-ga, nii et uus versioon ei teeks paha
_________________ Web3 | ERC721A |
| Kommentaarid: 44 loe/lisa |
43 |
taimpsfm
24.01.2008 15:14:32
| Helbeke kirjutas: |
| Wow! Üle 10 aasta sai standardite peale vilistatud, mis siis nüüd juhtus? |
See pole ka nüüd tõsi. IE7 arendustsükli ajal oli tugevalt näha MS'i soovi asju paremaks teha ja korda saada. IE7'ga ei kukkunud lihtsalt välja. :D
Senikaua kuniks Trident renderdusmootorit ei hüljata, ei suudeta ka asju korda teha. Ei ole normaalne, et mootor, mis võeti kasutusele IE4 poolt aastal '97, on tänaseni kasutuses. Kui auto lootusetult ajale jalgu jääb, tuleb ikka uus muretseda. :)
Rain01
24.01.2008 17:43:13
| Vidget kirjutas: |
Vastupidi, veebiarendajad hõõruvad käsi kokku, neil ju jälle käed-jalad tööd täis ja raha tuleb. Eks pea nemadki kuidagi oma palga välja teenima  |
Ka siis mitte, kui selle eest makstakse. Tööd on niigi väga palju.  |
| Helbeke kirjutas: |
Senikaua kuniks Trident renderdusmootorit ei hüljata, ei suudeta ka asju korda teha. Ei ole normaalne, et mootor, mis võeti kasutusele IE4 poolt aastal '97, on tänaseni kasutuses. Kui auto lootusetult ajale jalgu jääb, tuleb ikka uus muretseda.  |
amen
M$ teinud niii palju igast lolle trikke... nüüd võiks siis ühe targa trikki teha ja mingi sund uuendamise teha vähemalt IE7 peale... sest praegu IE6 kasutajaid ikka kõige rohkem ja seal see standardite seis kõige sitem
| Kommentaarid: 13 loe/lisa |
10 |
24.01.2008 19:04:46
| Rain01 kirjutas: |
| M$ teinud niii palju igast lolle trikke... nüüd võiks siis ühe targa trikki teha ja mingi sund uuendamise teha vähemalt IE7 peale... sest praegu IE6 kasutajaid ikka kõige rohkem ja seal see standardite seis kõige sitem |
niikaua kuni Windows 2000 on veel ametlikult toetatud ei saa seda teha kuna IE7 nõuab XP SP2 või uuemat
| Kommentaarid: 85 loe/lisa |
jnt
24.01.2008 20:00:49
mikk36, Win2k toetus lõppeb see aasta ära?
106 |
24.01.2008 22:02:48
| jnt kirjutas: |
| mikk36, Win2k toetus lõppeb see aasta ära? |
Extended Support Period until June/July 2010
Tr
29.01.2008 23:06:39
Re: Internet Explorer 8 lubab hakata veebistandardeid järgima |
| Skeptik kirjutas: |
| Microsoft soovib muuta oma uue brauseri, Internet Explorer 8, veebimootori veebistandardeid aktsepteerivaks. |
Mingi naljanurk siin või ?
raido357
29.01.2008 23:08:23
// ei midagi enamat.
| Kommentaarid: 78 loe/lisa |
29.01.2008 23:55:23
| Tr kirjutas: |
| Skeptik kirjutas: |
Mingi naljanurk siin või ?  |
kui nad juba mozillaga koostööd teevad, siis mis see enam ära ei ole siis ?
Spezz
67 |
06.03.2008 11:47:48
here we go 8)
06.03.2008 11:51:39
Laadin ka selle huvi pärast alla.
| Kommentaarid: 94 loe/lisa |
81 |
06.03.2008 11:56:42
| carlking kirjutas: |
| Laadin ka selle huvi pärast alla. |
saab näha kuidas siis IE7 vs IE8 mu uut lehte näitavad
06.03.2008 12:08:24
Njah, mind ei huvita kuidas ta mõnda lehte näitab, mingid nupud hüppavad koguaeg ette seal, kui näiteks teksti selectid, eriti ei meeldi. Firefox on näpu sees.
81 |
.Eestlane.
