siLc
186 |
Viilutaja
| Kommentaarid: 226 loe/lisa |
196 |
pots4t4j4
08.07.2018 12:09:57
| Mis sa seda timespy tulemust siia firestrike alla topid ?
401 |
Viilutaja
196 |
Karlakass
09.07.2018 22:46:02
Riistvara: Acer Predator Helios 300 PH317-51 LÄPPAR
CPU: i7 7700 HQ 2,800 4(8)
RAM: 12288 MB
1. A-Data 4096 Mb/ DDR4-2400
2. Kingston 8192 Mb/ DDR4-2666
GPU: 1. iNTEL HD 630
2. Nvidia GeForce GTX 1060 / 6144 Mb clock 1505(1455) mem clock 2027(2002)
DISPLAY: 1920x1080
DRIVE: 1. c: KINGSTON RBUSNS 8180DS3128GH (128Gb)
2. d: TOSHIBA MQ04ABF100 (1Tb)
OP SÜS: W10 Home x64
SKOORID: FIRESTRIKE 10211
graph. s 12127
g. test1 57,20 fps
g. test2 48,91 fps
physics s. 10454
p. test 33,19 fps
combined 4600
c. test 21,40 fps
anubis
283 |
Viilutaja
12.09.2018 16:23:25
https://www.3dmark.com/compare/fs/16315434/fs/16344983
Ryzen 5 1600@3.8Ghz
Ref. VEGA64 + Morpheus II cooler+120mm fans + Vega64 LC bios (core 1750/945). Turbo preset
3DMark Score - 18 578
Graphics Score - 24 802
Physics Score - 17300
Combined Score - 6704
Graphics Test 1 - 121.27 fps
Graphics Test 2 - 97.09 fps
Physics Test - 54,92 fps
Combined Test - 31.19 fps
Ryzen 5 1600@3.8Ghz
Ref. VEGA64 + Morpheus II cooler+120mm fans + Vega64 def bios (core 1630/945). Turbo preset
3DMark Score - 18232
Graphics Score - 23900
Physics Score - 17402
Combined Score - 6 736
Graphics Test 1 - 117.75 fps
Graphics Test 2 - 92.99 fps
Physics Test - 55.25 fps
Combined Test - 31.33 fps
GPU skoori vahe peaaegu 1000p.
GPU temp oli 62C LC_biosega
HBM2 temp oli 64C LC_biosega
Proovin nüüd teha mingid testjooksud OC'tud HBM2'ga ka.
_________________ Parim kodukino projektor müügis: https://foorum.hinnavaatlus.ee/viewtopic.php?p=11768241#11768241 |
196 |
anubis
283 |
Kremka
| Kommentaarid: 80 loe/lisa |
72 |
Viilutaja
28.09.2018 13:10:42
https://www.3dmark.com/fs/16492416
Ryzen 5 1600@3.8Ghz
Ref. VEGA64 + Morpheus II cooler+120mm fans + Vega64 LC bios (core 1750/1100hbm). Custom preset.
P7:1750mhz 1130mv
HBM2: 1100mhz 950mv
+50% pwr
Kui 1750mhz oli pandud siis reaalselt jooksis seal (1660-1670mhz vahemikus benchis).
3DMark Score - 19 493
Graphics Score - 26 556
Physics Score - 17 525
Combined Score - 6897
Graphics Test 1 - 130.79 fps
Graphics Test 2 - 103.35 fps
Physics Test - 55.4 fps
Combined Test - 32.08 fps
Sellisena oli ta ka 100% stabiilne, jooksutas 3DMark FiresStrike stress testi läbi, skooriga 98.5%.
Seega on veel ruumi.
GPU-Z näitas ainult kaardi max voolutarvet 307W. Keskmist ei mäleta, kuid oli alla 300W.
196 |
217 |
Viilutaja
196 |
217 |
Viilutaja
03.10.2018 14:51:20
E: https://www.3dmark.com/compare/fs/16546496
Ryzen 5 1600@3.8Ghz
Ref. VEGA64 + Morpheus II cooler+120mm fans + Vega64 LC bios.
OverDrive toolist määratud:
P6: 1680mhz 1140mv
P7: 1750mhz 1170mv
HBM2: 1140mhz 975mv
+50% pwr
Target temp 65C
Kui 1750mhz oli pandud siis reaalselt jooksis seal (1680-1715mhz vahemikus benchis). Game 1 madalamal sagedusel ja Game2 testis tõstis stabiilselt 1700-1715 mhz peale.
3DMark Score - 19 747
Graphics Score - 27 155
Physics Score - 17 548
Combined Score - 6 910
Graphics Test 1 - 133.83 fps
Graphics Test 2 - 105.62 fps
Physics Test - 55.71 fps
Combined Test - 32.14 fps
Temperatuurid üle 65C ei tõuse (gpu,hbm2), muud max tempid jäävad 85C juurde.
GPU-Z näitas ainult kaardi max voolutarvet 333W. Keskmine oli 290W.
On veel ruumi, sest stress stressis on stabiilne. Peab ainult rohkem jahedat õhku peale saama.
Oleks veeplokk ja saaks max tempi sinna 40C peale, siis 1800+ mhz oleks stabiilne.
Aga on ikka ulme, milleks Vega võimeline on, kui tehasest ei pandaks niipalju volti peale ja suht sita jahutusega.
FireStrike Extreme lasin ka 1 korra.
https://www.3dmark.com/fs/16549595
Graphics Score 12 546
Physics Score 17 963
Combined Score 4 726
FireStrike Ultra
https://www.3dmark.com/fs/16549664
Graphics Score 6 370
Physics Score 17 388
Combined Score 2 817
196 |
anubis
15.10.2018 23:24:25
R7 2700X @ 4,1Ghz http://valid.x86.fr/u1m9jh
Palit GTX1080Ti Turbo (+150core/+450mem/110 power limit)
Fire Strike Ultra
https://www.3dmark.com/fs/16697824
3DMark Score - 7351
Graphics Score - 7272
Physics Score - 20875
Combined Score - 3891
Graphics Test 1 - 40.42 fps
Graphics Test 2 - 25.97 fps
Physics Test - 66.27 fps
Combined Test - 18.1 fps
Fire Strike Extreme
https://www.3dmark.com/fs/16697858
3DMark Score - 13840
Graphics Score - 14793
Physics Score - 21433
Combined Score - 6870
Graphics Test 1 - 77.67 fps
Graphics Test 2 - 54.88 fps
Physics Test - 68.04 fps
Combined Test - 31.95 fps
Fire Strike
https://www.3dmark.com/fs/16697890
3DMark Score - 21948
Graphics Score - 30254
Physics Score - 21414
Combined Score - 7264
Graphics Test 1 - 145.15 fps
Graphics Test 2 - 120.26 fps
Physics Test - 67.98 fps
Combined Test - 33.79 fps
283 |
razor
18.10.2018 00:23:23
L5640 @ ~4,2ghz (220x19)
ddr3 @ 2200mhz cl10-15-15-31
GTX 1070 @ def
https://www.3dmark.com/fs/16693768
3DMark Score - 15201
Graphics Score - 18042
Physics Score - 14573
Combined Score - 7184
120 |
oog
Viilutaja
196 |
XeStAiSy
Aeg Maha 2a
| Kommentaarid: 12 loe/lisa |
Kremka
72 |
Viilutaja
196 |
Kremka
09.02.2019 23:18:39
Äkki sheerid enda Wattman profiili
72 |
Viilutaja
09.02.2019 23:53:47
| Kremka kirjutas: |
Äkki sheerid enda Wattman profiili  |
Aga palun!
See pole küll WattMan kuid kasutan seda OverDrivenTooli. Mugavam ja lihtsam, kuid saad samad asjad ka Wattmani panna.
Kuid võin juba ette öelda, et need minu seaded ei pruugi üldse sul toimida. Oleneb väga palju Silicon Loteriist.
Mina üritasin näiteks saada samad voldid ja klokid nagu nendel kahel, kellel on ikka väga väga head tulemused. Kuid ei saa lihtsalt.
Proovisin nende skoore kuidagi saada, aga nendel on sisuliselt cherry picked Vegad. Üks nendest ütles, et proovis läbi 10 kaarti ja valis nendest parima.
196 |
anubis
283 |
siLc
186 |
Viilutaja
196 |
20.02.2019 21:22:30
stock radeon vii on samas augus?
_________________ - londiste
217 |
Viilutaja
196 |
26.04.2019 22:20:18
Lasin siis kah, ajaviiteks ühe....
https://www.3dmark.com/fs/19139913
196 |
koiott
07.05.2019 18:44:25
Märgin teema ära: https://www.3dmark.com/fs/19266015
Positiivselt üllatunud RX 480ne osas. Kuigi ma ei saa selle kaardi mälude hingeelust aru..2200MHz peal ei saa arugi, et midagi muutuks vs 2000MHz, samas kui panna 1900-1950MHz, siis fps ikka natuke kukub.
136 |
anubis
283 |
WäntWõll
make.believe
17.06.2019 09:49:12
hmm huvitav tulemus, eile kui kaarti vahetasin siis proovisin ka.
Vega 64 LC stoc + 8700k @ 5GHz
3dmark score oli 22300 ca.
Õhtal saab ueusti lasta siis vaatan detailid ka üle, mis lisa andis, tundub et prose
300 |
anubis
17.07.2019 18:04:48
Mul pigem GPU voolusäästlikuks timmitud, ~185-210w koormuse all. ~1525-1550mhz core loadi all.
edit:
MSI Navi 5700 @stock
R5 3600x @stock
https://www.techpowerup.com/gpuz/details/dgxhv
http://valid.x86.fr/ewdpyw
Fire Strike
https://www.3dmark.com/fs/19872633
3DMark Score - 19969
Graphics Score - 23248
Physics Score - 20129
Combined Score - 9649
Graphics Test 1 - 108.08 fps
Graphics Test 2 - 94.93 fps
Physics Test - 63.9 fps
Combined Test - 44.88 fps
Fire Strike Extreme
https://www.3dmark.com/fs/19872616
3DMark Score - 10292
Graphics Score - 11023
Physics Score - 20228
Combined Score - 4607
Graphics Test 1 - 53.98 fps
Graphics Test 2 - 43.1 fps
Physics Test - 64.22 fps
Combined Test - 21.43 fps
Fire Strike Ultra
https://www.3dmark.com/fs/19872587
3DMark Score - 5352
Graphics Score - 5313
Physics Score - 20231
Combined Score - 2614
Graphics Test 1 - 26.7 fps
Graphics Test 2 - 20.36 fps
Physics Test - 64.23 fps
Combined Test - 12.16 fps
edit: OCtult
Fire Strike
https://www.3dmark.com/fs/19873830
3DMark Score - 20717
Graphics Score - 24397
Physics Score - 20142
Combined Score - 9920
Graphics Test 1 - 113.54 fps
Graphics Test 2 - 99.54 fps
Physics Test - 63.94 fps
Combined Test - 46.14 fps
Fire Strike Extreme
https://www.3dmark.com/fs/19873811
3DMark Score - 10684
Graphics Score - 11460
Physics Score - 20174
Combined Score - 4827
Graphics Test 1 - 56.19 fps
Graphics Test 2 - 44.76 fps
Physics Test - 64.04 fps
Combined Test - 22.45 fps
Fire Strike Ultra
https://www.3dmark.com/fs/19873743
3DMark Score - 5606
Graphics Score - 5579
Physics Score - 20140
Combined Score - 2742
Graphics Test 1 - 27.91 fps
Graphics Test 2 - 21.46 fps
Combined Test - 12.75 fps
Edit: Navi 5700XT @stock
R5 3600x @stock
Fire Strike
https://www.3dmark.com/fs/19888430
3DMark Score - 21512
Graphics Score - 26307
Physics Score - 19654
Combined Score - 9668
Graphics Test 1 - 122.44 fps
Graphics Test 2 - 107.32 fps
Physics Test - 62.4 fps
Combined Test - 44.97 fps
Fire Strike Extreme
https://www.3dmark.com/fs/19888397
3DMark Score - 11494
Graphics Score - 12449
Physics Score - 19896
Combined Score - 5205
Graphics Test 1 - 61.48 fps
Graphics Test 2 - 48.34 fps
Physics Test - 63.16 fps
Combined Test - 24.21 fps
Fire Strike Ultra
https://www.3dmark.com/fs/19888360
3DMark Score - 6014
Graphics Score - 5998
Physics Score - 20148
Combined Score - 2960
Graphics Test 1 - 30.1 fps
Graphics Test 2 - 23.01 fps
Physics Test - 63.96 fps
Combined Test - 13.77 fps
283 |
flake
| Kommentaarid: 63 loe/lisa |
60 |
anubis
22.07.2019 01:31:26
Navi 5700xt @50% power limit ja GPU max
R5 3600x @4.2ghz 1.325v
Fire Strike
https://www.3dmark.com/fs/19935408
3DMark Score - 22759
Graphics Score - 28290
Physics Score - 20305
Combined Score - 9961
Graphics Test 1 - 132.42 fps
Graphics Test 2 - 114.84 fps
Physics Test - 64.46 fps
Combined Test - 46.33 fps
Fire Strike Extreme
https://www.3dmark.com/fs/19935374
3DMark Score - 12365
Graphics Score - 13463
Physics Score - 20290
Combined Score - 5627
Graphics Test 1 - 66.95 fps
Graphics Test 2 - 52.0 fps
Physics Test - 64.41 fps
Combined Test - 26.17 fps
Fire Strike Ultra
https://www.3dmark.com/fs/19935339
3DMark Score - 6493
Graphics Score - 6503
Physics Score - 20316
Combined Score - 3196
Graphics Test 1 - 33.34 fps
Graphics Test 2 - 24.55 fps
Physics Test - 64.5 fps
Combined Test - 14.87 fps
283 |
razor
14.08.2019 03:30:05
R5 1600 @ 4ghz / DDR4 @ 3000 / 1070 @ 2100 / 4300
Tundub, et combined on kuidagi vahepeal korda tehtud
https://www.3dmark.com/fs/20147803
3DMark Score - 17056
Graphics Score - 19764
Physics Score - 18201
Combined Score - 8039
120 |
jKazej
02.09.2019 15:47:32
Proovisin ka üle pika aja jälle, vanaraua kohta ütleks, et täitsa viisakas tulemus.
R7 1700X 4.0GHz 1.35V
2x16GB Micron E-die OC-tud 3466C16
2x 980 Ti(üks G1 Gaming teine on EVGA Hybrid, Hybridil kirjutasin uue BIOSe, et matchiks G1 stock turbo algoritmi)
https://www.3dmark.com/3dm/39077642?
| Kommentaarid: 36 loe/lisa |
ertr2
| Kommentaarid: 67 loe/lisa |
65 |
Reisengof
28.11.2019 07:35:40
Suht häbiväärne tulemus, katsetasin eile kellamist ka. Mida suurem clock seda väiksem tulemus. Kas sellest eraldi Graphics scorest ei loe välja ,et prose piirab kuidagi?
Prose 6700K@ 4 GHz (stock)
1080 ti OC
Skoor:19830
https://www.3dmark.com/3dm/41372072?
_________________ Kui olen OK hinna pakkunud ja vastatakse,et müüdud juba saab koheselt negatiivse. |
| Kommentaarid: 98 loe/lisa |
96 |
Arx07
28.11.2019 09:16:20
| Reisengof, see et overclockimisega prose rohkem piirama hakkab ei kõla loogiliselt. Power limiti ikka keerasid põhja? Temperatuur ei läinud üle 80 kraadi?
Levelxer
28.11.2019 11:40:01
| Steamis 3DMark alla hinnatud 85% muidu.
114 |
Reisengof
28.11.2019 11:59:29
| Arx07 kirjutas: |
| Reisengof, see et overclockimisega prose rohkem piirama hakkab ei kõla loogiliselt. Power limiti ikka keerasid põhja? Temperatuur ei läinud üle 80 kraadi? |
power limit 130% ja fanid huugavad 2800rpm peal. 2063 mhz stabiilne.
96 |
Arx07
28.11.2019 13:21:16
| Reisengof, ja voldid? Mu 1080 oli toorelt kõrge voldiga, mälu järgi muutsin ca 2050mhz @1,05V ja lisaks paremale tulemusele oli ka kaart jahedam.
gaido
Evil
Hull
28.11.2019 19:10:33
Amd Ryzen 7 3700X @ 4,4ghz
Sapphire Radeon RX Vega 64 @ 1700/1150
Score: 22728
202 |
Reisengof
06.12.2019 02:32:06
Enne prose vahetust
kõik stocki tagasi ja
punktiskoor 20 015
Graphics Score29 401
Physics Score12 889
Combined Score7 804
8700K ja kerge oc
23 772
Graphics Score28 224
Physics Score23 921
Combined Score10 448
96 |
anubis
20.12.2019 18:54:30
Ryzen 9 3950x @default https://valid.x86.fr/58cywq
Gainward RTX 2080 SUPER™ Phantom @default https://www.techpowerup.com/gpuz/details/my96d
Fire Strike
https://www.3dmark.com/fs/21284457
3DMark Score - 25891
Graphics Score - 27744
Physics Score - 32303
Combined Score - 14396
Graphics Test 1 - 134.27 fps
Graphics Test 2 - 109.5 fps
Physics Test - 102.55 fps
Combined Test - 66.96 fps
Fire Strike Extreme
https://www.3dmark.com/fs/21284569
3DMark Score - 13464
Graphics Score - 13657
Physics Score - 32326
Combined Score - 6797
Graphics Test 1 - 73.23 fps
Graphics Test 2 - 49.94 fps
Physics Test - 102.62 fps
Combined Test - 31.62 fps
Fire Strike Ultra
https://www.3dmark.com/fs/21284688
3DMark Score - 6979
Graphics Score - 6722
Physics Score - 32527
Combined Score - 3691
Graphics Test 1 - 38.66 fps
Graphics Test 2 - 23.5 fps
Physics Test - 103.26 fps
Combined Test - 17.17 fps
283 |
XeStAiSy
Aeg Maha 2a
26.04.2021 20:11:27
Keegi polnud siia postitanud midagi uuemat
EXTREME
https://www.3dmark.com/3dm/61066701?
A-Circus.
| Kommentaarid: 50 loe/lisa |
48 |
raimzu
| Kommentaarid: 48 loe/lisa |
45 |
