uus teema   vasta Raud »  Protsessorid »  AMD Socket AM2 Platform märgi kõik teemad loetuks
mine lehele 1, 2, 3, 4, 5  järgmine
margusser
sõnum 21.02.2006 17:09:11 AMD Socket AM2 Platform vasta tsitaadiga
http://www.tomshardware.com/2006/02/21/a_look_at_amds_socket_am2_platform/
Gogo thumbs_up.gif AMD!!
The Socket AM2 generation is certainly not going to outperform comparable Socket 939 (DDR400) processors at DDR2-667 memory speeds-see our benchmarks. This is why AMD decided to wait for DDR2-800 and launch in June.
Since the production process is not going to be changed, power consumption and heat dissipation in the mainstream will remain where they are today. We did some basic testing, but as expected the difference was not worth mentioning.
AMD is going to introduce low-powered processors for power and noise sensitive environments. The single cores will maintain a 35 W power envelope, while the dual cores won't exceed 65 W. The latter is the mainstream thermal design that Intel intends to introduce with its upcoming Conroe processors in Q3. What we find amazing is that AMD must be able to reach these envelopes using its 90 nm technology, while Intel had to switch to 65 nm in order to maintain this course.
Moving the Sempron and Athlon families to a common socket eliminated the need for separate budget and mainstream/performance platforms.
The current Socket 754/939 Athlon 64 processors and motherboards usually cannot cope with more than 4 GB of RAM-there are few 2 GB DDR400 DIMMs-although addressing more than 4 GB is technically possible. The Socket AM2 Athlons will be able to use attractively-priced 2 GB DDR2 DIMMs.
The changed mounting mechanism for the CPU cooler will annoy enthusiasts who spent a lot of money on a sophisticated, motherboard-mounted solution. However, we expect average Joe to be good to go with the boxed cooler or other 3rd party products that certainly won't be more expensive due to this change.
Things are changing quite a bit. First, we have to say that the AM2 platform we received for this quick preview was as stable as a production system - this probably would not have been the case few years ago. Second, it is interesting to see that AMD is ready to launch AM2, and yet it is still waiting for the right moment. DDR2-800 and higher chip densities are a good justification for delaying the launch to late Q2.
Three years ago, AMD could never have afforded to delay a major technology launch for the sake of waiting for the ideal moment (or to make sure the new chips are available in sufficient quantities). Today, the Athlon 64 processor family is widely considered superior, which puts AMD into a role as leader rather than as a struggling competitor.
The Socket AM2 is a generation change that is becoming increasingly necessary for the sake of supporting memory that will be mainstream in mid-2006 and into 2007. It won't change the performance landscape by much, unless AMD decides to make some fundamental changes to the architecture such as upgrading the FX to 4 MB cache. However, it will also be the basis for the upcoming 65 nm processors that are due at the end of this year. That is when things are going to heat up; the shootout between Intel's Conroe desktop processor and AMD's shrunk Athlons will be as hot as the Gigahertz battle in 2000.
Kommentaarid: 215 loe/lisa Kasutajad arvavad:  :: 4 :: 0 :: 167
Slazenger
Slazenger
sõnum 21.02.2006 17:11:43 vasta tsitaadiga
Socket 940 sellep2rast, et m6ned lollid ei ostaks valet proset muidu poleks tarvis olnud füüsilist muutust icon_biggrin.gif
Kommentaarid: 74 loe/lisa Kasutajad arvavad:  :: 1 :: 0 :: 69
RKsilver
sõnum 21.02.2006 17:13:37 Re: AMD Socket AM2 Platform vasta tsitaadiga
margusser kirjutas:
Kommentaarid: 172 loe/lisa Kasutajad arvavad:  :: 2 :: 3 :: 140
Ho Ho
Ho Ho
sõnum 21.02.2006 17:24:26 Re: AMD Socket AM2 Platform vasta tsitaadiga
kutsa99 kirjutas:
margusser kirjutas:
Mis seal imelikku on? Inteli 65nm prosed on juba kuu-kaks letil ning sügiseks peaks conroe'l olema samuti 4M cache't.
riaak
riaak
sõnum 21.02.2006 17:24:33 vasta tsitaadiga
Tegelt kui teste vaadata siis def sätetel saab isegi 939 käest lutti icon_rolleyes.gif
Lootsin küll et vahe märgatav aga mis. IMO ülepaisutatud performance tõus thumbs_down.gif
¯\_(ツ)_/¯
Kommentaarid: 119 loe/lisa Kasutajad arvavad:  :: 0 :: 1 :: 105
Ho Ho
Ho Ho
sõnum 21.02.2006 17:51:28 vasta tsitaadiga
Seal räägitakse et viga on aeglases mälus (DDR2 667 vs DDR2 800). Kiirema mälu peale liikudes on kiirusevahe maksimaalselt 20% ning seda ainult tingimustes kus kiirus on piiratud ainult mälu läbilaske poolt.
Mina eeldaks et kiirusekasv DDR2 667->DDR2 800 peale minnes on umbkaudu sama kui kellata DDR1 400 -> DDR1 480 peale, ehk siis mälu panna käima 200 MHz asemel 240MHz peal ilma prose kiirust muutmata. Ma ei ole veel kuulnud et selline väike mälu kellamine oleks mõnes testis tulemust oluliselt muutnud. Ainus kus midagi märgatavalt muutuda võib on mälu läbilaske testid.
Denkeš
Denkeš
sõnum 21.02.2006 18:25:17 vasta tsitaadiga
Kindasti oli ka see üks suur pidur: 2x 512 MB DDR2-667 (333 MHz, CL3-2-2-8, 1T)
Running at CL-4-4-4-12 Timings - not changeable in test motherboard BIOS
Kokkuvõttes üks suht mõttetu test, kasutati mingeid pooltooreid proset ja emaplaati, mingis mõttes paljudele antireklaam kes ei viitsinud süveneda.
a.k.a Ummikummi
Kommentaarid: 5 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 4
Ho Ho
Ho Ho
sõnum 21.02.2006 18:53:57 vasta tsitaadiga
Miks ta siis niiväga pidur ikka on. Taimingud ei mõjuta nagunii enamus testides rohkem kui paar-kolm protsenti.
Sponge
Sponge
sõnum 21.02.2006 18:55:17 vasta tsitaadiga
njah eks veel on vara vaadata mis loomad on, kui välja tulevad siis vast, kas cold bug, OC normaaln tingimustes, uued driverid jne.. praegu oli see asi imho väga toores alles ning suht mõttetu "anti" reklaam tõesti kui ei süvene asjasse icon_rolleyes.gif
Kommentaarid: 398 loe/lisa Kasutajad arvavad:  :: 4 :: 4 :: 323
Denkeš
Denkeš
sõnum 21.02.2006 18:59:57 vasta tsitaadiga
Täpselt nii piisavalt need 2-3% ongi ,et paista kehvem kui eelkäija, selline tobe psühholoogiline efekt kuna kõik ju ootavad uuest mudelist midagi enamat icon_confused.gif
a.k.a Ummikummi
Raits754
sõnum 21.02.2006 19:20:40 vasta tsitaadiga
Muideks mina ootan/ootasin sellest uuest platformist suuremat kui 20% kiirusekasvu. Kui see nii on , siis ma küll selle peale raha kulutama ei hakka ( Kindlasti on ju selle hind kahekordne s939 hindadega? ) . kahekordne kiirusekasv - kahekordne hind - on seeditav . 20% kiirusekasv - kahekordne hind - ei ole seeditav.
soovija
soovija
sõnum 21.02.2006 19:26:49 vasta tsitaadiga
Kommentaarid: 100 loe/lisa Kasutajad arvavad:  :: 0 :: 4 :: 85
Ho Ho
Ho Ho
sõnum 21.02.2006 19:26:59 vasta tsitaadiga
Millest sa eeldad et hind kahekordne on? Minu arvamus on et hind märkimisväärselt ei muutu võrreldes praeguste prosedega, vast max 10-15% on alguses kallim ning sügiseks kukub kas praegustega samale pulgale või isegi odavamaks et Inteli uutele vidinatele vastu saada.
lamp
lamp
sõnum 21.02.2006 21:29:11 vasta tsitaadiga
ei teagi kus see "amd pwnorzzz" on kui am2 sellisel kujul aeglasem kui s939..
aga ilmselt juunikuuks saab se olema siiski 1-5% am2 kasuks..
4M L3'ga opteronid ka FX'iks teha näib olevat põhjendatud samm - 3.33G EE'le jääb se ilmselt alla, aga mitte nii nagu
ilma selle lisacacheta versioon..
eriti julm
Kommentaarid: 193 loe/lisa Kasutajad arvavad:  :: 1 :: 1 :: 169
soovija
soovija
sõnum 21.02.2006 21:34:58 vasta tsitaadiga
Siiski usun et tuleb kõva ,vähemalt konkureerib taas Pentiumiga ,suurenev vahemälu on ka positiivne icon_exclaim.gif
lamp
lamp
sõnum 21.02.2006 21:40:46 vasta tsitaadiga
soovija kirjutas:
"tavaline" inimene seda suurt tähele ei pane.. $999 FX ostma vist koolipoisid ei jookse icon_razz1.gif
aga ma pakun, et klokkides tuleb selle am2 potentsiaal välja - ddr2-800 3-2-2-1 timingutega on asi, millele ddr1 lähedale ei saa.. ja kui ddr2 yle 1000 läheb, siis juba tänu suurele kiirusele on see latentsus oluliselt väiksem kui madalama kiirusega
ddr1'el.. praegu on lihtsalt võimalus, et ka too am2 ES prose mem kontra on bugine..
eriti julm
Ho Ho
Ho Ho
sõnum 21.02.2006 21:57:59 vasta tsitaadiga
Btw, kas AM2 peale tulevatel prosedel on L2 iga tuuma kohta eraldi või on jagatud nagu Intelil? Kui jagatud siis peaks olema sellest rohkem kasu kui eraldi olevast cachest.
soovija
soovija
sõnum 21.02.2006 22:06:19 vasta tsitaadiga
Tavaline jah ei pane aga meie oleme suuremas osas ikkagi OC-d ja saame mängudes nähtava võimsuse vahe võrreldes 939-ga
Ho Ho arvan et tuleb jagatult nagu Pentiumil.
Ise olen pikemat aega juba raha kogunud . DDR2 soojendab minu südant ,kuna Pentium ei koti mind üldse.
Olen olnud ainult Celeroni ja AMD peal ja AMD peale ka jään. Varem oli DDR2 ainult Pentiumi pärusmaa thumbs_down.gif
lamp
lamp
sõnum 21.02.2006 22:18:34 vasta tsitaadiga
Ho Ho kirjutas:
prosed peaks olema samad kui s939, vahe siis uus mem kontra ja tviigitud tootmisprotsess ka icon_wink.gif
jagatud peaks olema ainult see opteroni/FXi L3 cache..
eriti julm
Ho Ho
Ho Ho
sõnum 21.02.2006 22:25:28 vasta tsitaadiga
soovija kirjutas:
Ma ise arvan miskipärast et esialgu tuleb siiski eraldi. Põhjuseks see et siiani olen näinud et L2 suurust on märgitud ikka 2x1M/512k mitte 2/1M. Loodetavasti mõne hilisema rev'iga tuleb see võimalus.
Üks koht kus jagatud cachest kõvasti kasu oleks on tarkvaraline ray tracing. Näiteks kui cache on 4M siis saaks cachesse tirida 4M jagu andmeid kuid kui kummagil corel on eraldi cache peaks kumbagis olema oma koopia, ehk siis mahtuvus oleks sisuliselt poole väiksem ning vajatakse rohkem mälupöördusi.
lamp kirjutas:
Ega sa kogemata ei tea kui suur see L3 olema hakab?
Kui tead ka L3'st andmete lugemise kiiruse võrdlus mälu ja L2'ga võid sellest ka rääkida icon_razz1.gif
soovija
soovija
sõnum 21.02.2006 22:43:00 vasta tsitaadiga
Jah ,ennast huvitab see asi väga nii et kellel teadmisi siis jagagu neid.
lamp
lamp
sõnum 21.02.2006 23:19:58 vasta tsitaadiga
Ho Ho kirjutas:
L3 peaks 4M olema, see on suht paljudes kohtades välja öeldud..
a ilmselt see l3 cachega variant on nende top-end mudel..
umbes nagu inteli 16M l3'ega "tulsa"
kiirusekohta ei oska ma mittemidagi öelda.. eks see l3 peab ideepoolest selle crossbari ja mem kontra vahel olema..
ilmselt se crossbar on ka asi, mida on am2 prosedel uuendatud ja just sellesama l3 pärast.
eriti julm
Ho Ho
Ho Ho
sõnum 21.02.2006 23:42:44 vasta tsitaadiga
Vanal "heal" pP4 EE'l oli 512k L2 ning 2.5M L3 kui õieti mäletan ehk siis L3 5x suurem kui L2. AMD'l on per core kõigest 2x suurem mahutavus. Võiks siis juba nagu tulevastel Intelitel et 12M või rohkem icon_razz1.gif
Ainus hea asi on et läbi L3 peaks saama tuumad omavahel üsna kiirelt andmeid vahetada eeldusel et läbi L1/2 see võimalik ei ole*. Kui õieti mäletan siis conroe ja sõbrad saavad omavahel suhelda läbi L1, praegused dualcore P4'd suhtlevad läbi põhjasilla.
*) ma pole praegste dualcore AMD'de kohta seda uurinud, võimalik et nad suudavad omavahel läbi mingi cache otse andmeid vahetada. Ähmaselt meenub et mingisugune andmekanal neil tuumadel siiski oli omavahel, võibolla HT link vmt.
tjj
tjj
sõnum 21.02.2006 23:54:35 vasta tsitaadiga
Ho Ho kirjutas:
Jagatud..
Kommentaarid: 161 loe/lisa Kasutajad arvavad:  :: 6 :: 0 :: 117
Ho Ho
Ho Ho
sõnum 22.02.2006 00:09:29 vasta tsitaadiga
tjj kirjutas:
Jagatud..
Selle pildi pealt loen mina välja et siiski on L2 kummagi tuuma jaoks eraldi ning üks tuum ei saa teise cache't otse kasutada icon_rolleyes.gif
Loomulikult ma pole mingi asjatundja, mõni kindlustav link võiks kellelgi olla icon_smile.gif
Kui oleks jagatud siis miks räägitakse cache suurustest 2x1M ning mitte 2M shared?
HDTanel
Overclocker
HDTanel
sõnum 22.02.2006 00:13:00 vasta tsitaadiga
Hästi läheb siis peale 27. Veebruari peaks saama näppida asja juba. Emaplaadiga ei oska öelda, DFI pole veel lubanud saata M2 emaplaati testiks aga üritan saada siiski
Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
One
sõnum 22.02.2006 00:13:57 vasta tsitaadiga
tjj
tjj
sõnum 22.02.2006 01:09:12 vasta tsitaadiga
Tomshardware review kohta:
Kasutati vana Windsor 90nm revisiioni (ei toeta DDR-II 800), mis omab IMC defekti ja ei saa siiski peegelda lõppseeria jõudsust.
Emaplaat (nVidia chipset logics) ei andnud ka muuta RAM timingud (4-4-4-12 forced) ja seetõttu võrdlemine DDR400 @ 2-2-2-5 andis selliseid tulemusi.
Ho Ho kirjutas:
tjj kirjutas:
Jagatud..
Tegelikult algusest arvatavasti ei lugenud sinu küsimust tähelepanelikult.. icon_smile.gif Pidasin meeles seda, et L2 1MB-1MB on mitte shared, vaid jagatud omavahel (pildi järgi see on hästi nähtud)..
2 core, aga üldine IMC.. Võib-olla core 1 saab IMC järgi kasutada core 2 L2, kui core 2 on idle.. 8)
Le Inc
Le Inc
sõnum 22.02.2006 17:37:58 vasta tsitaadiga
Mõeldakse ka väiksele võimsustarbele:
Kas siin mõeldakse rüpperaalide protsessoreid? Või tilgub siit midagi ka desktop'ile?
tjj
tjj
sõnum 22.02.2006 17:44:02 vasta tsitaadiga
Le Inc kirjutas:
Desktop-ile ka ikka..
http://www.tomshardware.com/2006/02/21/a_look_at_amds_socket_am2_platform/page5.html
viimati muutis tjj 22.02.2006 17:56:31, muudetud 1 kord
Auron
Auron
sõnum 22.02.2006 17:50:15 vasta tsitaadiga
Jap seal ikka desktopi peetakse silmas ja just töökohti kus vaikne arvuti hea oleks.
One
sõnum 22.02.2006 23:34:27 vasta tsitaadiga
link :: Albatron AM2 mobo
mnjaah
hmekk
hmekk
sõnum 22.02.2006 23:40:36 vasta tsitaadiga
msi on juba ammu esimese am2 mobo välja andnud
EDIT:
http://chinanews.sina.com/tech/2006/0206/18561026193.html
http://www.sdbear.com/2/lib/200602/06/20060206054.htm
Fotoblogi / Flickr
Kommentaarid: 102 loe/lisa Kasutajad arvavad:  :: 0 :: 8 :: 68
HDTanel
Overclocker
HDTanel
sõnum 22.02.2006 23:51:44 vasta tsitaadiga
edit: Albatron segane? icon_lol.gif floppy kaabli veab perse auku icon_biggrin.gif
Krüpto
Ho Ho
Ho Ho
sõnum 22.02.2006 23:54:23 vasta tsitaadiga
PlatoonSgtElias kirjutas:
edit: Albatron segane? icon_lol.gif floppy kaabli veab <b>piix</b> auku icon_biggrin.gif
Kes seda flopit ikka vajab, ma pole juba ~2a oma masinates flopiseadet omanud icon_razz1.gif
pähkel
pähkel
sõnum 23.02.2006 00:12:10 vasta tsitaadiga
Kui RAIDi tahad kasutada siis on vaja
Kommentaarid: 38 loe/lisa Kasutajad arvavad:  :: 0 :: 2 :: 35
Ho Ho
Ho Ho
sõnum 23.02.2006 00:16:02 vasta tsitaadiga
pähkel kirjutas:
Alles hiljuti sai ühele masinale raidis kettad installitud, pold vaja midagi muud kui OS'i installiplaate.
Tbit
sõnum 23.02.2006 00:50:21 vasta tsitaadiga
Uue CPU ploki peab ostma nüüd?? icon_neutral.gif...
plokki ei pea tingimata kui käed olemas et uus kinnitus teha, a jahutused on küll kõik mingi uued K9 seeria omad kuna K8 jahutitega pole seal erilist sitahaisu ka kompatiiblusest järel icon_neutral.gif .
DVD is da 4483MB :-/)
|OSTAN|-> T43 pikk jahutus
Kommentaarid: 265 loe/lisa Kasutajad arvavad:  :: 0 :: 3 :: 230
lamp
lamp
sõnum 23.02.2006 01:30:16 vasta tsitaadiga
pähkel kirjutas:
flopiraidi?
eriti julm
pähkel
pähkel
sõnum 23.02.2006 12:03:58 vasta tsitaadiga
lamp kirjutas:
pähkel kirjutas:
flopiraidi?
Flopiraidi muidugi. Paned 4 tükki raidi ja saed kõik rekordid pooleks icon_eek.gif
Ho Ho
Ho Ho
sõnum 23.02.2006 12:10:19 vasta tsitaadiga
link :: RAID
Keegi rääkis flopiraidist?
margusser
sõnum 23.02.2006 12:12:51 vasta tsitaadiga
Tbit
sõnum 23.02.2006 12:46:00 vasta tsitaadiga
liiga hea, et tõsi olla, mõnikord tõesti oleks vaja megane fail flopilt kiiremini kätte saada siis tuleb seda ennem 5x ümber kopeerida ?
Auron
Auron
sõnum 23.02.2006 17:00:38 vasta tsitaadiga
Tbit kirjutas:
liiga hea, et tõsi olla, mõnikord tõesti oleks vaja megane fail flopilt kiiremini kätte saada siis tuleb seda enne 5x ümber kopeerida ?
No siis ei osta lihtsalt seda "paha" emaplaati.Kõige odavam USB2.0 flash kaart (128)MB maksab alla 200 eegu.Niipalju võiks niivinget plaati ja süsteemi soetaval inimesel ju raha olla, et ajaga niipaljugi kaasas käia icon_rolleyes.gif
PS:Ise pole mingi 4-5 aastat flopit enam kasutand.
hmekk
hmekk
sõnum 24.02.2006 13:01:55 vasta tsitaadiga
nuh
muidugi võiks mainida, et amd-l tuleb ka uus socket välja
http://www.dailytech.com/article.aspx?newsid=958
quad core
Fotoblogi / Flickr
Ho Ho
Ho Ho
sõnum 24.02.2006 13:14:07 vasta tsitaadiga
Lihtsalt vaheinfoks et Inteli esimesed quadcore prosed peaks saadaval olema juba enne selle aasta lõppu icon_smile.gif
Nende võimekust AMD quadcorega ei oska võrrelda, kõik oleneb konkreetsest rakendusest ning Inteli FSB kiirusest.
Denkeš
Denkeš
sõnum 24.02.2006 22:29:37 vasta tsitaadiga
Veel üks AM2 emme, kadund Abitilt:http://www.aoaforums.com/forum/amd-motherboards-and-cpus/35567-halways-beta-testing-abits-nf5-mobo.html, ilus trükiplaat icon_razz1.gif
a.k.a Ummikummi
PPriit
sõnum 25.02.2006 01:50:37 vasta tsitaadiga
Ho Ho kirjutas:
pähkel kirjutas:
Kui tegu SATA RAID'iga, nt. nForce4 puhul, siis kuda sa sinna ajad Linuxi peale?
Ho Ho
Ho Ho
sõnum 25.02.2006 02:05:02 vasta tsitaadiga
PPriit kirjutas:
Ho Ho kirjutas:
pähkel kirjutas:
Kuna tegu on nii või naa tarkvaralise raidiga siis kasutan OS'i sisse ehitatud RAID'i võimalusi icon_smile.gif
PPriit
sõnum 25.02.2006 02:10:45 vasta tsitaadiga
Ho Ho kirjutas:
PPriit kirjutas:
Ho Ho kirjutas:
pähkel kirjutas:
No kui tarkvaraline siis selge pilt.
uus teema   vasta Raud »  Protsessorid »  AMD Socket AM2 Platform mine lehele 1, 2, 3, 4, 5  järgmine
