uus teema   vasta Uudised »  Tarkvara ja arvutimängud »  Internet Explorer 8 lubab hakata veebistandardeid järgima märgi kõik teemad loetuks
mine lehele 1, 2, 3, 4, 5  järgmine
sõnum 23.01.2008 23:08:39 Internet Explorer 8 lubab hakata veebistandardeid järgima vasta tsitaadiga
Microsoft soovib muuta oma uue brauseri, Internet Explorer 8, veebimootori veebistandardeid aktsepteerivaks. Teisalt jälle toetama kõiki teisi veebilehti, mis on siiani kujundatud IE6 ja IE7 silmas pidades. Arendajad räägivad tulevase IE8 juures kolmest erinevast compatibility mode-st. Populaarseima brauseri beetaversioon jõuab avalikkuse ette selle aasta esimesel poolel.
In keeping with its ongoing aim to not "break the Web" with major changes to the Internet Explorer (IE) rendering engine, Microsoft this week revealed how it will handle its support of Web standards in the next version of the Web browser. IE 8 will sport three different compatibility modes, up from two in IE 7, one of which will more firmly conform to modern Web standards.
There's just one problem: This new more rigid standards mode won't be enabled by default because, Microsoft says, enabling it will break compatibility with too much of the existing Web. According to Chris Wilson, an IE platform architect, there are half a billion IE users and "billions" of pages on the Web today that already work in IE 6 and IE 7. Supporting incompatible standards in IE 8 would therefore be a mistake, he says.
Microsoft's "Don't break the Web" approach is a natural offshoot of the company's longstanding plans to break customer compatibility as little as possible during product upgrades. But in this case, there are concerns in the developer community that Microsoft is being far too conservative. The company's approach to compatibility in IE 8 appears to be quite complex, with the most rigid standards mode requiring developers to add certain tags to their Web site pages so that the upcoming browser will render accordingly.
The end result is this tiered support of Web standards. IE 8 will support "quirks mode," which allows the browser to render like IE 6 and previous IE versions, "standards mode," which is based on IE 7, and the new more rigid standards mode. This latter option will require developers to modify their pages to support it.
allikas: Intenet Explorer 8 blog by Chris Wilson (IE Platform Architect) ja Microsoft Talks Standards Support for IE 8
veel: IE8 now renders the "Acid2 Face" correctly in IE8 standards mode
sõnum 23.01.2008 23:53:43 vasta tsitaadiga
Microsoftil tuleb lühikese aja jooksul päris mitu uut versiooni erinevatest programmidest välja - Live Messenger ja IE. Kas nad mitte ei kiirusta liialt? icon_rolleyes.gif
M: Intel i5 4590 protsessorid
M: HP Elitedesk 800 G3 SFF
M: HP Elitdesk 800 G2 Mini 35W
Kommentaarid: 749 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 563
sõnum 24.01.2008 00:01:06 vasta tsitaadiga
ei usu... vahe tuleb umbes 2 aastat ma arvan. IE7 final tuli välja ju 2006 aasta oktoobris.
IE8 põhirõhk saab olema turvalisusel ja nagu eelnevalt öeldud, omab uut mootorit.
taimpsfm
taimpsfm
sõnum 24.01.2008 00:07:48 vasta tsitaadiga
Ehk siis -- IE8 ei läbi Acid2 testi. :)
Testi loetakse õnnestunuks üksnes default-sätetega,
sinna alla ei kuulu kindlasti mitte lisa-meta-element.
Jep, nii see on, veebiarendajad peavad kõikidele oma lehtedele lisama teatud meta-elemendi, et uus IE8 mootor tööle rakendada. Kui seda elementi pole, käitub IE8 väidetavalt nagu IE7 -- ehk siis tammub paigal ja on edasi standarditevaenulik.
Aga jah, maailm ja veebiarendajad on sellise info peale üpris kurvad ja vihased.
Huvitav, et Firefoxi ja Opera uued versioonid ei "lõhu veebi". :)
Pritsin asjakohaseid viiteid ka:
http://annevankesteren.nl/2008/01/ie-lock-in
http://weblogs.mozillazine.org/roc/archives/2008/01/post_2.html
http://weblogs.mozillazine.org/roc/archives/2008/01/slipping_the_ba.html
http://www.webstandards.org/2008/01/22/microsofts-version-targeting-proposal/
http://www.456bereastreet.com/archive/200801/standards_mode_is_the_new_quirks_mode/
Here we go again. Fixing the web for Microsoft. Isn’t Microsoft supposed to be fixing IE for the web?
Allikas: Microsoft’s Version Targeting Proposal
Taimar.eeJälgi mind Twitteris!
viimati muutis taimpsfm 24.01.2008 00:09:49, muudetud 1 kord
Kommentaarid: 8 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 7
sõnum 24.01.2008 00:11:57 vasta tsitaadiga
eks nad mõnes mõttes söövad oma suppi. kõik on nö. poolvigaste IE6 ja IE7 harjunud ja kui nüüd tahta midagi "korralikku" teha, siis ollakse nurgas - üleminek oleks liiga karm. tulemuseks see, et vaikmisi pole IE8 mode toetatud.
As a result, according to Microsoft, an internal debug build of IE8 passes the Acid2 test in IE8 standards mode. However, the version of IE8 that will be released will not pass Acid2 as it will require pages to specifically request to be rendered in IE8 standards mode, and Acid2 does not request this.
allikas: http://en.wikipedia.org/wiki/Internet_Explorer#Version_8
taimpsfm
taimpsfm
sõnum 24.01.2008 00:18:42 vasta tsitaadiga
Söövadki, jah. Oleks IE6 väljatulekule järgnenud pidev ja pühendunud arendus, poleks me ilmselt selle küna ees. Oleks, poleks...
Aga see üleminek tuleks teha... IE jääbki muidu virelema.
Huvitav, milline on perspektiiv... Kas IE9 jaoks tuleb omakorda uus element lisada ja browseris on juba 4 erinevat renderdus-režiimi? Kas IE9, IE10, jne vaikimisi režiimiks on samuti IE7?
painkillah
painkillah
sõnum 24.01.2008 00:40:03 vasta tsitaadiga
Vidget
Vidget
sõnum 24.01.2008 10:09:59 vasta tsitaadiga
taimpsfm kirjutas:
Huvitav, et Firefoxi ja Opera uued versioonid ei "lõhu veebi". icon_smile.gif
Vastupidi, veebiarendajad hõõruvad käsi kokku, neil ju jälle käed-jalad tööd täis ja raha tuleb. Eks pea nemadki kuidagi oma palga välja teenima icon_lol.gif
Kommentaarid: 148 loe/lisa Kasutajad arvavad:  :: 1 :: 4 :: 128
taimpsfm
taimpsfm
sõnum 24.01.2008 11:42:30 vasta tsitaadiga
Vidget kirjutas:
Vastupidi, veebiarendajad hõõruvad käsi kokku, neil ju jälle käed-jalad tööd täis ja raha tuleb. Eks pea nemadki kuidagi oma palga välja teenima :lol:
IE eri versioonide bugide fiximine ei ole arendajale kuidagi meelepärane töö.
Ka siis mitte, kui selle eest makstakse. Tööd on niigi väga palju. :)
Helbeke
Helbeke
sõnum 24.01.2008 13:45:31 vasta tsitaadiga
Wow! Üle 10 aasta sai standardite peale vilistatud, mis siis nüüd juhtus?
i like my sugar with coffe and cream
Kommentaarid: 16 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 13
Nokia
Serverid.ee
Nokia
sõnum 24.01.2008 14:13:38 vasta tsitaadiga
Seda tahaks küll proovida, eluaeg olnud IE-ga, nii et uus versioon ei teeks paha icon_smile.gif
Web3 | ERC721A
Kommentaarid: 44 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 43
taimpsfm
taimpsfm
sõnum 24.01.2008 15:14:32 vasta tsitaadiga
Helbeke kirjutas:
See pole ka nüüd tõsi. IE7 arendustsükli ajal oli tugevalt näha MS'i soovi asju paremaks teha ja korda saada. IE7'ga ei kukkunud lihtsalt välja. :D
Senikaua kuniks Trident renderdusmootorit ei hüljata, ei suudeta ka asju korda teha. Ei ole normaalne, et mootor, mis võeti kasutusele IE4 poolt aastal '97, on tänaseni kasutuses. Kui auto lootusetult ajale jalgu jääb, tuleb ikka uus muretseda. :)
Rain01
Rain01
sõnum 24.01.2008 17:43:13 vasta tsitaadiga
taimpsfm kirjutas:
Vidget kirjutas:
Ka siis mitte, kui selle eest makstakse. Tööd on niigi väga palju. icon_smile.gif
taimpsfm kirjutas:
Helbeke kirjutas:
See pole ka nüüd tõsi. IE7 arendustsükli ajal oli tugevalt näha MS'i soovi asju paremaks teha ja korda saada. IE7'ga ei kukkunud lihtsalt välja. icon_biggrin.gif
Senikaua kuniks Trident renderdusmootorit ei hüljata, ei suudeta ka asju korda teha. Ei ole normaalne, et mootor, mis võeti kasutusele IE4 poolt aastal '97, on tänaseni kasutuses. Kui auto lootusetult ajale jalgu jääb, tuleb ikka uus muretseda. icon_smile.gif
amen
M$ teinud niii palju igast lolle trikke... nüüd võiks siis ühe targa trikki teha ja mingi sund uuendamise teha vähemalt IE7 peale... sest praegu IE6 kasutajaid ikka kõige rohkem ja seal see standardite seis kõige sitem
Kommentaarid: 13 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 10
sõnum 24.01.2008 19:04:46 vasta tsitaadiga
Rain01 kirjutas:
niikaua kuni Windows 2000 on veel ametlikult toetatud ei saa seda teha kuna IE7 nõuab XP SP2 või uuemat
jnt
jnt
sõnum 24.01.2008 20:00:49 vasta tsitaadiga
mikk36, Win2k toetus lõppeb see aasta ära?
Kommentaarid: 115 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 106
sõnum 24.01.2008 22:02:48 vasta tsitaadiga
jnt kirjutas:
Extended Support Period until June/July 2010
Tr
Tr
sõnum 29.01.2008 23:06:39 Re: Internet Explorer 8 lubab hakata veebistandardeid järgima vasta tsitaadiga
Skeptik kirjutas:
raido357
sõnum 29.01.2008 23:08:23 vasta tsitaadiga
icon_lol.gif // ei midagi enamat.
sõnum 29.01.2008 23:55:23 Re: Internet Explorer 8 lubab hakata veebistandardeid järgima vasta tsitaadiga
Tr kirjutas:
Skeptik kirjutas:
kui nad juba mozillaga koostööd teevad, siis mis see enam ära ei ole siis ?
Spezz
sõnum 06.03.2008 11:33:24 vasta tsitaadiga
Beeta allalaetav - http://www.microsoft.com/windows/products/winfamily/ie/ie8/readiness/Install.htm
Kommentaarid: 71 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 67
sõnum 06.03.2008 11:47:48 vasta tsitaadiga
Spezz kirjutas:
here we go 8)
sõnum 06.03.2008 11:51:39 vasta tsitaadiga
Laadin ka selle huvi pärast alla.
sõnum 06.03.2008 11:56:42 vasta tsitaadiga
carlking kirjutas:
sõnum 06.03.2008 12:08:24 vasta tsitaadiga
Njah, mind ei huvita kuidas ta mõnda lehte näitab, mingid nupud hüppavad koguaeg ette seal, kui näiteks teksti selectid, eriti ei meeldi. Firefox on näpu sees.
.Eestlane.
.Eestlane.
sõnum 06.03.2008 14:47:13 vasta tsitaadiga
Pisut uuendustest siit:
http://code.msdn.microsoft.com/ie8whitepapers/Release/ProjectReleases.aspx?ReleaseId=568
Lugege pdf faili.
Beta iseenesest tundub veel igati toores. Vähemalt mu oma lehte, mis töötab pmst korralikult igas brauseris v.a Konqueror, keerab IE8 täitsa imelikuks, ja mõni kord veel midagi vajutades või kasutades lingi targetit (url/#miski) ei liiguta lehte, samas kui IE6-s ja IE7-s kõik töötab.
uus teema   vasta Uudised »  Tarkvara ja arvutimängud »  Internet Explorer 8 lubab hakata veebistandardeid järgima mine lehele 1, 2, 3, 4, 5  järgmine
