uus teema   See teema on lukus, sa ei saa siin muuta postitusi või vastata teemale! Hinnavaatlus »  Vaba Mikrofon »  Autode teema vol.4 (Küsitlus: Kas suitsetad autos (tavasigaretti)?) märgi kõik teemad loetuks
mine lehele eelmine  1, 2, 3 ... 722, 723, 724 ... 762, 763, 764  järgmine
Ei, ei suitseta üldse
80%
 80%  [ 104 ]
Ei suitseta autos, mujal küll
12%
 12%  [ 16 ]
Jah, suitsukonide jaoks kasutan tuhatoosi
3%
 3%  [ 4 ]
Jah, suitsukonid viskan aknast välja
4%
 4%  [ 6 ]
hääli kokku : 130
Oisu.
sõnum 16.08.2018 09:54:46 vasta tsitaadiga
Ehk on parem, kui teadmata ajalooga vana aku.
https://www.1a.ee/autokaubad/akud_laadijad/autoakud/varta_blue_dynamic_d24
Markos
sõnum 16.08.2018 09:55:17 vasta tsitaadiga
Yes:
On October 13, 2015 Toyota made public details of the Fourth Generation Hybrid Synergy Drive to be introduced in the 2016 model year. The transaxle and traction motor have been redesigned, delivering a reduction in their combined weight. The traction motor itself is considerably more compact and gains a better power-to-weight ratio. Notably there is a 20 percent reduction in mechanical losses due to friction compared to the previous model. The Motor Speed Reduction Device (a second planetary gear set found only in the Third Generation P410 and P510 transaxles), and which connects the traction motor directly to the Power Split Device, and thereafter to the wheels, has been replaced with parallel gears on the Fourth Generation P610 transaxle. The 2012– Prius c retains the P510 transaxle. The P610 transaxle employs helical gears rather than the straight-cut spur gears employed in the earlier transaxles, and which run more smoothly and quietly, while also accommodating higher mechanical loads.
madoc
sõnum 16.08.2018 10:06:47 vasta tsitaadiga
Markos kirjutas:
Yes:
Sinu jutt käib ju Toyota kohta (prius).
"Powered by second-generation Lexus Hybrid Drive, the IS 300h" - http://www.toyota-centar.hr/downloads/lexus/IS/IS_katalog_eng.pdf
Kommentaarid: 35 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 34
sõnum 16.08.2018 10:13:30 vasta tsitaadiga
Haa, oleksid pidanud priuse ostma
Markos
sõnum 16.08.2018 10:19:54 vasta tsitaadiga
madoc kirjutas:
Markos kirjutas:
Yes:
See pole ju sama auto, vaid eelmine. Hübriidajam, vedrustus jms on kõik uus.
sõnum 16.08.2018 10:36:46 vasta tsitaadiga
Markos kirjutas:
madoc kirjutas:
hkurujo88r kirjutas:
Mis masin see "meeste riist" on?
See oli laenatud "550hj XKR-S" cabrio, aga hiljem selgus, et ikkagi 420hj XKR
Korjasin foorumiannaalidest info üles ja sain sellise tabeli:
Tuleb välja, et is250 on hakanud vaikselt enam tarbima vanuse kasvades ja is300h proovitud numbrid vähenema...
Lahe tabel! (no on viitsimist). Kuupäevadest lähtuvalt võiks öelda, et numbrite taga on erinevad tingimused, teekond põhiliselt. Miks kütsi kulu viimastel aastatel linnas järsult tõusis, on ilmselt seetõttu, et jätsin "suitsetamise maha", ehk siis ei viitsinud enam mootorit soojendada, nagu varemalt, vaid panin külmaga minema. 2015 is300h tulemused on võetud väga lühiajalise perioodi (üks nädalavahetus) pealt, mitte nagu nüüd terve paak kolme nädala jooksul + tegemist oli ikkagi ka teise autoga, ehk siis eelmine is, eelmise põlve hübriidajamiga. Mis tants selle 12 ümber käib, see on ju linna/maantee keskmine. Ainult linna pole mul praegust võimalik 300h puhul öelda, sest ei ole tervet paaki linnas maha sõitnud. Ma omateada olen ka koguaeg väitnud, et is250 on maanteel suhteliselt ökonoomne, aga linnas lühikeste otse peal ikka paras bensuröövel, st vahe on 2x+ ja kunagi sai vist ka välja öeldud, et lisades hübriidi, tuleb linnakulu maanteega samale tasemele. Vaatlustulemused seda nüüd ka kinnitavad. Mis nendesse tehasenäitajatesse puutub, siis 4,5 ei ole võimalik saada keskmiseks.
Et siis seisvalt töötav auto sul kütusekulu keskmist ei tõsta?
Pätu
Pätu
sõnum 16.08.2018 10:41:47 vasta tsitaadiga
Milleks üldse mootorit soojendada kohapeal? Manuaalis on ka ju kirjas, et kohapeal mootorit ei ole mõtet soojendada.
Oisu.
sõnum 16.08.2018 10:41:56 vasta tsitaadiga
Lubatust võtab pea liitri jagu rohkem icon_evil.gif Tabeli pidajate seas siiski 7 % ökomate seas icon_razz.gif Järeldus: tehaseandmed täielik BS icon_evil.gif
sõnum 16.08.2018 10:50:45 vasta tsitaadiga
Pätu kirjutas:
Markos
sõnum 16.08.2018 11:13:14 vasta tsitaadiga
Nagu näha, on mõtet. Kulu tõusis mitu liitrit kohe. Varemalt lasin ikka nii 5 min kohapeal tiksuda, eriti talvel. Et siis nagu selgub juuresolevalt pildilt ja kogu sellest sae- undamisest on väga suured erinevused selles, kuidas ja kus autot kasutatakse.
madoc
sõnum 16.08.2018 11:13:43 vasta tsitaadiga
Markos kirjutas:
Fine, prefacelift oli siis gen2 süsteem. Kust infot leiab muutuste kohta? Vb ma olen oskamatu, aga ei leia üles.
Ainuke info 4. gen süsteemide kohta käib UX ja ES 2019a mudelite kohta.
"is 300h "fourth generation Hybrid Drive System" -es -ux" otsing googlis ei anna midagi.
GS 300h on ka 2. gen süsteemi peal.
viimati muutis madoc 16.08.2018 11:23:45, muudetud 2 korda
Max Powers
sõnum 16.08.2018 11:18:07 vasta tsitaadiga
http://forte.delfi.ee/news/auto/fotod-lexus-tutvustas-tallinnas-oma-tutikat-iselaadivat-hubriidmaasturit?id=83368063
Kas Markos on juba seees istunud?
sõnum 16.08.2018 11:33:21 vasta tsitaadiga
Mis elukas see iselaadiv on?
Mehe sõnul on iselaadiv hübriid pistikhübriidi kõrval hea variant, kuna ei nõua inimestelt käitumisharjumuste muutmist
Siit nagu ei saa midagi selgeks
Look Right
Anna vin
Look Right
sõnum 16.08.2018 11:52:16 vasta tsitaadiga
jeesus188 kirjutas:
Bensumootorilt ja pidurdamise ajal laeb akusid. Stepslit autol pole.
rtfm99
sõnum 16.08.2018 11:53:18 vasta tsitaadiga
Pätu kirjutas:
ma hingan suurema külmaga esiklaasi kohe läbipaistmatuks kui ei soojenda.
KillFrenzy
KillFrenzy
sõnum 16.08.2018 11:55:40 vasta tsitaadiga
Allrait kirjutas:
jeesus188 kirjutas:
See on varem ka siit läbi käinud, ehk täiesti tavaline hübriid. Lihtsalt marketingi kavalpead üritavad tehnikavõõrastele inimestele mingi udu ajada.
pppd
sõnum 16.08.2018 11:57:41 vasta tsitaadiga
ja mille poolest erineb see uus "iselaadiv" sellest vanast tavalisest hübriidist, millel ka pistikut polnud? Või on ehk tegu sellise arenguga, mille tulemusel võime me varsti oodata uut ja innovatiivset "akuvaba hübriidi", mille puhul on mootori konstruktsiooni oluliselt lihtsustatud ning kogu töö tehakse ära vedelkütuse poolt? icon_smile.gif
oliver.
sõnum 16.08.2018 12:09:37 vasta tsitaadiga
Ehk on see marketingitermin tingitud reaalsest vajadusest - kui ütled, et ostsid hübriidi, siis tihtilugu päritakse, kuidas laadimine käib. Äkki nii jõuab autovõõrale inimesele paremini pärale, et on "iselaadiv".
sõnum 16.08.2018 13:05:16 vasta tsitaadiga
Huvitav roikaprobleem või Ma ei tea mis.
Kui kiirendafa ja turbo rõhk üleval siis tekib selline heli nagu sees salongivent puhuls esiklaasile. Niisama sõites pole miskit. Just siis kui turbo rõhk üleval...
Mis otsi andmas on?
Max Powers
sõnum 16.08.2018 13:06:32 vasta tsitaadiga
Kumba soovitate - uus Kia ceed või Skoda Octavia. Asking for a friend
KillFrenzy
KillFrenzy
sõnum 16.08.2018 13:13:08 vasta tsitaadiga
Nägin eile octaviat, välja näeb nagu sedaan, aga tegelikult vist luukpära vms. ehk ilmselt tõuseb tagaklaas ka üles ja taga on kojamees. Kui okse see kojamees välja näeb seal.
Renka
Renka
sõnum 16.08.2018 13:15:36 vasta tsitaadiga
hkurujo88r
sõnum 16.08.2018 13:17:07 vasta tsitaadiga
Ceed, saab pikema garantii. Uus täitsa kobe ka.
Viimaselajal tuttavatel skoda/volks/audiga probleeme palju, just suht uute sõidukitega. Garantiis tihedalt käima.
Kommentaarid: 126 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 120
sõnum 16.08.2018 13:19:31 vasta tsitaadiga
ceed on odavam.
- londiste
Oliverk
sõnum 16.08.2018 13:26:59 vasta tsitaadiga
Kuuldavasti pidi antud austatud foorumlane 1.0 liitrist mootorit vaatama. Seetõttu ka ei julge ise siit küsida.
Skodaga pidi LED tuled saama. Kial vaeste halogeenid.
viimati muutis Oliverk 16.08.2018 13:27:47, muudetud 1 kord
Tjena
sõnum 16.08.2018 13:27:11 vasta tsitaadiga
Tagumine kojamees on lisavarustus Octavial, niiet paljud on ilma selleta
Kommentaarid: 26 loe/lisa Kasutajad arvavad:  :: 0 :: 0 :: 24
hkurujo88r
sõnum 16.08.2018 13:31:52 vasta tsitaadiga
Oliverk kirjutas:
Pätsidele saad halogeenid vb. Muidu led tuled ikka.
Oliverk
sõnum 16.08.2018 13:32:49 vasta tsitaadiga
Oliverk kirjutas:
Vahib mingeid odavaid laopanne. Kui Lede tahad Kiale peab tehasest tellima ja lööb rahakoti uppi.
rocky-b
rocky-b
sõnum 16.08.2018 13:34:08 vasta tsitaadiga
g30 viiene bemm ikka võtta
sõnum 16.08.2018 13:37:12 vasta tsitaadiga
Oliverk kirjutas:
Oliverk kirjutas:
400 või 500€ mis need led tuled maksid lööb rahakoti uppi?
Skoda näeb rõve ja on julm kallis kui mingit varustust tahad.
Kia kõrval võib hyundai i30 ka vaadata. Jagavad vist samu mootoreid ja värki.
hkurujo88r
sõnum 16.08.2018 13:40:06 vasta tsitaadiga
http://www.auto24.ee/used/2861998
http://www.auto24.ee/used/2837173
No skoda veits suurem. Aga ei mõista miks see esi ots nii okse oli vaja teha...
sõnum 16.08.2018 13:48:50 vasta tsitaadiga
https://www.kia.ee/models/show/Kia-CEEd-SW/pricelist.pdf
https://az749841.vo.msecnd.net/sitesetee/alv1/d3bc1e61-c7cf-4e9d-b5c5-34244a203df1/Octavia2018_A4_est.b659a7ea0fdec1a459eb987423bdcc02.pdf
skoda kallimatest mudelitest annab rohkem alla kaubelda, aga mitte palju.
- londiste
Max Powers
sõnum 16.08.2018 13:51:44 vasta tsitaadiga
see on vana ceed.
rtfm99
sõnum 16.08.2018 14:07:24 vasta tsitaadiga
mis sellel esiotsal viga on?
rocky-b
rocky-b
sõnum 16.08.2018 14:25:12 vasta tsitaadiga
Kunagi piltidel oli jube jah, aga reaalses elus nagu kriibi. Vähemalt pole tajunud seda, kui vastu sõidab mõni.
sõnum 16.08.2018 14:37:49 vasta tsitaadiga
Enamus foorumipässe autosid pildilt ainult vahibki
Oisu.
sõnum 16.08.2018 14:42:03 vasta tsitaadiga
Ma lihtne päss, ikka ostan ka.
One
sõnum 16.08.2018 14:46:46 vasta tsitaadiga
Sold OUT kirjutas:
Räägib päss kellel autot pole ning toiduks on põrandale asetatud muna majoneesiga thumbs_up.gif icon_lol.gif
rocky-b
rocky-b
sõnum 16.08.2018 14:51:00 vasta tsitaadiga
Leib ka
sõnum 16.08.2018 15:00:05 vasta tsitaadiga
Ei tahtnud panni määrida
toooomas
sõnum 16.08.2018 15:02:27 vasta tsitaadiga
salatoimik kirjutas:
Kui kiirendafa ja turbo rõhk üleval siis tekib selline heli nagu sees salongivent puhuks esiklaasile. Niisama sõites pole miskit. Just siis kui turbo rõhk üleval...
Mis otsi andmas on?
Intercooleri lõdvik pragunenud võib olla. Siis suurema rõhuga puhub sealt õhku välja.
sõnum 16.08.2018 16:47:14 vasta tsitaadiga
toooomas kirjutas:
Mis otsi andmas on?
see oli kunagi ammu puru ja mingit häält ei teinud või vähemalt sisse ei kostnud. Nüüd aga kõrvalistuja poolt tuleb nagu uhaks esiaknale seest õhku...
One
sõnum 16.08.2018 16:49:24 vasta tsitaadiga
Autol mootor(diisel) kahtlaselt klobisema hakanud.. Kohe jooksuga remonti või tasuks mingit kütuselisandit proovida?
Tjena
sõnum 16.08.2018 17:02:18 vasta tsitaadiga
Ma soovitan siin “spetsialistide” jagalemist lugeda nii kaua kuniks äkki läheb ise korda. Või siis ei lähe
One
sõnum 16.08.2018 17:04:53 vasta tsitaadiga
rocky-b
rocky-b
sõnum 16.08.2018 17:06:30 vasta tsitaadiga
Muidugi mõista
sõnum 16.08.2018 17:57:50 vasta tsitaadiga
Mis otsi andmas on?
Turbo lõdvikud ja intercooler käi üle. Vaakumid ka.
prtv
sõnum 16.08.2018 18:03:16 vasta tsitaadiga
pane uued eelsüüteküünlad, 120€ tükk
iir
iir
sõnum 16.08.2018 18:19:27 vasta tsitaadiga
prtv kirjutas:
WUT
sõnum 16.08.2018 18:22:41 vasta tsitaadiga
Lexus vast, kullatud küünlad
uus teema   See teema on lukus, sa ei saa siin muuta postitusi või vastata teemale! Hinnavaatlus »  Vaba Mikrofon »  Autode teema vol.4 (Küsitlus: Kas suitsetad autos (tavasigaretti)?) mine lehele eelmine  1, 2, 3 ... 722, 723, 724 ... 762, 763, 764  järgmine
