As you know, the last few months have been a difficult time for the cryptocurrency market, which has also affected the operation of our service.
We have made every possible effort in order to resolve the problem that has arisen – for instance, we have considered a variety of technical solutions, which would have allowed us to lower expenses related to maintenance and electricity. However, due to the general instability of the market, the actions we have taken could not significantly influence the current situation.
For over a month our users encountered a situation when the payouts were lower than the maintenance fees, resulting in zero accruals to the balance. As of 18.07.2018, the payouts were lower than maintenance for 28 consecutive days.
BTC mining continues being unprofitable, in light of which we would like to inform you that on 18.07.2018 we were forced to start disabling SHA hardware and today, on 20.07.2018, stop the mining service of active SHA-256 contracts in accordance with clause 5.5 of our Terms of Service, which are required to be accepted when creating a purchase and are the basis of concluding the contract.
We expect that the cryptocurrency market situation will stabilize in the nearest future and we will be able to offer our users new advantageous solutions.
We will continue to inform you about any changes. Stay tuned for updates!
Keegi teab, kui Hashflare nüüd lepingud lõpetab, siis ka selle raha mis seal niisama tiksub saab ikka välja kanda, kui BC on alla väljavõtmise limiiti?
Mul tekkis sama küsimus ... _________________ * CyberTiger *
Huvitav muster on viimasel nädalal joonistunud. Kui tavapäraselt BTC tõus-langus jooksevad kõik altcoinid samas rütmis kaasa, siis nüüd on vaid kuningas isiklikult teinud väga kena 7p graafiku, kui teised koinid aga on hoopis langenud... mhh?
Aga see muster sarnaneb väga eelmise aasta suve teise poolega, kus oli täpselt sama seis, et BTC tõusis, aga teised koinid ei teinud väga välja sellest.
DVDRW, eelmise postituse jätkuks nii palju, et kui toona suve lõpp altid ei olnud koostööaltid BTC'ga, siis detsembri lõpp, kui kuningas alla käima hakkas, siis just altid olid need kes veel nädalaid tõusid ja tõusid. Elame näeme. So far so good.
BTC turuosa kasvab ning altcoinid kannatavad, super aeg altcoine osta.
Suurel määral mõjutab btc hinnakõikumist Bitmex, tüübid paugutavad 50x võimendusega. 24h volume bitmexis 6 miljardit.. ei oskagi midagi arvata sellest, mõni proovinud ka võimendusega õhu kauplemist?
Kas oleks kellelgi huvi krüptokaevanduse või misiganes rohke elektrivajadusega kola majutusteenuse vastu?
On üks hoonetekompleks kus on suht jõude seisvad eraldi peakaitsmed 63A, 63A, 63A, 180A, 250A (korda kolm faasi per peakaitse, toitev alajaam on hetkel kahe 400A trahvoga).
Mis võiks olla nõuded jahutuse, tuleohutuse, valve, ligipääsetavuse osas?
Kõik sõltub suures osas sellest, milliseks elektri hind kokku kujuneb? Kas oskad konkreetse numbri öelda?
https://maailm.postimees.ee/5913348/venezuelas-seotakse-rahareformi-kaigus-valuuta-kruptorahaga
"Venezuela president Nicolás Maduro teatas Venezuela riigitelevisiooni otseeetris, et 20. augustist denomineeritakse Venezuela valuuta bolivar ja see seotakse krüptoraha petroga."
"Uutel rahatähtedel on viis nulli vähem. Presidendi sõnul võimaldab uue vääringu krüptorahaga sidumine põhjalikult muuta riigi rahanduse olukorda." _________________
"Paar nädalat tagasi Saaremaal toimunud muusikafestival I Land Sound oli maailmas üks esimesi festivale, kus külastajad said jookide ja söökide eest tasuda krüptorahal põhineva maksevahendiga.
Festivali külastajatele jagati välja ligi tuhat käepaela, mis olid varustatud NFC-kiibiga, millele sai virtuaalset raha peale kanda. Rahana oli kasutusel Dash krüptovaluuta, mille loojate sõnul olid käepaela lahendusest huvitatud I Land Soundi korraldajad."
https://geenius.ee/uudis/saaremaa-muusikafestivalil-kasutati-kruptorahal-pohinevat-maksevahendit/ _________________
Ei töötand väga see lahendus seal. Reede (teine päev) igatahes ei töötand ja kaardimakse terminalid olid otsitud välja, laupäeval aga oli inimesi juba kes maksid sellega.
Algselt küll reklaamiti et maksmine toimub vaid sellega aga läks veidike teisiti. _________________ Lae pildid -> pilt.io
Kui ma tulen mingile üritusele või satun välismaal kohta kus saan krüptos maksta siis ei saa olla sellist asja, et vaid mingit ühte raha küsitakse. Kasutama peab mingit ühist walletit, mis ülemaailmselt heakskiidu saaks (Ethos, Bread vms) ja siis kui vaja maksta peavad seal walletis KÕIK valuutad olema võimelikud arve eest tasuma ja ka offlines, st kui pole sul internetti sest enamik juhtudel sul seda telefonis välismaal pole ja mingisse suva wifisse ka enda telefoniga sisse logima ei hakka ju.. kui just mingid eriti väikesed summad peal pole.. mida ilmselt teha tuleb samas tulevikus, et kui tahad krüptot telefonis hoida siis väikesed summad lihtsalt söögi maksmise eest vms.
Siin võibolla tulevad appi erinevad krüpto kaardid ala nagu Spatium vms _________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel
Siis läheb raskeks, kuna kodukasutajal on tubli kolmandik odavam elekter..
Kes seal võrguteenust pakub ja mis paketiga?
AFAIK Elektrilevi on, paketti ei tea aga nüüd uurisin neid hinnakirju ja eks need paketid tuleks siis vastavalt tarbimisele valida, enne panin numbrid Võrk2 ja EE marginaali järgi.
63A puhul Elektrilevi Võrk4 + Alexela Blue Plus annaks võitu alles ~2-3 kWh 24*7 tarbimise juures. 10 kWh 24*7 oleks €0,106 kWh kuu keskmine umbkaudu. Aga üks 63A võimaldaks 40+ kWh 24*7.
Just nii. Kodus näiteks kasutad kuus 15MW jagu energiat ja ongi hind seal 8-9 sendi vahepeal kenasti.
[..]OKEx positions can notably be leveraged by as much as 20 times under current rules. Instead, it operates using a so-called “socialized claw-back” policy for cases where a trade shortfall is incurred.
The “claw-back” means that the losses from the unfilled order will need to be covered by counterpart traders. In this instance, those with unrealized gains on their short positions this week are set to lose 18 percent of their profits to foot the bill, as Bloomberg notes.
Kui nende legal osakonnal abi on vaja, siis nt Olympicu t&c ütleb järgmist:
"4.4.2. Mänguautomaadi funktsionaalse häire, elektroonilise või mehhaanilise rikke või mänguautomaadi manipuleerimise tagajärjel mänguautomaadi ekraanile ilmuv informatsioon ei ole mängu võit ja väljamaksmisele ei kuulu."
Tegemist on "metsiku läänega", regulatsioonid puuduvad, nad võivad igasuguseid asju kirjutada oma tingimustesse ja kasutaja peab lihtsalt leppima (kui ta tingimustega nõustunud on).
Mis mõttes internetti ei ole? Ma käin 10x vähemalt igast riikides aastas ja alati nett olemas
Huvitav, mis selle viimase "verelaskmise" põhjused täpsemalt on? See, et SEC lükkas Bitcoini kohta otsuse andmise septembrisse? Kuskilt lugesin, et neil on lausa võimalik kuni järgmise aasta a la esimese kvartali lõpuni aega selle vastuse andmisega. _________________ Live long and prosper!
Hind käib üles/alla ja koguaeg on mingi uudis siin ja seal, inimestel on loomulik instinkt need kokku panna, et mingi muster leida aga minu teooria on, et tegelikult pole neil teineteisega eriti midagi pistmist. Kui zuumida natuke välja siis ilmneb, et aasta alguse krahh ikka veel kestab ja liigub täpselt sama moodi nagu 2 eelmist krüpto krahhi või nagu .com mulli krahh või üleüldiselt nagu üks korralik krahh peaks käima. Lainetamine saab arvatavasti see aasta otsa, millal järgmine mull tuleb ei oska öelda aga kunagi ikka rahu ja kannatust.
Bitcoin on hetkel Türgis kasutust leidmas vara säilitamiseks ajal mil türgi liir on üsna vabalanguses ja välisvaluutasse vahetamine tugevalt piiratud. Sarnast liikumist nähtud ka muudes kriisi käes vaevlevates riikides.
https://www.ccn.com/bitcoin-price-drops-against-turkish-lira-as-treasury-seeks-to-calm-investors/ _________________ Olen jah muusika suhtes elitaarne sitapea
000 WHILE hangover
001 drink beer
rekt = wrecked - purustatud, põhja lastud, hävitatud. Unrekt siis vastupidi - tuhast tõusnud. Neti släng
Aga + punktid nii palju kui seda oli siis püänt oli hea
sa ei või postitada uusi teemasid siia foorumisse sa ei või vastata selle foorumi teemadele sa ei või muuta oma postitusi selles foorumis sa ei või kustutada oma postitusi selles foorumis sa ei või vastata küsitlustele selles foorumis sa ei saa lisada manuseid selles foorumis sa ei või manuseid alla laadida selles foorumis
