| Kui vana on sinu igapäevaselt enimkasutatav teler? |
| Alla 1 aasta |
11% |
[ 50 ] |
| 1-3 aastat |
31% |
[ 141 ] |
| 4-6 aastat |
25% |
[ 114 ] |
| 7-10 aastat |
18% |
[ 83 ] |
| 11-13 aastat |
7% |
[ 33 ] |
| 14-16 aastat |
3% |
[ 15 ] |
| 17-20 aastat |
0% |
[ 4 ] |
| Üle 20 aasta |
1% |
[ 5 ] |
| hääli kokku : 445 |
anubis
23.08.2018 07:50:47
| Jah. Väiksemaid neil vist polegi plaanis lähemal ajal toota.
283 |
pinkman
23.08.2018 08:35:21
| 65'' QLED-TELER SAMSUNG Q7F Kas kellelgi juba on.Kas tasub osta.
| Kommentaarid: 35 loe/lisa |
28 |
MaxPower
23.08.2018 10:26:35
| von Wu kirjutas: |
| Parem pilt on alati etem kui suur ekraan. Ja kui lisaks 4K materjalile vaatad ka madalama resolutsiooniga saateid, siis on samuti väiksem ekraan parem. |
| Kommentaarid: 12 loe/lisa |
12 |
p3000
23.08.2018 15:26:50
TOKYO (Reuters) - Panasonic Corp said on Thursday it has partnered an affiliate of Japan Display Inc to license out a low-cost organic light-emitting diode (OLED) panel-making process, a possible alternative to the conventional method used by dominant South Korean manufacturers.
The unlisted affiliate, JOLED Inc, is in talks with several global panel producers to license its printing process for OLED panels, where organic color materials are deposited onto glass substrates in a way similar to ink-jet printing. |
link
kas siis TV-d või väikesed telefoniekraanid.. ei saanud aru.
keegi võiks kokkuvõtte teha..
edit
lisan juurde oled-info lehelt uudise
JOLED plans to license its inkjet printing technology to OLED makers. JOLED has been developing its technology in collaboration with Panasonic since its founding in 2015. JOLED's technology was originally developed in Panasonic at around 2006.
Under the new collaboration, Panasonic will handle the design and development of printing equipment, while SCREEN Finetech will manufacture the printing equipment under license to Panasonic Production Engineering, and will sell it and provide maintenance and other services together with JOLED.
Towards the end of 2017, JOLED started commercial production of its 21.6" 4K OLED panels. JOLED's mass production line will be established in Nomi City, Ishikawa Prefecture. The capacity of the new fab will be 20,000 monthly 5.5-Gen (1300x1500 mm) substrates and the plan is to begin mass production in 2020. |
https://www.oled-info.com/joled-panasonic-and-screen-finetech-co-develop-and-sale-oled-printing-equipment
viimati muutis p3000 23.08.2018 17:28:46, muudetud 2 korda |
| Kommentaarid: 15 loe/lisa |
15 |
23.08.2018 17:04:25
IMO räägib kõigist üleüldse.
182 |
kodanik2
| Kommentaarid: 56 loe/lisa |
51 |
24.08.2018 10:07:54
_________________ - londiste
216 |
aR_
Rauno266
24.08.2018 12:04:44
| Ma isiklikult soovitaks Philipsit. Philipsi Ambilight on väga hea feature ja tõenäoliselt oma järgmise OLED-i ostul vaatan ka Philipsi poole just selle pärast.
| Kommentaarid: 45 loe/lisa |
41 |
omang
24.08.2018 12:25:48
Küsin tarkadelt arvamust - hetkel kodus 65" Samsung KS7000 . Väga hea pildiga telekas. AGA kas tasub hakata B7 vastu vahetama?
| Kommentaarid: 23 loe/lisa |
23 |
heretic666
24.08.2018 18:02:13
| omang kirjutas: |
Küsin tarkadelt arvamust - hetkel kodus 65" Samsung KS7000 . Väga hea pildiga telekas. AGA kas tasub hakata B7 vastu vahetama?  |
B7 paneel sama mis selle aasta seeria paneelidel.
7. Seeria puhul B7, selle aasta seeriate puhul C8 kui hammas peale hakkab (kiirem prose).
| Kommentaarid: 73 loe/lisa |
Klooose
24.08.2018 18:05:58
Võib-olla veidi offtopic, aga millega te meediat teleritesse striimite? Juhtmetega lahendused kohe mitte ei sobi. 4K üle WiFi ei jookse ma oletan?
_________________ Ära arva kunagi, et see on täiuslik. |
| Kommentaarid: 10 loe/lisa |
10 |
anubis
24.08.2018 18:08:08
| Gbit juhtmega on alati parim variant.
283 |
24.08.2018 18:17:08
| anubis kirjutas: |
| Gbit juhtmega on alati parim variant. |
Ma ei tea kuidas teistel tootjatel, aga lg ei raatsi gigast kaarti telekasse panna 100Mbps piisab. (87/79 tuli praegu)
Ok, mul vajadust pole, asjad liiguvad üle hdmi juhtme. Aga võiks nagu gigase sisse visata.
7 :: |
360 |
pots4t4j4
24.08.2018 18:51:00
| B7 striimib ka netflixi äpiga kenast üle wifi.
401 |
wirx
24.08.2018 20:14:45
Netflix striimib 4K seetõttu kenasti ära, et Netflixi 4K on mingi 15-20mbit ehk, samal ajal on 1080p bluray plaadil 30-40mbit ja 4K on siis topelt, kui mitte rohkemgi.
| Kommentaarid: 80 loe/lisa |
anubis
24.08.2018 20:53:10
| Netflix 4k UHD on HEVC/h. 265, BluRay on AVC/h.264. Sama pildikvaliteet enamasti 2x..2.5x madalama bitrate juures.
283 |
24.08.2018 21:40:04
| Tomorrow kirjutas: |
Otsin kah uut telekat. 4 aastat vanal Philipsil suri taustvalgus ära ja vahetamine pole mõttekas arvestades kulu ja teleka enda väärtust.
Hinnavahemik 450-550
Ainult Telia TV jaoks
Peaks olema nn crescent jalaga, kuna telekalauale ei mahu selline kus jalad on äärtes.
Üks väga oluline liides on headphone out, et saaks juhtmeta kõrvaklapid ühendada. Kahjuks enamus telekatel on ainult optical out mis eemaldab valikust suure hulga mudeleid. Huvitav kas optical>3,5mm adapter toimiks?
Oluline on ka vaatenurgad.
Ega vaatan, et alla 4K pole mõtet võtta. FHD jms ei anna olulist hinnasäästu enam. Samas HDR pole ka oluline. Kui on siis on boonus. Kui mitte, siis puudust ei tunne. Niikuinii ei hakata sealt HDR sisu vaatama.
Samas eelistaks hinna eest ikka tehnilistelt andmetelt võimalikult head. Ehk siis direct backlight mitte edge ja kui mingi local dimming ka on, siis on pluss. Mõistagi siis ka keskel olev jalg ja headphone out.
Ise olen vaadanud ja võrdlenud ja silma on jäänud LG 49UJ7507 mudel. 43 tolline sama seeria oma on sama hinnaga seega mõttetu ja 55 tolline on ligi 200€ kallim ja hinnapiirist väljas. Nii või naa oleks upgrade praeguse 40 tollise pealt. Ega üle 55 tollist ei saakski panna laua peale suuruse tõttu seega 49 paistab olevat optimaalne. Hind paistab olevat 510+ ehk hinnapiiris.
Lugedes ülevaateid, siis suurem miinus paistab olevat see, et kasutab RGBW mis tähendab, et pole vist päris 4K? Ja et local dimming on aga mitte eriti hea.
Samas enamus LG mudelitel puudub headphone out jällegi.
https://geizhals.eu/lg-electronics-49uj7507-a1723856.html
Oskate midagi paremat soovitada selle hinna eest millel sobiv jalg ja liides? |
Taneli rõõmuks panen siis HV lingi mudelile mille lõpuks võtsin: UJ7507 (2017 mudel) paistab, et oli igalt poolt otsa lõppenud.
Seega pidin võtma UK6470 (2018 mudel): https://www.hinnavaatlus.ee/1176470/lg-49-49uk6470/
https://www.lg.com/uk/tvs/lg-49UK6470PLC
Pildiga võib rahule jääda 474€ eest. Muidugi pimedas pole IPS teab mis vapustav aga vähemalt on ühtlane ja pole mingit bleedi või cloudingut. Upgrade 40" 1080p Philipsi pealt on siiski märgatav.
Kahju, et eesti telekanalid niii kehva kvaliteediga on. Vaatasin huvipärast Youtube äppist üle 5Ghz Wi-Fi mõningaid 4K HDR videoid mis nägid ikka päris head välja. Telekas küll toetab HDR aga võrdlemisi madala kontrasti tõttu pole see teab mis elamus.
Ega smart tv kah teab mis kiire pole aga see jääb osaliselt puldi taha kah. Peab magic remote juurde ostma vist. Samas kuna 99% ajast Telia digiboksi taga siis pole vahet. Selleks ajaks kui telekanalid ükskord järgi jõuavad ja 4K HDR sisu hakkavad pakkuma on meil kodudes vist juba 8K OLED mudelid isegi 500€ kandis
Põhiline nurisemiskohat on koostevaliteet. Eriti teleri tagune tundub olevat ikka superõhukesest plastikust mis vetrub päris korralikult kui teatud kohas surve alla panna
| Kommentaarid: 92 loe/lisa |
OPollo
24.08.2018 21:58:21
Põhiline nurisemiskohat on koostevaliteet. Eriti teleri tagune tundub olevat ikka superõhukesest plastikust mis vetrub päris korralikult kui teatud kohas surve alla panna  |
Kui paljusi inimesi sa muidu tead, kes käivad igapäevaselt telekat tagant "surumas" ?
See osa nüüd vast küll kedagi reaalselt morjendada ei tohiks ... ?
| Kommentaarid: 7 loe/lisa |
OPollo
25.08.2018 00:36:08
| OPollo, Normaalne see kah pole. |
Ka see pole normaalne tänapäeval, et telod nii kiiresti purunevad. Vale telekas, vale telo siis soetatud, kui sellised asjad nii kiirelt häirima hakkavad
Minu silmis on see täiesti normaalne, et teleka tagune EI OLE carboniga üle võõbatud ja seeläbi 300 hinnale otsa keevitatud, see on lihtsalt nii teisejärguline paneel selles koosluses, et isiklikult tõesti ei oska isegi selle peale tulla, et vinguda selle teema üle ...
Tegija telku oli, igatsen. Vanamees lajatas teinekord paar kõvemat tutakat ja siis ei virvendand ka enam
25.08.2018 12:36:03
OPollo, sa võiksid vähem mingit suvalist körti toota ja rohkem teemakohast panustada. Kui teleka tagune plastik tundub ERITI õrn, siis sellest ka räägitakse ja on igati okei seda ära märkida.
Tomorrow, kui hull see on... seisva teleka suhtes vast suva, a kolides, jne. oleks muret tekitav või ei paneks ka liigutatava jala külge?
182 |
25.08.2018 14:18:09
| rmc kirjutas: |
Tomorrow, kui hull see on... seisva teleka suhtes vast suva, a kolides, jne. oleks muret tekitav või ei paneks ka liigutatava jala külge? |
No tundus suht üllatav kui õhuke see on. Ma eeldasin, et plastik on aga, et see nii õhuke seal on seda ma ette ei näinud. Ega jumala eest ju kuskil ülevaadetes seda välja ei tooda. Lihtsalt vuristatakse tootja specid ette heal juhul. Asjalikumad kalibreerivad ka ära ja testivad peegeldusi, vaatenurki jms. Paraku enamus teste on high end telekate kohta. Keegi ei viitsi testida alla 500€ mudeleid
Teen mõni päev video sellest, et aimu saaksite. Välja vahetama selle pärast ei hakka, kuna eriti ei liiguta seda ja pildi suhtes etteheited pole. VESA kinnitused on olemas ja seda see mõjutada ei tohiks. Peale vaadates midagi aru ei saa.
