| Küsitlus: Kas suitsetad autos (tavasigaretti)? |
| Ei, ei suitseta üldse |
80% |
[ 104 ] |
| Ei suitseta autos, mujal küll |
12% |
[ 16 ] |
| Jah, suitsukonide jaoks kasutan tuhatoosi |
3% |
[ 4 ] |
| Jah, suitsukonid viskan aknast välja |
4% |
[ 6 ] |
| hääli kokku : 130 |
Oisu.
Markos
16.08.2018 08:55:17
Yes:
| On October 13, 2015 Toyota made public details of the Fourth Generation Hybrid Synergy Drive to be introduced in the 2016 model year. The transaxle and traction motor have been redesigned, delivering a reduction in their combined weight. The traction motor itself is considerably more compact and gains a better power-to-weight ratio. Notably there is a 20 percent reduction in mechanical losses due to friction compared to the previous model. The Motor Speed Reduction Device (a second planetary gear set found only in the Third Generation P410 and P510 transaxles), and which connects the traction motor directly to the Power Split Device, and thereafter to the wheels, has been replaced with parallel gears on the Fourth Generation P610 transaxle. The 2012– Prius c retains the P510 transaxle. The P610 transaxle employs helical gears rather than the straight-cut spur gears employed in the earlier transaxles, and which run more smoothly and quietly, while also accommodating higher mechanical loads. |
| Kommentaarid: 14 loe/lisa |
12 |
madoc
16.08.2018 09:06:47
| Markos kirjutas: |
Yes:
Sinu jutt käib ju Toyota kohta (prius).
"Powered by second-generation Lexus Hybrid Drive, the IS 300h" - http://www.toyota-centar.hr/downloads/lexus/IS/IS_katalog_eng.pdf
| Kommentaarid: 35 loe/lisa |
34 |
16.08.2018 09:13:30
Haa, oleksid pidanud priuse ostma
| Kommentaarid: 95 loe/lisa |
Markos
16.08.2018 09:19:54
| madoc kirjutas: |
| Markos kirjutas: |
Yes:
"Powered by second-generation Lexus Hybrid Drive, the IS 300h" - http://www.toyota-centar.hr/downloads/lexus/IS/IS_katalog_eng.pdf |
See pole ju sama auto, vaid eelmine. Hübriidajam, vedrustus jms on kõik uus.
12 |
16.08.2018 09:36:46
| Markos kirjutas: |
| madoc kirjutas: |
| hkurujo88r kirjutas: |
| Mis masin see "meeste riist" on? |
See oli laenatud "550hj XKR-S" cabrio, aga hiljem selgus, et ikkagi 420hj XKR
Korjasin foorumiannaalidest info üles ja sain sellise tabeli:
Tuleb välja, et is250 on hakanud vaikselt enam tarbima vanuse kasvades ja is300h proovitud numbrid vähenema... |
Lahe tabel! (no on viitsimist). Kuupäevadest lähtuvalt võiks öelda, et numbrite taga on erinevad tingimused, teekond põhiliselt. Miks kütsi kulu viimastel aastatel linnas järsult tõusis, on ilmselt seetõttu, et jätsin "suitsetamise maha", ehk siis ei viitsinud enam mootorit soojendada, nagu varemalt, vaid panin külmaga minema. 2015 is300h tulemused on võetud väga lühiajalise perioodi (üks nädalavahetus) pealt, mitte nagu nüüd terve paak kolme nädala jooksul + tegemist oli ikkagi ka teise autoga, ehk siis eelmine is, eelmise põlve hübriidajamiga. Mis tants selle 12 ümber käib, see on ju linna/maantee keskmine. Ainult linna pole mul praegust võimalik 300h puhul öelda, sest ei ole tervet paaki linnas maha sõitnud. Ma omateada olen ka koguaeg väitnud, et is250 on maanteel suhteliselt ökonoomne, aga linnas lühikeste otse peal ikka paras bensuröövel, st vahe on 2x+ ja kunagi sai vist ka välja öeldud, et lisades hübriidi, tuleb linnakulu maanteega samale tasemele. Vaatlustulemused seda nüüd ka kinnitavad. Mis nendesse tehasenäitajatesse puutub, siis 4,5 ei ole võimalik saada keskmiseks. |
Et siis seisvalt töötav auto sul kütusekulu keskmist ei tõsta?
| Kommentaarid: 85 loe/lisa |
Pätu
16.08.2018 09:41:47
| Milleks üldse mootorit soojendada kohapeal? Manuaalis on ka ju kirjas, et kohapeal mootorit ei ole mõtet soojendada.
89 |
Oisu.
16.08.2018 09:41:56
Lubatust võtab pea liitri jagu rohkem Tabeli pidajate seas siiski 7 % ökomate seas Järeldus: tehaseandmed täielik BS
16.08.2018 09:50:45
| Pätu kirjutas: |
| Milleks üldse mootorit soojendada kohapeal? Manuaalis on ka ju kirjas, et kohapeal mootorit ei ole mõtet soojendada. |
Äkkii lihtsalt normaalsed inimesed ei suitseta autos?
196 |
Markos
16.08.2018 10:13:14
Nagu näha, on mõtet. Kulu tõusis mitu liitrit kohe. Varemalt lasin ikka nii 5 min kohapeal tiksuda, eriti talvel. Et siis nagu selgub juuresolevalt pildilt ja kogu sellest sae- undamisest on väga suured erinevused selles, kuidas ja kus autot kasutatakse.
12 |
madoc
16.08.2018 10:13:43
| Markos kirjutas: |
| See pole ju sama auto, vaid eelmine. Hübriidajam, vedrustus jms on kõik uus. |
Fine, prefacelift oli siis gen2 süsteem. Kust infot leiab muutuste kohta? Vb ma olen oskamatu, aga ei leia üles.
Ainuke info 4. gen süsteemide kohta käib UX ja ES 2019a mudelite kohta.
"is 300h "fourth generation Hybrid Drive System" -es -ux" otsing googlis ei anna midagi.
GS 300h on ka 2. gen süsteemi peal.
viimati muutis madoc 16.08.2018 10:23:45, muudetud 2 korda |
34 |
Max Powers
182 |
16.08.2018 10:33:21
Mis elukas see iselaadiv on?
Kas hetke omadele peab käsitsi elektrit juurde pumpama?
| Mehe sõnul on iselaadiv hübriid pistikhübriidi kõrval hea variant, kuna ei nõua inimestelt käitumisharjumuste muutmist |
Siit nagu ei saa midagi selgeks
Look Right
Anna vin
16.08.2018 10:52:16
| jeesus188 kirjutas: |
Siit nagu ei saa midagi selgeks |
Bensumootorilt ja pidurdamise ajal laeb akusid. Stepslit autol pole.
_________________ Ehitusprojektid ja konstruktiivsed lahendused HV kasutajatele soodsamalt
M: Zafira A/Astra G põhjakaitse - 30€ |
| Kommentaarid: 19 loe/lisa |
18 |
rtfm99
16.08.2018 10:53:18
| Pätu kirjutas: |
ma hingan suurema külmaga esiklaasi kohe läbipaistmatuks kui ei soojenda.
_________________ |
KillFrenzy
16.08.2018 10:55:40
| Allrait kirjutas: |
Bensumootorilt ja pidurdamise ajal laeb akusid. Stepslit autol pole. |
See on varem ka siit läbi käinud, ehk täiesti tavaline hübriid. Lihtsalt marketingi kavalpead üritavad tehnikavõõrastele inimestele mingi udu ajada.
134 |
pppd
16.08.2018 10:57:41
ja mille poolest erineb see uus "iselaadiv" sellest vanast tavalisest hübriidist, millel ka pistikut polnud? Või on ehk tegu sellise arenguga, mille tulemusel võime me varsti oodata uut ja innovatiivset "akuvaba hübriidi", mille puhul on mootori konstruktsiooni oluliselt lihtsustatud ning kogu töö tehakse ära vedelkütuse poolt?
oliver.
16.08.2018 11:09:37
| Ehk on see marketingitermin tingitud reaalsest vajadusest - kui ütled, et ostsid hübriidi, siis tihtilugu päritakse, kuidas laadimine käib. Äkki nii jõuab autovõõrale inimesele paremini pärale, et on "iselaadiv".
| Kommentaarid: 280 loe/lisa |
239 |
16.08.2018 12:05:16
Huvitav roikaprobleem või Ma ei tea mis.
Kui kiirendafa ja turbo rõhk üleval siis tekib selline heli nagu sees salongivent puhuls esiklaasile. Niisama sõites pole miskit. Just siis kui turbo rõhk üleval...
Isegi kui kliima bälja lülitada
Mis otsi andmas on?
| Kommentaarid: 39 loe/lisa |
Max Powers
16.08.2018 12:06:32
| Kumba soovitate - uus Kia ceed või Skoda Octavia. Asking for a friend
182 |
KillFrenzy
16.08.2018 12:13:08
Nägin eile octaviat, välja näeb nagu sedaan, aga tegelikult vist luukpära vms. ehk ilmselt tõuseb tagaklaas ka üles ja taga on kojamees. Kui okse see kojamees välja näeb seal.
134 |
Renka
16.08.2018 12:15:36
61 |
hkurujo88r
16.08.2018 12:17:07
Ceed, saab pikema garantii. Uus täitsa kobe ka.
Viimaselajal tuttavatel skoda/volks/audiga probleeme palju, just suht uute sõidukitega. Garantiis tihedalt käima.
120 |
16.08.2018 12:19:31
ceed on odavam.
_________________ - londiste
217 |
Oliverk
16.08.2018 12:26:59
Kuuldavasti pidi antud austatud foorumlane 1.0 liitrist mootorit vaatama. Seetõttu ka ei julge ise siit küsida.
Skodaga pidi LED tuled saama. Kial vaeste halogeenid.
viimati muutis Oliverk 16.08.2018 12:27:47, muudetud 1 kord |
| Kommentaarid: 27 loe/lisa |
26 |
Tjena
16.08.2018 12:27:11
| Tagumine kojamees on lisavarustus Octavial, niiet paljud on ilma selleta
| Kommentaarid: 26 loe/lisa |
24 |
hkurujo88r
16.08.2018 12:31:52
| Oliverk kirjutas: |
Skodaga pidi LED tuled saama. Kial vaeste halogeenid. |
Pätsidele saad halogeenid vb. Muidu led tuled ikka.
120 |
Oliverk
16.08.2018 12:32:49
| Oliverk kirjutas: |
Pätsidele saad halogeenid vb. Muidu led tuled ikka. |
Vahib mingeid odavaid laopanne. Kui Lede tahad Kiale peab tehasest tellima ja lööb rahakoti uppi.
26 |
rocky-b
16.08.2018 12:34:08
| g30 viiene bemm ikka võtta
| Kommentaarid: 13 loe/lisa |
16.08.2018 12:37:12
| Oliverk kirjutas: |
| Oliverk kirjutas: |
Vahib mingeid odavaid laopanne. Kui Lede tahad Kiale peab tehasest tellima ja lööb rahakoti uppi. |
400 või 500€ mis need led tuled maksid lööb rahakoti uppi?
Skoda näeb rõve ja on julm kallis kui mingit varustust tahad.
Kia kõrval võib hyundai i30 ka vaadata. Jagavad vist samu mootoreid ja värki.
hkurujo88r
120 |
217 |
Max Powers
16.08.2018 12:51:44
| see on vana ceed.
182 |
rtfm99
16.08.2018 13:07:24
mis sellel esiotsal viga on?
_________________ |
rocky-b
16.08.2018 13:25:12
| Kunagi piltidel oli jube jah, aga reaalses elus nagu kriibi. Vähemalt pole tajunud seda, kui vastu sõidab mõni.
16.08.2018 13:37:49
Enamus foorumipässe autosid pildilt ainult vahibki
Oisu.
16.08.2018 13:42:03
| Ma lihtne päss, ikka ostan ka.
One
16.08.2018 13:46:46
| Sold OUT kirjutas: |
| Enamus foorumipässe autosid pildilt ainult vahibki |
Räägib päss kellel autot pole ning toiduks on põrandale asetatud muna majoneesiga
728 |
rocky-b
16.08.2018 13:51:00
| Leib ka
16.08.2018 14:00:05
Ei tahtnud panni määrida
toooomas
16.08.2018 14:02:27
| salatoimik kirjutas: |
Kui kiirendafa ja turbo rõhk üleval siis tekib selline heli nagu sees salongivent puhuks esiklaasile. Niisama sõites pole miskit. Just siis kui turbo rõhk üleval...
Isegi kui kliima välja lülitada
Mis otsi andmas on? |
Intercooleri lõdvik pragunenud võib olla. Siis suurema rõhuga puhub sealt õhku välja.
| Kommentaarid: 16 loe/lisa |
16 |
16.08.2018 15:47:14
| toooomas kirjutas: |
Intercooleri lõdvik pragunenud võib olla. Siis suurema rõhuga puhub sealt õhku välja. |
see oli kunagi ammu puru ja mingit häält ei teinud või vähemalt sisse ei kostnud. Nüüd aga kõrvalistuja poolt tuleb nagu uhaks esiaknale seest õhku...
One
16.08.2018 15:49:24
| Autol mootor(diisel) kahtlaselt klobisema hakanud.. Kohe jooksuga remonti või tasuks mingit kütuselisandit proovida?
728 |
Tjena
16.08.2018 16:02:18
| Ma soovitan siin “spetsialistide” jagalemist lugeda nii kaua kuniks äkki läheb ise korda. Või siis ei lähe
24 |
One
16.08.2018 16:04:53
Eks siis tuleb pressialla viia
728 |
rocky-b
16.08.2018 16:06:30
| Muidugi mõista
16.08.2018 16:57:50
Turbo lõdvikud ja intercooler käi üle. Vaakumid ka.
725 |
prtv
16.08.2018 17:03:16
pane uued eelsüüteküünlad, 120€ tükk
_________________ |
| Kommentaarid: 82 loe/lisa |
73 |
iir
16.08.2018 17:19:27
| prtv kirjutas: |
| pane uued eelsüüteküünlad, 120€ tükk |
WUT
Mis autol
| Kommentaarid: 90 loe/lisa |
16.08.2018 17:22:41
Lexus vast, kullatud küünlad
