margusser
21.02.2006 17:09:11
AMD Socket AM2 Platform |
http://www.tomshardware.com/2006/02/21/a_look_at_amds_socket_am2_platform/
Gogo AMD!!
The Socket AM2 generation is certainly not going to outperform comparable Socket 939 (DDR400) processors at DDR2-667 memory speeds-see our benchmarks. This is why AMD decided to wait for DDR2-800 and launch in June.
Since the production process is not going to be changed, power consumption and heat dissipation in the mainstream will remain where they are today. We did some basic testing, but as expected the difference was not worth mentioning.
AMD is going to introduce low-powered processors for power and noise sensitive environments. The single cores will maintain a 35 W power envelope, while the dual cores won't exceed 65 W. The latter is the mainstream thermal design that Intel intends to introduce with its upcoming Conroe processors in Q3. What we find amazing is that AMD must be able to reach these envelopes using its 90 nm technology, while Intel had to switch to 65 nm in order to maintain this course.
Moving the Sempron and Athlon families to a common socket eliminated the need for separate budget and mainstream/performance platforms.
The current Socket 754/939 Athlon 64 processors and motherboards usually cannot cope with more than 4 GB of RAM-there are few 2 GB DDR400 DIMMs-although addressing more than 4 GB is technically possible. The Socket AM2 Athlons will be able to use attractively-priced 2 GB DDR2 DIMMs.
The changed mounting mechanism for the CPU cooler will annoy enthusiasts who spent a lot of money on a sophisticated, motherboard-mounted solution. However, we expect average Joe to be good to go with the boxed cooler or other 3rd party products that certainly won't be more expensive due to this change.
Things are changing quite a bit. First, we have to say that the AM2 platform we received for this quick preview was as stable as a production system - this probably would not have been the case few years ago. Second, it is interesting to see that AMD is ready to launch AM2, and yet it is still waiting for the right moment. DDR2-800 and higher chip densities are a good justification for delaying the launch to late Q2.
Three years ago, AMD could never have afforded to delay a major technology launch for the sake of waiting for the ideal moment (or to make sure the new chips are available in sufficient quantities). Today, the Athlon 64 processor family is widely considered superior, which puts AMD into a role as leader rather than as a struggling competitor.
The Socket AM2 is a generation change that is becoming increasingly necessary for the sake of supporting memory that will be mainstream in mid-2006 and into 2007. It won't change the performance landscape by much, unless AMD decides to make some fundamental changes to the architecture such as upgrading the FX to 4 MB cache. However, it will also be the basis for the upcoming 65 nm processors that are due at the end of this year. That is when things are going to heat up; the shootout between Intel's Conroe desktop processor and AMD's shrunk Athlons will be as hot as the Gigahertz battle in 2000.
167 |
Slazenger
21.02.2006 17:11:43
AMD pwnorzz again
X2 here i come
Socket 940 sellep2rast, et m6ned lollid ei ostaks valet proset muidu poleks tarvis olnud füüsilist muutust
| Kommentaarid: 74 loe/lisa |
69 |
RKsilver
21.02.2006 17:13:37
Re: AMD Socket AM2 Platform |
| margusser kirjutas: |
| The Socket AM2 is a generation change that is becoming increasingly necessary for the sake of supporting memory that will be mainstream in mid-2006 and into 2007. It won't change the performance landscape by much, unless AMD decides to make some fundamental changes to the architecture such as upgrading the FX to 4 MB cache. However, it will also be the basis for the upcoming 65 nm processors that are due at the end of this year. That is when things are going to heat up; the shootout between Intel's Conroe desktop processor and AMD's shrunk Athlons will be as hot as the Gigahertz battle in 2000. |
Osaapiix
| Kommentaarid: 172 loe/lisa |
140 |
Ho Ho
21.02.2006 17:24:26
| kutsa99 kirjutas: |
Osaapiix  |
Mis seal imelikku on? Inteli 65nm prosed on juba kuu-kaks letil ning sügiseks peaks conroe'l olema samuti 4M cache't.
87 |
riaak
21.02.2006 17:24:33
Tegelt kui teste vaadata siis def sätetel saab isegi 939 käest lutti
Lootsin küll et vahe märgatav aga mis. IMO ülepaisutatud performance tõus
Aga eks praktika näita mida need meile toovad
_________________ ¯\_(ツ)_/¯ |
105 |
Ho Ho
21.02.2006 17:51:28
Seal räägitakse et viga on aeglases mälus (DDR2 667 vs DDR2 800). Kiirema mälu peale liikudes on kiirusevahe maksimaalselt 20% ning seda ainult tingimustes kus kiirus on piiratud ainult mälu läbilaske poolt.
Mina eeldaks et kiirusekasv DDR2 667->DDR2 800 peale minnes on umbkaudu sama kui kellata DDR1 400 -> DDR1 480 peale, ehk siis mälu panna käima 200 MHz asemel 240MHz peal ilma prose kiirust muutmata. Ma ei ole veel kuulnud et selline väike mälu kellamine oleks mõnes testis tulemust oluliselt muutnud. Ainus kus midagi märgatavalt muutuda võib on mälu läbilaske testid.
87 |
Denke
21.02.2006 18:25:17
Kindasti oli ka see üks suur pidur: 2x 512 MB DDR2-667 (333 MHz, CL3-2-2-8, 1T)
Running at CL-4-4-4-12 Timings - not changeable in test motherboard BIOS Kokkuvõttes üks suht mõttetu test, kasutati mingeid pooltooreid proset ja emaplaati, mingis mõttes paljudele antireklaam kes ei viitsinud süveneda.
Ho Ho
21.02.2006 18:53:57
Miks ta siis niiväga pidur ikka on. Taimingud ei mõjuta nagunii enamus testides rohkem kui paar-kolm protsenti.
87 |
Sponge
21.02.2006 18:55:17
njah eks veel on vara vaadata mis loomad on, kui välja tulevad siis vast, kas cold bug, OC normaaln tingimustes, uued driverid jne.. praegu oli see asi imho väga toores alles ning suht mõttetu "anti" reklaam tõesti kui ei süvene asjasse
| Kommentaarid: 398 loe/lisa |
323 |
Denke
21.02.2006 18:59:57
Täpselt nii piisavalt need 2-3% ongi ,et paista kehvem kui eelkäija, selline tobe psühholoogiline efekt kuna kõik ju ootavad uuest mudelist midagi enamat
Raits754
21.02.2006 19:20:40
| Muideks mina ootan/ootasin sellest uuest platformist suuremat kui 20% kiirusekasvu. Kui see nii on , siis ma küll selle peale raha kulutama ei hakka ( Kindlasti on ju selle hind kahekordne s939 hindadega? ) . kahekordne kiirusekasv - kahekordne hind - on seeditav . 20% kiirusekasv - kahekordne hind - ei ole seeditav.
soovija
21.02.2006 19:26:49
AMD purustab ja pulstib taas Intelit
AMD powwa
85 |
Ho Ho
21.02.2006 19:26:59
Millest sa eeldad et hind kahekordne on? Minu arvamus on et hind märkimisväärselt ei muutu võrreldes praeguste prosedega, vast max 10-15% on alguses kallim ning sügiseks kukub kas praegustega samale pulgale või isegi odavamaks et Inteli uutele vidinatele vastu saada.
87 |
lamp
21.02.2006 21:29:11
ei teagi kus see "amd pwnorzzz" on kui am2 sellisel kujul aeglasem kui s939..
aga ilmselt juunikuuks saab se olema siiski 1-5% am2 kasuks..
4M L3'ga opteronid ka FX'iks teha näib olevat põhjendatud samm - 3.33G EE'le jääb se ilmselt alla, aga mitte nii nagu
ilma selle lisacacheta versioon..
169 |
soovija
21.02.2006 21:34:58
Siiski usun et tuleb kõva ,vähemalt konkureerib taas Pentiumiga ,suurenev vahemälu on ka positiivne
85 |
lamp
21.02.2006 21:40:46
| soovija kirjutas: |
Siiski usun et tuleb kõva ,vähemalt konkureerib taas Pentiumiga ,suurenev vahemälu on ka positiivne  |
"tavaline" inimene seda suurt tähele ei pane.. $999 FX ostma vist koolipoisid ei jookse
aga ma pakun, et klokkides tuleb selle am2 potentsiaal välja - ddr2-800 3-2-2-1 timingutega on asi, millele ddr1 lähedale ei saa.. ja kui ddr2 yle 1000 läheb, siis juba tänu suurele kiirusele on see latentsus oluliselt väiksem kui madalama kiirusega
ddr1'el.. praegu on lihtsalt võimalus, et ka too am2 ES prose mem kontra on bugine..
169 |
Ho Ho
21.02.2006 21:57:59
Btw, kas AM2 peale tulevatel prosedel on L2 iga tuuma kohta eraldi või on jagatud nagu Intelil? Kui jagatud siis peaks olema sellest rohkem kasu kui eraldi olevast cachest.
87 |
soovija
21.02.2006 22:06:19
Tavaline jah ei pane aga meie oleme suuremas osas ikkagi OC-d ja saame mängudes nähtava võimsuse vahe võrreldes 939-ga
Ho Ho arvan et tuleb jagatult nagu Pentiumil.
Ise olen pikemat aega juba raha kogunud . DDR2 soojendab minu südant ,kuna Pentium ei koti mind üldse.
Olen olnud ainult Celeroni ja AMD peal ja AMD peale ka jään. Varem oli DDR2 ainult Pentiumi pärusmaa
85 |
lamp
21.02.2006 22:18:34
| Ho Ho kirjutas: |
| Btw, kas AM2 peale tulevatel prosedel on L2 iga tuuma kohta eraldi või on jagatud nagu Intelil? Kui jagatud siis peaks olema sellest rohkem kasu kui eraldi olevast cachest. |
prosed peaks olema samad kui s939, vahe siis uus mem kontra ja tviigitud tootmisprotsess ka
jagatud peaks olema ainult see opteroni/FXi L3 cache..
169 |
Ho Ho
21.02.2006 22:25:28
| soovija kirjutas: |
| Ho Ho arvan et tuleb jagatult nagu Pentiumil. |
Ma ise arvan miskipärast et esialgu tuleb siiski eraldi. Põhjuseks see et siiani olen näinud et L2 suurust on märgitud ikka 2x1M/512k mitte 2/1M. Loodetavasti mõne hilisema rev'iga tuleb see võimalus.
Üks koht kus jagatud cachest kõvasti kasu oleks on tarkvaraline ray tracing. Näiteks kui cache on 4M siis saaks cachesse tirida 4M jagu andmeid kuid kui kummagil corel on eraldi cache peaks kumbagis olema oma koopia, ehk siis mahtuvus oleks sisuliselt poole väiksem ning vajatakse rohkem mälupöördusi.
| lamp kirjutas: |
| jagatud peaks olema ainult see opteroni/FXi L3 cache.. |
Ega sa kogemata ei tea kui suur see L3 olema hakab?
Kui tead ka L3'st andmete lugemise kiiruse võrdlus mälu ja L2'ga võid sellest ka rääkida
87 |
soovija
21.02.2006 22:43:00
Jah ,ennast huvitab see asi väga nii et kellel teadmisi siis jagagu neid.
85 |
lamp
21.02.2006 23:19:58
| Ho Ho kirjutas: |
Kui tead ka L3'st andmete lugemise kiiruse võrdlus mälu ja L2'ga võid sellest ka rääkida  |
L3 peaks 4M olema, see on suht paljudes kohtades välja öeldud..
a ilmselt see l3 cachega variant on nende top-end mudel..
umbes nagu inteli 16M l3'ega "tulsa"
kiirusekohta ei oska ma mittemidagi öelda.. eks see l3 peab ideepoolest selle crossbari ja mem kontra vahel olema..
ilmselt se crossbar on ka asi, mida on am2 prosedel uuendatud ja just sellesama l3 pärast.
169 |
Ho Ho
21.02.2006 23:42:44
Kui on 4M siis ju suht vähe
Vanal "heal" pP4 EE'l oli 512k L2 ning 2.5M L3 kui õieti mäletan ehk siis L3 5x suurem kui L2. AMD'l on per core kõigest 2x suurem mahutavus. Võiks siis juba nagu tulevastel Intelitel et 12M või rohkem
Ainus hea asi on et läbi L3 peaks saama tuumad omavahel üsna kiirelt andmeid vahetada eeldusel et läbi L1/2 see võimalik ei ole*. Kui õieti mäletan siis conroe ja sõbrad saavad omavahel suhelda läbi L1, praegused dualcore P4'd suhtlevad läbi põhjasilla.
*) ma pole praegste dualcore AMD'de kohta seda uurinud, võimalik et nad suudavad omavahel läbi mingi cache otse andmeid vahetada. Ähmaselt meenub et mingisugune andmekanal neil tuumadel siiski oli omavahel, võibolla HT link vmt.
87 |
tjj
21.02.2006 23:54:35
| Ho Ho kirjutas: |
Jagatud..
| Kommentaarid: 161 loe/lisa |
6 :: |
117 |
Ho Ho
22.02.2006 00:09:29
Selle pildi pealt loen mina välja et siiski on L2 kummagi tuuma jaoks eraldi ning üks tuum ei saa teise cache't otse kasutada
Loomulikult ma pole mingi asjatundja, mõni kindlustav link võiks kellelgi olla
Kui oleks jagatud siis miks räägitakse cache suurustest 2x1M ning mitte 2M shared?
87 |
HDTanel
Overclocker
22.02.2006 00:13:00
Hästi läheb siis peale 27. Veebruari peaks saama näppida asja juba. Emaplaadiga ei oska öelda, DFI pole veel lubanud saata M2 emaplaati testiks aga üritan saada siiski
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
496 |
One
728 |
tjj
22.02.2006 01:09:12
Tomshardware review kohta:
Kasutati vana Windsor 90nm revisiioni (ei toeta DDR-II 800), mis omab IMC defekti ja ei saa siiski peegelda lõppseeria jõudsust.
Emaplaat (nVidia chipset logics) ei andnud ka muuta RAM timingud (4-4-4-12 forced) ja seetõttu võrdlemine DDR400 @ 2-2-2-5 andis selliseid tulemusi.
| Ho Ho kirjutas: |
Kui oleks jagatud siis miks räägitakse cache suurustest 2x1M ning mitte 2M shared? |
Tegelikult algusest arvatavasti ei lugenud sinu küsimust tähelepanelikult.. Pidasin meeles seda, et L2 1MB-1MB on mitte shared, vaid jagatud omavahel (pildi järgi see on hästi nähtud)..
2 core, aga üldine IMC.. Võib-olla core 1 saab IMC järgi kasutada core 2 L2, kui core 2 on idle.. 8)
6 :: |
117 |
Le Inc
22.02.2006 17:37:58
Mõeldakse ka väiksele võimsustarbele:
Kas siin mõeldakse rüpperaalide protsessoreid? Või tilgub siit midagi ka desktop'ile?
| Kommentaarid: 56 loe/lisa |
54 |
tjj
22.02.2006 17:44:02
| Le Inc kirjutas: |
Kas siin mõeldakse rüpperaalide protsessoreid? Või tilgub siit midagi ka desktop'ile? |
Desktop-ile ka ikka..
http://www.tomshardware.com/2006/02/21/a_look_at_amds_socket_am2_platform/page5.html
viimati muutis tjj 22.02.2006 17:56:31, muudetud 1 kord |
6 :: |
117 |
Auron
22.02.2006 17:50:15
| Jap seal ikka desktopi peetakse silmas ja just töökohti kus vaikne arvuti hea oleks.
133 |
One
728 |
hmekk
8 :: |
68 |
HDTanel
Overclocker
22.02.2006 23:51:44
Uue CPU ploki peab ostma nüüd??
edit: Albatron segane? floppy kaabli veab perse auku
496 |
Ho Ho
22.02.2006 23:54:23
| PlatoonSgtElias kirjutas: |
edit: Albatron segane? floppy kaabli veab <b>piix</b> auku  |
Kes seda flopit ikka vajab, ma pole juba ~2a oma masinates flopiseadet omanud
87 |
pähkel
23.02.2006 00:12:10
| Kui RAIDi tahad kasutada siis on vaja
| Kommentaarid: 38 loe/lisa |
Ho Ho
23.02.2006 00:16:02
| pähkel kirjutas: |
| Kui RAIDi tahad kasutada siis on vaja |
Korralikud OS'id omavad draivereid kernelis
Alles hiljuti sai ühele masinale raidis kettad installitud, pold vaja midagi muud kui OS'i installiplaate.
87 |
Tbit
23.02.2006 00:50:21
Uue CPU ploki peab ostma nüüd?? ... |
plokki ei pea tingimata kui käed olemas et uus kinnitus teha, a jahutused on küll kõik mingi uued K9 seeria omad kuna K8 jahutitega pole seal erilist sitahaisu ka kompatiiblusest järel .
|OSTAN|-> T43 pikk jahutus |
230 |
lamp
23.02.2006 01:30:16
| pähkel kirjutas: |
flopiraidi?
169 |
pähkel
23.02.2006 12:03:58
| lamp kirjutas: |
| pähkel kirjutas: |
flopiraidi? |
Flopiraidi muidugi. Paned 4 tükki raidi ja saed kõik rekordid pooleks
Ho Ho
23.02.2006 12:10:19
link :: RAID
Keegi rääkis flopiraidist?
87 |
margusser
23.02.2006 12:12:51
Ho Ho, väga vajalik asi
167 |
Tbit
23.02.2006 12:46:00
liiga hea, et tõsi olla, mõnikord tõesti oleks vaja megane fail flopilt kiiremini kätte saada siis tuleb seda ennem 5x ümber kopeerida ?
230 |
Auron
23.02.2006 17:00:38
| Tbit kirjutas: |
| liiga hea, et tõsi olla, mõnikord tõesti oleks vaja megane fail flopilt kiiremini kätte saada siis tuleb seda enne 5x ümber kopeerida ? |
No siis ei osta lihtsalt seda "paha" emaplaati.Kõige odavam USB2.0 flash kaart (128)MB maksab alla 200 eegu.Niipalju võiks niivinget plaati ja süsteemi soetaval inimesel ju raha olla, et ajaga niipaljugi kaasas käia
PS:Ise pole mingi 4-5 aastat flopit enam kasutand.
133 |
hmekk
8 :: |
68 |
Ho Ho
24.02.2006 13:14:07
Lihtsalt vaheinfoks et Inteli esimesed quadcore prosed peaks saadaval olema juba enne selle aasta lõppu
Nende võimekust AMD quadcorega ei oska võrrelda, kõik oleneb konkreetsest rakendusest ning Inteli FSB kiirusest.
87 |
Denke
PPriit
25.02.2006 01:50:37
| Ho Ho kirjutas: |
| pähkel kirjutas: |
Alles hiljuti sai ühele masinale raidis kettad installitud, pold vaja midagi muud kui OS'i installiplaate. |
Kui tegu SATA RAID'iga, nt. nForce4 puhul, siis kuda sa sinna ajad Linuxi peale?
| Kommentaarid: 9 loe/lisa |
9 |
Ho Ho
25.02.2006 02:05:02
| PPriit kirjutas: |
| Ho Ho kirjutas: |
| pähkel kirjutas: |
Kui tegu SATA RAID'iga, nt. nForce4 puhul, siis kuda sa sinna ajad Linuxi peale? |
Kuna tegu on nii või naa tarkvaralise raidiga siis kasutan OS'i sisse ehitatud RAID'i võimalusi
87 |
PPriit
25.02.2006 02:10:45
| Ho Ho kirjutas: |
| PPriit kirjutas: |
| Ho Ho kirjutas: |
| pähkel kirjutas: |
Kuna tegu on nii või naa tarkvaralise raidiga siis kasutan OS'i sisse ehitatud RAID'i võimalusi  |
No kui tarkvaraline siis selge pilt.
9 |
