uus teema   vasta Uudised »  Tarkvara ja arvutimängud »  Internet Explorer 8 lubab hakata veebistandardeid järgima märgi kõik teemad loetuks
mine lehele 1, 2, 3  järgmine
sõnum 24.01.2008 00:08:39 Internet Explorer 8 lubab hakata veebistandardeid järgima vasta tsitaadiga
Microsoft soovib muuta oma uue brauseri, Internet Explorer 8, veebimootori veebistandardeid aktsepteerivaks. Teisalt jälle toetama kõiki teisi veebilehti, mis on siiani kujundatud IE6 ja IE7 silmas pidades. Arendajad räägivad tulevase IE8 juures kolmest erinevast compatibility mode-st. Populaarseima brauseri beetaversioon jõuab avalikkuse ette selle aasta esimesel poolel.
In keeping with its ongoing aim to not "break the Web" with major changes to the Internet Explorer (IE) rendering engine, Microsoft this week revealed how it will handle its support of Web standards in the next version of the Web browser. IE 8 will sport three different compatibility modes, up from two in IE 7, one of which will more firmly conform to modern Web standards.
There's just one problem: This new more rigid standards mode won't be enabled by default because, Microsoft says, enabling it will break compatibility with too much of the existing Web. According to Chris Wilson, an IE platform architect, there are half a billion IE users and "billions" of pages on the Web today that already work in IE 6 and IE 7. Supporting incompatible standards in IE 8 would therefore be a mistake, he says.
Microsoft's "Don't break the Web" approach is a natural offshoot of the company's longstanding plans to break customer compatibility as little as possible during product upgrades. But in this case, there are concerns in the developer community that Microsoft is being far too conservative. The company's approach to compatibility in IE 8 appears to be quite complex, with the most rigid standards mode requiring developers to add certain tags to their Web site pages so that the upcoming browser will render accordingly.
The end result is this tiered support of Web standards. IE 8 will support "quirks mode," which allows the browser to render like IE 6 and previous IE versions, "standards mode," which is based on IE 7, and the new more rigid standards mode. This latter option will require developers to modify their pages to support it.
allikas: Intenet Explorer 8 blog by Chris Wilson (IE Platform Architect) ja Microsoft Talks Standards Support for IE 8
veel: IE8 now renders the "Acid2 Face" correctly in IE8 standards mode
sõnum 24.01.2008 00:53:43 vasta tsitaadiga
Microsoftil tuleb lühikese aja jooksul päris mitu uut versiooni erinevatest programmidest välja - Live Messenger ja IE. Kas nad mitte ei kiirusta liialt? icon_rolleyes.gif
M: Intel i5 4590 protsessorid
M: HP Elitedesk 800 G3 SFF
Kommentaarid: 755 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 567
sõnum 24.01.2008 01:01:06 vasta tsitaadiga
ei usu... vahe tuleb umbes 2 aastat ma arvan. IE7 final tuli välja ju 2006 aasta oktoobris.
IE8 põhirõhk saab olema turvalisusel ja nagu eelnevalt öeldud, omab uut mootorit.
taimpsfm
taimpsfm
sõnum 24.01.2008 01:07:48 vasta tsitaadiga
Ehk siis -- IE8 ei läbi Acid2 testi. :)
Testi loetakse õnnestunuks üksnes default-sätetega,
sinna alla ei kuulu kindlasti mitte lisa-meta-element.
Jep, nii see on, veebiarendajad peavad kõikidele oma lehtedele lisama teatud meta-elemendi, et uus IE8 mootor tööle rakendada. Kui seda elementi pole, käitub IE8 väidetavalt nagu IE7 -- ehk siis tammub paigal ja on edasi standarditevaenulik.
Aga jah, maailm ja veebiarendajad on sellise info peale üpris kurvad ja vihased.
Huvitav, et Firefoxi ja Opera uued versioonid ei "lõhu veebi". :)
Pritsin asjakohaseid viiteid ka:
http://annevankesteren.nl/2008/01/ie-lock-in
http://weblogs.mozillazine.org/roc/archives/2008/01/post_2.html
http://weblogs.mozillazine.org/roc/archives/2008/01/slipping_the_ba.html
http://www.webstandards.org/2008/01/22/microsofts-version-targeting-proposal/
http://www.456bereastreet.com/archive/200801/standards_mode_is_the_new_quirks_mode/
Here we go again. Fixing the web for Microsoft. Isn’t Microsoft supposed to be fixing IE for the web?
Allikas: Microsoft’s Version Targeting Proposal
Taimar.eeJälgi mind Twitteris!
viimati muutis taimpsfm 24.01.2008 01:09:49, muudetud 1 kord
Kommentaarid: 8 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 7
sõnum 24.01.2008 01:11:57 vasta tsitaadiga
eks nad mõnes mõttes söövad oma suppi. kõik on nö. poolvigaste IE6 ja IE7 harjunud ja kui nüüd tahta midagi "korralikku" teha, siis ollakse nurgas - üleminek oleks liiga karm. tulemuseks see, et vaikmisi pole IE8 mode toetatud.
As a result, according to Microsoft, an internal debug build of IE8 passes the Acid2 test in IE8 standards mode. However, the version of IE8 that will be released will not pass Acid2 as it will require pages to specifically request to be rendered in IE8 standards mode, and Acid2 does not request this.
allikas: http://en.wikipedia.org/wiki/Internet_Explorer#Version_8
taimpsfm
taimpsfm
sõnum 24.01.2008 01:18:42 vasta tsitaadiga
Söövadki, jah. Oleks IE6 väljatulekule järgnenud pidev ja pühendunud arendus, poleks me ilmselt selle küna ees. Oleks, poleks...
Aga see üleminek tuleks teha... IE jääbki muidu virelema.
Huvitav, milline on perspektiiv... Kas IE9 jaoks tuleb omakorda uus element lisada ja browseris on juba 4 erinevat renderdus-režiimi? Kas IE9, IE10, jne vaikimisi režiimiks on samuti IE7?
painkillah
painkillah
sõnum 24.01.2008 01:40:03 vasta tsitaadiga
Vidget
Vidget
sõnum 24.01.2008 11:09:59 vasta tsitaadiga
taimpsfm kirjutas:
Huvitav, et Firefoxi ja Opera uued versioonid ei "lõhu veebi". icon_smile.gif
Vastupidi, veebiarendajad hõõruvad käsi kokku, neil ju jälle käed-jalad tööd täis ja raha tuleb. Eks pea nemadki kuidagi oma palga välja teenima icon_lol.gif
Kommentaarid: 148 loe/lisa Kasutajad arvavad:  :: 1 :: 4 :: 128
taimpsfm
taimpsfm
sõnum 24.01.2008 12:42:30 vasta tsitaadiga
Vidget kirjutas:
Vastupidi, veebiarendajad hõõruvad käsi kokku, neil ju jälle käed-jalad tööd täis ja raha tuleb. Eks pea nemadki kuidagi oma palga välja teenima :lol:
IE eri versioonide bugide fiximine ei ole arendajale kuidagi meelepärane töö.
Ka siis mitte, kui selle eest makstakse. Tööd on niigi väga palju. :)
Helbeke
Helbeke
sõnum 24.01.2008 14:45:31 vasta tsitaadiga
Wow! Üle 10 aasta sai standardite peale vilistatud, mis siis nüüd juhtus?
i like my sugar with coffe and cream
Kommentaarid: 16 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 13
Nokia
Serverid.ee
Nokia
sõnum 24.01.2008 15:13:38 vasta tsitaadiga
Seda tahaks küll proovida, eluaeg olnud IE-ga, nii et uus versioon ei teeks paha icon_smile.gif
Web3 | ERC721A
Kommentaarid: 44 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 43
taimpsfm
taimpsfm
sõnum 24.01.2008 16:14:32 vasta tsitaadiga
Helbeke kirjutas:
See pole ka nüüd tõsi. IE7 arendustsükli ajal oli tugevalt näha MS'i soovi asju paremaks teha ja korda saada. IE7'ga ei kukkunud lihtsalt välja. :D
Senikaua kuniks Trident renderdusmootorit ei hüljata, ei suudeta ka asju korda teha. Ei ole normaalne, et mootor, mis võeti kasutusele IE4 poolt aastal '97, on tänaseni kasutuses. Kui auto lootusetult ajale jalgu jääb, tuleb ikka uus muretseda. :)
Rain01
Rain01
sõnum 24.01.2008 18:43:13 vasta tsitaadiga
taimpsfm kirjutas:
Vidget kirjutas:
Ka siis mitte, kui selle eest makstakse. Tööd on niigi väga palju. icon_smile.gif
taimpsfm kirjutas:
Helbeke kirjutas:
See pole ka nüüd tõsi. IE7 arendustsükli ajal oli tugevalt näha MS'i soovi asju paremaks teha ja korda saada. IE7'ga ei kukkunud lihtsalt välja. icon_biggrin.gif
Senikaua kuniks Trident renderdusmootorit ei hüljata, ei suudeta ka asju korda teha. Ei ole normaalne, et mootor, mis võeti kasutusele IE4 poolt aastal '97, on tänaseni kasutuses. Kui auto lootusetult ajale jalgu jääb, tuleb ikka uus muretseda. icon_smile.gif
amen
M$ teinud niii palju igast lolle trikke... nüüd võiks siis ühe targa trikki teha ja mingi sund uuendamise teha vähemalt IE7 peale... sest praegu IE6 kasutajaid ikka kõige rohkem ja seal see standardite seis kõige sitem
Kommentaarid: 13 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 10
sõnum 24.01.2008 20:04:46 vasta tsitaadiga
Rain01 kirjutas:
niikaua kuni Windows 2000 on veel ametlikult toetatud ei saa seda teha kuna IE7 nõuab XP SP2 või uuemat
jnt
jnt
sõnum 24.01.2008 21:00:49 vasta tsitaadiga
mikk36, Win2k toetus lõppeb see aasta ära?
Kommentaarid: 117 loe/lisa Kasutajad arvavad:  :: 2 :: 0 :: 108
sõnum 24.01.2008 23:02:48 vasta tsitaadiga
jnt kirjutas:
Extended Support Period until June/July 2010
Tr
Tr
sõnum 30.01.2008 00:06:39 Re: Internet Explorer 8 lubab hakata veebistandardeid järgima vasta tsitaadiga
Skeptik kirjutas:
raido357
sõnum 30.01.2008 00:08:23 vasta tsitaadiga
icon_lol.gif // ei midagi enamat.
sõnum 30.01.2008 00:55:23 Re: Internet Explorer 8 lubab hakata veebistandardeid järgima vasta tsitaadiga
Tr kirjutas:
Skeptik kirjutas:
kui nad juba mozillaga koostööd teevad, siis mis see enam ära ei ole siis ?
Spezz
sõnum 06.03.2008 12:33:24 vasta tsitaadiga
Beeta allalaetav - http://www.microsoft.com/windows/products/winfamily/ie/ie8/readiness/Install.htm
Kommentaarid: 71 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 67
sõnum 06.03.2008 12:47:48 vasta tsitaadiga
Spezz kirjutas:
here we go 8)
sõnum 06.03.2008 12:51:39 vasta tsitaadiga
Laadin ka selle huvi pärast alla.
sõnum 06.03.2008 12:56:42 vasta tsitaadiga
carlking kirjutas:
sõnum 06.03.2008 13:08:24 vasta tsitaadiga
Njah, mind ei huvita kuidas ta mõnda lehte näitab, mingid nupud hüppavad koguaeg ette seal, kui näiteks teksti selectid, eriti ei meeldi. Firefox on näpu sees.
.Eestlane.
.Eestlane.
sõnum 06.03.2008 15:47:13 vasta tsitaadiga
Pisut uuendustest siit:
http://code.msdn.microsoft.com/ie8whitepapers/Release/ProjectReleases.aspx?ReleaseId=568
Lugege pdf faili.
Beta iseenesest tundub veel igati toores. Vähemalt mu oma lehte, mis töötab pmst korralikult igas brauseris v.a Konqueror, keerab IE8 täitsa imelikuks, ja mõni kord veel midagi vajutades või kasutades lingi targetit (url/#miski) ei liiguta lehte, samas kui IE6-s ja IE7-s kõik töötab.
Goldec
Goldec
sõnum 06.03.2008 18:44:58 vasta tsitaadiga
Minge vaadake mida ACID3 test IE8-st arvab icon_biggrin.gif icon_biggrin.gif
Kommentaarid: 9 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 7
sõnum 06.03.2008 19:01:21 vasta tsitaadiga
Goldec kirjutas:
IE8 mode-s beta failib
sõnum 06.03.2008 19:56:12 vasta tsitaadiga
Skeptik kirjutas:
Goldec kirjutas:
ka viimane versioon Fx3'st failib
66/100
Goldec
Goldec
sõnum 06.03.2008 22:41:24 vasta tsitaadiga
mikk36 kirjutas:
Skeptik kirjutas:
Goldec kirjutas:
66/100
Ja muide, 68/100 juba.
Kuigi webkit on suht kõigist ees..
sõnum 06.03.2008 23:01:58 vasta tsitaadiga
IE8 failib mul 17/100 juures ja sama brauser IE7 mode-s failib 14/100 juures. default seadistus.
its2cold
sõnum 06.03.2008 23:05:57 vasta tsitaadiga
9.50 beta build 9815 teeb 68/100
Kommentaarid: 198 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 175
M00t
M00t
sõnum 06.03.2008 23:53:47 vasta tsitaadiga
mul IE8 jääbki seda laadima:
http://events.apple.com.edgesuite.net/rtp20e92/event/index.html?internal=pd4lje2fa
Kommentaarid: 77 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 73
Goldec
Goldec
sõnum 07.03.2008 19:05:25 vasta tsitaadiga
Ok, kas keegi oskab öelda kuidas ma saaks IE7ks tagasi downgradeda?
AJ
AJ
sõnum 07.03.2008 19:14:04 vasta tsitaadiga
Goldec kirjutas:
Selles testis ei hiilha ükski browser
http://www.dailytech.com/Acid3+Test+Unleashed+Murders+Every+Current+Browser/article10975.htm
M00t
M00t
sõnum 07.03.2008 19:19:05 vasta tsitaadiga
Goldec kirjutas:
downloadid IE7'me?
sõnum 07.03.2008 19:54:51 vasta tsitaadiga
AJ kirjutas:
Goldec kirjutas:
parem-parem
täna juba 68/100 Fx3'e nightly
Sendler
sõnum 08.03.2008 17:44:04 vasta tsitaadiga
Endal Safari 3.1 76/100
Kommentaarid: 37 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 34
juku1987
sõnum 10.07.2008 20:55:51 vasta tsitaadiga
Ma kasutan Firefox4 arendusversiooni 3.1a1pre mis andis ACID3 testi tulemuseks 80/100 icon_smile.gif
sõnum 28.08.2008 09:24:48 vasta tsitaadiga
Microsoft adds privacy tools to IE8: So-called porn mode tools to debut in IE8 Beta 2 this month thumbs_up.gif
artikkel: http://www.computerworld.com/action/article.do?command=viewArticleBasic&articleId=9113419&intsrc=hm_list
IE8 Beta 2 download: http://www.microsoft.com/windows/internet-explorer/beta/worldwide-sites.aspx
Nu
Nu
sõnum 28.08.2008 18:49:54 vasta tsitaadiga
http://battlescore.de/bf2/player.php?pid=99032874
pildid (badged ja medalid) korraks näitab ära ja siis kaotab ära.
compability view'ga korras.
restore last session väga hea asi.
arvuti pani pange ühe vana prgrammi pärast ja peale restarti IE käima panin siis
DO you want it.. And if you had it would you flaunt it...
ss
Kommentaarid: 177 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 157
Mario.
sõnum 28.08.2008 19:01:59 vasta tsitaadiga
Beta2 on ikka käkerdis veel. Ei kutsu kasutama. Ei jõudnudki väga näppida, üle viskas, nagu ff. 7 kärab veel hästi.
Nu
Nu
sõnum 29.08.2008 08:31:53 vasta tsitaadiga
mulle hakkab küll järjest rohkem meeldima.
compability modes probleeme rohkem ei täheldanud lehtede kuvamisega.
seadistamis võimalusi palju rohkem ja just selliseid mida lihtne kasutaja kasutab.
võibolla ie7 ka need olemas aga ie8 jäid need kohe silma.
ss
CnZ
sõnum 30.08.2008 18:33:34 vasta tsitaadiga
sõnum 30.08.2008 18:38:42 vasta tsitaadiga
CnZ, see ei tähenda, et see halb oleks
CnZ
sõnum 30.08.2008 18:44:32 vasta tsitaadiga
ei, seda muidugi (minu arust on tegu vägagi hea featuuriga), lihtsalt uurisin seda ja pidasin märkuseks ära tuua icon_smile.gif
sõnum 30.08.2008 18:53:37 vasta tsitaadiga
CnZ kirjutas:
jah, vaata kui nõme, pea kõik tänapäevased brauserid oskavad sessiooni taastada icon_rolleyes.gif icon_lol.gif
duplex
duplex
sõnum 01.09.2008 11:52:26 vasta tsitaadiga
postimehes siis uudis samal teemal:
http://www.tarbija24.ee/010908/esileht/olulised_teemad/tarbija24/tehnika/341294.php
Kommentaarid: 65 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 63
Renka
Renka
sõnum 01.09.2008 15:01:37 vasta tsitaadiga
CnZ kirjutas:
irw, et IE tegi FF'ilt ripoffi? Toome nüüd mängu Opera. Paku mis ajast Operal see feature olemas on? icon_rolleyes.gif
EDIT: mitte ma ei taha siin hakata vaidlema kes kellegilt midagi maha tegi. Lihtsalt enne kui keegi hakkab siin kedagi milleski süüdistama siis võiks ennast asjadega kurssi viia, et see feature ei ole kaugeltki mitte FF'ist alguse saanud. Ja sellised a tegi b pealt maha jutud imevad üldse sajaga. Head ideed tulebki kasutada - ja veel paremaks arendada. Lõpuks võitja on see kes kõik asjad suudab ühte patta panna nii, et seda oleks mugav kasutada.
Rain01
Rain01
sõnum 23.09.2008 17:38:02 vasta tsitaadiga
Täna sain sellise kirja microsoftilt ja minul kui veebiarendajal ajas see kiri harja mitte vähe punaseks seda lugedes ja ma usun kes tegeleb ka veebide ehitamisega ja neid kõikidele broweritele vastavaks seadistamisel see tekst külmaks ei jäta.
Hea Internetimaastiku kujundaja!
Microsoft on Internet Explorer 8 (IE8) arendusega võtnud julge rolli asuda seisma Interneti standardite järgimise eest ning lähtub kontseptsioonist „disaini korra, kasuta kõikjal“.
Internet koosneb juba täna paljuski lehekülgedest, mis ei vasta täielikult standarditele ja oluline on, et ka uue IE versiooniga saaksid inimesed oma lemmiklehekülgi vaadata sellisena, nagu nad harjunud on.
Seetõttu pöördub Microsoft kõigi veebkeskkondade haldajate poole palvega aidata kaasa meie pingutustele luua parem ja standardiseeritum internetimaastik.
On mõistetav, et lehekülgede standardiseerimine on pikk ja vaevarikas töö, mis nõuab täiendavat ressurssi. Loodetavasti valmistatakse uued veebilehed juba standardeid täpsemalt järgides. Kuniks selle tööga ühele poole saadakse, on Microsoft loonud võimaluse kasutada meta-tag’i veebilehe või veebiserveri põhiselt, mis võimaldab IE8 veebilehitseja automaatselt viia IE7 kuvamisrežiimi, mispuhul lehekülgi näidatakse sellisena nagu nad täna paistavad.
Tegemist on vaid ühe rea lisamisega pealeheküljele ja Microsoft palub siiralt kõigil keskkondade administraatoritel leida hetk selle muudatuse tegemiseks juba täna. Täpne info mida teha, asub aadressil: http://support.microsoft.com/kb/956197
Taust:
Microsoft on ajalooliselt olnud veebistandardite liidri rollis ja seisab ka täna standardiseerimise ning ühilduvuse eest. Üks oluline maamärk selles tegevuses on IE8 loomine, mis kasutab veebilehtede kuvamiseks vaikimisi uut, täielikult standarditele vastavat meetodit.
Alates veebinduse algusaegadest on olnud disainerite tase väga erinev, ning ka veebileheküljed on alati olnud oma tegijate nägu, seda mitte ainult disaini, vaid ka kirjutatava HTML koodi poolest. Tihti kasutatakse HTML konstruktsioone, mis ei vasta standarditele, kuid mida veebilehitsejad suudavad siiski näidata nii nagu disainer ette kujutas. Aastate jooksul on seetõttu tekkinud hulgaliselt veebilehekülgi, mis ei vasta standarditele, ning mis põhjustavad veebilahendusi ning veebilehitsejaid valmistavatele firmadel palju lisatööd.
Iga uue veebilehitseja valmistamisel on lisaks kirjutatud standarditele tarvis jälgida aukartust äratavat hulka kirjutamata reegleid, et teada milliseid vigu veebilehitseja tohib vigadena käsitleda ja millistest tuleb „mööda vaadata“ ja eeldada, et disainer mõtles tegelikult hoopis „nii“. Seda kõike selleks, et veebilehed ka lehitseja uue versioon ilmumisel samasugused välja näeksid nagu varem.
Veebilehekülgede valmistajad omakorda peavad kõike mida nad valmistavad, testima enne avalikkusele kättesaadavaks tegemist mitmete eri tüüpi veebilehitsejate eri versioonidega, et tulemus oleks kõigi lehitsejate puhul samasugune.
IE8 väljatulekuga ning kontseptsiooni „disaini korra, kasuta kõikjal“ rakendamisega anname disaineritele võimaluse kasutada oma aega innovaatiliste uute toodete loomiseks, mitte lõpututeks testideks erinevate veebilehitsejatega.
Koos suudame me luua standarditele vastava Interneti. See on ülioluline samm selle poole, et informatsioon oleks ühtviisi kättesaadav ja sama nauditava visuaalse välimusega nii arvutis, telefonis, autos, kui kõikjal mujal, kuhu veebilehed kunagi jõuavad!
Nagu mida vi**u kelleks nad endid õige peavad? Nagu nemad oleks hullud standartite loojad ja järgijad ja kogu ülejäänud maailm siis teeb vigaseid veebe ja nende browserid parandavad? Või kas siis see uus suur pealkiri "hakkame järgime standardeid" tähendabki siis, et hakatakse oma mingeid microsofti standardeid järgima mitte üldiseid
Renka
Renka
sõnum 23.09.2008 18:05:20 vasta tsitaadiga
Igati positiivne on see ju thumbs_up.gif Ütleks selle peale: "lõpuks ometi"
Või ma ei saa ru mis seal halba on?
uus teema   vasta Uudised »  Tarkvara ja arvutimängud »  Internet Explorer 8 lubab hakata veebistandardeid järgima mine lehele 1, 2, 3  järgmine
