DVDRW
19.07.2018 17:23:56
Ei tea, kõigub. Vahepeal näitab alla €
anubis
21.07.2018 10:16:23
https://twitter.com/hashflare/status/1020322805290872834
tsitaat: |
Dear users!
As you know, the last few months have been a difficult time for the cryptocurrency market, which has also affected the operation of our service.
We have made every possible effort in order to resolve the problem that has arisen – for instance, we have considered a variety of technical solutions, which would have allowed us to lower expenses related to maintenance and electricity. However, due to the general instability of the market, the actions we have taken could not significantly influence the current situation.
For over a month our users encountered a situation when the payouts were lower than the maintenance fees, resulting in zero accruals to the balance. As of 18.07.2018, the payouts were lower than maintenance for 28 consecutive days.
BTC mining continues being unprofitable, in light of which we would like to inform you that on 18.07.2018 we were forced to start disabling SHA hardware and today, on 20.07.2018, stop the mining service of active SHA-256 contracts in accordance with clause 5.5 of our Terms of Service, which are required to be accepted when creating a purchase and are the basis of concluding the contract.
We expect that the cryptocurrency market situation will stabilize in the nearest future and we will be able to offer our users new advantageous solutions.
We will continue to inform you about any changes. Stay tuned for updates!
Respectfully,
HashFlare team |
Kaarta
21.07.2018 10:33:12
Twitteris kogutakse rahvast, et HF kohtusse kaevata. Eks näis, mis sest saab.
dohc-48v12
Aeg maha 1p
Sebastian
22.07.2018 11:46:46
Keegi teab, kui Hashflare nüüd lepingud lõpetab, siis ka selle raha mis seal niisama tiksub saab ikka välja kanda, kui BC on alla väljavõtmise limiiti?
cybertiger
22.07.2018 21:32:39
Sebastian kirjutas: |
Keegi teab, kui Hashflare nüüd lepingud lõpetab, siis ka selle raha mis seal niisama tiksub saab ikka välja kanda, kui BC on alla väljavõtmise limiiti? |
Mul tekkis sama küsimus ...
_________________ * CyberTiger * |
Kaarta
22.07.2018 21:55:02
Saatke supporti kiri.
posthuman
23.07.2018 19:55:12
Huvitav muster on viimasel nädalal joonistunud. Kui tavapäraselt BTC tõus-langus jooksevad kõik altcoinid samas rütmis kaasa, siis nüüd on vaid kuningas isiklikult teinud väga kena 7p graafiku, kui teised koinid aga on hoopis langenud... mhh?
Aga see muster sarnaneb väga eelmise aasta suve teise poolega, kus oli täpselt sama seis, et BTC tõusis, aga teised koinid ei teinud väga välja sellest.
DVDRW
23.07.2018 19:59:15
Sest et mul on kõik altcoinides
Mingi jutt, et Lighting network teeb kõik altcoinid obsolete. Ehk kõik lähevad nulli.
posthuman
23.07.2018 21:54:54
DVDRW, eelmise postituse jätkuks nii palju, et kui toona suve lõpp altid ei olnud koostööaltid BTC'ga, siis detsembri lõpp, kui kuningas alla käima hakkas, siis just altid olid need kes veel nädalaid tõusid ja tõusid. Elame näeme. So far so good.
Equinox
masternode
24.07.2018 19:47:47
posthuman kirjutas: |
Aga see muster sarnaneb väga eelmise aasta suve teise poolega, kus oli täpselt sama seis, et BTC tõusis, aga teised koinid ei teinud väga välja sellest. |
BTC turuosa kasvab ning altcoinid kannatavad, super aeg altcoine osta.
Suurel määral mõjutab btc hinnakõikumist Bitmex, tüübid paugutavad 50x võimendusega. 24h volume bitmexis 6 miljardit.. ei oskagi midagi arvata sellest, mõni proovinud ka võimendusega õhu kauplemist?
NB - bitcoin broke downtrend resistance today
posthuman
24.07.2018 22:42:02
kõik kombes, altid jooksid kõik täna kenasti järgi. vähemalt on toimumas üle mitme kuu midagi huvitavat
DVDRW
25.07.2018 01:45:03
Imelik jah, Mitu kuud olid kõik coinid olnud kooris ühel joonel. Nüüd on tõusud/mõõnad kõik läbisegi all over the place.
Tar
26.07.2018 13:04:59
Kas oleks kellelgi huvi krüptokaevanduse või misiganes rohke elektrivajadusega kola majutusteenuse vastu?
On üks hoonetekompleks kus on suht jõude seisvad eraldi peakaitsmed 63A, 63A, 63A, 180A, 250A (korda kolm faasi per peakaitse, toitev alajaam on hetkel kahe 400A trahvoga).
Mis võiks olla nõuded jahutuse, tuleohutuse, valve, ligipääsetavuse osas?
yerba
26.07.2018 13:09:48
Tar kirjutas: |
Mis võiks olla nõuded jahutuse, tuleohutuse, valve, ligipääsetavuse osas? |
Kõik sõltub suures osas sellest, milliseks elektri hind kokku kujuneb? Kas oskad konkreetse numbri öelda?
Tar
27.07.2018 11:20:18
yerba kirjutas: |
Kõik sõltub suures osas sellest, milliseks elektri hind kokku kujuneb? Kas oskad konkreetse numbri öelda? |
Eks ta suht börsihinna ja kirve võrguteenuse järgi kujuneb, viimase kuu peale vaadates on suurusjärgus €0.16 kWh päev €0.12 kWh öö.
yerba
27.07.2018 11:23:57
Tar kirjutas: |
yerba kirjutas: |
Eks ta suht börsihinna ja kirve võrguteenuse järgi kujuneb, viimase kuu peale vaadates on suurusjärgus €0.16 kWh päev €0.12 kWh öö. |
Siis läheb raskeks, kuna kodukasutajal on tubli kolmandik odavam elekter..
Kes seal võrguteenust pakub ja mis paketiga?
Kristocfc
27.07.2018 11:49:38
kuram mul ka ikka sinna 0,13 kwh keskmine koos võrgutasudega.... kus odavamalt koju elektrit antakse?
yerba
27.07.2018 12:49:28
Kristocfc kirjutas: |
kuram mul ka ikka sinna 0,13 kwh keskmine koos võrgutasudega.... kus odavamalt koju elektrit antakse? |
Igivana teema.
Elektrilevi pakett 4 + alexela bluebörs
27.07.2018 13:04:18
"Paar nädalat tagasi Saaremaal toimunud muusikafestival I Land Sound oli maailmas üks esimesi festivale, kus külastajad said jookide ja söökide eest tasuda krüptorahal põhineva maksevahendiga.
Festivali külastajatele jagati välja ligi tuhat käepaela, mis olid varustatud NFC-kiibiga, millele sai virtuaalset raha peale kanda. Rahana oli kasutusel Dash krüptovaluuta, mille loojate sõnul olid käepaela lahendusest huvitatud I Land Soundi korraldajad."
https://geenius.ee/uudis/saaremaa-muusikafestivalil-kasutati-kruptorahal-pohinevat-maksevahendit/
ufo56
27.07.2018 14:21:36
rmc kirjutas: |
https://geenius.ee/uudis/saaremaa-muusikafestivalil-kasutati-kruptorahal-pohinevat-maksevahendit/ |
Ei töötand väga see lahendus seal. Reede (teine päev) igatahes ei töötand ja kaardimakse terminalid olid otsitud välja, laupäeval aga oli inimesi juba kes maksid sellega.
Algselt küll reklaamiti et maksmine toimub vaid sellega aga läks veidike teisiti.
Lae pildid -> pilt.io |
HDTanel
Overclocker
27.07.2018 16:37:18
Kui ma tulen mingile üritusele või satun välismaal kohta kus saan krüptos maksta siis ei saa olla sellist asja, et vaid mingit ühte raha küsitakse. Kasutama peab mingit ühist walletit, mis ülemaailmselt heakskiidu saaks (Ethos, Bread vms) ja siis kui vaja maksta peavad seal walletis KÕIK valuutad olema võimelikud arve eest tasuma ja ka offlines, st kui pole sul internetti sest enamik juhtudel sul seda telefonis välismaal pole ja mingisse suva wifisse ka enda telefoniga sisse logima ei hakka ju.. kui just mingid eriti väikesed summad peal pole.. mida ilmselt teha tuleb samas tulevikus, et kui tahad krüptot telefonis hoida siis väikesed summad lihtsalt söögi maksmise eest vms.
Siin võibolla tulevad appi erinevad krüpto kaardid ala nagu Spatium vms
_________________ Krüpto
Minu Youtube - HDTanel
Minu Instagram - HDTanel |
Tar
27.07.2018 22:31:30
yerba kirjutas: |
Kes seal võrguteenust pakub ja mis paketiga? |
AFAIK Elektrilevi on, paketti ei tea aga nüüd uurisin neid hinnakirju ja eks need paketid tuleks siis vastavalt tarbimisele valida, enne panin numbrid Võrk2 ja EE marginaali järgi.
63A puhul Elektrilevi Võrk4 + Alexela Blue Plus annaks võitu alles ~2-3 kWh 24*7 tarbimise juures. 10 kWh 24*7 oleks €0,106 kWh kuu keskmine umbkaudu. Aga üks 63A võimaldaks 40+ kWh 24*7.
