siLc
186 |
Viilutaja
| Kommentaarid: 226 loe/lisa |
196 |
pots4t4j4
08.07.2018 11:09:57
| Mis sa seda timespy tulemust siia firestrike alla topid ?
401 |
Viilutaja
08.07.2018 12:08:00
| pots4t4j4 kirjutas: |
| Mis sa seda timespy tulemust siia firestrike alla topid ? |
My bad, 2 eraldi teemat oli lahti. Honest mistake.
Chill!
196 |
Karlakass
09.07.2018 21:46:02
Riistvara: Acer Predator Helios 300 PH317-51 LÄPPAR
CPU: i7 7700 HQ 2,800 4(8)
RAM: 12288 MB
1. A-Data 4096 Mb/ DDR4-2400
2. Kingston 8192 Mb/ DDR4-2666
GPU: 1. iNTEL HD 630
2. Nvidia GeForce GTX 1060 / 6144 Mb clock 1505(1455) mem clock 2027(2002)
DISPLAY: 1920x1080
DRIVE: 1. c: KINGSTON RBUSNS 8180DS3128GH (128Gb)
2. d: TOSHIBA MQ04ABF100 (1Tb)
OP SÜS: W10 Home x64
SKOORID: FIRESTRIKE 10211
graph. s 12127
g. test1 57,20 fps
g. test2 48,91 fps
physics s. 10454
p. test 33,19 fps
combined 4600
c. test 21,40 fps
anubis
283 |
Viilutaja
12.09.2018 15:23:25
https://www.3dmark.com/compare/fs/16315434/fs/16344983
Ryzen 5 1600@3.8Ghz
Ref. VEGA64 + Morpheus II cooler+120mm fans + Vega64 LC bios (core 1750/945). Turbo preset
3DMark Score - 18 578
Graphics Score - 24 802
Physics Score - 17300
Combined Score - 6704
Graphics Test 1 - 121.27 fps
Graphics Test 2 - 97.09 fps
Physics Test - 54,92 fps
Combined Test - 31.19 fps
Ryzen 5 1600@3.8Ghz
Ref. VEGA64 + Morpheus II cooler+120mm fans + Vega64 def bios (core 1630/945). Turbo preset
3DMark Score - 18232
Graphics Score - 23900
Physics Score - 17402
Combined Score - 6 736
Graphics Test 1 - 117.75 fps
Graphics Test 2 - 92.99 fps
Physics Test - 55.25 fps
Combined Test - 31.33 fps
GPU skoori vahe peaaegu 1000p.
GPU temp oli 62C LC_biosega
HBM2 temp oli 64C LC_biosega
Proovin nüüd teha mingid testjooksud OC'tud HBM2'ga ka.
196 |
anubis
283 |
Kremka
| Kommentaarid: 77 loe/lisa |
69 |
Viilutaja
28.09.2018 12:10:42
https://www.3dmark.com/fs/16492416
Ryzen 5 1600@3.8Ghz
Ref. VEGA64 + Morpheus II cooler+120mm fans + Vega64 LC bios (core 1750/1100hbm). Custom preset.
P7:1750mhz 1130mv
HBM2: 1100mhz 950mv
+50% pwr
Kui 1750mhz oli pandud siis reaalselt jooksis seal (1660-1670mhz vahemikus benchis).
3DMark Score - 19 493
Graphics Score - 26 556
Physics Score - 17 525
Combined Score - 6897
Graphics Test 1 - 130.79 fps
Graphics Test 2 - 103.35 fps
Physics Test - 55.4 fps
Combined Test - 32.08 fps
Sellisena oli ta ka 100% stabiilne, jooksutas 3DMark FiresStrike stress testi läbi, skooriga 98.5%.
Seega on veel ruumi.
GPU-Z näitas ainult kaardi max voolutarvet 307W. Keskmist ei mäleta, kuid oli alla 300W.
196 |
216 |
Viilutaja
28.09.2018 17:21:21
OC' tulemus?
Mis stock on?
196 |
216 |
Viilutaja
03.10.2018 13:51:20
E: https://www.3dmark.com/compare/fs/16546496
Ryzen 5 1600@3.8Ghz
Ref. VEGA64 + Morpheus II cooler+120mm fans + Vega64 LC bios.
OverDrive toolist määratud:
P6: 1680mhz 1140mv
P7: 1750mhz 1170mv
HBM2: 1140mhz 975mv
+50% pwr
Target temp 65C
Kui 1750mhz oli pandud siis reaalselt jooksis seal (1680-1715mhz vahemikus benchis). Game 1 madalamal sagedusel ja Game2 testis tõstis stabiilselt 1700-1715 mhz peale.
3DMark Score - 19 747
Graphics Score - 27 155
Physics Score - 17 548
Combined Score - 6 910
Graphics Test 1 - 133.83 fps
Graphics Test 2 - 105.62 fps
Physics Test - 55.71 fps
Combined Test - 32.14 fps
Temperatuurid üle 65C ei tõuse (gpu,hbm2), muud max tempid jäävad 85C juurde.
GPU-Z näitas ainult kaardi max voolutarvet 333W. Keskmine oli 290W.
On veel ruumi, sest stress stressis on stabiilne. Peab ainult rohkem jahedat õhku peale saama.
Oleks veeplokk ja saaks max tempi sinna 40C peale, siis 1800+ mhz oleks stabiilne.
Aga on ikka ulme, milleks Vega võimeline on, kui tehasest ei pandaks niipalju volti peale ja suht sita jahutusega.
FireStrike Extreme lasin ka 1 korra.
https://www.3dmark.com/fs/16549595
Graphics Score 12 546
Physics Score 17 963
Combined Score 4 726
FireStrike Ultra
https://www.3dmark.com/fs/16549664
Graphics Score 6 370
Physics Score 17 388
Combined Score 2 817
196 |
anubis
15.10.2018 22:24:25
R7 2700X @ 4,1Ghz http://valid.x86.fr/u1m9jh
Palit GTX1080Ti Turbo (+150core/+450mem/110 power limit)
Fire Strike Ultra
https://www.3dmark.com/fs/16697824
3DMark Score - 7351
Graphics Score - 7272
Physics Score - 20875
Combined Score - 3891
Graphics Test 1 - 40.42 fps
Graphics Test 2 - 25.97 fps
Physics Test - 66.27 fps
Combined Test - 18.1 fps
Fire Strike Extreme
https://www.3dmark.com/fs/16697858
3DMark Score - 13840
Graphics Score - 14793
Physics Score - 21433
Combined Score - 6870
Graphics Test 1 - 77.67 fps
Graphics Test 2 - 54.88 fps
Physics Test - 68.04 fps
Combined Test - 31.95 fps
Fire Strike
https://www.3dmark.com/fs/16697890
3DMark Score - 21948
Graphics Score - 30254
Physics Score - 21414
Combined Score - 7264
Graphics Test 1 - 145.15 fps
Graphics Test 2 - 120.26 fps
Physics Test - 67.98 fps
Combined Test - 33.79 fps
283 |
razor
17.10.2018 23:23:23
L5640 @ ~4,2ghz (220x19)
ddr3 @ 2200mhz cl10-15-15-31
GTX 1070 @ def
https://www.3dmark.com/fs/16693768
3DMark Score - 15201
Graphics Score - 18042
Physics Score - 14573
Combined Score - 7184
120 |
oog
Viilutaja
196 |
XeStAiSy
Aeg Maha 2a
| Kommentaarid: 12 loe/lisa |
Kremka
69 |
Viilutaja
196 |
Kremka
09.02.2019 22:18:39
Äkki sheerid enda Wattman profiili
69 |
Viilutaja
09.02.2019 22:53:47
| Kremka kirjutas: |
Äkki sheerid enda Wattman profiili  |
Aga palun!
See pole küll WattMan kuid kasutan seda OverDrivenTooli. Mugavam ja lihtsam, kuid saad samad asjad ka Wattmani panna.
Kuid võin juba ette öelda, et need minu seaded ei pruugi üldse sul toimida. Oleneb väga palju Silicon Loteriist.
Mina üritasin näiteks saada samad voldid ja klokid nagu nendel kahel, kellel on ikka väga väga head tulemused. Kuid ei saa lihtsalt.
Proovisin nende skoore kuidagi saada, aga nendel on sisuliselt cherry picked Vegad. Üks nendest ütles, et proovis läbi 10 kaarti ja valis nendest parima.
196 |
anubis
283 |
siLc
186 |
